[U-Boot] [PATCH 6/8] Add TI816X specific register definitions
Also move some non common defintions from hardware.h --- arch/arm/include/asm/arch-am33xx/hardware.h | 7 +-- arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 5 ++ arch/arm/include/asm/arch-am33xx/hardware_ti814x.h | 5 ++ arch/arm/include/asm/arch-am33xx/hardware_ti816x.h | 58 ++++++++++++++++++++ 4 files changed, 70 insertions(+), 5 deletions(-) create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_ti816x.h
diff --git a/arch/arm/include/asm/arch-am33xx/hardware.h b/arch/arm/include/asm/arch-am33xx/hardware.h index 5a27f9c..7f3b555 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware.h +++ b/arch/arm/include/asm/arch-am33xx/hardware.h @@ -23,6 +23,8 @@ #include <asm/arch/omap.h> #ifdef CONFIG_AM33XX #include <asm/arch/hardware_am33xx.h> +#elif defined(CONFIG_TI816X) +#include <asm/arch/hardware_ti816x.h> #elif defined(CONFIG_TI814X) #include <asm/arch/hardware_ti814x.h> #endif @@ -67,15 +69,10 @@ /* DDR Base address */ #define DDR_CTRL_ADDR 0x44E10E04 #define DDR_CONTROL_BASE_ADDR 0x44E11404 -#define DDR_PHY_CMD_ADDR2 0x47C0C800 -#define DDR_PHY_DATA_ADDR2 0x47C0C8C8
/* UART */ #define DEFAULT_UART_BASE UART0_BASE
-#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) -#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE - /* GPMC Base address */ #define GPMC_BASE 0x50000000
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h b/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h index fa02f19..49a4392 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h +++ b/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h @@ -43,8 +43,13 @@ /* DDR Base address */ #define DDR_PHY_CMD_ADDR 0x44E12000 #define DDR_PHY_DATA_ADDR 0x44E120C8 +#define DDR_PHY_CMD_ADDR2 0x47C0C800 +#define DDR_PHY_DATA_ADDR2 0x47C0C8C8 #define DDR_DATA_REGS_NR 2
+#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) +#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE + /* CPSW Config space */ #define CPSW_MDIO_BASE 0x4A101000
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h b/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h index a950ac3..ae0f370 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h +++ b/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h @@ -42,8 +42,13 @@ /* DDR Base address */ #define DDR_PHY_CMD_ADDR 0x47C0C400 #define DDR_PHY_DATA_ADDR 0x47C0C4C8 +#define DDR_PHY_CMD_ADDR2 0x47C0C800 +#define DDR_PHY_DATA_ADDR2 0x47C0C8C8 #define DDR_DATA_REGS_NR 4
+#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) +#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE + /* CPSW Config space */ #define CPSW_MDIO_BASE 0x4A100800
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h b/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h new file mode 100644 index 0000000..cb75d09 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h @@ -0,0 +1,58 @@ +/* + * hardware_ti816x.h + * + * TI816x hardware specific header + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * Based on TI-PSP-04.00.02.14 + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __AM33XX_HARDWARE_TI816X_H +#define __AM33XX_HARDWARE_TI816X_H + +/* Watchdog Timer */ +#define WDT_BASE 0x480C2000 + +/* Control Module Base Address */ +#define CTRL_BASE 0x48140000 + +/* PRCM Base Address */ +#define PRCM_BASE 0x48180000 + +/* VTP Base address */ +#define VTP0_CTRL_ADDR 0x48198358 + +/* DDR Base address */ +#define DDR_PHY_CMD_ADDR 0x48198000 +#define DDR_PHY_DATA_ADDR 0x481980C8 +#define DDR_PHY_CMD_ADDR2 0x4819A000 +#define DDR_PHY_DATA_ADDR2 0x4819A0C8 +#define DDR_DATA_REGS_NR 4 + +/* UART */ +#define UART0_BASE 0x48020000 +#define UART1_BASE 0x48022000 +#define UART2_BASE 0x48024000 + +#define DDRPHY_0_CONFIG_BASE 0x48198000 +#define DDRPHY_1_CONFIG_BASE 0x4819a000 +#define DDRPHY_CONFIG_BASE ((emif == 0) ? DDRPHY_0_CONFIG_BASE:DDRPHY_1_CONFIG_BASE) + +/* CPSW Config space */ +#define CPSW_MDIO_BASE 0x4A100800 + +/* RTC base address */ +#define RTC_BASE 0x480C0000 + +#endif /* __AM33XX_HARDWARE_TI816X_H */
"TENART" == TENART Antoine atenart@adeneo-embedded.com writes:
TENART> Also move some non common defintions from hardware.h TENART> --- TENART> arch/arm/include/asm/arch-am33xx/hardware.h | 7 +-- TENART> arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 5 ++ TENART> arch/arm/include/asm/arch-am33xx/hardware_ti814x.h | 5 ++ TENART> arch/arm/include/asm/arch-am33xx/hardware_ti816x.h | 58 ++++++++++++++++++++ TENART> 4 files changed, 70 insertions(+), 5 deletions(-) TENART> create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_ti816x.h
TENART> +#define DDRPHY_0_CONFIG_BASE 0x48198000 TENART> +#define DDRPHY_1_CONFIG_BASE 0x4819a000 TENART> +#define DDRPHY_CONFIG_BASE ((emif == 0) ? DDRPHY_0_CONFIG_BASE:DDRPHY_1_CONFIG_BASE) TENART> + TENART> +/* CPSW Config space */ TENART> +#define CPSW_MDIO_BASE 0x4A100800
ti816x doesn't have CPSW, so the name is a bit odd (the base address matches the emac mdio module). The emac driver expects an asm/arch/emac_defs.h header with a EMAC_MDIO_BASE_ADDR define (among others).
Perhaps just drop it from here as you're not adding emac support in this series anyway.
Agreed, and please check the whole series over for other unused defines. We shouldn't import things we aren't using.
Peter Korsgaard
TENART Antoine
