[PATCH u-boot 0/4] mmc: Explain and cleanup partition selection
Some people do not want to read review comments in emails. So put comments and explanation into the source code itself; make emmc partition selection code more explicit and validate configuration in bubt command.
Pali Rohár (4): mmc: spl: Make partition choice in default_spl_mmc_emmc_boot_partition() more explicit cmd: mvebu/bubt: Validate EXT_CSD[179] eMMC register in mmc_burn_image() sunxi: eMMC: Add comments explaining mapping between bootpart and mmc_switch_part() board: purism: Use U-Boot mmc function for converting boot part to part access
arch/arm/mach-sunxi/board.c | 12 ++++++++++- board/purism/librem5/librem5.c | 6 +----- cmd/mvebu/bubt.c | 24 +++++++++++++++++++-- common/spl/spl_mmc.c | 38 +++++++++++++++++++++++++++------- 4 files changed, 64 insertions(+), 16 deletions(-)
To make eMMC partition choosing in default_spl_mmc_emmc_boot_partition() function better understandable, rewrite it via explicit switch-case code pattern.
Also add a warning when eMMC EXT_CSD[179] register is configured by user to value which is not suitable for eMMC booting and SPL do not know how to interpret it.
Note that when booting from eMMC device via EXT_CSD[179] register is explicitly disabled then SPL still loads and boots from this eMMC device from User Area partition. This behavior was not changed in this commit and should be revisited in the future.
Signed-off-by: Pali Rohár pali@kernel.org
--- This patch depends on another patch: mmc: spl: Add comments for default_spl_mmc_emmc_boot_partition() https://patchwork.ozlabs.org/project/uboot/patch/20230404202805.8523-1-pali@... --- common/spl/spl_mmc.c | 38 ++++++++++++++++++++++++++++++-------- 1 file changed, 30 insertions(+), 8 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 2426500dbcb9..df20a75efc29 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -408,15 +408,37 @@ int default_spl_mmc_emmc_boot_partition(struct mmc *mmc) * * Note: See difference between EXT_CSD_EXTRACT_PARTITION_ACCESS * and EXT_CSD_EXTRACT_BOOT_PART, specially about User area value. - * - * FIXME: When booting from this eMMC device is explicitly - * disabled then we use User area for booting. This is incorrect. - * Probably we should skip this eMMC device and select the next - * one for booting. Or at least throw warning about this fallback. */ - part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); - if (part == 7) - part = 0; + if (mmc->part_config == MMCPART_NOAVAILABLE) + part = 0; /* If partitions are not supported then we have only User Area partition */ + else { + switch(EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config)) { + case 0: /* Booting from this eMMC device is disabled */ +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + puts("spl: WARNING: Booting from this eMMC device is disabled in EXT_CSD[179] register\n"); + puts("spl: WARNING: Continuing anyway and selecting User Area partition for booting\n"); +#endif + /* FIXME: This is incorrect and probably we should select next eMMC device for booting */ + part = 0; + break; + case 1: /* Boot partition 1 is used for booting */ + part = 1; + break; + case 2: /* Boot partition 2 is used for booting */ + part = 2; + break; + case 7: /* User area is used for booting */ + part = 0; + break; + default: /* Other values are reserved */ +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + puts("spl: WARNING: EXT_CSD[179] register is configured to boot from Reserved value\n"); + puts("spl: WARNING: Selecting User Area partition for booting\n"); +#endif + part = 0; + break; + } + } #endif return part; }
Signed-off-by: Pali Rohár pali@kernel.org --- Changes in v2: * Disable showing warning on sama5d2_xplained due to size restrictions --- This patch depends on another patch: mmc: spl: Add comments for default_spl_mmc_emmc_boot_partition() https://patchwork.ozlabs.org/project/uboot/patch/20230404202805.8523-1-pali@... --- common/spl/Kconfig | 7 +++++++ common/spl/spl_mmc.c | 46 ++++++++++++++++++++++++++++++++++++-------- 2 files changed, 45 insertions(+), 8 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 865571d4579c..0574d22b3b25 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -855,6 +855,13 @@ config SPL_MMC_WRITE help Enable write access to MMC and SD Cards in SPL
+config SPL_MMC_WARNINGS + bool "Print MMC warnings" + depends on SPL_MMC + default y if !TARGET_SAMA5D2_XPLAINED + help + Print SPL MMC warnings. You can disable this option to reduce SPL size. +
