[PATCH] configs: iot2050: Disable CONFIG_CONSOLE_MUX
We only have serial as console option, and leaving this on turns on SYS_CONSOLE_IS_IN_ENV which is also not true for these devices, leaving an ugly
In: No input devices available! Out: No output devices available! Err: No error devices available!
behind.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com ---
Fix for 2023.10.
configs/iot2050_defconfig | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/configs/iot2050_defconfig b/configs/iot2050_defconfig index bc9ca16fac3..3f05f8c38d7 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_defconfig @@ -18,7 +18,6 @@ CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="k3-am6528-iot2050-basic" CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_SYS_PROMPT="IOT2050> " CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_SPL_SERIAL=y @@ -41,7 +40,6 @@ CONFIG_AUTOBOOT_FLUSH_STDIN=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE to stop autoboot in %d seconds...\n" CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_BOOTCOMMAND="run start_watchdog; run distro_bootcmd" -CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -62,6 +60,7 @@ CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x380000 +CONFIG_SYS_PROMPT="IOT2050> " CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_ASKENV=y
behind.
Jan Kiszka
