Re: [U-Boot-Users] [DNX#2006081142000027] [PATCH 01/07 v2 ]: General code modification for m [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006081142000027] was created:
<snip>
General code modification for mpc7448hpc2 board support.
- Add 7447A and 7448 processor support.
- Add the following flags.
CFG_CONFIG_BUS_CLK : If the 74xx bus frequency can be configured dynamically (such as by switch on board), this flag should be set.
CFG_EXCEPTION_AFTER_RELOCATE: If an exception occurs after the u-boot relocates to RAM, this flag should be set
CFG_SERIAL_HANG_IN_EXCEPTION: If the print out function will cause the system hang in exception, this flag should be set.
There is a design issue for tsi108/109 pci configure read. When pci scan the slots, if there is no pci card, the tsi108/9 will cause a machine check exception for mpc7448 processor.
Signed-off-by: Alexandre Bounine alexandreb@tundra.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com
MAKEALL | 4 +-- Makefile | 3 ++ README | 22 ++++++++-------- cpu/74xx_7xx/cpu.c | 22 ++++++++++++++-- cpu/74xx_7xx/cpu_init.c | 2 + cpu/74xx_7xx/speed.c | 55 ++++++++++++++++++++++++++++++++++++++--- drivers/Makefile | 6 ++-- include/74xx_7xx.h | 1 + include/asm-ppc/global_data.h | 3 ++ lib_ppc/extable.c | 10 +++++++ 10 files changed, 105 insertions(+), 23 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 467a9be..2f41936 100755 --- a/MAKEALL +++ b/MAKEALL @@ -139,8 +139,8 @@ ## 74xx/7xx Systems
LIST_74xx=" \
- DB64360 DB64460 EVB64260 P3G4
- PCIPPC2 PCIPPC6 ZUMA
- DB64360 DB64460 EVB64260 mpc7448hpc2
- P3G4 PCIPPC2 PCIPPC6 ZUMA
LIST_7xx=" \ diff --git a/Makefile b/Makefile index 128ae59..c910f39 100644 --- a/Makefile +++ b/Makefile @@ -1489,6 +1489,9 @@ EVB64260_config \ EVB64260_750CX_config: unconfig @./mkconfig EVB64260 ppc 74xx_7xx evb64260
+mpc7448hpc2_config: unconfig
- @./mkconfig $(@:_config=) ppc 74xx_7xx mpc7448hpc2
P3G4_config: unconfig @./mkconfig $(@:_config=) ppc 74xx_7xx evb64260
diff --git a/README b/README index e772c1a..f7f53d1 100644 --- a/README +++ b/README @@ -2289,17 +2289,17 @@ configurations; the following names are csb272_config lwmon_config sbc8260_config CU824_config MBX860T_config sbc8560_33_config DUET_ADS_config MBX_config sbc8560_66_config
- EBONY_config MPC8260ADS_config SM850_config
- ELPT860_config MPC8540ADS_config SPD823TS_config
- ESTEEM192E_config MPC8540EVAL_config stxgp3_config
- ETX094_config MPC8560ADS_config SXNI855T_config
- FADS823_config NETVIA_config TQM823L_config
- FADS850SAR_config omap1510inn_config TQM850L_config
- FADS860T_config omap1610h2_config TQM855L_config
- FPS850L_config omap1610inn_config TQM860L_config
omap5912osk_config walnut_config
omap2420h4_config Yukon8220_config
ZPC1900_config
- EBONY_config mpc7448hpc2_config SM850_config
- ELPT860_config MPC8260ADS_config SPD823TS_config
- ESTEEM192E_config MPC8540ADS_config stxgp3_config
- ETX094_config MPC8540EVAL_config SXNI855T_config
- FADS823_config NMPC8560ADS_config TQM823L_config
- FADS850SAR_config NETVIA_config TQM850L_config
- FADS860T_config omap1510inn_config TQM855L_config
- FPS850L_config omap1610h2_config TQM860L_config
omap1610inn_config walnut_config
</snip>
Your U-Boot support team
DENX Support System
