[U-Boot] [PATCH] cfb_console: fix build breakage
Commit 09c2e90c110ef99f1203685acd1059114a51b167 "unify version_string" introduced a build breakage in cfb_console.c
---8<--- cfb_console.c:1497: warning: format '%s' expects type 'char *', but argument 3 has type 'const char (*)[]' --->8---
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- drivers/video/cfb_console.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 77e7285..b56197f 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1494,7 +1494,7 @@ static void *video_logo (void)
logo_plot (video_fb_address, VIDEO_COLS, 0, 0);
- sprintf (info, " %s", &version_string); + sprintf (info, " %s", version_string);
space = (VIDEO_LINE_LEN / 2 - VIDEO_INFO_X) / VIDEO_FONT_WIDTH; len = strlen(info);
Dear =?UTF-8?q?Andreas=20Bie=C3=9Fmann?=,
In message 1311923413-62087-1-git-send-email-andreas.devel@googlemail.com you wrote:
Signed-off-by: Andreas BieÃmann andreas.devel@googlemail.com
Applied, thanks.
Hello.
Signed-off-by: Andreas Bießmannandreas.devel@googlemail.com
- sprintf (info, " %s",&version_string);
- sprintf (info, " %s", version_string);
This wouldn't pass checkpatch.pl -- remove the space before paren.
WBR, Sergei
Dear Sergei Shtylyov,
Yes, you are right. But this patch is just intended to fix the compile problem.
Cleanup patches for this file will follow soon :-)
The following 3 patches will clean up cfb_console.c so that future patches are more likely to pass checkpatch without problems.
The following warnings will not be fixed:
WARNING: externs should be avoided in .c files
WARNING: consider using strict_strtoul in preference to simple_strtoul
Run cfb_console.c through indent and manually fix some of he deficiencies of the automatic line breaking.
Fix multiline comments, excessive line spacing and such.
No changes to code done.
Signed-off-by: Wolfgang Denk wd@denx.de --- drivers/video/cfb_console.c | 1093 ++++++++++++++++++++++++------------------- 1 files changed, 609 insertions(+), 484 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index b56197f..917bba6 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -29,76 +29,83 @@ * At the moment only the 8x16 font is tested and the font fore- and * background color is limited to black/white/gray colors. The Linux * logo can be placed in the upper left corner and additional board - * information strings (that normaly goes to serial port) can be drawed. + * information strings (that normally goes to serial port) can be drawn. * * The console driver can use the standard PC keyboard interface (i8042) * for character input. Character output goes to a memory mapped video * framebuffer with little or big-endian organisation. * With environment setting 'console=serial' the console i/o can be * forced to serial port. - - The driver uses graphic specific defines/parameters/functions: - - (for SMI LynxE graphic chip) - - CONFIG_VIDEO_SMI_LYNXEM - use graphic driver for SMI 710,712,810 - VIDEO_FB_LITTLE_ENDIAN - framebuffer organisation default: big endian - VIDEO_HW_RECTFILL - graphic driver supports hardware rectangle fill - VIDEO_HW_BITBLT - graphic driver supports hardware bit blt - - Console Parameters are set by graphic drivers global struct: - - VIDEO_VISIBLE_COLS - x resolution - VIDEO_VISIBLE_ROWS - y resolution - VIDEO_PIXEL_SIZE - storage size in byte per pixel - VIDEO_DATA_FORMAT - graphical data format GDF - VIDEO_FB_ADRS - start of video memory - - CONFIG_I8042_KBD - AT Keyboard driver for i8042 - VIDEO_KBD_INIT_FCT - init function for keyboard - VIDEO_TSTC_FCT - keyboard_tstc function - VIDEO_GETC_FCT - keyboard_getc function - - CONFIG_CONSOLE_CURSOR - on/off drawing cursor is done with delay - loop in VIDEO_TSTC_FCT (i8042) - CONFIG_SYS_CONSOLE_BLINK_COUNT - value for delay loop - blink rate - CONFIG_CONSOLE_TIME - display time/date in upper right corner, - needs CONFIG_CMD_DATE and CONFIG_CONSOLE_CURSOR - CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner - CONFIG_VIDEO_BMP_LOGO - use bmp_logo instead of linux_logo - CONFIG_CONSOLE_EXTRA_INFO - display additional board information strings - that normaly goes to serial port. This define - requires a board specific function: - video_drawstring (VIDEO_INFO_X, - VIDEO_INFO_Y + i*VIDEO_FONT_HEIGHT, - info); - that fills a info buffer at i=row. - s.a: board/eltec/bab7xx. -CONFIG_VGA_AS_SINGLE_DEVICE - If set the framebuffer device will be initialised - as an output only device. The Keyboard driver - will not be set-up. This may be used, if you - have none or more than one Keyboard devices - (USB Keyboard, AT Keyboard). - -CONFIG_VIDEO_SW_CURSOR: - Draws a cursor after the last character. No - blinking is provided. Uses the macros CURSOR_SET - and CURSOR_OFF. -CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the - graphic chip. Uses the macro CURSOR_SET. - ATTENTION: If booting an OS, the display driver - must disable the hardware register of the graphic - chip. Otherwise a blinking field is displayed -*/ + * + * The driver uses graphic specific defines/parameters/functions: + * + * (for SMI LynxE graphic chip) + * + * CONFIG_VIDEO_SMI_LYNXEM - use graphic driver for SMI 710,712,810 + * VIDEO_FB_LITTLE_ENDIAN - framebuffer organisation default: big endian + * VIDEO_HW_RECTFILL - graphic driver supports hardware rectangle fill + * VIDEO_HW_BITBLT - graphic driver supports hardware bit blt + * + * Console Parameters are set by graphic drivers global struct: + * + * VIDEO_VISIBLE_COLS - x resolution + * VIDEO_VISIBLE_ROWS - y resolution + * VIDEO_PIXEL_SIZE - storage size in byte per pixel + * VIDEO_DATA_FORMAT - graphical data format GDF + * VIDEO_FB_ADRS - start of video memory + * + * CONFIG_I8042_KBD - AT Keyboard driver for i8042 + * VIDEO_KBD_INIT_FCT - init function for keyboard + * VIDEO_TSTC_FCT - keyboard_tstc function + * VIDEO_GETC_FCT - keyboard_getc function + * + * CONFIG_CONSOLE_CURSOR - on/off drawing cursor is done with + * delay loop in VIDEO_TSTC_FCT (i8042) + * + * CONFIG_SYS_CONSOLE_BLINK_COUNT - value for delay loop - blink rate + * CONFIG_CONSOLE_TIME - display time/date in upper right + * corner, needs CONFIG_CMD_DATE and + * CONFIG_CONSOLE_CURSOR + * CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner + * CONFIG_VIDEO_BMP_LOGO - use bmp_logo instead of linux_logo + * CONFIG_CONSOLE_EXTRA_INFO - display additional board information + * strings that normaly goes to serial + * port. This define requires a board + * specific function: + * video_drawstring (VIDEO_INFO_X, + * VIDEO_INFO_Y + i*VIDEO_FONT_HEIGHT, + * info); + * that fills a info buffer at i=row. + * s.a: board/eltec/bab7xx. + * CONFIG_VGA_AS_SINGLE_DEVICE - If set the framebuffer device will be + * initialized as an output only device. + * The Keyboard driver will not be + * set-up. This may be used, if you have + * no or more than one Keyboard devices + * (USB Keyboard, AT Keyboard). + * + * CONFIG_VIDEO_SW_CURSOR: - Draws a cursor after the last + * character. No blinking is provided. + * Uses the macros CURSOR_SET and + * CURSOR_OFF. + * + * CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability + * of the graphic chip. Uses the macro + * CURSOR_SET. ATTENTION: If booting an + * OS, the display driver must disable + * the hardware register of the graphic + * chip. Otherwise a blinking field is + * displayed. + */
#include <common.h> #include <version.h> - #include <malloc.h>
-/*****************************************************************************/ -/* Console device defines with SMI graphic */ -/* Any other graphic must change this section */ -/*****************************************************************************/ +/* + * Console device defines with SMI graphic + * Any other graphic must change this section + */
#ifdef CONFIG_VIDEO_SMI_LYNXEM
@@ -107,9 +114,9 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the #define VIDEO_HW_BITBLT #endif
-/*****************************************************************************/ -/* Defines for the CT69000 driver */ -/*****************************************************************************/ +/* + * Defines for the CT69000 driver + */ #ifdef CONFIG_VIDEO_CT69000
