Pull request: u-boot-imx u-boot-imx-20210720
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit f929ce50727bf1019323d6c199dfd3a5755c5474:
Merge branch '2021-07-16-cleanup-image-support' (2021-07-17 11:39:50 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20210720
for you to fetch changes up to bd8e26606db62a0434c7f09adfa6ec666b36985b:
imx: imx8mm: Add support for Kontron Electronics SL/BL i.MX8M-Mini boards (N801x) (2021-07-19 23:30:47 +0200)
---------------------------------------------------------------- CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/8325
- imx8: add support for i.MX8ULP Kontron MX8MM - imx6ul: Kontron mx6ul
---------------------------------------------------------------- Frieder Schrempf (2): imx: imx6ul: Add support for Kontron Electronics SL/BL i.MX6UL/ULL boards (N63xx/N64xx) imx: imx8mm: Add support for Kontron Electronics SL/BL i.MX8M-Mini boards (N801x)
Peng Fan (24): arm: imx: add i.MX8ULP basic Kconfig option arm: imx: add i.MX8ULP cpu type and helper arm: imx: sys_proto: move boot mode define to common header arm: imx8ulp: support print cpu info imx: imx8ulp: add get reset cause arm: imx: basic i.MX8ULP support arm: imx: parse-container: guard included header files arm: imx: move container Kconfig under mach-imx net: fec_mxc: support i.MX8ULP driver: serial: fsl_lpuart: support i.MX8ULP arm: imx8ulp: add clock support drivers: mmc: fsl_esdhc_imx: support i.MX8ULP arm: imx8ulp: disable wdog3 arm: imx8ulp: add rdc support arm: imx8ulp: add trdc release request arm: imx8ulp: release trdc and assign lpav from RTD to APD imx8ulp: unify rdc functions arm: imx8ulp: add dummy imx_get_mac_from_fuse arm: imx8ulp: add iomuxc support imx8ulp: soc: correct reset cause imx8ulp: move struct mu_type to common header imx8ulp: add upower api support arm: dts: add i.MX8ULP dtsi arm: imx: add i.MX8ULP EVK support
Ye Li (20): arm: imx8: Move container parser and image to mach-imx common folder arm: imx8: Move container image header file to mach-imx arm: imx8ulp: add container support driver: misc: Add MU and S400 API to communicate with Sentinel pinctrl: Add pinctrl driver for imx8ulp arm: imx8ulp: soc: Change to use CMC1 to get bootcfg arm: imx8ulp: Enable full L2 cache in SPL arm: imx8ulp: Update the reset vector in u-boot drivers: misc: s400_api: Update S400_SUCCESS_IND to 0xd6 drivers: misc: imx8ulp: Add S400 API for image authentication drivers: misc: imx8ulp: Update S400 API for release RDC drivers: misc: s400_api: Update API for fuse read and write arm: imx8ulp: release and configure XRDC at early phase arm: imx8ulp: Probe the S400 MU device in arch init arm: iMX8ULP: Add boot device relevant functions arm: imx8ulp: Allocate DCNANO and MIPI_DSI to AD domain driver: misc: imx8ulp: Add fuse driver for imx8ulp imx8ulp: Use DGO_GP5 to get boot config imx8ulp: Add workaround for eMMC boot ddr: Add DDR driver for iMX8ULP
arch/arm/Kconfig | 11 ++ arch/arm/Makefile | 4 +- arch/arm/dts/Makefile | 9 +- arch/arm/dts/imx6ul-kontron-n631x-s-u-boot.dtsi | 7 ++ arch/arm/dts/imx6ul-kontron-n631x-s.dts | 17 +++ arch/arm/dts/imx6ul-kontron-n631x-som.dtsi | 14 +++ arch/arm/dts/imx6ul-kontron-n6x1x-s-u-boot.dtsi | 98 +++++++++++++++++ arch/arm/dts/imx6ul-kontron-n6x1x-s.dts | 423 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6ul-kontron-n6x1x-s.dtsi | 420 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6ul-kontron-n6x1x-som-common.dtsi | 124 ++++++++++++++++++++++ arch/arm/dts/imx6ull-kontron-n641x-s-u-boot.dtsi | 7 ++ arch/arm/dts/imx6ull-kontron-n641x-s.dts | 16 +++ arch/arm/dts/imx6ull-kontron-n641x-som.dtsi | 13 +++ arch/arm/dts/imx8mm-kontron-n801x-s-lvds.dts | 116 ++++++++++++++++++++ arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi | 237 +++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mm-kontron-n801x-s.dts | 387 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mm-kontron-n801x-som.dtsi | 298 ++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8ulp-evk-u-boot.dtsi | 40 +++++++ arch/arm/dts/imx8ulp-evk.dts | 223 +++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8ulp-pinfunc.h | 978 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8ulp.dtsi | 728 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx/cpu.h | 4 + arch/arm/include/asm/arch-imx8ulp/cgc.h | 130 +++++++++++++++++++++++ arch/arm/include/asm/arch-imx8ulp/clock.h | 41 ++++++++ arch/arm/include/asm/arch-imx8ulp/ddr.h | 38 +++++++ arch/arm/include/asm/arch-imx8ulp/gpio.h | 20 ++++ arch/arm/include/asm/arch-imx8ulp/imx-regs.h | 162 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx8ulp/imx8ulp-pins.h | 60 +++++++++++ arch/arm/include/asm/arch-imx8ulp/iomux.h | 82 +++++++++++++++ arch/arm/include/asm/arch-imx8ulp/mu_hal.h | 12 +++ arch/arm/include/asm/arch-imx8ulp/pcc.h | 139 ++++++++++++++++++++++++ arch/arm/include/asm/arch-imx8ulp/rdc.h | 27 +++++ arch/arm/include/asm/arch-imx8ulp/s400_api.h | 41 ++++++++ arch/arm/include/asm/arch-imx8ulp/sys_proto.h | 19 ++++ arch/arm/include/asm/arch-imx8ulp/upower.h | 15 +++ arch/arm/include/asm/arch-mx7ulp/sys_proto.h | 9 -- arch/arm/include/asm/global_data.h | 5 + arch/arm/include/asm/{arch-imx8 => mach-imx}/image.h | 2 + arch/arm/include/asm/mach-imx/sys_proto.h | 13 ++- arch/arm/mach-imx/Kconfig | 15 ++- arch/arm/mach-imx/Makefile | 5 + arch/arm/mach-imx/cmd_dek.c | 2 +- arch/arm/mach-imx/{imx8/image.c => image-container.c} | 51 +++++++-- arch/arm/mach-imx/imx8/Kconfig | 13 --- arch/arm/mach-imx/imx8/Makefile | 3 - arch/arm/mach-imx/imx8/ahab.c | 2 +- arch/arm/mach-imx/imx8m/Kconfig | 8 ++ arch/arm/mach-imx/imx8ulp/Kconfig | 23 ++++ arch/arm/mach-imx/imx8ulp/Makefile | 11 ++ arch/arm/mach-imx/imx8ulp/cgc.c | 455 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/clock.c | 397 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/iomux.c | 58 ++++++++++ arch/arm/mach-imx/imx8ulp/lowlevel_init.S | 26 +++++ arch/arm/mach-imx/imx8ulp/pcc.c | 449 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/rdc.c | 411 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/soc.c | 544 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/upower/Makefile | 6 ++ arch/arm/mach-imx/imx8ulp/upower/upower_api.c | 485 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/upower/upower_api.h | 258 +++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/upower/upower_hal.c | 179 +++++++++++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 9 ++ arch/arm/mach-imx/{imx8 => }/parse-container.c | 4 +- arch/arm/mach-imx/spl_imx_romapi.c | 172 +++++++++++++++++++++++------- board/freescale/imx8ulp_evk/Kconfig | 14 +++ board/freescale/imx8ulp_evk/MAINTAINERS | 6 ++ board/freescale/imx8ulp_evk/Makefile | 7 ++ board/freescale/imx8ulp_evk/ddr_init.c | 207 ++++++++++++++++++++++++++++++++++++ board/freescale/imx8ulp_evk/imx8ulp_evk.c | 67 ++++++++++++ board/freescale/imx8ulp_evk/lpddr4_timing.c | 1158 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/freescale/imx8ulp_evk/spl.c | 115 ++++++++++++++++++++ board/kontron/sl-mx6ul/Kconfig | 15 +++ board/kontron/sl-mx6ul/MAINTAINERS | 9 ++ board/kontron/sl-mx6ul/Makefile | 8 ++ board/kontron/sl-mx6ul/kontron_mx6ul.c | 85 +++++++++++++++ board/kontron/sl-mx6ul/spl.c | 376 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/kontron/sl-mx8mm/Kconfig | 15 +++ board/kontron/sl-mx8mm/MAINTAINERS | 7 ++ board/kontron/sl-mx8mm/Makefile | 9 ++ board/kontron/sl-mx8mm/imximage.cfg | 9 ++ board/kontron/sl-mx8mm/kontron_mx8mm.c | 102 ++++++++++++++++++ board/kontron/sl-mx8mm/lpddr4_timing.c | 1846 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/kontron/sl-mx8mm/spl.c | 322 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ configs/imx8ulp_evk_defconfig | 103 ++++++++++++++++++ configs/kontron_mx6ul_defconfig | 109 +++++++++++++++++++ configs/kontron_mx8mm_defconfig | 124 ++++++++++++++++++++++ drivers/Makefile | 1 + drivers/ddr/imx/Kconfig | 1 + drivers/ddr/imx/imx8ulp/Kconfig | 11 ++ drivers/ddr/imx/imx8ulp/Makefile | 9 ++ drivers/ddr/imx/imx8ulp/ddr_init.c | 217 ++++++++++++++++++++++++++++++++++++++ drivers/misc/Makefile | 1 + drivers/misc/imx8ulp/Makefile | 4 + drivers/misc/imx8ulp/fuse.c | 198 ++++++++++++++++++++++++++++++++++ drivers/misc/imx8ulp/imx8ulp_mu.c | 234 +++++++++++++++++++++++++++++++++++++++++ drivers/misc/imx8ulp/s400_api.c | 244 ++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/Kconfig | 2 +- drivers/mmc/fsl_esdhc_imx.c | 12 ++- drivers/net/Kconfig | 2 +- drivers/net/fec_mxc.c | 2 +- drivers/pinctrl/nxp/Kconfig | 14 +++ drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-imx8ulp.c | 44 ++++++++ include/configs/imx8ulp_evk.h | 107 +++++++++++++++++++ include/configs/kontron_common.h | 86 +++++++++++++++ include/configs/kontron_mx6ul.h | 52 +++++++++ include/configs/kontron_mx8mm.h | 66 ++++++++++++ include/dt-bindings/clock/imx8ulp-clock.h | 247 +++++++++++++++++++++++++++++++++++++++++++ include/fsl_lpuart.h | 2 +- 108 files changed, 14758 insertions(+), 87 deletions(-) create mode 100644 arch/arm/dts/imx6ul-kontron-n631x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n631x-s.dts create mode 100644 arch/arm/dts/imx6ul-kontron-n631x-som.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s.dts create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s.dtsi create mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-som-common.dtsi create mode 100644 arch/arm/dts/imx6ull-kontron-n641x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ull-kontron-n641x-s.dts create mode 100644 arch/arm/dts/imx6ull-kontron-n641x-som.dtsi create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-s-lvds.dts create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-s-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-s.dts create mode 100644 arch/arm/dts/imx8mm-kontron-n801x-som.dtsi create mode 100644 arch/arm/dts/imx8ulp-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx8ulp-evk.dts create mode 100644 arch/arm/dts/imx8ulp-pinfunc.h create mode 100644 arch/arm/dts/imx8ulp.dtsi create mode 100644 arch/arm/include/asm/arch-imx8ulp/cgc.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/clock.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/ddr.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/gpio.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/imx-regs.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/imx8ulp-pins.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/iomux.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/mu_hal.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/pcc.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/rdc.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/s400_api.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/sys_proto.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/upower.h rename arch/arm/include/asm/{arch-imx8 => mach-imx}/image.h (95%) rename arch/arm/mach-imx/{imx8/image.c => image-container.c} (79%) create mode 100644 arch/arm/mach-imx/imx8ulp/Kconfig create mode 100644 arch/arm/mach-imx/imx8ulp/Makefile create mode 100644 arch/arm/mach-imx/imx8ulp/cgc.c create mode 100644 arch/arm/mach-imx/imx8ulp/clock.c create mode 100644 arch/arm/mach-imx/imx8ulp/iomux.c create mode 100644 arch/arm/mach-imx/imx8ulp/lowlevel_init.S create mode 100644 arch/arm/mach-imx/imx8ulp/pcc.c create mode 100644 arch/arm/mach-imx/imx8ulp/rdc.c create mode 100644 arch/arm/mach-imx/imx8ulp/soc.c create mode 100644 arch/arm/mach-imx/imx8ulp/upower/Makefile create mode 100644 arch/arm/mach-imx/imx8ulp/upower/upower_api.c create mode 100644 arch/arm/mach-imx/imx8ulp/upower/upower_api.h create mode 100644 arch/arm/mach-imx/imx8ulp/upower/upower_hal.c rename arch/arm/mach-imx/{imx8 => }/parse-container.c (98%) create mode 100644 board/freescale/imx8ulp_evk/Kconfig create mode 100644 board/freescale/imx8ulp_evk/MAINTAINERS create mode 100644 board/freescale/imx8ulp_evk/Makefile create mode 100644 board/freescale/imx8ulp_evk/ddr_init.c create mode 100644 board/freescale/imx8ulp_evk/imx8ulp_evk.c create mode 100644 board/freescale/imx8ulp_evk/lpddr4_timing.c create mode 100644 board/freescale/imx8ulp_evk/spl.c create