[U-Boot] [PATCH v4 0/4] add support for new arch stv0991
This patchset add support for new arch stv0991.
Changes in v4: - rebased to current master - added maintainers info
Changes in v3: - removed period from commit messages
Changes in v2: - corrected files license to GPL-2.0+ - replaced printf() usage with puts() for string print - sorted sourcing of board Kconfig
Vikas Manocha (4): stv0991: Add basic stv0991 architecture support stv0991: enable ethernet support stv0991: default + misc command configs enabled stv0991: add maintainer information
MAINTAINERS | 6 + arch/arm/Kconfig | 5 + arch/arm/cpu/armv7/stv0991/Makefile | 9 ++ arch/arm/cpu/armv7/stv0991/clock.c | 41 +++++++ arch/arm/cpu/armv7/stv0991/lowlevel.S | 12 ++ arch/arm/cpu/armv7/stv0991/pinmux.c | 62 +++++++++++ arch/arm/cpu/armv7/stv0991/reset.c | 26 +++++ arch/arm/cpu/armv7/stv0991/timer.c | 114 +++++++++++++++++++ arch/arm/include/asm/arch-stv0991/gpio.h | 22 ++++ arch/arm/include/asm/arch-stv0991/hardware.h | 73 ++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_cgu.h | 116 ++++++++++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_creg.h | 95 ++++++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_defs.h | 16 +++ arch/arm/include/asm/arch-stv0991/stv0991_gpt.h | 43 ++++++++ arch/arm/include/asm/arch-stv0991/stv0991_periph.h | 44 ++++++++ arch/arm/include/asm/arch-stv0991/stv0991_wdru.h | 28 +++++ board/st/stv0991/Kconfig | 23 ++++ board/st/stv0991/MAINTAINERS | 5 + board/st/stv0991/Makefile | 8 ++ board/st/stv0991/stv0991.c | 91 +++++++++++++++ configs/stv0991_defconfig | 3 + include/configs/stv0991.h | 88 +++++++++++++++ 22 files changed, 930 insertions(+) create mode 100644 arch/arm/cpu/armv7/stv0991/Makefile create mode 100644 arch/arm/cpu/armv7/stv0991/clock.c create mode 100644 arch/arm/cpu/armv7/stv0991/lowlevel.S create mode 100644 arch/arm/cpu/armv7/stv0991/pinmux.c create mode 100644 arch/arm/cpu/armv7/stv0991/reset.c create mode 100644 arch/arm/cpu/armv7/stv0991/timer.c create mode 100644 arch/arm/include/asm/arch-stv0991/gpio.h create mode 100644 arch/arm/include/asm/arch-stv0991/hardware.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_cgu.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_creg.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_defs.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_gpt.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_periph.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_wdru.h create mode 100644 board/st/stv0991/Kconfig create mode 100644 board/st/stv0991/MAINTAINERS create mode 100644 board/st/stv0991/Makefile create mode 100644 board/st/stv0991/stv0991.c create mode 100644 configs/stv0991_defconfig create mode 100644 include/configs/stv0991.h
stv0991 architecture support added. It contains the support for following blocks - Timer - uart
Signed-off-by: Vikas Manocha vikas.manocha@st.com ---
Changes in v4: - added maintainers info - rebased to current master