#define VIDEO_FB_LITTLE_ENDIAN @@ -117,9 +124,9 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the #define VIDEO_HW_BITBLT #endif
-/*****************************************************************************/ -/* Defines for the SED13806 driver */ -/*****************************************************************************/ +/* + * Defines for the SED13806 driver + */ #ifdef CONFIG_VIDEO_SED13806
#ifndef CONFIG_TOTAL5200 @@ -129,9 +136,9 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the #define VIDEO_HW_BITBLT #endif
-/*****************************************************************************/ -/* Defines for the SED13806 driver */ -/*****************************************************************************/ +/* + * Defines for the SED13806 driver + */ #ifdef CONFIG_VIDEO_SM501
#ifdef CONFIG_HH405 @@ -139,9 +146,9 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the #endif #endif
-/*****************************************************************************/ -/* Defines for the MB862xx driver */ -/*****************************************************************************/ +/* + * Defines for the MB862xx driver + */ #ifdef CONFIG_VIDEO_MB862xx
#ifdef CONFIG_VIDEO_CORALP @@ -153,24 +160,24 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the #endif #endif
-/*****************************************************************************/ -/* Include video_fb.h after definitions of VIDEO_HW_RECTFILL etc */ -/*****************************************************************************/ +/* + * Include video_fb.h after definitions of VIDEO_HW_RECTFILL etc. + */ #include <video_fb.h>
-/*****************************************************************************/ -/* some Macros */ -/*****************************************************************************/ +/* + * some Macros + */ #define VIDEO_VISIBLE_COLS (pGD->winSizeX) #define VIDEO_VISIBLE_ROWS (pGD->winSizeY) #define VIDEO_PIXEL_SIZE (pGD->gdfBytesPP) #define VIDEO_DATA_FORMAT (pGD->gdfIndex) #define VIDEO_FB_ADRS (pGD->frameAdrs)
-/*****************************************************************************/ -/* Console device defines with i8042 keyboard controller */ -/* Any other keyboard controller must change this section */ -/*****************************************************************************/ +/* + * Console device defines with i8042 keyboard controller + * Any other keyboard controller must change this section + */
#ifdef CONFIG_I8042_KBD #include <i8042.h> @@ -180,9 +187,9 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the #define VIDEO_GETC_FCT i8042_getc #endif
-/*****************************************************************************/ -/* Console device */ -/*****************************************************************************/ +/* + * Console device + */
#include <version.h> #include <linux/types.h> @@ -203,20 +210,20 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the
#endif
-/*****************************************************************************/ -/* Cursor definition: */ -/* CONFIG_CONSOLE_CURSOR: Uses a timer function (see drivers/input/i8042.c) */ -/* to let the cursor blink. Uses the macros */ -/* CURSOR_OFF and CURSOR_ON. */ -/* CONFIG_VIDEO_SW_CURSOR: Draws a cursor after the last character. No */ -/* blinking is provided. Uses the macros CURSOR_SET */ -/* and CURSOR_OFF. */ -/* CONFIG_VIDEO_HW_CURSOR: Uses the hardware cursor capability of the */ -/* graphic chip. Uses the macro CURSOR_SET. */ -/* ATTENTION: If booting an OS, the display driver */ -/* must disable the hardware register of the graphic */ -/* chip. Otherwise a blinking field is displayed */ -/*****************************************************************************/ +/* + * Cursor definition: + * CONFIG_CONSOLE_CURSOR: Uses a timer function (see drivers/input/i8042.c) + * to let the cursor blink. Uses the macros + * CURSOR_OFF and CURSOR_ON. + * CONFIG_VIDEO_SW_CURSOR: Draws a cursor after the last character. No + * blinking is provided. Uses the macros CURSOR_SET + * and CURSOR_OFF. + * CONFIG_VIDEO_HW_CURSOR: Uses the hardware cursor capability of the + * graphic chip. Uses the macro CURSOR_SET. + * ATTENTION: If booting an OS, the display driver + * must disable the hardware register of the graphic + * chip. Otherwise a blinking field is displayed + */ #if !defined(CONFIG_CONSOLE_CURSOR) && \ !defined(CONFIG_VIDEO_SW_CURSOR) && \ !defined(CONFIG_VIDEO_HW_CURSOR) @@ -228,9 +235,11 @@ CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability of the
#ifdef CONFIG_CONSOLE_CURSOR #ifdef CURSOR_ON -#error only one of CONFIG_CONSOLE_CURSOR,CONFIG_VIDEO_SW_CURSOR,CONFIG_VIDEO_HW_CURSOR can be defined +#error only one of CONFIG_CONSOLE_CURSOR, CONFIG_VIDEO_SW_CURSOR, \ + or CONFIG_VIDEO_HW_CURSOR can be defined #endif -void console_cursor (int state); +void console_cursor(int state); + #define CURSOR_ON console_cursor(1) #define CURSOR_OFF console_cursor(0) #define CURSOR_SET @@ -245,7 +254,8 @@ void console_cursor (int state);
#ifdef CONFIG_VIDEO_SW_CURSOR #ifdef CURSOR_ON -#error only one of CONFIG_CONSOLE_CURSOR,CONFIG_VIDEO_SW_CURSOR,CONFIG_VIDEO_HW_CURSOR can be defined +#error only one of CONFIG_CONSOLE_CURSOR, CONFIG_VIDEO_SW_CURSOR, \ + or CONFIG_VIDEO_HW_CURSOR can be defined #endif #define CURSOR_ON #define CURSOR_OFF video_putchar(console_col * VIDEO_FONT_WIDTH,\ @@ -256,13 +266,14 @@ void console_cursor (int state);
#ifdef CONFIG_VIDEO_HW_CURSOR #ifdef CURSOR_ON -#error only one of CONFIG_CONSOLE_CURSOR,CONFIG_VIDEO_SW_CURSOR,CONFIG_VIDEO_HW_CURSOR can be defined +#error only one of CONFIG_CONSOLE_CURSOR, CONFIG_VIDEO_SW_CURSOR, \ + or CONFIG_VIDEO_HW_CURSOR can be defined #endif #define CURSOR_ON #define CURSOR_OFF #define CURSOR_SET video_set_hw_cursor(console_col * VIDEO_FONT_WIDTH, \ (console_row * VIDEO_FONT_HEIGHT) + video_logo_height) -#endif /* CONFIG_VIDEO_HW_CURSOR */ +#endif /* CONFIG_VIDEO_HW_CURSOR */
#ifdef CONFIG_VIDEO_LOGO #ifdef CONFIG_VIDEO_BMP_LOGO @@ -272,7 +283,7 @@ void console_cursor (int state); #define VIDEO_LOGO_LUT_OFFSET BMP_LOGO_OFFSET #define VIDEO_LOGO_COLORS BMP_LOGO_COLORS
-#else /* CONFIG_VIDEO_BMP_LOGO */ +#else /* CONFIG_VIDEO_BMP_LOGO */ #define LINUX_LOGO_WIDTH 80 #define LINUX_LOGO_HEIGHT 80 #define LINUX_LOGO_COLORS 214 @@ -283,13 +294,13 @@ void console_cursor (int state); #define VIDEO_LOGO_HEIGHT LINUX_LOGO_HEIGHT #define VIDEO_LOGO_LUT_OFFSET LINUX_LOGO_LUT_OFFSET #define VIDEO_LOGO_COLORS LINUX_LOGO_COLORS -#endif /* CONFIG_VIDEO_BMP_LOGO */ +#endif /* CONFIG_VIDEO_BMP_LOGO */ #define VIDEO_INFO_X (VIDEO_LOGO_WIDTH) #define VIDEO_INFO_Y (VIDEO_FONT_HEIGHT/2) -#else /* CONFIG_VIDEO_LOGO */ +#else /* CONFIG_VIDEO_LOGO */ #define VIDEO_LOGO_WIDTH 0 #define VIDEO_LOGO_HEIGHT 0 -#endif /* CONFIG_VIDEO_LOGO */ +#endif /* CONFIG_VIDEO_LOGO */
#define VIDEO_COLS VIDEO_VISIBLE_COLS #define VIDEO_ROWS VIDEO_VISIBLE_ROWS @@ -314,101 +325,114 @@ void console_cursor (int state);
/* Macros */ #ifdef VIDEO_FB_LITTLE_ENDIAN -#define SWAP16(x) ((((x) & 0x00ff) << 8) | ( (x) >> 8)) -#define SWAP32(x) ((((x) & 0x000000ff) << 24) | (((x) & 0x0000ff00) << 8)|\ - (((x) & 0x00ff0000) >> 8) | (((x) & 0xff000000) >> 24) ) -#define SHORTSWAP32(x) ((((x) & 0x000000ff) << 8) | (((x) & 0x0000ff00) >> 8)|\ - (((x) & 0x00ff0000) << 8) | (((x) & 0xff000000) >> 8) ) +#define SWAP16(x) ((((x) & 0x00ff) << 8) | \ + ((x) >> 8) \ + ) +#define SWAP32(x) ((((x) & 0x000000ff) << 24) | \ + (((x) & 0x0000ff00) << 8) | \ + (((x) & 0x00ff0000) >> 8) | \ + (((x) & 0xff000000) >> 24) \ + ) +#define SHORTSWAP32(x) ((((x) & 0x000000ff) << 8) | \ + (((x) & 0x0000ff00) >> 8) | \ + (((x) & 0x00ff0000) << 8) | \ + (((x) & 0xff000000) >> 8) \ + ) #else -#define SWAP16(x) (x) -#define SWAP32(x) (x) +#define SWAP16(x) (x) +#define SWAP32(x) (x) #if defined(VIDEO_FB_16BPP_WORD_SWAP) -#define SHORTSWAP32(x) ( ((x) >> 16) | ((x) << 16) ) +#define SHORTSWAP32(x) (((x) >> 16) | ((x) << 16)) #else -#define SHORTSWAP32(x) (x) +#define SHORTSWAP32(x) (x) #endif #endif