config SPL_MPC8XXX_INIT_DDR bool "Support MPC8XXX DDR init" diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index f7a42a11477d..ec424ceded0e 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -408,15 +408,45 @@ int default_spl_mmc_emmc_boot_partition(struct mmc *mmc) * * Note: See difference between EXT_CSD_EXTRACT_PARTITION_ACCESS * and EXT_CSD_EXTRACT_BOOT_PART, specially about User area value. - * - * FIXME: When booting from this eMMC device is explicitly - * disabled then we use User area for booting. This is incorrect. - * Probably we should skip this eMMC device and select the next - * one for booting. Or at least throw warning about this fallback. */ - part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); - if (part == 7) - part = 0; + if (mmc->part_config == MMCPART_NOAVAILABLE) + part = 0; /* If partitions are not supported then we have only User Area partition */ + else { + switch(EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config)) { + case 0: /* Booting from this eMMC device is disabled */ +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT +#ifdef CONFIG_SPL_MMC_WARNINGS + puts("spl: WARNING: Booting from this eMMC device is disabled in EXT_CSD[179] register\n"); + puts("spl: WARNING: Continuing anyway and selecting User Area partition for booting\n"); +#else + puts("spl: mmc: fallback to user area\n"); +#endif +#endif + /* FIXME: This is incorrect and probably we should select next eMMC device for booting */ + part = 0; + break; + case 1: /* Boot partition 1 is used for booting */ + part = 1; + break; + case 2: /* Boot partition 2 is used for booting */ + part = 2; + break; + case 7: /* User area is used for booting */ + part = 0; + break; + default: /* Other values are reserved */ +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT +#ifdef CONFIG_SPL_MMC_WARNINGS + puts("spl: WARNING: EXT_CSD[179] register is configured to boot from Reserved value\n"); + puts("spl: WARNING: Selecting User Area partition for booting\n"); +#else + puts("spl: mmc: fallback to user area\n"); +#endif +#endif + part = 0; + break; + } + } #endif return part; }
Changes in v2:
- Disable showing warning on sama5d2_xplained due to size restrictions
- bool "Print MMC warnings"
- depends on SPL_MMC
- default y if !TARGET_SAMA5D2_XPLAINED
- help
*/* one for booting. Or at least throw warning about this fallback.
- if (part == 7)
part = 0;
- if (mmc->part_config == MMCPART_NOAVAILABLE)
- else {
+#else
+#endif +#endif
part = 0;
break;
part = 1;
break;
part = 2;
break;
part = 0;
break;
+#else
+#endif +#endif
part = 0;
break;
#endif
Please just use debug() for these messages.
Changes in v2:
- help
- if (part == 7)
part = 0;
- else {
+#else
+#endif +#endif
part = 0;
break;
part = 1;
break;
part = 2;
break;
part = 0;
break;
+#else
+#endif +#endif
part = 0;
break;
#endif
-- Tom
All other error/warning messages in this file are printed via puts(). So I'm just following the current style (and I'm really not going to change all occurrences in this patch).
Changes in v2:
- help
- if (part == 7)
part = 0;
- else {
+#else
+#endif +#endif
part = 0;
break;
part = 1;
break;
part = 2;
break;
part = 0;
break;
+#else
+#endif +#endif
part = 0;
break;
#endif
Except for the messages in that file which use debug() they use puts(), yes. Since none of these are fatal messages (you're falling through) please switch them to debug() rather than introduce a new CONFIG symbol, so that if someone is bringing up a platform where this is a problem they'll be able to debug it, but the general case does not increase the binary size of most platforms. I'm not asking you to change anything existing in the file, only what you're adding.
Changes in v2:
- help
- if (part == 7)
part = 0;
- else {
+#else
+#endif +#endif
part = 0;
break;
part = 1;
break;
part = 2;
break;
part = 0;
break;
+#else
+#endif +#endif
part = 0;
break;
#endif
-- Tom
We should at those two places fail. But I do not want to break existing improperly configured setups, so warning a good way to show people that they have something misconfigured. Later in future we switch warnings to fatal errors. But if we do not show anything at these points, nobody would figure out that has improper setup configuration. debug() is IIRC not shown by default.
Changes in v2:
- help
- if (part == 7)
part = 0;
- else {
+#else
+#endif +#endif
part = 0;
break;
part = 1;
break;
part = 2;
break;
part = 0;
break;
+#else
+#endif +#endif
part = 0;
break;
#endif
Ah, so the plan is they should be fatal, and there's a way to fix the configuration? Lets just panic() them now, instead. I really really do not want to grow every SPL+MMC using board (which is a lot of them) by several hundred bytes of strings. Lets catch the mis-configuration, merge it in early in the cycle (right now for v2023.10 for example, especially since the MMC custodian is promising to review things and get a PR out ASAP), and see what falls out. A panic() and a big comment explaining things should suffice.
