[PATCH] phy: usbphyc: use regulator_set_enable_if_allowed for disabling vdd supply
Use regulator_set_enable_if_allowed() api instead of regulator_set_enable() while disabling vdd supply. This way the driver doesn't see an error when disabling an always-on regulator.
This patch is needed since the commit f93fab312615 ("Revert 'power: regulator: Return success on attempt to disable an always-on regulator'") and use the API introduced by commit cc4a224af226 ("power: regulator: Introduce regulator_set_enable_if_allowed api").
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/phy/phy-stm32-usbphyc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/phy/phy-stm32-usbphyc.c b/drivers/phy/phy-stm32-usbphyc.c index 464b0735e8..c6d3048602 100644 --- a/drivers/phy/phy-stm32-usbphyc.c +++ b/drivers/phy/phy-stm32-usbphyc.c @@ -263,7 +263,7 @@ static int stm32_usbphyc_phy_power_off(struct phy *phy) return 0;
if (usbphyc_phy->vdd) { - ret = regulator_set_enable(usbphyc_phy->vdd, false); + ret = regulator_set_enable_if_allowed(usbphyc_phy->vdd, false); if (ret) return ret; }
if (ret) return ret; }ret = regulator_set_enable_if_allowed(usbphyc_phy->vdd, false);
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Patrice
Thanks
Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied to u-boot-stm/master
Thanks
Patrice
Patrice CHOTARD
Patrick Delaunay