#if defined(DEBUG) || defined(DEBUG_CFB_CONSOLE) -#define PRINTD(x) printf(x) +#define PRINTD(x) printf(x) #else #define PRINTD(x) #endif
#ifdef CONFIG_CONSOLE_EXTRA_INFO -extern void video_get_info_str ( /* setup a board string: type, speed, etc. */ - int line_number, /* location to place info string beside logo */ - char *info /* buffer for info string */ - ); - +/* + * setup a board string: type, speed, etc. + * + * line_number: location to place info string beside logo + * info: buffer for info string + */ +extern void video_get_info_str(int line_number, char *info); #endif
/* Locals */ static GraphicDevice *pGD; /* Pointer to Graphic array */
-static void *video_fb_address; /* frame buffer address */ +static void *video_fb_address; /* frame buffer address */ static void *video_console_address; /* console buffer start address */
static int video_logo_height = VIDEO_LOGO_HEIGHT;
-static int console_col = 0; /* cursor col */ -static int console_row = 0; /* cursor row */ +static int console_col = 0; /* cursor col */ +static int console_row = 0; /* cursor row */
-static u32 eorx, fgx, bgx; /* color pats */ +static u32 eorx, fgx, bgx; /* color pats */
static const int video_font_draw_table8[] = { - 0x00000000, 0x000000ff, 0x0000ff00, 0x0000ffff, - 0x00ff0000, 0x00ff00ff, 0x00ffff00, 0x00ffffff, - 0xff000000, 0xff0000ff, 0xff00ff00, 0xff00ffff, - 0xffff0000, 0xffff00ff, 0xffffff00, 0xffffffff }; + 0x00000000, 0x000000ff, 0x0000ff00, 0x0000ffff, + 0x00ff0000, 0x00ff00ff, 0x00ffff00, 0x00ffffff, + 0xff000000, 0xff0000ff, 0xff00ff00, 0xff00ffff, + 0xffff0000, 0xffff00ff, 0xffffff00, 0xffffffff +};
static const int video_font_draw_table15[] = { - 0x00000000, 0x00007fff, 0x7fff0000, 0x7fff7fff }; + 0x00000000, 0x00007fff, 0x7fff0000, 0x7fff7fff +};
static const int video_font_draw_table16[] = { - 0x00000000, 0x0000ffff, 0xffff0000, 0xffffffff }; + 0x00000000, 0x0000ffff, 0xffff0000, 0xffffffff +};
static const int video_font_draw_table24[16][3] = { - { 0x00000000, 0x00000000, 0x00000000 }, - { 0x00000000, 0x00000000, 0x00ffffff }, - { 0x00000000, 0x0000ffff, 0xff000000 }, - { 0x00000000, 0x0000ffff, 0xffffffff }, - { 0x000000ff, 0xffff0000, 0x00000000 }, - { 0x000000ff, 0xffff0000, 0x00ffffff }, - { 0x000000ff, 0xffffffff, 0xff000000 }, - { 0x000000ff, 0xffffffff, 0xffffffff }, - { 0xffffff00, 0x00000000, 0x00000000 }, - { 0xffffff00, 0x00000000, 0x00ffffff }, - { 0xffffff00, 0x0000ffff, 0xff000000 }, - { 0xffffff00, 0x0000ffff, 0xffffffff }, - { 0xffffffff, 0xffff0000, 0x00000000 }, - { 0xffffffff, 0xffff0000, 0x00ffffff }, - { 0xffffffff, 0xffffffff, 0xff000000 }, - { 0xffffffff, 0xffffffff, 0xffffffff } }; + {0x00000000, 0x00000000, 0x00000000}, + {0x00000000, 0x00000000, 0x00ffffff}, + {0x00000000, 0x0000ffff, 0xff000000}, + {0x00000000, 0x0000ffff, 0xffffffff}, + {0x000000ff, 0xffff0000, 0x00000000}, + {0x000000ff, 0xffff0000, 0x00ffffff}, + {0x000000ff, 0xffffffff, 0xff000000}, + {0x000000ff, 0xffffffff, 0xffffffff}, + {0xffffff00, 0x00000000, 0x00000000}, + {0xffffff00, 0x00000000, 0x00ffffff}, + {0xffffff00, 0x0000ffff, 0xff000000}, + {0xffffff00, 0x0000ffff, 0xffffffff}, + {0xffffffff, 0xffff0000, 0x00000000}, + {0xffffffff, 0xffff0000, 0x00ffffff}, + {0xffffffff, 0xffffffff, 0xff000000}, + {0xffffffff, 0xffffffff, 0xffffffff} +};
static const int video_font_draw_table32[16][4] = { - { 0x00000000, 0x00000000, 0x00000000, 0x00000000 }, - { 0x00000000, 0x00000000, 0x00000000, 0x00ffffff }, - { 0x00000000, 0x00000000, 0x00ffffff, 0x00000000 }, - { 0x00000000, 0x00000000, 0x00ffffff, 0x00ffffff }, - { 0x00000000, 0x00ffffff, 0x00000000, 0x00000000 }, - { 0x00000000, 0x00ffffff, 0x00000000, 0x00ffffff }, - { 0x00000000, 0x00ffffff, 0x00ffffff, 0x00000000 }, - { 0x00000000, 0x00ffffff, 0x00ffffff, 0x00ffffff }, - { 0x00ffffff, 0x00000000, 0x00000000, 0x00000000 }, - { 0x00ffffff, 0x00000000, 0x00000000, 0x00ffffff }, - { 0x00ffffff, 0x00000000, 0x00ffffff, 0x00000000 }, - { 0x00ffffff, 0x00000000, 0x00ffffff, 0x00ffffff }, - { 0x00ffffff, 0x00ffffff, 0x00000000, 0x00000000 }, - { 0x00ffffff, 0x00ffffff, 0x00000000, 0x00ffffff }, - { 0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00000000 }, - { 0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00ffffff } }; - - -/******************************************************************************/ - -static void video_drawchars (int xx, int yy, unsigned char *s, int count) + {0x00000000, 0x00000000, 0x00000000, 0x00000000}, + {0x00000000, 0x00000000, 0x00000000, 0x00ffffff}, + {0x00000000, 0x00000000, 0x00ffffff, 0x00000000}, + {0x00000000, 0x00000000, 0x00ffffff, 0x00ffffff}, + {0x00000000, 0x00ffffff, 0x00000000, 0x00000000}, + {0x00000000, 0x00ffffff, 0x00000000, 0x00ffffff}, + {0x00000000, 0x00ffffff, 0x00ffffff, 0x00000000}, + {0x00000000, 0x00ffffff, 0x00ffffff, 0x00ffffff}, + {0x00ffffff, 0x00000000, 0x00000000, 0x00000000}, + {0x00ffffff, 0x00000000, 0x00000000, 0x00ffffff}, + {0x00ffffff, 0x00000000, 0x00ffffff, 0x00000000}, + {0x00ffffff, 0x00000000, 0x00ffffff, 0x00ffffff}, + {0x00ffffff, 0x00ffffff, 0x00000000, 0x00000000}, + {0x00ffffff, 0x00ffffff, 0x00000000, 0x00ffffff}, + {0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00000000}, + {0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00ffffff} +}; + + +static void video_drawchars(int xx, int yy, unsigned char *s, int count) { u8 *cdat, *dest, *dest0; int rows, offset, c; @@ -423,12 +447,15 @@ static void video_drawchars (int xx, int yy, unsigned char *s, int count) c = *s; cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; - dest += VIDEO_LINE_LEN) { + rows--; dest += VIDEO_LINE_LEN) { u8 bits = *cdat++;
- ((u32 *) dest)[0] = (video_font_draw_table8[bits >> 4] & eorx) ^ bgx; - ((u32 *) dest)[1] = (video_font_draw_table8[bits & 15] & eorx) ^ bgx; + ((u32 *) dest)[0] = + (video_font_draw_table8[bits >> 4] & + eorx) ^ bgx; + ((u32 *) dest)[1] = + (video_font_draw_table8[bits & 15] & + eorx) ^ bgx; } dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; s++; @@ -440,14 +467,25 @@ static void video_drawchars (int xx, int yy, unsigned char *s, int count) c = *s; cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; - dest += VIDEO_LINE_LEN) { + rows--; dest += VIDEO_LINE_LEN) { u8 bits = *cdat++;
- ((u32 *) dest)[0] = SHORTSWAP32 ((video_font_draw_table15 [bits >> 6] & eorx) ^ bgx); - ((u32 *) dest)[1] = SHORTSWAP32 ((video_font_draw_table15 [bits >> 4 & 3] & eorx) ^ bgx); - ((u32 *) dest)[2] = SHORTSWAP32 ((video_font_draw_table15 [bits >> 2 & 3] & eorx) ^ bgx); - ((u32 *) dest)[3] = SHORTSWAP32 ((video_font_draw_table15 [bits & 3] & eorx) ^ bgx); + ((u32 *) dest)[0] = + SHORTSWAP32((video_font_draw_table15 + [bits >> 6] & eorx) ^ + bgx); + ((u32 *) dest)[1] = + SHORTSWAP32((video_font_draw_table15 + [bits >> 4 & 3] & eorx) ^ + bgx); + ((u32 *) dest)[2] = + SHORTSWAP32((video_font_draw_table15 + [bits >> 2 & 3] & eorx) ^ + bgx); + ((u32 *) dest)[3] = + SHORTSWAP32((video_font_draw_table15 + [bits & 3] & eorx) ^ + bgx); } dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; s++; @@ -459,14 +497,25 @@ static void video_drawchars (int xx, int yy, unsigned char *s, int count) c = *s; cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; - dest += VIDEO_LINE_LEN) { + rows--; dest += VIDEO_LINE_LEN) { u8 bits = *cdat++;
- ((u32 *) dest)[0] = SHORTSWAP32 ((video_font_draw_table16 [bits >> 6] & eorx) ^ bgx); - ((u32 *) dest)[1] = SHORTSWAP32 ((video_font_draw_table16 [bits >> 4 & 3] & eorx) ^ bgx); - ((u32 *) dest)[2] = SHORTSWAP32 ((video_font_draw_table16 [bits >> 2 & 3] & eorx) ^ bgx); - ((u32 *) dest)[3] = SHORTSWAP32 ((video_font_draw_table16 [bits & 3] & eorx) ^ bgx); + ((u32 *) dest)[0] = + SHORTSWAP32((video_font_draw_table16 + [bits >> 6] & eorx) ^ + bgx); + ((u32 *) dest)[1] = + SHORTSWAP32((video_font_draw_table16 + [bits >> 4 & 3] & eorx) ^ + bgx); + ((u32 *) dest)[2] = + SHORTSWAP32((video_font_draw_table16 + [bits >> 2 & 3] & eorx) ^ + bgx); + ((u32 *) dest)[3] = + SHORTSWAP32((video_font_draw_table16 + [bits & 3] & eorx) ^ + bgx); } dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; s++; @@ -478,18 +527,33 @@ static void video_drawchars (int xx, int yy, unsigned char *s, int count) c = *s; cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; - dest += VIDEO_LINE_LEN) { + rows--; dest += VIDEO_LINE_LEN) { u8 bits = *cdat++;