Changes in v2:
- help
- if (part == 7)
part = 0;
- else {
+#else
+#endif +#endif
part = 0;
break;
part = 1;
break;
part = 2;
break;
part = 0;
break;
+#else
+#endif +#endif
part = 0;
break;
#endif
Yes, EXT_CSD[179] is configurable register, you can change boot partition bits (those are non-volatile) via your favorite emmc config tool. U-Boot has also tool "mmc partconf" which can do that. But you first need to be able enter into u-boot console and also you need to enable this tool your board config file.
-- Tom
Ok, I can change "reserved values" to panic().
About "booting is disabled" - I do not think that panic is correct here. See inline comments in code. Rather do the correct thing - skip emmc and let SPL to boot from next source. But some message needs to be printed here why emmc was skipped....
On Thu, Jul 06, 2023 at 07:35:02PM +0200, Pali Rohár wrote: > To make eMMC partition choosing in default_spl_mmc_emmc_boot_partition() > function better understandable, rewrite it via explicit switch-case code > pattern. > > Also add a warning when eMMC EXT_CSD[179] register is configured by user to > value which is not suitable for eMMC booting and SPL do not know how to > interpret it. > > Note that when booting from eMMC device via EXT_CSD[179] register is > explicitly disabled then SPL still loads and boots from this eMMC device > from User Area partition. This behavior was not changed in this commit and > should be revisited in the future. > > Signed-off-by: Pali Rohár pali@kernel.org > --- > Changes in v2: > * Disable showing warning on sama5d2_xplained due to size restrictions > --- > This patch depends on another patch: > mmc: spl: Add comments for default_spl_mmc_emmc_boot_partition() > https://patchwork.ozlabs.org/project/uboot/patch/20230404202805.8523-1-pali@... > --- > common/spl/Kconfig | 7 +++++++ > common/spl/spl_mmc.c | 46 ++++++++++++++++++++++++++++++++++++-------- > 2 files changed, 45 insertions(+), 8 deletions(-) > > diff --git a/common/spl/Kconfig b/common/spl/Kconfig > index 865571d4579c..0574d22b3b25 100644 > --- a/common/spl/Kconfig > +++ b/common/spl/Kconfig > @@ -855,6 +855,13 @@ config SPL_MMC_WRITE > help > Enable write access to MMC and SD Cards in SPL > > +config SPL_MMC_WARNINGS > + bool "Print MMC warnings" > + depends on SPL_MMC > + default y if !TARGET_SAMA5D2_XPLAINED > + help > + Print SPL MMC warnings. You can disable this option to reduce SPL size. > + > > config SPL_MPC8XXX_INIT_DDR > bool "Support MPC8XXX DDR init" > diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c > index f7a42a11477d..ec424ceded0e 100644 > --- a/common/spl/spl_mmc.c > +++ b/common/spl/spl_mmc.c > @@ -408,15 +408,45 @@ int default_spl_mmc_emmc_boot_partition(struct mmc *mmc) > * > * Note: See difference between EXT_CSD_EXTRACT_PARTITION_ACCESS > * and EXT_CSD_EXTRACT_BOOT_PART, specially about User area value. > - * > - * FIXME: When booting from this eMMC device is explicitly > - * disabled then we use User area for booting. This is incorrect. > - * Probably we should skip this eMMC device and select the next > - * one for booting. Or at least throw warning about this fallback. > */ > - part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); > - if (part == 7) > - part = 0; > + if (mmc->part_config == MMCPART_NOAVAILABLE) > + part = 0; /* If partitions are not supported then we have only User Area partition */ > + else { > + switch(EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config)) { > + case 0: /* Booting from this eMMC device is disabled */ > +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT > +#ifdef CONFIG_SPL_MMC_WARNINGS > + puts("spl: WARNING: Booting from this eMMC device is disabled in EXT_CSD[179] register\n"); > + puts("spl: WARNING: Continuing anyway and selecting User Area partition for booting\n"); > +#else > + puts("spl: mmc: fallback to user area\n"); > +#endif > +#endif > + /* FIXME: This is incorrect and probably we should select next eMMC device for booting */ > + part = 0; > + break; > + case 1: /* Boot partition 1 is used for booting */ > + part = 1; > + break; > + case 2: /* Boot partition 2 is used for booting */ > + part = 2; > + break; > + case 7: /* User area is used for booting */ > + part = 0; > + break; > + default: /* Other values are reserved */ > +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT > +#ifdef CONFIG_SPL_MMC_WARNINGS > + puts("spl: WARNING: EXT_CSD[179] register is configured to boot from Reserved value\n"); > + puts("spl: WARNING: Selecting User Area partition for booting\n"); > +#else > + puts("spl: mmc: fallback to user area\n"); > +#endif > +#endif > + part = 0; > + break; > + } > + } > #endif
How verbose all of this needs to be depends on who is likely to encounter this type of problem. Are we talking about systems in the wild today that are misconfigured, or are we talking about problems that will arise as part of bringing up a new design and if you don't do X correctly then Y will happen oddly/wrongly?
