[U-Boot] [PATCH V4 3/3] OMAP5: I2C: Set I2C_BUS_MAX to 5 to enable I2C4 and I2C5
I2C4 and I2C5 are utilized on all known OMAP5 hardware platforms. In order to be able to select one of these buses however, I2C_BUS_MAX has to be set to 5; do this here.
Please note that for working bus selection, a fix to the i2c driver is required as well (subject of a separate patch).
Signed-off-by: Lubomir Popov lpopov@mm-sol.com --- Changes since V3: Added detailed commit messages.
Changes since V2: Separate patches consolidated into a series.
Changes since V1: Fixed line wrap issues.
arch/arm/include/asm/arch-omap5/i2c.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-omap5/i2c.h b/arch/arm/include/asm/arch-omap5/i2c.h index 68be03b..ec39a53 100644 --- a/arch/arm/include/asm/arch-omap5/i2c.h +++ b/arch/arm/include/asm/arch-omap5/i2c.h @@ -23,7 +23,7 @@ #ifndef _OMAP5_I2C_H_ #define _OMAP5_I2C_H_
-#define I2C_BUS_MAX 3 +#define I2C_BUS_MAX 5 #define I2C_DEFAULT_BASE I2C_BASE1
struct i2c {
Lubomir Popov