- ((u32 *) dest)[0] = SWAP32 ((video_font_draw_table32 [bits >> 4][0] & eorx) ^ bgx); - ((u32 *) dest)[1] = SWAP32 ((video_font_draw_table32 [bits >> 4][1] & eorx) ^ bgx); - ((u32 *) dest)[2] = SWAP32 ((video_font_draw_table32 [bits >> 4][2] & eorx) ^ bgx); - ((u32 *) dest)[3] = SWAP32 ((video_font_draw_table32 [bits >> 4][3] & eorx) ^ bgx); - ((u32 *) dest)[4] = SWAP32 ((video_font_draw_table32 [bits & 15][0] & eorx) ^ bgx); - ((u32 *) dest)[5] = SWAP32 ((video_font_draw_table32 [bits & 15][1] & eorx) ^ bgx); - ((u32 *) dest)[6] = SWAP32 ((video_font_draw_table32 [bits & 15][2] & eorx) ^ bgx); - ((u32 *) dest)[7] = SWAP32 ((video_font_draw_table32 [bits & 15][3] & eorx) ^ bgx); + ((u32 *) dest)[0] = + SWAP32((video_font_draw_table32 + [bits >> 4][0] & eorx) ^ bgx); + ((u32 *) dest)[1] = + SWAP32((video_font_draw_table32 + [bits >> 4][1] & eorx) ^ bgx); + ((u32 *) dest)[2] = + SWAP32((video_font_draw_table32 + [bits >> 4][2] & eorx) ^ bgx); + ((u32 *) dest)[3] = + SWAP32((video_font_draw_table32 + [bits >> 4][3] & eorx) ^ bgx); + ((u32 *) dest)[4] = + SWAP32((video_font_draw_table32 + [bits & 15][0] & eorx) ^ bgx); + ((u32 *) dest)[5] = + SWAP32((video_font_draw_table32 + [bits & 15][1] & eorx) ^ bgx); + ((u32 *) dest)[6] = + SWAP32((video_font_draw_table32 + [bits & 15][2] & eorx) ^ bgx); + ((u32 *) dest)[7] = + SWAP32((video_font_draw_table32 + [bits & 15][3] & eorx) ^ bgx); } dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; s++; @@ -501,16 +565,27 @@ static void video_drawchars (int xx, int yy, unsigned char *s, int count) c = *s; cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; - dest += VIDEO_LINE_LEN) { + rows--; dest += VIDEO_LINE_LEN) { u8 bits = *cdat++;
- ((u32 *) dest)[0] = (video_font_draw_table24[bits >> 4][0] & eorx) ^ bgx; - ((u32 *) dest)[1] = (video_font_draw_table24[bits >> 4][1] & eorx) ^ bgx; - ((u32 *) dest)[2] = (video_font_draw_table24[bits >> 4][2] & eorx) ^ bgx; - ((u32 *) dest)[3] = (video_font_draw_table24[bits & 15][0] & eorx) ^ bgx; - ((u32 *) dest)[4] = (video_font_draw_table24[bits & 15][1] & eorx) ^ bgx; - ((u32 *) dest)[5] = (video_font_draw_table24[bits & 15][2] & eorx) ^ bgx; + ((u32 *) dest)[0] = + (video_font_draw_table24[bits >> 4][0] + & eorx) ^ bgx; + ((u32 *) dest)[1] = + (video_font_draw_table24[bits >> 4][1] + & eorx) ^ bgx; + ((u32 *) dest)[2] = + (video_font_draw_table24[bits >> 4][2] + & eorx) ^ bgx; + ((u32 *) dest)[3] = + (video_font_draw_table24[bits & 15][0] + & eorx) ^ bgx; + ((u32 *) dest)[4] = + (video_font_draw_table24[bits & 15][1] + & eorx) ^ bgx; + ((u32 *) dest)[5] = + (video_font_draw_table24[bits & 15][2] + & eorx) ^ bgx; } dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; s++; @@ -519,23 +594,18 @@ static void video_drawchars (int xx, int yy, unsigned char *s, int count) } }
-/*****************************************************************************/ - -static inline void video_drawstring (int xx, int yy, unsigned char *s) +static inline void video_drawstring(int xx, int yy, unsigned char *s) { - video_drawchars (xx, yy, s, strlen ((char *)s)); + video_drawchars(xx, yy, s, strlen((char *) s)); }
-/*****************************************************************************/ - -static void video_putchar (int xx, int yy, unsigned char c) +static void video_putchar(int xx, int yy, unsigned char c) { - video_drawchars (xx, yy + video_logo_height, &c, 1); + video_drawchars(xx, yy + video_logo_height, &c, 1); }
-/*****************************************************************************/ #if defined(CONFIG_CONSOLE_CURSOR) || defined(CONFIG_VIDEO_SW_CURSOR) -static void video_set_cursor (void) +static void video_set_cursor(void) { /* swap drawing colors */ eorx = fgx; @@ -543,9 +613,8 @@ static void video_set_cursor (void) bgx = eorx; eorx = fgx ^ bgx; /* draw cursor */ - video_putchar (console_col * VIDEO_FONT_WIDTH, - console_row * VIDEO_FONT_HEIGHT, - ' '); + video_putchar(console_col * VIDEO_FONT_WIDTH, + console_row * VIDEO_FONT_HEIGHT, ' '); /* restore drawing colors */ eorx = fgx; fgx = bgx; @@ -553,9 +622,9 @@ static void video_set_cursor (void) eorx = fgx ^ bgx; } #endif -/*****************************************************************************/ + #ifdef CONFIG_CONSOLE_CURSOR -void console_cursor (int state) +void console_cursor(int state) { static int last_state = 0;
@@ -565,92 +634,88 @@ void console_cursor (int state)
/* time update only if cursor is on (faster scroll) */ if (state) { - rtc_get (&tm); - - sprintf (info, " %02d:%02d:%02d ", tm.tm_hour, tm.tm_min, - tm.tm_sec); - video_drawstring (VIDEO_VISIBLE_COLS - 10 * VIDEO_FONT_WIDTH, - VIDEO_INFO_Y, (uchar *)info); - - sprintf (info, "%02d.%02d.%04d", tm.tm_mday, tm.tm_mon, - tm.tm_year); - video_drawstring (VIDEO_VISIBLE_COLS - 10 * VIDEO_FONT_WIDTH, - VIDEO_INFO_Y + 1 * VIDEO_FONT_HEIGHT, (uchar *)info); + rtc_get(&tm); + + sprintf(info, " %02d:%02d:%02d ", tm.tm_hour, tm.tm_min, + tm.tm_sec); + video_drawstring(VIDEO_VISIBLE_COLS - 10 * VIDEO_FONT_WIDTH, + VIDEO_INFO_Y, (uchar *) info); + + sprintf(info, "%02d.%02d.%04d", tm.tm_mday, tm.tm_mon, + tm.tm_year); + video_drawstring(VIDEO_VISIBLE_COLS - 10 * VIDEO_FONT_WIDTH, + VIDEO_INFO_Y + 1 * VIDEO_FONT_HEIGHT, + (uchar *) info); } #endif
if (state && (last_state != state)) { - video_set_cursor (); + video_set_cursor(); }
if (!state && (last_state != state)) { /* clear cursor */ - video_putchar (console_col * VIDEO_FONT_WIDTH, - console_row * VIDEO_FONT_HEIGHT, - ' '); + video_putchar(console_col * VIDEO_FONT_WIDTH, + console_row * VIDEO_FONT_HEIGHT, ' '); }
last_state = state; } #endif
-/*****************************************************************************/ - #ifndef VIDEO_HW_RECTFILL -static void memsetl (int *p, int c, int v) +static void memsetl(int *p, int c, int v) { while (c--) *(p++) = v; } #endif
-/*****************************************************************************/ - #ifndef VIDEO_HW_BITBLT -static void memcpyl (int *d, int *s, int c) +static void memcpyl(int *d, int *s, int c) { while (c--) *(d++) = *(s++); } #endif
-/*****************************************************************************/ - -static void console_scrollup (void) +static void console_scrollup(void) { /* copy up rows ignoring the first one */
#ifdef VIDEO_HW_BITBLT - video_hw_bitblt (VIDEO_PIXEL_SIZE, /* bytes per pixel */ - 0, /* source pos x */ - video_logo_height + VIDEO_FONT_HEIGHT, /* source pos y */ - 0, /* dest pos x */ - video_logo_height, /* dest pos y */ - VIDEO_VISIBLE_COLS, /* frame width */ - VIDEO_VISIBLE_ROWS - video_logo_height - VIDEO_FONT_HEIGHT /* frame height */ + video_hw_bitblt(VIDEO_PIXEL_SIZE, /* bytes per pixel */ + 0, /* source pos x */ + video_logo_height + + VIDEO_FONT_HEIGHT, /* source pos y */ + 0, /* dest pos x */ + video_logo_height, /* dest pos y */ + VIDEO_VISIBLE_COLS, /* frame width */ + VIDEO_VISIBLE_ROWS + - video_logo_height + - VIDEO_FONT_HEIGHT /* frame height */ ); #else - memcpyl (CONSOLE_ROW_FIRST, CONSOLE_ROW_SECOND, - CONSOLE_SCROLL_SIZE >> 2); + memcpyl(CONSOLE_ROW_FIRST, CONSOLE_ROW_SECOND, + CONSOLE_SCROLL_SIZE >> 2); #endif
/* clear the last one */ #ifdef VIDEO_HW_RECTFILL - video_hw_rectfill (VIDEO_PIXEL_SIZE, /* bytes per pixel */ - 0, /* dest pos x */ - VIDEO_VISIBLE_ROWS - VIDEO_FONT_HEIGHT, /* dest pos y */ - VIDEO_VISIBLE_COLS, /* frame width */ - VIDEO_FONT_HEIGHT, /* frame height */ - CONSOLE_BG_COL /* fill color */ + video_hw_rectfill(VIDEO_PIXEL_SIZE, /* bytes per pixel */ + 0, /* dest pos x */ + VIDEO_VISIBLE_ROWS + - VIDEO_FONT_HEIGHT, /* dest pos y */ + VIDEO_VISIBLE_COLS, /* frame width */ + VIDEO_FONT_HEIGHT, /* frame height */ + CONSOLE_BG_COL /* fill color */ ); #else - memsetl (CONSOLE_ROW_LAST, CONSOLE_ROW_SIZE >> 2, CONSOLE_BG_COL); + memsetl(CONSOLE_ROW_LAST, CONSOLE_ROW_SIZE >> 2, CONSOLE_BG_COL); #endif }