On Thursday 06 July 2023 13:42:18 Tom Rini wrote: > On Thu, Jul 06, 2023 at 07:35:02PM +0200, Pali Rohár wrote: > > To make eMMC partition choosing in default_spl_mmc_emmc_boot_partition() > > function better understandable, rewrite it via explicit switch-case code > > pattern. > > > > Also add a warning when eMMC EXT_CSD[179] register is configured by user to > > value which is not suitable for eMMC booting and SPL do not know how to > > interpret it. > > > > Note that when booting from eMMC device via EXT_CSD[179] register is > > explicitly disabled then SPL still loads and boots from this eMMC device > > from User Area partition. This behavior was not changed in this commit and > > should be revisited in the future. > > > > Signed-off-by: Pali Rohár pali@kernel.org > > --- > > Changes in v2: > > * Disable showing warning on sama5d2_xplained due to size restrictions > > --- > > This patch depends on another patch: > > mmc: spl: Add comments for default_spl_mmc_emmc_boot_partition() > > https://patchwork.ozlabs.org/project/uboot/patch/20230404202805.8523-1-pali@... > > --- > > common/spl/Kconfig | 7 +++++++ > > common/spl/spl_mmc.c | 46 ++++++++++++++++++++++++++++++++++++-------- > > 2 files changed, 45 insertions(+), 8 deletions(-) > > > > diff --git a/common/spl/Kconfig b/common/spl/Kconfig > > index 865571d4579c..0574d22b3b25 100644 > > --- a/common/spl/Kconfig > > +++ b/common/spl/Kconfig > > @@ -855,6 +855,13 @@ config SPL_MMC_WRITE > > help > > Enable write access to MMC and SD Cards in SPL > > > > +config SPL_MMC_WARNINGS > > + bool "Print MMC warnings" > > + depends on SPL_MMC > > + default y if !TARGET_SAMA5D2_XPLAINED > > + help > > + Print SPL MMC warnings. You can disable this option to reduce SPL size. > > + > > > > config SPL_MPC8XXX_INIT_DDR > > bool "Support MPC8XXX DDR init" > > diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c > > index f7a42a11477d..ec424ceded0e 100644 > > --- a/common/spl/spl_mmc.c > > +++ b/common/spl/spl_mmc.c > > @@ -408,15 +408,45 @@ int default_spl_mmc_emmc_boot_partition(struct mmc *mmc) > > * > > * Note: See difference between EXT_CSD_EXTRACT_PARTITION_ACCESS > > * and EXT_CSD_EXTRACT_BOOT_PART, specially about User area value. > > - * > > - * FIXME: When booting from this eMMC device is explicitly > > - * disabled then we use User area for booting. This is incorrect. > > - * Probably we should skip this eMMC device and select the next > > - * one for booting. Or at least throw warning about this fallback. > > */ > > - part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); > > - if (part == 7) > > - part = 0; > > + if (mmc->part_config == MMCPART_NOAVAILABLE) > > + part = 0; /* If partitions are not supported then we have only User Area partition */ > > + else { > > + switch(EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config)) { > > + case 0: /* Booting from this eMMC device is disabled */ > > +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT > > +#ifdef CONFIG_SPL_MMC_WARNINGS > > + puts("spl: WARNING: Booting from this eMMC device is disabled in EXT_CSD[179] register\n"); > > + puts("spl: WARNING: Continuing anyway and selecting User Area partition for booting\n"); > > +#else > > + puts("spl: mmc: fallback to user area\n"); > > +#endif > > +#endif > > + /* FIXME: This is incorrect and probably we should select next eMMC device for booting */ > > + part = 0; > > + break; > > + case 1: /* Boot partition 1 is used for booting */ > > + part = 1; > > + break; > > + case 2: /* Boot partition 2 is used for booting */ > > + part = 2; > > + break; > > + case 7: /* User area is used for booting */ > > + part = 0; > > + break; > > + default: /* Other values are reserved */ > > +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT > > +#ifdef CONFIG_SPL_MMC_WARNINGS > > + puts("spl: WARNING: EXT_CSD[179] register is configured to boot from Reserved value\n"); > > + puts("spl: WARNING: Selecting User Area partition for booting\n"); > > +#else > > + puts("spl: mmc: fallback to user area\n"); > > +#endif > > +#endif > > + part = 0; > > + break; > > + } > > + } > > #endif > > Please just use debug() for these messages.