arch/arm/Kconfig | 5 + arch/arm/cpu/armv7/stv0991/Makefile | 9 ++ arch/arm/cpu/armv7/stv0991/clock.c | 27 +++++ arch/arm/cpu/armv7/stv0991/lowlevel.S | 12 +++ arch/arm/cpu/armv7/stv0991/pinmux.c | 48 +++++++++ arch/arm/cpu/armv7/stv0991/reset.c | 26 +++++ arch/arm/cpu/armv7/stv0991/timer.c | 114 ++++++++++++++++++++ arch/arm/include/asm/arch-stv0991/hardware.h | 73 +++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_cgu.h | 80 ++++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_creg.h | 82 ++++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_defs.h | 16 +++ arch/arm/include/asm/arch-stv0991/stv0991_gpt.h | 43 ++++++++ arch/arm/include/asm/arch-stv0991/stv0991_periph.h | 43 ++++++++ arch/arm/include/asm/arch-stv0991/stv0991_wdru.h | 28 +++++ board/st/stv0991/Kconfig | 23 ++++ board/st/stv0991/Makefile | 8 ++ board/st/stv0991/stv0991.c | 54 ++++++++++ configs/stv0991_defconfig | 3 + include/configs/stv0991.h | 58 ++++++++++ 19 files changed, 752 insertions(+) create mode 100644 arch/arm/cpu/armv7/stv0991/Makefile create mode 100644 arch/arm/cpu/armv7/stv0991/clock.c create mode 100644 arch/arm/cpu/armv7/stv0991/lowlevel.S create mode 100644 arch/arm/cpu/armv7/stv0991/pinmux.c create mode 100644 arch/arm/cpu/armv7/stv0991/reset.c create mode 100644 arch/arm/cpu/armv7/stv0991/timer.c create mode 100644 arch/arm/include/asm/arch-stv0991/hardware.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_cgu.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_creg.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_defs.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_gpt.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_periph.h create mode 100644 arch/arm/include/asm/arch-stv0991/stv0991_wdru.h create mode 100644 board/st/stv0991/Kconfig create mode 100644 board/st/stv0991/Makefile create mode 100644 board/st/stv0991/stv0991.c create mode 100644 configs/stv0991_defconfig create mode 100644 include/configs/stv0991.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3955978..71faf5e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -339,6 +339,10 @@ config TARGET_SPEAR600 bool "Support spear600" select CPU_ARM926EJS
+config TARGET_STV0991 + bool "Support stv0991" + select CPU_V7 + config TARGET_X600 bool "Support x600" select CPU_ARM926EJS @@ -932,6 +936,7 @@ source "board/spear/spear600/Kconfig" source "board/spear/x600/Kconfig" source "board/st-ericsson/snowball/Kconfig" source "board/st-ericsson/u8500/Kconfig" +source "board/st/stv0991/Kconfig" source "board/sunxi/Kconfig" source "board/syteco/jadecpu/Kconfig" source "board/syteco/zmx25/Kconfig" diff --git a/arch/arm/cpu/armv7/stv0991/Makefile b/arch/arm/cpu/armv7/stv0991/Makefile new file mode 100644 index 0000000..95641d3 --- /dev/null +++ b/arch/arm/cpu/armv7/stv0991/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2014 +# Vikas Manocha, ST Microelectronics, vikas.manocha@stcom +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := timer.o clock.o pinmux.o reset.o +obj-y += lowlevel.o diff --git a/arch/arm/cpu/armv7/stv0991/clock.c b/arch/arm/cpu/armv7/stv0991/clock.c new file mode 100644 index 0000000..aca6aba --- /dev/null +++ b/arch/arm/cpu/armv7/stv0991/clock.c @@ -0,0 +1,27 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/stv0991_cgu.h> +#include<asm/arch/stv0991_periph.h> + +static struct stv0991_cgu_regs *const stv0991_cgu_regs = \ + (struct stv0991_cgu_regs *) (CGU_BASE_ADDR); + +void