[U-Boot] ImportError: No module named _libfdt
Hello,
I am new to U-Boot and trying to compile source code in order to get U-Boot working on a BananaPi.
I get the following error while compiling the latest version of master branch:
Has anyone an idea about why Python is not happy?
Thank you, JM
On Sat, Jun 17, 2017 at 6:45 PM, Jean-Marc Beaune jm.beaune@gmail.com wrote:
Hello,
If you're using the upstream dtc you'll need something newer than the latest actual release to pull in the python bindings, even then I've found errors because I think u-boot has something different to upstream that is some how being utilised in the .07 RCs but I've not had time to look closer at it.
Peter
On 17.06.2017 19:45, jm.beaune at gmail.com (Jean-Marc Beaune) wrote:
Hello,
Thank you, JM
I experienced the same problem while trying to compile for a BananaPro.
The problem was my system using python3 as default python interpreter. This causes the _libfdt module being compiled for python3 only. But the script "./tools/binman/binman", that threw the exception, explicitly requires python2.
This was on v2017.09 btw.
Conrad
Jean-Marc Beaune
Peter Robinson
