[PATCH] imx8mq_evk: Remove FEC and Ethernet PHY board code
With Ethernet DM in place, there is no longer the need for having the board_phy_config() and setup_fec() functions anymore.
Remove them.
Successfully tested a TFTP transfer after these changes.
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/imx8mq_evk/imx8mq_evk.c | 30 ------------------------- 1 file changed, 30 deletions(-)
diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index e39480585609..e577e4d9ccaa 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -54,38 +54,8 @@ int board_early_init_f(void) return 0; }
-#ifdef CONFIG_FEC_MXC -static int setup_fec(void) -{ - struct iomuxc_gpr_base_regs *gpr = - (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; - - /* Use 125M anatop REF_CLK1 for ENET1, not from external */ - clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0); - return set_clk_enet(ENET_125MHZ); -} - -int board_phy_config(struct phy_device *phydev) -{ - /* enable rgmii rxc skew and phy mode select to RGMII copper */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); - - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); - - if (phydev->drv->config) - phydev->drv->config(phydev); - return 0; -} -#endif - int board_init(void) { -#ifdef CONFIG_FEC_MXC - setup_fec(); -#endif - #if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_DWC3) init_usb_clk(); #endif
Remove them.
Applied to u-boot-imx/next, thanks.
Fabio Estevam