clock_setup(int peripheral) +{ + switch (peripheral) { + case UART_CLOCK_CFG: + writel(UART_CLK_CFG, &stv0991_cgu_regs->uart_freq); + break; + case ETH_CLOCK_CFG: + break; + default: + break; + } +} diff --git a/arch/arm/cpu/armv7/stv0991/lowlevel.S b/arch/arm/cpu/armv7/stv0991/lowlevel.S new file mode 100644 index 0000000..6dafba3 --- /dev/null +++ b/arch/arm/cpu/armv7/stv0991/lowlevel.S @@ -0,0 +1,12 @@ +/* + * (C) Copyright 2014 stmicroelectronics + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <linux/linkage.h> + +ENTRY(lowlevel_init) + mov pc, lr +ENDPROC(lowlevel_init) diff --git a/arch/arm/cpu/armv7/stv0991/pinmux.c b/arch/arm/cpu/armv7/stv0991/pinmux.c new file mode 100644 index 0000000..6d4414a --- /dev/null +++ b/arch/arm/cpu/armv7/stv0991/pinmux.c @@ -0,0 +1,48 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/io.h> +#include <asm/arch/stv0991_creg.h> +#include <asm/arch/stv0991_periph.h> +#include <asm/arch/hardware.h> + +static struct stv0991_creg *const stv0991_creg = \ + (struct stv0991_creg *)CREG_BASE_ADDR; + +int stv0991_pinmux_config(int peripheral) +{ + switch (peripheral) { + case UART_GPIOC_30_31: + /* SSDA/SSCL pad muxing to UART Rx/Dx */ + writel((readl(&stv0991_creg->mux12) & GPIOC_31_MUX_MASK) | + CFG_GPIOC_31_UART_RX, + &stv0991_creg->mux12); + writel((readl(&stv0991_creg->mux12) & GPIOC_30_MUX_MASK) | + CFG_GPIOC_30_UART_TX, + &stv0991_creg->mux12); + /* SSDA/SSCL pad config to push pull*/ + writel((readl(&stv0991_creg->cfg_pad6) & GPIOC_31_MODE_MASK) | + CFG_GPIOC_31_MODE_PP, + &stv0991_creg->cfg_pad6); + writel((readl(&stv0991_creg->cfg_pad6) & GPIOC_30_MODE_MASK) | + CFG_GPIOC_30_MODE_HIGH, + &stv0991_creg->cfg_pad6); + break; + case UART_GPIOB_16_17: + /* ethernet rx_6/7 to UART Rx/Dx */ + writel((readl(&stv0991_creg->mux7) & GPIOB_17_MUX_MASK) | + CFG_GPIOB_17_UART_RX, + &stv0991_creg->mux7); + writel((readl(&stv0991_creg->mux7) & GPIOB_16_MUX_MASK) | + CFG_GPIOB_16_UART_TX, + &stv0991_creg->mux7); + break; + default: + break; + } + return 0; +} diff --git a/arch/arm/cpu/armv7/stv0991/reset.c b/arch/arm/cpu/armv7/stv0991/reset.c new file mode 100644 index 0000000..3384b32 --- /dev/null +++ b/arch/arm/cpu/armv7/stv0991/reset.c @@ -0,0 +1,26 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/stv0991_wdru.h> +void reset_cpu(ulong ignored) +{ + puts("System is going to reboot ...\n"); + /* + * This 1 second delay will allow the above message + * to be printed before reset + */ + udelay((1000 * 1000)); + + /* Setting bit 1 of the WDRU unit will reset the SoC */ + writel(WDRU_RST_SYS, &stv0991_wd_ru_ptr->wdru_ctrl1); + + /* system will restart */ + while (1) + ; +} diff --git a/arch/arm/cpu/armv7/stv0991/timer.c b/arch/arm/cpu/armv7/stv0991/timer.c new file mode 100644 index 0000000..8654b8b --- /dev/null +++ b/arch/arm/cpu/armv7/stv0991/timer.c @@ -0,0 +1,114 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch-stv0991/hardware.h> +#include <asm/arch-stv0991/stv0991_cgu.h> +#include <asm/arch-stv0991/stv0991_gpt.h> + +static struct stv0991_cgu_regs *const stv0991_cgu_regs = \ + (struct stv0991_cgu_regs *) (CGU_BASE_ADDR); + +#define READ_TIMER() (readl(&gpt1_regs_ptr->cnt) & GPT_FREE_RUNNING) +#define