-/*****************************************************************************/ - -static void console_back (void) +static void console_back(void) { CURSOR_OFF; console_col--; @@ -661,14 +726,11 @@ static void console_back (void) if (console_row < 0) console_row = 0; } - video_putchar (console_col * VIDEO_FONT_WIDTH, - console_row * VIDEO_FONT_HEIGHT, - ' '); + video_putchar(console_col * VIDEO_FONT_WIDTH, + console_row * VIDEO_FONT_HEIGHT, ' '); }
-/*****************************************************************************/ - -static void console_newline (void) +static void console_newline(void) { /* Check if last character in the line was just drawn. If so, cursor was overwriten and need not to be cleared. Cursor clearing without this @@ -683,33 +745,31 @@ static void console_newline (void) /* Check if we need to scroll the terminal */ if (console_row >= CONSOLE_ROWS) { /* Scroll everything up */ - console_scrollup (); + console_scrollup();
/* Decrement row number */ console_row--; } }
-static void console_cr (void) +static void console_cr(void) { CURSOR_OFF; console_col = 0; }
-/*****************************************************************************/ - -void video_putc (const char c) +void video_putc(const char c) { static int nl = 1;
switch (c) { case 13: /* back to first column */ - console_cr (); + console_cr(); break;
case '\n': /* next line */ if (console_col || (!console_col && nl)) - console_newline (); + console_newline(); nl = 1; break;
@@ -719,52 +779,47 @@ void video_putc (const char c) console_col &= ~0x0007;
if (console_col >= CONSOLE_COLS) - console_newline (); + console_newline(); break;
case 8: /* backspace */ - console_back (); + console_back(); break;
default: /* draw the char */ - video_putchar (console_col * VIDEO_FONT_WIDTH, - console_row * VIDEO_FONT_HEIGHT, - c); + video_putchar(console_col * VIDEO_FONT_WIDTH, + console_row * VIDEO_FONT_HEIGHT, c); console_col++;
/* check for newline */ if (console_col >= CONSOLE_COLS) { - console_newline (); + console_newline(); nl = 0; } } CURSOR_SET; }
- -/*****************************************************************************/ - -void video_puts (const char *s) +void video_puts(const char *s) { - int count = strlen (s); + int count = strlen(s);
while (count--) - video_putc (*s++); + video_putc(*s++); }
-/*****************************************************************************/ - /* * Do not enforce drivers (or board code) to provide empty * video_set_lut() if they do not support 8 bpp format. * Implement weak default function instead. */ -void __video_set_lut (unsigned int index, unsigned char r, - unsigned char g, unsigned char b) +void __video_set_lut(unsigned int index, unsigned char r, + unsigned char g, unsigned char b) { } -void video_set_lut (unsigned int, unsigned char, unsigned char, unsigned char) - __attribute__((weak, alias("__video_set_lut"))); + +void video_set_lut(unsigned int, unsigned char, unsigned char, unsigned char) + __attribute__ ((weak, alias("__video_set_lut")));
#if defined(CONFIG_CMD_BMP) || defined(CONFIG_SPLASH_SCREEN)
@@ -774,17 +829,26 @@ void video_set_lut (unsigned int, unsigned char, unsigned char, unsigned char) }
#define FILL_15BIT_555RGB(r,g,b) { \ - *(unsigned short *)fb = SWAP16((unsigned short)(((r>>3)<<10) | ((g>>3)<<5) | (b>>3))); \ + *(unsigned short *)fb = \ + SWAP16((unsigned short)(((r>>3)<<10) | \ + ((g>>3)<<5) | \ + (b>>3))); \ fb += 2; \ }
#define FILL_16BIT_565RGB(r,g,b) { \ - *(unsigned short *)fb = SWAP16((unsigned short)((((r)>>3)<<11) | (((g)>>2)<<5) | ((b)>>3))); \ + *(unsigned short *)fb = \ + SWAP16((unsigned short)((((r)>>3)<<11)| \ + (((g)>>2)<<5) | \ + ((b)>>3))); \ fb += 2; \ }
#define FILL_32BIT_X888RGB(r,g,b) { \ - *(unsigned long *)fb = SWAP32((unsigned long)(((r<<16) | (g<<8) | b))); \ + *(unsigned long *)fb = \ + SWAP32((unsigned long)(((r<<16) | \ + (g<<8) | \ + b))); \ fb += 4; \ }
@@ -805,13 +869,12 @@ void video_set_lut (unsigned int, unsigned char, unsigned char, unsigned char) #endif
#if defined(VIDEO_FB_16BPP_PIXEL_SWAP) -static void inline fill_555rgb_pswap(uchar *fb, int x, - u8 r, u8 g, u8 b) +static inline void fill_555rgb_pswap(uchar *fb, int x, u8 r, u8 g, u8 b) { - ushort *dst = (ushort *)fb; - ushort color = (ushort)(((r >> 3) << 10) | - ((g >> 3) << 5) | - (b >> 3)); + ushort *dst = (ushort *) fb; + ushort color = (ushort) (((r >> 3) << 10) | + ((g >> 3) << 5) | + (b >> 3)); if (x & 1) *(--dst) = color; else @@ -827,18 +890,18 @@ static void inline fill_555rgb_pswap(uchar *fb, int x, /* Pre-calculated color table entry */ struct palette { union { - unsigned short w; /* word */ - unsigned int dw; /* double word */ - } ce; /* color entry */ + unsigned short w; /* word */ + unsigned int dw; /* double word */ + } ce; /* color entry */ };
/* * Helper to draw encoded/unencoded run. */ -static void draw_bitmap (uchar **fb, uchar *bm, struct palette *p, - int cnt, int enc) +static void draw_bitmap(uchar **fb, uchar *bm, struct palette *p, + int cnt, int enc) { - ulong addr = (ulong)*fb; + ulong addr = (ulong) *fb; int *off; int enc_off = 1; int i; @@ -852,28 +915,28 @@ static void draw_bitmap (uchar **fb, uchar *bm, struct palette *p, switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_INDEX: for (i = 0; i < cnt; i++) - *(unsigned char *)addr++ = bm[*off]; + *(unsigned char *) addr++ = bm[*off]; break; case GDF_15BIT_555RGB: case GDF_16BIT_565RGB: /* differences handled while pre-calculating palette */ for (i = 0; i < cnt; i++) { - *(unsigned short *)addr = p[bm[*off]].ce.w; + *(unsigned short *) addr = p[bm[*off]].ce.w; addr += 2; } break; case GDF_32BIT_X888RGB: for (i = 0; i < cnt; i++) { - *(unsigned long *)addr = p[bm[*off]].ce.dw; + *(unsigned long *) addr = p[bm[*off]].ce.dw; addr += 4; } break; } - *fb = (uchar *)addr; /* return modified address */ + *fb = (uchar *) addr; /* return modified address */ }
-static int display_rle8_bitmap (bmp_image_t *img, int xoff, int yoff, - int width, int height) +static int display_rle8_bitmap(bmp_image_t *img, int xoff, int yoff, + int width, int height) { unsigned char *bm; unsigned char *fbp; @@ -890,17 +953,17 @@ static int display_rle8_bitmap (bmp_image_t *img, int xoff, int yoff, y = __le32_to_cpu(img->header.height) - 1; ncolors = __le32_to_cpu(img->header.colors_used); bpp = VIDEO_PIXEL_SIZE; - fbp = (unsigned char *)((unsigned int)video_fb_address + - (((y + yoff) * VIDEO_COLS) + xoff) * bpp); + fbp = (unsigned char *) ((unsigned int) video_fb_address + + (((y + yoff) * VIDEO_COLS) + xoff) * bpp);
- bm = (uchar *)img + __le32_to_cpu(img->header.data_offset); + bm = (uchar *) img + __le32_to_cpu(img->header.data_offset);
/* pre-calculate and setup palette */ switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_INDEX: for (i = 0; i < ncolors; i++) { cte = img->color_table[i]; - video_set_lut (i, cte.red, cte.green, cte.blue); + video_set_lut(i, cte.red, cte.green, cte.blue); } break; case GDF_15BIT_555RGB: @@ -923,13 +986,14 @@ static int display_rle8_bitmap (bmp_image_t *img, int xoff, int yoff, case GDF_32BIT_X888RGB: for (i = 0; i < ncolors; i++) { cte = img->color_table[i]; - p[i].ce.dw = SWAP32((cte.red << 16) | (cte.green << 8) | + p[i].ce.dw = SWAP32((cte.red << 16) | + (cte.green << 8) | cte.blue); } break; default: printf("RLE Bitmap unsupported in video mode 0x%x\n", - VIDEO_DATA_FORMAT); + VIDEO_DATA_FORMAT); return -1; }
@@ -943,7 +1007,7 @@ static int display_rle8_bitmap (bmp_image_t *img, int xoff, int yoff, x = 0; y--; fbp = (unsigned char *) - ((unsigned int)video_fb_address + + ((unsigned int) video_fb_address + (((y + yoff) * VIDEO_COLS) + xoff) * bpp); continue; @@ -956,7 +1020,7 @@ static int display_rle8_bitmap (bmp_image_t *img, int xoff, int yoff, x += bm[2]; y -= bm[3]; fbp = (unsigned char *) - ((unsigned int)video_fb_address + + ((unsigned int) video_fb_address + (((y + yoff) * VIDEO_COLS) + x + xoff) * bpp); bm += 4; @@ -977,13 +1041,13 @@ static int display_rle8_bitmap (bmp_image_t *img, int xoff, int yoff, } if (x + runlen > width) cnt = width - x; - draw_bitmap (&fbp, bm, p, cnt, 0); + draw_bitmap(&fbp, bm, p, cnt, 0); x += runlen; } next_run: bm += runlen; if (runlen & 1) - bm++; /* 0 padding if length is odd */ + bm++; /* 0 padding if length is odd */ } break; default: @@ -994,7 +1058,7 @@ next_run: if (pixels > limit) goto error;