-- Tom
I have no idea. We already seen that not all people understood how it works. And also people are always creative in inventing hacks. So this is mainly for existing systems.
For future in mmc area I have just cleanup patches which should not result in code change or in behavior change.
On Thu, Jul 06, 2023 at 07:49:18PM +0200, Pali Rohár wrote: > On Thursday 06 July 2023 13:42:18 Tom Rini wrote: > > On Thu, Jul 06, 2023 at 07:35:02PM +0200, Pali Rohár wrote: > > > To make eMMC partition choosing in default_spl_mmc_emmc_boot_partition() > > > function better understandable, rewrite it via explicit switch-case code > > > pattern. > > > > > > Also add a warning when eMMC EXT_CSD[179] register is configured by user to > > > value which is not suitable for eMMC booting and SPL do not know how to > > > interpret it. > > > > > > Note that when booting from eMMC device via EXT_CSD[179] register is > > > explicitly disabled then SPL still loads and boots from this eMMC device > > > from User Area partition. This behavior was not changed in this commit and > > > should be revisited in the future. > > > > > > Signed-off-by: Pali Rohár pali@kernel.org > > > --- > > > Changes in v2: > > > * Disable showing warning on sama5d2_xplained due to size restrictions > > > --- > > > This patch depends on another patch: > > > mmc: spl: Add comments for default_spl_mmc_emmc_boot_partition() > > > https://patchwork.ozlabs.org/project/uboot/patch/20230404202805.8523-1-pali@... > > > --- > > > common/spl/Kconfig | 7 +++++++ > > > common/spl/spl_mmc.c | 46 ++++++++++++++++++++++++++++++++++++-------- > > > 2 files changed, 45 insertions(+), 8 deletions(-) > > > > > > diff --git a/common/spl/Kconfig b/common/spl/Kconfig > > > index 865571d4579c..0574d22b3b25 100644 > > > --- a/common/spl/Kconfig > > > +++ b/common/spl/Kconfig > > > @@ -855,6 +855,13 @@ config SPL_MMC_WRITE > > > help > > > Enable write access to MMC and SD Cards in SPL > > > > > > +config SPL_MMC_WARNINGS > > > + bool "Print MMC warnings" > > > + depends on SPL_MMC > > > + default y if !TARGET_SAMA5D2_XPLAINED > > > + help > > > + Print SPL MMC warnings. You can disable this option to reduce SPL size. > > > + > > > > > > config SPL_MPC8XXX_INIT_DDR > > > bool "Support MPC8XXX DDR init" > > > diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c > > > index f7a42a11477d..ec424ceded0e 100644 > > > --- a/common/spl/spl_mmc.c > > > +++ b/common/spl/spl_mmc.c > > > @@ -408,15 +408,45 @@ int default_spl_mmc_emmc_boot_partition(struct mmc *mmc) > > > * > > > * Note: See difference between EXT_CSD_EXTRACT_PARTITION_ACCESS > > > * and EXT_CSD_EXTRACT_BOOT_PART, specially about User area value. > > > - * > > > - * FIXME: When booting from this eMMC device is explicitly > > > - * disabled then we use User area for booting. This is incorrect. > > > - * Probably we should skip this eMMC device and select the next > > > - * one for booting. Or at least throw warning about this fallback. > > > */ > > > - part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); > > > - if (part == 7) > > > - part = 0; > > > + if (mmc->part_config == MMCPART_NOAVAILABLE) > > > + part = 0; /* If partitions are not supported then we have only User Area partition */ > > > + else { > > > + switch(EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config)) { > > > + case 0: /* Booting from this eMMC device is disabled */ > > > +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT > > > +#ifdef CONFIG_SPL_MMC_WARNINGS > > > + puts("spl: WARNING: Booting from this eMMC device is disabled in EXT_CSD[179] register\n"); > > > + puts("spl: WARNING: Continuing anyway and selecting User Area partition for booting\n"); > > > +#else > > > + puts("spl: mmc: fallback to user area\n"); > > > +#endif > > > +#endif > > > + /* FIXME: This is incorrect and probably we should select next eMMC device for booting */ > > > + part = 0; > > > + break; > > > + case 1: /* Boot partition 1 is used for booting */ > > > + part = 1; > > > + break; > > > + case 2: /* Boot partition 2 is used for booting */ > > > + part = 2; > > > + break; > > > + case 7: /* User area is used for booting */ > > > + part = 0; > > > + break; > > > + default: /* Other values are reserved */ > > > +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT > > > +#ifdef CONFIG_SPL_MMC_WARNINGS > > > + puts("spl: WARNING: EXT_CSD[179] register is configured to boot from Reserved value\n"); > > > + puts("spl: WARNING: Selecting User Area partition for booting\n"); > > > +#else > > > + puts("spl: mmc: fallback to user area\n"); > > > +#endif > > > +#endif > > > + part = 0; > > > + break; > > > + } > > > + } > > > #endif > > > > Please just use debug() for these messages. > > All other error/warning messages in this file are printed via puts(). > So I'm just following the current style (and I'm really not going to > change all occurrences in this patch).
