[GIT PULL] Please pull u-boot-imx-master-20240317
Hi Tom,
Please pull these fixes from u-boot-imx, thanks.
The following changes since commit 86fd291a7990af84e96808f48eff2219dd4ef496:
Merge tag 'efi-2024-04-rc5' of https://source.denx.de/u-boot/custodians/u-boot-efi (2024-03-13 20:39:46 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240317
for you to fetch changes up to e648c4a3455a4d1880efe121602ed90a0bc9b53f:
arm: imx: imx8m: soc: Fix NPU/VPU fdt disable fixup (2024-03-17 18:00:04 -0300)
u-boot-imx-master-20240317 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/19974
- Fix build error when SoM detection on Phytec board. - Fix sc_misc_otp_fuse_read() error check on colibri-imx8x/apalis-imx8. - Fix NPU/VPU fdt disable fixup on i.MX8M. ---------------------------------------------------------------- Benjamin Hahn (1): board: phytec: define get_som_type also when SoM detection is disabled
Fabio Estevam (2): colibri-imx8x: Fix sc_misc_otp_fuse_read() error check apalis-imx8: Fix sc_misc_otp_fuse_read() error check
Vitor Soares (1): arm: imx: imx8m: soc: Fix NPU/VPU fdt disable fixup
arch/arm/mach-imx/imx8m/soc.c | 18 ++++++++++++++---- board/phytec/common/phytec_som_detection.c | 5 +++++ board/toradex/apalis-imx8/apalis-imx8.c | 2 +- board/toradex/colibri-imx8x/colibri-imx8x.c | 2 +- 4 files changed, 21 insertions(+), 6 deletions(-)
On Sun, Mar 17, 2024 at 08:34:20PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
