The following changes since commit 54e96680cb96fb7a4b8f43fd949c62054004d3e5:
Merge branch 'master' of git://git.denx.de/u-boot-microblaze (2012-02-26 22:17:40 +0100)
git://git.denx.de/u-boot-nand-flash.git master
Prabhakar Kushwaha (2): mtd/nand: Fix IFC driver to support 2K NAND page mtd/nand:Fix wrong usage of is_blank() in fsl_ifc_run_command
Scott Wood (2): Revert "nand: make 1-bit software ECC configurable" nand: reinstate lazy bad block scanning
Tom Rini (1): cmd_nand.c: Fix 'nand dump' after latest MTD resync
common/cmd_nand.c | 5 ++- drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/fsl_ifc_nand.c | 77 ++++++++++++++++++++------------------- drivers/mtd/nand/nand_base.c | 14 ++++---- include/linux/mtd/nand.h | 2 + include/linux/mtd/nand_ecc.h | 25 ------------- 6 files changed, 53 insertions(+), 72 deletions(-)
Dear Scott Wood,
Applied, thanks.
Scott Wood