-- Tom
OK, so how about something like: case 0: /* Booting from this eMMC device is disabled */ /* Long comment to explain likely mis-configuration and how to fix it */ puts("spl: mmc: eMMC misconfigured, falling back to eMMC user area\n"); fallthrough; case 7: part = 0; break; case 1: /* Boot partition 1 is used for booting */ part = 1; break; case 2: /* Boot partition 2 is used for booting */ part = 2; break;
As that shouldn't be too much of a size increase from strings, but still be "scary" enough that users will report the message to find out what's going on, and we can investigate from there (my first open question is what case the TI ARCH_OMAP2PLUS trigger as ROM does not support the boot partitions there for booting, that was only fixed in the K3 parts).
Also indicate an error when eMMC EXT_CSD[179] register is configured by user to value which is not suitable for eMMC booting and SPL do not know how to interpret it.
Signed-off-by: Pali Rohár pali@kernel.org --- Changes in v3: * Instead of showing (verbose) warning, make them as errors and propagate them back to caller. * Add comment with explanation what happened and how to fix possible misconfigured configuration.
Changes in v2: * Disable showing warning on sama5d2_xplained due to size restrictions --- This patch depends on another patch: mmc: spl: Add comments for default_spl_mmc_emmc_boot_partition() https://patchwork.ozlabs.org/project/uboot/patch/20230404202805.8523-1-pali@... --- common/spl/spl_mmc.c | 56 +++++++++++++++++++++++++++++++++++++------- 1 file changed, 48 insertions(+), 8 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index f7a42a11477d..656363a3b51a 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -408,15 +408,46 @@ int default_spl_mmc_emmc_boot_partition(struct mmc *mmc) * * Note: See difference between EXT_CSD_EXTRACT_PARTITION_ACCESS * and EXT_CSD_EXTRACT_BOOT_PART, specially about User area value. - * - * FIXME: When booting from this eMMC device is explicitly - * disabled then we use User area for booting. This is incorrect. - * Probably we should skip this eMMC device and select the next - * one for booting. Or at least throw warning about this fallback. */ - part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); - if (part == 7) - part = 0; + if (mmc->part_config == MMCPART_NOAVAILABLE) + part = 0; /* If partitions are not supported then we have only User Area partition */ + else { + switch(EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config)) { + case 0: /* Booting from this eMMC device is disabled */ + /* + * This eMMC device has disabled booting. + * This may happen because of misconfiguration of eMMC device or + * because user explicitly wanted to not boot from this eMMC device. + * eMMC boot configuration can be changed by "mmc partconf" command. + */ + part = -ENXIO; /* negative value indicates error */ + /* Note that error message is printed by caller of this function. */ + break; + case 1: /* Boot partition 1 is used for booting */ + part = 1; + break; + case 2: /* Boot partition 2 is used for booting */ + part = 2; + break; + case 7: /* User area is used for booting */ + part = 0; + break; + default: /* Other values are reserved */ + /* + * This eMMC device has configured booting from reserved value. + * This may happen because of misconfiguration of eMMC device or + * because this is newer eMMC device than what U-Boot understand. + * If newer eMMC specification defines meaning for some reserved + * values then switch above should be updated for new cases. + * At this stage we do not know how to interpret this reserved + * value so return error. + * eMMC boot configuration can be changed by "mmc partconf" command. + */ + part = -EINVAL; /* negative value indicates error */ + /* Note that error message is printed by caller of this function. */ + break; + } + } #endif return part; } @@ -471,6 +502,15 @@ int spl_mmc_load(struct spl_image_info *spl_image, switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: part = spl_mmc_emmc_boot_partition(mmc); + if (part < 0) { +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + if (part == -ENXIO) + puts("spl: mmc booting disabled\n"); + else + puts("spl: mmc misconfigured\n"); +#endif + return part; + }
if (CONFIG_IS_ENABLED(MMC_TINY)) err = mmc_switch_part(mmc, part);
I did some quick local testing to check on the size impact and this is indeed quite manageable, thanks for reworking things!