mode 100644 board/kontron/sl-mx6ul/Kconfig create mode 100644 board/kontron/sl-mx6ul/MAINTAINERS create mode 100644 board/kontron/sl-mx6ul/Makefile create mode 100644 board/kontron/sl-mx6ul/kontron_mx6ul.c create mode 100644 board/kontron/sl-mx6ul/spl.c create mode 100644 board/kontron/sl-mx8mm/Kconfig create mode 100644 board/kontron/sl-mx8mm/MAINTAINERS create mode 100644 board/kontron/sl-mx8mm/Makefile create mode 100644 board/kontron/sl-mx8mm/imximage.cfg create mode 100644 board/kontron/sl-mx8mm/kontron_mx8mm.c create mode 100644 board/kontron/sl-mx8mm/lpddr4_timing.c create mode 100644 board/kontron/sl-mx8mm/spl.c create mode 100644 configs/imx8ulp_evk_defconfig create mode 100644 configs/kontron_mx6ul_defconfig create mode 100644 configs/kontron_mx8mm_defconfig create mode 100644 drivers/ddr/imx/imx8ulp/Kconfig create mode 100644 drivers/ddr/imx/imx8ulp/Makefile create mode 100644 drivers/ddr/imx/imx8ulp/ddr_init.c create mode 100644 drivers/misc/imx8ulp/Makefile create mode 100644 drivers/misc/imx8ulp/fuse.c create mode 100644 drivers/misc/imx8ulp/imx8ulp_mu.c create mode 100644 drivers/misc/imx8ulp/s400_api.c create mode 100644 drivers/pinctrl/nxp/pinctrl-imx8ulp.c create mode 100644 include/configs/imx8ulp_evk.h create mode 100644 include/configs/kontron_common.h create mode 100644 include/configs/kontron_mx6ul.h create mode 100644 include/configs/kontron_mx8mm.h create mode 100644 include/dt-bindings/clock/imx8ulp-clock.h
Best regards, Stefano
On Tue, Jul 20, 2021 at 05:17:59PM +0200, Stefano Babic wrote:
Hi Tom,
NAK:
ERROR: fdt or initrd relocation disabled at boot time #2019: FILE: include/configs/kontron_common.h:67: + "fdt_high=0xffffffff\0" \
And this is likely a bad idea too: ERROR: fdt or initrd relocation disabled at boot time #2020: FILE: include/configs/kontron_common.h:68: + "initrd_high=0xffffffff\0" \
but I haven't looked at all of include/configs/kontron_common.h to make sure it follows all of the layout stuff documented for example in: https://source.denx.de/u-boot/u-boot/-/blob/master/include/configs/ti_armv7_... (which is also true for aarch64 best I can tell from https://www.kernel.org/doc/Documentation/arm64/booting.rst).
And since I'm noting things, checkpatch has a whole bunch of formatting issues throughout as well (kontron and generic imx8 code both).
Hi Tom, Stefano,
Hi Tom,
NAK:
Sorry for the mess! I have fixed these issues and just sent a v4 for the Kontron board support patches.
Best regards Frieder
On 21.07.21 10:07, Frieder Schrempf wrote:
Hi Tom, Stefano,
Hi Tom,
NAK:
Thanks ! I have reverted (dropped) patches from u-boot-imx, we start again.
Sorry for non-text top posting.
The imx8ulp patch set has pin headers that would have lots warning, but we have agreement in Linux kernel that they are acceptable. Or you need we fix the line 100 warning?
Are there others blocking the patch set?
Thanks, Peng
获取 Outlook for iOShttps://aka.ms/o0ukef ________________________________ 发件人: Stefano Babic sbabic@denx.de 发送时间: 星期三, 七月 21, 2021 4:17 下午 收件人: Frieder Schrempf; Tom Rini; Stefano Babic; Peng Fan 抄送: U-Boot@lists.denx.de 主题: Re: Pull request: u-boot-imx u-boot-imx-20210720
Hi Tom, Stefano,
Hi Tom,
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgitlab.den... tags/u-boot-imx-20210720
NAK:
but I haven't looked at all of include/configs/kontron_common.h to make sure it follows all of the layout stuff documented for example in: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsource.den... (which is also true for aarch64 best I can tell from https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.kernel...).
-- ===================================================================== DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
I saw at least a few "spaces before tabs" and similar errors. The best answer I can give here is to run checkpatch.pl in the tree and make sure there's nothing that's not just pin headers/long lines. But I do think I saw some about general coding style too.
Frieder Schrempf
Peng Fan
Stefano Babic