- if (y < height) { /* only draw into visible area */ + if (y < height) { /* only draw into visible area */ if (x >= width) { x += runlen; bm += 2; @@ -1002,7 +1066,7 @@ next_run: } if (x + runlen > width) cnt = width - x; - draw_bitmap (&fbp, bm, p, cnt, 1); + draw_bitmap(&fbp, bm, p, cnt, 1); x += runlen; } bm += 2; @@ -1019,7 +1083,7 @@ error: /* * Display the BMP file located at address bmp_image. */ -int video_display_bitmap (ulong bmp_image, int x, int y) +int video_display_bitmap(ulong bmp_image, int x, int y) { ushort xcount, ycount; uchar *fb; @@ -1030,12 +1094,13 @@ int video_display_bitmap (ulong bmp_image, int x, int y) unsigned colors; unsigned long compression; bmp_color_table_entry_t cte; + #ifdef CONFIG_VIDEO_BMP_GZIP unsigned char *dst = NULL; ulong len; #endif
- WATCHDOG_RESET (); + WATCHDOG_RESET();
if (!((bmp->header.signature[0] == 'B') && (bmp->header.signature[1] == 'M'))) { @@ -1048,50 +1113,55 @@ int video_display_bitmap (ulong bmp_image, int x, int y) dst = malloc(CONFIG_SYS_VIDEO_LOGO_MAX_SIZE); if (dst == NULL) { printf("Error: malloc in gunzip failed!\n"); - return(1); + return 1; } - if (gunzip(dst, CONFIG_SYS_VIDEO_LOGO_MAX_SIZE, (uchar *)bmp_image, &len) != 0) { - printf ("Error: no valid bmp or bmp.gz image at %lx\n", bmp_image); + if (gunzip(dst, CONFIG_SYS_VIDEO_LOGO_MAX_SIZE, + (uchar *) bmp_image, + &len) != 0) { + printf("Error: no valid bmp or bmp.gz image at %lx\n", + bmp_image); free(dst); return 1; } if (len == CONFIG_SYS_VIDEO_LOGO_MAX_SIZE) { - printf("Image could be truncated (increase CONFIG_SYS_VIDEO_LOGO_MAX_SIZE)!\n"); + printf("Image could be truncated " + "(increase CONFIG_SYS_VIDEO_LOGO_MAX_SIZE)!\n"); }
/* * Set addr to decompressed image */ - bmp = (bmp_image_t *)dst; + bmp = (bmp_image_t *) dst;
if (!((bmp->header.signature[0] == 'B') && (bmp->header.signature[1] == 'M'))) { - printf ("Error: no valid bmp.gz image at %lx\n", bmp_image); + printf("Error: no valid bmp.gz image at %lx\n", + bmp_image); free(dst); return 1; } #else - printf ("Error: no valid bmp image at %lx\n", bmp_image); + printf("Error: no valid bmp image at %lx\n", bmp_image); return 1; #endif /* CONFIG_VIDEO_BMP_GZIP */ }
- width = le32_to_cpu (bmp->header.width); - height = le32_to_cpu (bmp->header.height); - bpp = le16_to_cpu (bmp->header.bit_count); - colors = le32_to_cpu (bmp->header.colors_used); - compression = le32_to_cpu (bmp->header.compression); + width = le32_to_cpu(bmp->header.width); + height = le32_to_cpu(bmp->header.height); + bpp = le16_to_cpu(bmp->header.bit_count); + colors = le32_to_cpu(bmp->header.colors_used); + compression = le32_to_cpu(bmp->header.compression);
- debug ("Display-bmp: %d x %d with %d colors\n", - width, height, colors); + debug("Display-bmp: %d x %d with %d colors\n", + width, height, colors);
if (compression != BMP_BI_RGB #ifdef CONFIG_VIDEO_BMP_RLE8 && compression != BMP_BI_RLE8 #endif - ) { - printf ("Error: compression type %ld not supported\n", - compression); + ) { + printf("Error: compression type %ld not supported\n", + compression); #ifdef CONFIG_VIDEO_BMP_GZIP if (dst) free(dst); @@ -1118,20 +1188,19 @@ int video_display_bitmap (ulong bmp_image, int x, int y) if ((y + height) > VIDEO_VISIBLE_ROWS) height = VIDEO_VISIBLE_ROWS - y;
- bmap = (uchar *) bmp + le32_to_cpu (bmp->header.data_offset); + bmap = (uchar *) bmp + le32_to_cpu(bmp->header.data_offset); fb = (uchar *) (video_fb_address + ((y + height - 1) * VIDEO_COLS * VIDEO_PIXEL_SIZE) + x * VIDEO_PIXEL_SIZE);
#ifdef CONFIG_VIDEO_BMP_RLE8 if (compression == BMP_BI_RLE8) { - return display_rle8_bitmap(bmp, - x, y, width, height); + return display_rle8_bitmap(bmp, x, y, width, height); } #endif
/* We handle only 4, 8, or 24 bpp bitmaps */ - switch (le16_to_cpu (bmp->header.bit_count)) { + switch (le16_to_cpu(bmp->header.bit_count)) { case 4: padded_line -= width / 2; ycount = height; @@ -1139,7 +1208,7 @@ int video_display_bitmap (ulong bmp_image, int x, int y) switch (VIDEO_DATA_FORMAT) { case GDF_32BIT_X888RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); /* * Don't assume that 'width' is an * even number @@ -1158,7 +1227,7 @@ int video_display_bitmap (ulong bmp_image, int x, int y) } bmap += padded_line; fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + VIDEO_PIXEL_SIZE; } break; default: @@ -1174,32 +1243,36 @@ int video_display_bitmap (ulong bmp_image, int x, int y) /* Copy colormap */ for (xcount = 0; xcount < colors; ++xcount) { cte = bmp->color_table[xcount]; - video_set_lut (xcount, cte.red, cte.green, cte.blue); + video_set_lut(xcount, cte.red, cte.green, + cte.blue); } } ycount = height; switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_INDEX: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { *fb++ = *bmap++; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF__8BIT_332RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { cte = bmp->color_table[*bmap++]; - FILL_8BIT_332RGB (cte.red, cte.green, cte.blue); + FILL_8BIT_332RGB(cte.red, cte.green, + cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_15BIT_555RGB: @@ -1207,56 +1280,65 @@ int video_display_bitmap (ulong bmp_image, int x, int y) #if defined(VIDEO_FB_16BPP_PIXEL_SWAP) int xpos = x; #endif - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { cte = bmp->color_table[*bmap++]; #if defined(VIDEO_FB_16BPP_PIXEL_SWAP) - fill_555rgb_pswap (fb, xpos++, cte.red, - cte.green, cte.blue); + fill_555rgb_pswap(fb, xpos++, cte.red, + cte.green, + cte.blue); fb += 2; #else - FILL_15BIT_555RGB (cte.red, cte.green, cte.blue); + FILL_15BIT_555RGB(cte.red, cte.green, + cte.blue); #endif } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_16BIT_565RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { cte = bmp->color_table[*bmap++]; - FILL_16BIT_565RGB (cte.red, cte.green, cte.blue); + FILL_16BIT_565RGB(cte.red, cte.green, + cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_32BIT_X888RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { cte = bmp->color_table[*bmap++]; - FILL_32BIT_X888RGB (cte.red, cte.green, cte.blue); + FILL_32BIT_X888RGB(cte.red, cte.green, + cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_24BIT_888RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { cte = bmp->color_table[*bmap++]; - FILL_24BIT_888RGB (cte.red, cte.green, cte.blue); + FILL_24BIT_888RGB(cte.red, cte.green, + cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; } @@ -1267,14 +1349,16 @@ int video_display_bitmap (ulong bmp_image, int x, int y) switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_332RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { - FILL_8BIT_332RGB (bmap[2], bmap[1], bmap[0]); + FILL_8BIT_332RGB(bmap[2], bmap[1], + bmap[0]); bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_15BIT_555RGB: @@ -1282,66 +1366,75 @@ int video_display_bitmap (ulong bmp_image, int x, int y) #if defined(VIDEO_FB_16BPP_PIXEL_SWAP) int xpos = x; #endif - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { #if defined(VIDEO_FB_16BPP_PIXEL_SWAP) - fill_555rgb_pswap (fb, xpos++, bmap[2], - bmap[1], bmap[0]); + fill_555rgb_pswap(fb, xpos++, bmap[2], + bmap[1], bmap[0]); fb += 2; #else - FILL_15BIT_555RGB (bmap[2], bmap[1], bmap[0]); + FILL_15BIT_555RGB(bmap[2], bmap[1], + bmap[0]); #endif bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_16BIT_565RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { - FILL_16BIT_565RGB (bmap[2], bmap[1], bmap[0]); + FILL_16BIT_565RGB(bmap[2], bmap[1], + bmap[0]); bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_32BIT_X888RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { - FILL_32BIT_X888RGB (bmap[2], bmap[1], bmap[0]); + FILL_32BIT_X888RGB(bmap[2], bmap[1], + bmap[0]); bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; case GDF_24BIT_888RGB: while (ycount--) { - WATCHDOG_RESET (); + WATCHDOG_RESET(); xcount = width; while (xcount--) { - FILL_24BIT_888RGB (bmap[2], bmap[1], bmap[0]); + FILL_24BIT_888RGB(bmap[2], bmap[1], + bmap[0]); bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * VIDEO_PIXEL_SIZE; + fb -= (VIDEO_VISIBLE_COLS + width) * + VIDEO_PIXEL_SIZE; } break; default: - printf ("Error: 24 bits/pixel bitmap incompatible with current video mode\n"); + printf("Error: 24 bits/pixel bitmap incompatible " + "with current video mode\n"); break; } break; default: - printf ("Error: %d bit/pixel bitmaps not supported by U-Boot\n", - le16_to_cpu (bmp->header.bit_count)); + printf("Error: %d bit/pixel bitmaps not supported by U-Boot\n", + le16_to_cpu(bmp->header.bit_count)); break; }