-- Tom
Unfortunately no, sama5d2_xplained_emmc, sama5d2_xplained_mmc and sama5d2_xplained_qspiflash are failing with v3; but not with v2.
Seems that these boards have their SPL at limit and adding any new puts() increase size over the limit.
So I think that there is no other way than just adding a new config option to hide this new puts().
We should enable LTO on those platforms then and buy us some space.
-- Tom
Ok, but then this is really out of what I have a free time to do...
When determining eMMC boot partition for a bootloader, validate that EXT_CSD[179] eMMC register is set to recognized value.
This prevent situation that EXT_CSD[179] Boot Enable value is improperly parsed and passed into EXT_CSD[179] Partition Access.
Signed-off-by: Pali Rohár pali@kernel.org --- cmd/mvebu/bubt.c | 24 ++++++++++++++++++++++-- 1 file changed, 22 insertions(+), 2 deletions(-)
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index ca24a5c1c4ba..b8fe7c7a1461 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -223,9 +223,29 @@ static int mmc_burn_image(size_t image_size) orig_part = mmc->block_dev.hwpart; #endif
- part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); - if (part == 7) + if (mmc->part_config == MMCPART_NOAVAILABLE) { part = 0; + } else { + switch (EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config)) { + case 0: /* Booting from this eMMC device is disabled */ + printf("Error - Booting from this eMMC device is disabled\n"); + printf("Hint: Use 'mmc partconf' command to choose boot partition\n"); + return -ENODEV; + case 1: /* Boot partition 1 is used for booting */ + part = 1; + break; + case 2: /* Boot partition 2 is used for booting */ + part = 2; + break; + case 7: /* User area is used for booting */ + part = 0; + break; + default: /* Other values are reserved / unsupported */ + printf("Error - This eMMC device has configured Reserved boot option\n"); + printf("Hint: Use 'mmc partconf' command to choose boot partition\n"); + return -ENODEV; + } + }
#ifdef CONFIG_BLK err = blk_dselect_hwpart(blk_desc, part);
Thanks, Stefan
- if (part == 7)
} else {
return -ENODEV;
part = 1;
break;
part = 2;
break;
part = 0;
break;
return -ENODEV;
Viele Grüße, Stefan Roese
+ Martin
- if (part == 7)
- if (mmc->part_config == MMCPART_NOAVAILABLE) { part = 0;
- } else {
return -ENODEV;
part = 1;
break;
part = 2;
break;
part = 0;
break;
return -ENODEV;
#ifdef CONFIG_BLK err = blk_dselect_hwpart(blk_desc, part); -- 2.20.1
Mapping between bootpart taken from EXT_CSD_EXTRACT_BOOT_PART() and Partition Access bits used by the mmc_switch_part() function may be quite misleading. So add extended comment describing why in sunxi case is this mapping just a simple identity. Because in generic case this mapping requires non-trivial mapping table.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-sunxi/board.c | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 391a65a5495f..73519f6262ec 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -381,7 +381,17 @@ static bool sunxi_valid_emmc_boot(struct mmc *mmc) (mmc->ext_csd[EXT_CSD_BOOT_BUS_WIDTH] & 0x1b) != 0x09) return false;
- /* Partition 0 is the user data partition, bootpart must be 1 or 2. */ + /* + * bootpart == 0 means that eMMC booting is disabled. + * bootpart == 1 or 2 means to boot from Boot Partition 1 or 2. + * bootpart == 7 means to boot from User Area. + * Other bootpart values are reserved. + * mmc_switch_part() takes partition access value which is: + * 0 for User Area; 1-2 for Boot Partition 1-2; 3 for RPMB; 4-7 for GP 1-4. + * We allow booting only from Boot Partition 1 or 2 so + * bootpart mapping between EXT_CSD_EXTRACT_BOOT_PART() + * and mmc_switch_part() is straightforward identity. + */ if (bootpart != 1 && bootpart != 2) return false;
Ah, indeed, many thanks for clearing this up! I missed the subtleties of bootpart meaning slightly different things between EXT_CSD_EXTRACT_BOOT_PART and mmc_switch_part(). It looks like we were quite lucky as we only care about 1 and 2 here!
