[U-Boot-Users] Compiler works! Yahoo! and now conf My for my Own PrPMC...
Hello,
Today I've fixed two major things: - installed ELDK @Suse Linux 8.1 - compiled U-Boot for BAB7xx board
Some questions are left: - make (command) Is this a standard Linux/Unix command? How does it know which GNU Compiler to use? - make all (command) What does it do? According to which paramters and which files? - Can a make a script file to set the compiler parameters like: export CROSS_COMPILE = ppc_74xx- - What is BASH$
- Where should I start to make a suitable U-Boot configuration for my own PrPMC Board: - MPC7410 - Marvell Galileo GT-64260 - 2MB Cache - 8MB Flash memory - 64MB SDRAM - One ehternet port connected (on P14 of the PMC)
- Is there a pre-defined configuration which looks like this configuration?
Thanks a lot!!
Greetz Roel
Am Mittwoch, 2. April 2003 15:16 schrieben Sie:
Hello,
Yes, it's one of the oldest toolsets to build binaries from a set of sources. GNU Make is more extensive than classic UN*X make.
There is an environment vatiable named CC. For GNU Make the default value is gcc.
All the stuf behind the target "all" inside your Makefile.
It hase to set in your Makefile or the environment that make will run.
- What is BASH$
???? I expect you mean $BASH ????
It's an environment vatiable too.
You should read some open documents, howtos and faqs about GNU Tool Chain and UN*X shell programming. See http://www.linuxdoc.org
PrPMC Board:
MPC7410
2MB Cache
8MB Flash memory
64MB SDRAM
I don't know abot, sorry.
Best regards.
Roel Loeffen
Stephan Linz
