[PATCH] debug_uart.h: make <debug_uart.h> self-contained
'uint' is not a primitive type. You need to include <linux/types.h> or otherwise change it to (unsigned int).
Signed-off-by: Masahiro Yamada masahiroy@kernel.org ---
include/debug_uart.h | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/include/debug_uart.h b/include/debug_uart.h index cd70ae1a04..4d1c58075c 100644 --- a/include/debug_uart.h +++ b/include/debug_uart.h @@ -88,28 +88,28 @@ void printascii(const char *str); * * @value: Value to output */ -void printhex2(uint value); +void printhex2(unsigned int value);
/** * printhex4() - Output a 4-digit hex value * * @value: Value to output */ -void printhex4(uint value); +void printhex4(unsigned int value);
/** * printhex8() - Output a 8-digit hex value * * @value: Value to output */ -void printhex8(uint value); +void printhex8(unsigned int value);
/** * printdec() - Output a decimalism value * * @value: Value to output */ -void printdec(uint value); +void printdec(unsigned int value);
#ifdef CONFIG_DEBUG_UART_ANNOUNCE #define _DEBUG_UART_ANNOUNCE printascii("<debug_uart> "); @@ -151,34 +151,34 @@ void printdec(uint value); _printch(*str++); \ } \ \ - static inline void printhex1(uint digit) \ + static inline void printhex1(unsigned int digit) \ { \ digit &= 0xf; \ _debug_uart_putc(digit > 9 ? digit - 10 + 'a' : digit + '0'); \ } \ \ - static inline void printhex(uint value, int digits) \ + static inline void printhex(unsigned int value, int digits) \ { \ while (digits-- > 0) \ printhex1(value >> (4 * digits)); \ } \ \ - void printhex2(uint value) \ + void printhex2(unsigned int value) \ { \ printhex(value, 2); \ } \ \ - void printhex4(uint value) \ + void printhex4(unsigned int value) \ { \ printhex(value, 4); \ } \ \ - void printhex8(uint value) \ + void printhex8(unsigned int value) \ { \ printhex(value, 8); \ } \ \ - void printdec(uint value) \ + void printdec(unsigned int value) \ { \ if (value > 10) { \ printdec(value / 10); \
Hi Masahiro,
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- @value: Value to output
- printhex4() - Output a 4-digit hex value
- printhex8() - Output a 8-digit hex value
- printdec() - Output a decimalism value
- static inline void printhex1(unsigned int digit) \ { \ digit &= 0xf; \ _debug_uart_putc(digit > 9 ? digit - 10 + 'a' : digit + '0'); \ } \ \
- static inline void printhex(unsigned int value, int digits) \ { \ while (digits-- > 0) \ printhex1(value >> (4 * digits)); \ } \ \
- void printhex2(unsigned int value) \ { \ printhex(value, 2); \ } \ \
- void printhex4(unsigned int value) \ { \ printhex(value, 4); \ } \ \
- void printhex8(unsigned int value) \ { \ printhex(value, 8); \ } \ \
- void printdec(unsigned int value) \ { \ if (value > 10) { \ printdec(value / 10); \
Signed-off-by: Masahiro Yamada masahiroy@kernel.org Reviewed-by: Kever Yang kever.yang@rock-chips.com
Kever Yang
Masahiro Yamada