Acked-by: Andre Przywara andre.przywara@arm.com
Queued for sunxi/master.
Cheers, Andre
if (bootpart != 1 && bootpart != 2) return false;*/
eMMC Boot Partition Enable bits in mmc->part_config (EXT_CSD[179]) has different coding than eMMC Partition Access bits.
Use spl_mmc_emmc_boot_partition() function which does this conversion properly (hopefully).
Signed-off-by: Pali Rohár pali@kernel.org --- board/purism/librem5/librem5.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/board/purism/librem5/librem5.c b/board/purism/librem5/librem5.c index 386ed1b4fb22..36ecac9d9ed0 100644 --- a/board/purism/librem5/librem5.c +++ b/board/purism/librem5/librem5.c @@ -41,11 +41,7 @@ int board_early_init_f(void) #if IS_ENABLED(CONFIG_LOAD_ENV_FROM_MMC_BOOT_PARTITION) uint board_mmc_get_env_part(struct mmc *mmc) { - uint part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); - - if (part == 7) - part = 0; - return part; + return spl_mmc_emmc_boot_partition(mmc); } #endif
Reviewed-by: Angus Ainslie angus@akkea.ca
Sorry for too late. After applied this patch-set, some board are failed with spl's size overflowed
The below is one of failed log.
+arm-linux-gnueabi-ld.bfd: region `.sram' overflowed by 352 bytes +make[2]: *** [scripts/Makefile.spl:527: spl/u-boot-spl] Error 1 +make[1]: *** [Makefile:2049: spl/u-boot-spl] Error 2
Best Regards, Jaehoon Chung
Crap, and again we have there same issue. Patch after months does not apply anymore. And resending the patch would again result in the same problem that it would not apply anymore after half of the year...
Anyway, only first patch is SPL specific, other should apply without any problem.
Here is v2 patch with simple fix for that platform: https://patchwork.ozlabs.org/project/uboot/patch/20230706173502.2796-1-pali@...
And it passed _now_ CI pipeline: https://github.com/u-boot/u-boot/pull/340
Hi
-----Original Message----- From: Pali Rohár pali@kernel.org Sent: Friday, July 7, 2023 2:39 AM To: Jaehoon Chung jh80.chung@samsung.com; Tom Rini trini@konsulko.com Cc: Peng Fan peng.fan@nxp.com; Stefan Roese sr@denx.de; u-boot@lists.denx.de Subject: Re: [PATCH u-boot 0/4] mmc: Explain and cleanup partition selection
Here is v2 patch with simple fix for that platform: https://protect2.fireeye.com/v1/url?k=bec9bc29-df42a906-bec83766-74fe485cbfe... 2e40f47b53afb09d&q=1&e=e8f6a6f2-8f6f-4bf1-9b91- 3f71d3577fc7&u=https%3A%2F%2Fpatchwork.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20230706173502.2796-1- pali%40kernel.org%2F
And it passed _now_ CI pipeline: https://protect2.fireeye.com/v1/url?k=543f3751-35b4227e-543ebc1e-74fe485cbfe... ff5f636a3c274f12&q=1&e=e8f6a6f2-8f6f-4bf1-9b91-3f71d3577fc7&u=https%3A%2F%2Fgithub.com%2Fu-boot%2Fu- boot%2Fpull%2F340
Thanks for sharing it.
-----Original Message----- From: Pali Rohár pali@kernel.org Sent: Thursday, July 6, 2023 7:51 PM To: Jaehoon Chung jh80.chung@samsung.com; Tom Rini trini@konsulko.com Cc: Peng Fan peng.fan@nxp.com; Stefan Roese sr@denx.de; u-boot@lists.denx.de Subject: Re: [PATCH u-boot 0/4] mmc: Explain and cleanup partition selection
Except spl specific patch, I will check again about your other patches. Thanks!
participants (6)
Andre Przywara
Angus Ainslie
Jaehoon Chung
Pali Rohár
Stefan Roese