@@ -1355,28 +1448,26 @@ int video_display_bitmap (ulong bmp_image, int x, int y) } #endif
#ifdef CONFIG_VIDEO_LOGO -void logo_plot (void *screen, int width, int x, int y) +void logo_plot(void *screen, int width, int x, int y) {
int xcount, i; - int skip = (width - VIDEO_LOGO_WIDTH) * VIDEO_PIXEL_SIZE; + int skip = (width - VIDEO_LOGO_WIDTH) * VIDEO_PIXEL_SIZE; int ycount = video_logo_height; unsigned char r, g, b, *logo_red, *logo_blue, *logo_green; unsigned char *source; - unsigned char *dest = (unsigned char *)screen + - ((y * width * VIDEO_PIXEL_SIZE) + - x * VIDEO_PIXEL_SIZE); + unsigned char *dest = (unsigned char *) screen + + ((y * width * VIDEO_PIXEL_SIZE) + x * VIDEO_PIXEL_SIZE);
#ifdef CONFIG_VIDEO_BMP_LOGO source = bmp_logo_bitmap;
/* Allocate temporary space for computing colormap */ - logo_red = malloc (BMP_LOGO_COLORS); - logo_green = malloc (BMP_LOGO_COLORS); - logo_blue = malloc (BMP_LOGO_COLORS); + logo_red = malloc(BMP_LOGO_COLORS); + logo_green = malloc(BMP_LOGO_COLORS); + logo_blue = malloc(BMP_LOGO_COLORS); /* Compute color map */ for (i = 0; i < VIDEO_LOGO_COLORS; i++) { logo_red[i] = (bmp_logo_palette[i] & 0x0f00) >> 4; @@ -1392,8 +1483,9 @@ void logo_plot (void *screen, int width, int x, int y)
if (VIDEO_DATA_FORMAT == GDF__8BIT_INDEX) { for (i = 0; i < VIDEO_LOGO_COLORS; i++) { - video_set_lut (i + VIDEO_LOGO_LUT_OFFSET, - logo_red[i], logo_green[i], logo_blue[i]); + video_set_lut(i + VIDEO_LOGO_LUT_OFFSET, + logo_red[i], logo_green[i], + logo_blue[i]); } }
@@ -1412,23 +1504,34 @@ void logo_plot (void *screen, int width, int x, int y) *dest = *source; break; case GDF__8BIT_332RGB: - *dest = ((r >> 5) << 5) | ((g >> 5) << 2) | (b >> 6); + *dest = ((r >> 5) << 5) | + ((g >> 5) << 2) | + (b >> 6); break; case GDF_15BIT_555RGB: #if defined(VIDEO_FB_16BPP_PIXEL_SWAP) - fill_555rgb_pswap (dest, xpos++, r, g, b); + fill_555rgb_pswap(dest, xpos++, r, g, b); #else *(unsigned short *) dest = - SWAP16 ((unsigned short) (((r >> 3) << 10) | ((g >> 3) << 5) | (b >> 3))); + SWAP16((unsigned short) ( + ((r >> 3) << 10) | + ((g >> 3) << 5) | + (b >> 3))); #endif break; case GDF_16BIT_565RGB: *(unsigned short *) dest = - SWAP16 ((unsigned short) (((r >> 3) << 11) | ((g >> 2) << 5) | (b >> 3))); + SWAP16((unsigned short) ( + ((r >> 3) << 11) | + ((g >> 2) << 5) | + (b >> 3))); break; case GDF_32BIT_X888RGB: *(unsigned long *) dest = - SWAP32 ((unsigned long) ((r << 16) | (g << 8) | b)); + SWAP32((unsigned long) ( + (r << 16) | + (g << 8) | + b)); break; case GDF_24BIT_888RGB: #ifdef VIDEO_FB_LITTLE_ENDIAN @@ -1448,15 +1551,13 @@ void logo_plot (void *screen, int width, int x, int y) dest += skip; } #ifdef CONFIG_VIDEO_BMP_LOGO - free (logo_red); - free (logo_green); - free (logo_blue); + free(logo_red); + free(logo_green); + free(logo_blue); #endif }
-/*****************************************************************************/ - -static void *video_logo (void) +static void *video_logo(void) { char info[128]; int space, len, y_off = 0; @@ -1465,76 +1566,82 @@ static void *video_logo (void) char *s; ulong addr;
- if ((s = getenv ("splashimage")) != NULL) { + if ((s = getenv("splashimage")) != NULL) { int x = 0, y = 0;
- addr = simple_strtoul (s, NULL, 16); + addr = simple_strtoul(s, NULL, 16); #ifdef CONFIG_SPLASH_SCREEN_ALIGN - if ((s = getenv ("splashpos")) != NULL) { + if ((s = getenv("splashpos")) != NULL) { if (s[0] == 'm') x = BMP_ALIGN_CENTER; else - x = simple_strtol (s, NULL, 0); + x = simple_strtol(s, NULL, 0);
- if ((s = strchr (s + 1, ',')) != NULL) { + if ((s = strchr(s + 1, ',')) != NULL) { if (s[1] == 'm') y = BMP_ALIGN_CENTER; else - y = simple_strtol (s + 1, NULL, 0); + y = simple_strtol(s + 1, NULL, 0); } } #endif /* CONFIG_SPLASH_SCREEN_ALIGN */
- if (video_display_bitmap (addr, x, y) == 0) { + if (video_display_bitmap(addr, x, y) == 0) { video_logo_height = 0; return ((void *) (video_fb_address)); } } #endif /* CONFIG_SPLASH_SCREEN */
- logo_plot (video_fb_address, VIDEO_COLS, 0, 0); + logo_plot(video_fb_address, VIDEO_COLS, 0, 0);
- sprintf (info, " %s", version_string); + sprintf(info, " %s", version_string);
if (len > space) { - video_drawchars (VIDEO_INFO_X, VIDEO_INFO_Y, - (uchar *)info, space); - video_drawchars (VIDEO_INFO_X + VIDEO_FONT_WIDTH, - VIDEO_INFO_Y + VIDEO_FONT_HEIGHT, - (uchar *)info + space, len - space); + video_drawchars(VIDEO_INFO_X, VIDEO_INFO_Y, + (uchar *) info, space); + video_drawchars(VIDEO_INFO_X + VIDEO_FONT_WIDTH, + VIDEO_INFO_Y + VIDEO_FONT_HEIGHT, + (uchar *) info + space, len - space); y_off = 1; } else - video_drawstring (VIDEO_INFO_X, VIDEO_INFO_Y, (uchar *)info); + video_drawstring(VIDEO_INFO_X, VIDEO_INFO_Y, (uchar *) info);
#ifdef CONFIG_CONSOLE_EXTRA_INFO { - int i, n = ((video_logo_height - VIDEO_FONT_HEIGHT) / VIDEO_FONT_HEIGHT); + int i, n = + ((video_logo_height - + VIDEO_FONT_HEIGHT) / VIDEO_FONT_HEIGHT);
for (i = 1; i < n; i++) { - video_get_info_str (i, info); + video_get_info_str(i, info); if (!*info) continue;
len = strlen(info); if (len > space) { - video_drawchars (VIDEO_INFO_X, - VIDEO_INFO_Y + - (i + y_off) * VIDEO_FONT_HEIGHT, - (uchar *)info, space); + video_drawchars(VIDEO_INFO_X, + VIDEO_INFO_Y + + (i + y_off) * + VIDEO_FONT_HEIGHT, + (uchar *) info, space); y_off++; - video_drawchars (VIDEO_INFO_X + VIDEO_FONT_WIDTH, - VIDEO_INFO_Y + - (i + y_off) * VIDEO_FONT_HEIGHT, - (uchar *)info + space, - len - space); + video_drawchars(VIDEO_INFO_X + + VIDEO_FONT_WIDTH, + VIDEO_INFO_Y + + (i + y_off) * + VIDEO_FONT_HEIGHT, + (uchar *) info + space, + len - space); } else { - video_drawstring (VIDEO_INFO_X, - VIDEO_INFO_Y + - (i + y_off) * VIDEO_FONT_HEIGHT, - (uchar *)info); + video_drawstring(VIDEO_INFO_X, + VIDEO_INFO_Y + + (i + y_off) * + VIDEO_FONT_HEIGHT, + (uchar *) info); } } } @@ -1544,74 +1651,93 @@ static void *video_logo (void) } #endif
- -/*****************************************************************************/ - -static int video_init (void) +static int video_init(void) { unsigned char color8;
- if ((pGD = video_hw_init ()) == NULL) + if ((pGD = video_hw_init()) == NULL) return -1;
video_fb_address = (void *) VIDEO_FB_ADRS; #ifdef CONFIG_VIDEO_HW_CURSOR - video_init_hw_cursor (VIDEO_FONT_WIDTH, VIDEO_FONT_HEIGHT); + video_init_hw_cursor(VIDEO_FONT_WIDTH, VIDEO_FONT_HEIGHT); #endif
