Re: [U-Boot-Users] Booting ELDK 4.0 kernel on MPC8548CDS
Kumar,
-----Original Message----- From: Kumar Gala [mailto:galak@kernel.crashing.org] Sent: Thursday, November 23, 2006 3:52 PM To: Demke Torsten-atd012 Cc: Thomas Schäfer; u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] Booting ELDK 4.0 kernel on MPC8548CDS
If you are using CONFIG_OF_FLAT_TREE _and_ "disable_of" ist likely that you see the same behaviour, because in that case the
"bootm" code
still uses the of-tree address (char *of_flat_tree), after
copying the
standard bd_info data to that address. You could check the pointer that is given to the kernel for
the board
info data (line 967, parameter 1 of (*kernel) (...)) (or change (*kernel) ((bd_t *)of_flat_tree,... to (*kernel) (kbd,...)
Regards, Torsten
This seems like a bug.
Looking at the code I'm confused how this works at all. I dont see of_flat_tree getting setting to anything at all.
Can you guys try out Grant's patch "[PATCH] Allow CONFIG_OF_FLAT_TREE to boot a non-arch/powerpc kernel" and see if that fixes the issue when building w/CONFIG_OF_FLAT_TREE enabled. His patch should make it so that a bootm w/1 or 2 args that aren't a multiimage should boot arch/ppc style.
I applied Grant's patch, I can now boot arch/ppc style (with kernel and ramdisk image) both with CONFIG_OF_FLAT_TREE defined and not defined in my board config.
Thomas
Thomas Schäfer