GPT_RESOLUTION (CONFIG_STV0991_HZ_CLOCK / CONFIG_STV0991_HZ) + +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->arch.tbl +#define lastdec gd->arch.lastinc + +int timer_init(void) +{ + /* Timer1 clock configuration */ + writel(TIMER1_CLK_CFG, &stv0991_cgu_regs->tim_freq); + writel(readl(&stv0991_cgu_regs->cgu_enable_2) | + TIMER1_CLK_EN, &stv0991_cgu_regs->cgu_enable_2); + + /* Stop the timer */ + writel(readl(&gpt1_regs_ptr->cr1) & ~GPT_CR1_CEN, &gpt1_regs_ptr->cr1); + writel(GPT_PRESCALER_128, &gpt1_regs_ptr->psc); + /* Configure timer for auto-reload */ + writel(readl(&gpt1_regs_ptr->cr1) | GPT_MODE_AUTO_RELOAD, + &gpt1_regs_ptr->cr1); + + /* load value for free running */ + writel(GPT_FREE_RUNNING, &gpt1_regs_ptr->arr); + + /* start timer */ + writel(readl(&gpt1_regs_ptr->cr1) | GPT_CR1_CEN, + &gpt1_regs_ptr->cr1); + + /* Reset the timer */ + lastdec = READ_TIMER(); + timestamp = 0; + + return 0; +} + +/* + * timer without interrupts + */ +ulong get_timer(ulong base) +{ + return (get_timer_masked() / GPT_RESOLUTION) - base; +} + +void __udelay(unsigned long usec) +{ + ulong tmo; + ulong start = get_timer_masked(); + ulong tenudelcnt = CONFIG_STV0991_HZ_CLOCK / (1000 * 100); + ulong rndoff; + + rndoff = (usec % 10) ? 1 : 0; + + /* tenudelcnt timer tick gives 10 microsecconds delay */ + tmo = ((usec / 10) + rndoff) * tenudelcnt; + + while ((ulong) (get_timer_masked() - start) < tmo) + ; +} + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER(); + + if (now >= lastdec) { + /* normal mode */ + timestamp += now - lastdec; + } else { + /* we have an overflow ... */ + timestamp += now + GPT_FREE_RUNNING - lastdec; + } + lastdec = now; + + return timestamp; +} + +void udelay_masked(unsigned long usec) +{ + return udelay(usec); +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return CONFIG_STV0991_HZ; +} diff --git a/arch/arm/include/asm/arch-stv0991/hardware.h b/arch/arm/include/asm/arch-stv0991/hardware.h new file mode 100644 index 0000000..3f6bcaf --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/hardware.h @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, STMicroelectronics, vikas.manocha@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_HARDWARE_H +#define _ASM_ARCH_HARDWARE_H + +/* STV0991 */ +#define SRAM0_BASE_ADDR 0x00000000UL +#define SRAM1_BASE_ADDR 0x00068000UL +#define SRAM2_BASE_ADDR 0x000D0000UL +#define SRAM3_BASE_ADDR 0x00138000UL +#define CFS_SRAM0_BASE_ADDR 0x00198000UL +#define CFS_SRAM1_BASE_ADDR 0x001B8000UL +#define FAST_SRAM_BASE_ADDR 0x001D8000UL +#define FLASH_BASE_ADDR 0x40000000UL +#define PL310_BASE_ADDR 0x70000000UL +#define HSAXIM_BASE_ADDR 0x70100000UL +#define IMGSS_BASE_ADDR 0x70200000UL +#define ADC_BASE_ADDR 0x80000000UL +#define GPIOA_BASE_ADDR 0x80001000UL +#define GPIOB_BASE_ADDR 0x80002000UL +#define GPIOC_BASE_ADDR 0x80003000UL +#define HDM_BASE_ADDR 0x80004000UL +#define THSENS_BASE_ADDR 0x80200000UL +#define GPTIMER2_BASE_ADDR 0x80201000UL +#define GPTIMER1_BASE_ADDR 0x80202000UL +#define QSPI_BASE_ADDR 0x80203000UL +#define CGU_BASE_ADDR 0x80204000UL +#define CREG_BASE_ADDR 0x80205000UL +#define PEC_BASE_ADDR 0x80206000UL +#define WDRU_BASE_ADDR 0x80207000UL +#define BSEC_BASE_ADDR 