/* Init drawing pats */ switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_INDEX: - video_set_lut (0x01, CONSOLE_FG_COL, CONSOLE_FG_COL, CONSOLE_FG_COL); - video_set_lut (0x00, CONSOLE_BG_COL, CONSOLE_BG_COL, CONSOLE_BG_COL); + video_set_lut(0x01, CONSOLE_FG_COL, CONSOLE_FG_COL, + CONSOLE_FG_COL); + video_set_lut(0x00, CONSOLE_BG_COL, CONSOLE_BG_COL, + CONSOLE_BG_COL); fgx = 0x01010101; bgx = 0x00000000; break; case GDF__8BIT_332RGB: color8 = ((CONSOLE_FG_COL & 0xe0) | - ((CONSOLE_FG_COL >> 3) & 0x1c) | CONSOLE_FG_COL >> 6); - fgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | color8; + ((CONSOLE_FG_COL >> 3) & 0x1c) | + CONSOLE_FG_COL >> 6); + fgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | + color8; color8 = ((CONSOLE_BG_COL & 0xe0) | - ((CONSOLE_BG_COL >> 3) & 0x1c) | CONSOLE_BG_COL >> 6); - bgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | color8; + ((CONSOLE_BG_COL >> 3) & 0x1c) | + CONSOLE_BG_COL >> 6); + bgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | + color8; break; case GDF_15BIT_555RGB: fgx = (((CONSOLE_FG_COL >> 3) << 26) | - ((CONSOLE_FG_COL >> 3) << 21) | ((CONSOLE_FG_COL >> 3) << 16) | - ((CONSOLE_FG_COL >> 3) << 10) | ((CONSOLE_FG_COL >> 3) << 5) | - (CONSOLE_FG_COL >> 3)); + ((CONSOLE_FG_COL >> 3) << 21) | + ((CONSOLE_FG_COL >> 3) << 16) | + ((CONSOLE_FG_COL >> 3) << 10) | + ((CONSOLE_FG_COL >> 3) << 5) | + (CONSOLE_FG_COL >> 3)); bgx = (((CONSOLE_BG_COL >> 3) << 26) | - ((CONSOLE_BG_COL >> 3) << 21) | ((CONSOLE_BG_COL >> 3) << 16) | - ((CONSOLE_BG_COL >> 3) << 10) | ((CONSOLE_BG_COL >> 3) << 5) | - (CONSOLE_BG_COL >> 3)); + ((CONSOLE_BG_COL >> 3) << 21) | + ((CONSOLE_BG_COL >> 3) << 16) | + ((CONSOLE_BG_COL >> 3) << 10) | + ((CONSOLE_BG_COL >> 3) << 5) | + (CONSOLE_BG_COL >> 3)); break; case GDF_16BIT_565RGB: fgx = (((CONSOLE_FG_COL >> 3) << 27) | - ((CONSOLE_FG_COL >> 2) << 21) | ((CONSOLE_FG_COL >> 3) << 16) | - ((CONSOLE_FG_COL >> 3) << 11) | ((CONSOLE_FG_COL >> 2) << 5) | - (CONSOLE_FG_COL >> 3)); + ((CONSOLE_FG_COL >> 2) << 21) | + ((CONSOLE_FG_COL >> 3) << 16) | + ((CONSOLE_FG_COL >> 3) << 11) | + ((CONSOLE_FG_COL >> 2) << 5) | + (CONSOLE_FG_COL >> 3)); bgx = (((CONSOLE_BG_COL >> 3) << 27) | - ((CONSOLE_BG_COL >> 2) << 21) | ((CONSOLE_BG_COL >> 3) << 16) | - ((CONSOLE_BG_COL >> 3) << 11) | ((CONSOLE_BG_COL >> 2) << 5) | - (CONSOLE_BG_COL >> 3)); + ((CONSOLE_BG_COL >> 2) << 21) | + ((CONSOLE_BG_COL >> 3) << 16) | + ((CONSOLE_BG_COL >> 3) << 11) | + ((CONSOLE_BG_COL >> 2) << 5) | + (CONSOLE_BG_COL >> 3)); break; case GDF_32BIT_X888RGB: - fgx = (CONSOLE_FG_COL << 16) | (CONSOLE_FG_COL << 8) | CONSOLE_FG_COL; - bgx = (CONSOLE_BG_COL << 16) | (CONSOLE_BG_COL << 8) | CONSOLE_BG_COL; + fgx = (CONSOLE_FG_COL << 16) | + (CONSOLE_FG_COL << 8) | + CONSOLE_FG_COL; + bgx = (CONSOLE_BG_COL << 16) | + (CONSOLE_BG_COL << 8) | + CONSOLE_BG_COL; break; case GDF_24BIT_888RGB: - fgx = (CONSOLE_FG_COL << 24) | (CONSOLE_FG_COL << 16) | - (CONSOLE_FG_COL << 8) | CONSOLE_FG_COL; - bgx = (CONSOLE_BG_COL << 24) | (CONSOLE_BG_COL << 16) | - (CONSOLE_BG_COL << 8) | CONSOLE_BG_COL; + fgx = (CONSOLE_FG_COL << 24) | + (CONSOLE_FG_COL << 16) | + (CONSOLE_FG_COL << 8) | + CONSOLE_FG_COL; + bgx = (CONSOLE_BG_COL << 24) | + (CONSOLE_BG_COL << 16) | + (CONSOLE_BG_COL << 8) | + CONSOLE_BG_COL; break; } eorx = fgx ^ bgx;
#ifdef CONFIG_VIDEO_LOGO /* Plot the logo and get start point of console */ - PRINTD ("Video: Drawing the logo ...\n"); - video_console_address = video_logo (); + PRINTD("Video: Drawing the logo ...\n"); + video_console_address = video_logo(); #else video_console_address = video_fb_address; #endif @@ -1623,9 +1749,6 @@ static int video_init (void) return 0; }
- -/*****************************************************************************/ - /* * Implement a weak default function for boards that optionally * need to skip the video initialization. @@ -1635,9 +1758,11 @@ int __board_video_skip(void) /* As default, don't skip test */ return 0; } -int board_video_skip(void) __attribute__((weak, alias("__board_video_skip")));
-int drv_video_init (void) +int board_video_skip(void) + __attribute__ ((weak, alias("__board_video_skip"))); + +int drv_video_init(void) { int skip_dev_init; struct stdio_dev console_dev; @@ -1647,10 +1772,10 @@ int drv_video_init (void) return 0;
/* Init video chip - returns with framebuffer cleared */ - skip_dev_init = (video_init () == -1); + skip_dev_init = (video_init() == -1);
#if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) - PRINTD ("KBD: Keyboard init ...\n"); + PRINTD("KBD: Keyboard init ...\n"); skip_dev_init |= (VIDEO_KBD_INIT_FCT == -1); #endif
@@ -1658,8 +1783,8 @@ int drv_video_init (void) return 0;
/* Init vga device */ - memset (&console_dev, 0, sizeof (console_dev)); - strcpy (console_dev.name, "vga"); + memset(&console_dev, 0, sizeof(console_dev)); + strcpy(console_dev.name, "vga"); console_dev.ext = DEV_EXT_VIDEO; /* Video extensions */ console_dev.flags = DEV_FLAGS_OUTPUT | DEV_FLAGS_SYSTEM; console_dev.putc = video_putc; /* 'putc' function */ @@ -1674,7 +1799,7 @@ int drv_video_init (void) console_dev.getc = VIDEO_GETC_FCT; /* 'getc' function */ #endif /* CONFIG_VGA_AS_SINGLE_DEVICE */
- if (stdio_register (&console_dev) != 0) + if (stdio_register(&console_dev) != 0) return 0;
/* Return success */
Dear Wolfgang Denk,
In message 1311969329-1109-2-git-send-email-wd@denx.de you wrote:
Run cfb_console.c through indent and manually fix some of he deficiencies of the automatic line breaking.
Fix multiline comments, excessive line spacing and such.
No changes to code done.
Signed-off-by: Wolfgang Denk wd@denx.de
drivers/video/cfb_console.c | 1093 ++++++++++++++++++++++++------------------- 1 files changed, 609 insertions(+), 484 deletions(-)
Applied, thanks.
Signed-off-by: Wolfgang Denk wd@denx.de --- drivers/video/cfb_console.c | 11 ++--------- 1 files changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 917bba6..d2dd421 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -348,13 +348,6 @@ void console_cursor(int state); #endif #endif
-#if defined(DEBUG) || defined(DEBUG_CFB_CONSOLE) -#define PRINTD(x) printf(x) -#else -#define PRINTD(x) -#endif - - #ifdef CONFIG_CONSOLE_EXTRA_INFO /* * setup a board string: type, speed, etc. @@ -1736,7 +1729,7 @@ static int video_init(void)
#ifdef CONFIG_VIDEO_LOGO /* Plot the logo and get start point of console */ - PRINTD("Video: Drawing the logo ...\n"); + debug("Video: Drawing the logo ...\n"); video_console_address = video_logo(); #else video_console_address = video_fb_address; @@ -1775,7 +1768,7 @@ int drv_video_init(void) skip_dev_init = (video_init() == -1);
#if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) - PRINTD("KBD: Keyboard init ...\n"); + debug("KBD: Keyboard init ...\n"); skip_dev_init |= (VIDEO_KBD_INIT_FCT == -1); #endif
Dear Wolfgang Denk,
Applied, thanks.
Fix the following:
ERROR: do not initialise statics to 0 or NULL ERROR: do not use assignment in if condition
Signed-off-by: Wolfgang Denk wd@denx.de --- drivers/video/cfb_console.c | 16 ++++++++++------ 1 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index d2dd421..6e9143e 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -366,8 +366,8 @@ static void *video_console_address; /* console buffer start address */
-static int console_col = 0; /* cursor col */ -static int console_row = 0; /* cursor row */ +static int console_col; /* cursor col */ +static int console_row; /* cursor row */
@@ -1559,18 +1559,21 @@ static void *video_logo(void) char *s; ulong addr;
- if ((s = getenv("splashimage")) != NULL) { + s = getenv("splashimage"); + if (s != NULL) { int x = 0, y = 0;
addr = simple_strtoul(s, NULL, 16); #ifdef CONFIG_SPLASH_SCREEN_ALIGN - if ((s = getenv("splashpos")) != NULL) { + s = getenv("splashpos"); + if ((s != NULL) { if (s[0] == 'm') x = BMP_ALIGN_CENTER; else x = simple_strtol(s, NULL, 0);
- if ((s = strchr(s + 1, ',')) != NULL) { + s = strchr(s + 1, ','); + if (s != NULL) { if (s[1] == 'm') y = BMP_ALIGN_CENTER; else @@ -1648,7 +1651,8 @@ static int video_init(void) { unsigned char color8;
- if ((pGD = video_hw_init()) == NULL) + pGD = video_hw_init()) == ; + if (pGD == NULL) return -1;
Hello.
On 29-07-2011 23:55, Wolfgang Denk wrote:
Fix the following:
Signed-off-by: Wolfgang Denkwd@denx.de
- pGD = video_hw_init()) == ;
Did you try to compile this? :-)
WBR, Sergei
Dear Sergei,
Heh. What's your guess?
Sorry, will send update.
Sergei, for quite some time you have been performing continuous and thorough error checking on a large number of patches. I know this is an ungrateful job - but an important one. I would like to say that I appreciate the work you are doing, and: thanks!
Fix the following:
Signed-off-by: Wolfgang Denk wd@denx.de --- Changes:
v2: Fix compile error / incomplete edit
- if ((pGD = video_hw_init()) == NULL) + pGD = video_hw_init(); + if (pGD == NULL) return -1;
Dear Wolfgang Denk,
In message 1312066089-16812-1-git-send-email-wd@denx.de you wrote:
Fix the following:
if ((s != NULL) {
-------------------^^ Grrrgh...
Applied after fixing this bug.
Best regards, Viele Grüße, Wolfgang Denk
Andreas Bießmann
Sergei Shtylyov
