[U-Boot] [PATCH] dfu: Delete superfluous initialization of the dfu_buf_size static variable
After extension of the dfu_get_buf() to also setup (implicitly) the dfu_buf_size variable it is not needed to set dfu_buf_size to CONFIG_SYS_DFU_DATA_BUF_SIZE.
This variable is set in the dfu_get_buf() by not only considering CONFIG_SYS_DFU_DATA_BUF but more importantly the "dfu_bufsiz" env variable. Therefore, dfu_get_buf() should be used for initialization.
Signed-off-by: Lukasz Majewski l.majewski@majess.pl --- drivers/dfu/dfu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index 0560afa..332be67 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -76,7 +76,7 @@ int dfu_init_env_entities(char *interface, char *devstr) }
static unsigned char *dfu_buf; -static unsigned long dfu_buf_size = CONFIG_SYS_DFU_DATA_BUF_SIZE; +static unsigned long dfu_buf_size;
unsigned char *dfu_free_buf(void) {
Hello Lukasz,
Reviewed-by: Przemyslaw Marczak p.marczak@samsung.com
Lukasz Majewski
Przemyslaw Marczak
