[U-Boot] [PATCH v2] spi: designware_spi: Disable and free clock when remove driver
Disable and free clock when remove driver.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
--- v2: - Check return value from clk_free() and return 0 when exit function --- drivers/spi/designware_spi.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 5cca414..8f0c602 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -516,8 +516,22 @@ static int dw_spi_set_mode(struct udevice *bus, uint mode) static int dw_spi_remove(struct udevice *bus) { struct dw_spi_priv *priv = dev_get_priv(bus); + int ret; + + ret = reset_release_bulk(&priv->resets); + if (ret) + return ret;
- return reset_release_bulk(&priv->resets); +#if CONFIG_IS_ENABLED(CLK) + ret = clk_disable(&priv->clk); + if (ret) + return ret; + + ret = clk_free(&priv->clk); + if (ret) + return ret; +#endif + return 0; }
static const struct dm_spi_ops dw_spi_ops = {
v2:
- int ret;
- ret = reset_release_bulk(&priv->resets);
- if (ret)
return ret;
- ret = clk_disable(&priv->clk);
- if (ret)
return ret;
- ret = clk_free(&priv->clk);
- if (ret)
return ret;
Acked-by: Marek Vasut marex@denx.de
btw this doesn't apply to socfpga/master .
v2:
int ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
Jagan,
Can you help to merge this patch?
And also this designware_spi's patch. This patch should apply first. https://patchwork.ozlabs.org/patch/967210/
Regards Ley Foon
Ley Foon Tan
Ley Foon Tan