0x80208000UL +#define DAP_ROM_BASE_ADDR 0x80210000UL +#define SOC_CTI_BASE_ADDR 0x80211000UL +#define TPIU_BASE_ADDR 0x80212000UL +#define TMC_ETF_BASE_ADDR 0x80213000UL +#define R4_ETM_BASE_ADDR 0x80214000UL +#define R4_CTI_BASE_ADDR 0x80215000UL +#define R4_DBG_BASE_ADDR 0x80216000UL +#define GMAC_BASE_ADDR 0x80300000UL +#define RNSS_BASE_ADDR 0x80302000UL +#define CRYP_BASE_ADDR 0x80303000UL +#define HASH_BASE_ADDR 0x80304000UL +#define GPDMA_BASE_ADDR 0x80305000UL +#define ISA_BASE_ADDR 0x8032A000UL +#define HCI_BASE_ADDR 0x80400000UL +#define I2C1_BASE_ADDR 0x80401000UL +#define I2C2_BASE_ADDR 0x80402000UL +#define SAI_BASE_ADDR 0x80403000UL +#define USI_BASE_ADDR 0x80404000UL +#define SPI1_BASE_ADDR 0x80405000UL +#define UART_BASE_ADDR 0x80406000UL +#define SPI2_BASE_ADDR 0x80500000UL +#define CAN_BASE_ADDR 0x80501000UL +#define USART1_BASE_ADDR 0x80502000UL +#define USART2_BASE_ADDR 0x80503000UL +#define USART3_BASE_ADDR 0x80504000UL +#define USART4_BASE_ADDR 0x80505000UL +#define USART5_BASE_ADDR 0x80506000UL +#define USART6_BASE_ADDR 0x80507000UL +#define SDI2_BASE_ADDR 0x80600000UL +#define SDI1_BASE_ADDR 0x80601000UL +#define VICA_BASE_ADDR 0x81000000UL +#define VICB_BASE_ADDR 0x81001000UL +#define STM_CHANNELS_BASE_ADDR 0x81100000UL +#define STM_BASE_ADDR 0x81110000UL +#define SROM_BASE_ADDR 0xFFFF0000UL + +#endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_cgu.h b/arch/arm/include/asm/arch-stv0991/stv0991_cgu.h new file mode 100644 index 0000000..4926395 --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/stv0991_cgu.h @@ -0,0 +1,80 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _STV0991_CGU_H +#define _STV0991_CGU_H + +struct stv0991_cgu_regs { + u32 cpu_freq; /* offset 0x0 */ + u32 icn2_freq; /* offset 0x4 */ + u32 dma_freq; /* offset 0x8 */ + u32 isp_freq; /* offset 0xc */ + u32 h264_freq; /* offset 0x10 */ + u32 osif_freq; /* offset 0x14 */ + u32 ren_freq; /* offset 0x18 */ + u32 tim_freq; /* offset 0x1c */ + u32 sai_freq; /* offset 0x20 */ + u32 eth_freq; /* offset 0x24 */ + u32 i2c_freq; /* offset 0x28 */ + u32 spi_freq; /* offset 0x2c */ + u32 uart_freq; /* offset 0x30 */ + u32 qspi_freq; /* offset 0x34 */ + u32 sdio_freq; /* offset 0x38 */ + u32 usi_freq; /* offset 0x3c */ + u32 can_line_freq; /* offset 0x40 */ + u32 debug_freq; /* offset 0x44 */ + u32 trace_freq; /* offset 0x48 */ + u32 stm_freq; /* offset 0x4c */ + u32 eth_ctrl; /* offset 0x50 */ + u32 reserved[3]; /* offset 0x54 */ + u32 osc_ctrl; /* offset 0x60 */ + u32 pll1_ctrl; /* offset 0x64 */ + u32 pll1_freq; /* offset 0x68 */ + u32 pll1_fract; /* offset 0x6c */ + u32 pll1_spread; /* offset 0x70 */ + u32 pll1_status; /* offset 0x74 */ + u32 pll2_ctrl; /* offset 0x78 */ + u32 pll2_freq; /* offset 0x7c */ + u32 pll2_fract; /* offset 0x80 */ + u32 pll2_spread; /* offset 0x84 */ + u32 pll2_status; /* offset 0x88 */ + u32 cgu_enable_1; /* offset 0x8c */ + u32 cgu_enable_2; /* offset 0x90 */ + u32 cgu_isp_pulse; /* offset 0x94 */ + u32 cgu_h264_pulse; /* offset 0x98 */ + u32 cgu_osif_pulse; /* offset 0x9c */ + u32 cgu_ren_pulse; /* offset 0xa0 */ + +}; + +/* CGU Timer */ +#define CLK_TMR_OSC 0 +#define CLK_TMR_MCLK 1 +#define CLK_TMR_PLL1 2 +#define CLK_TMR_PLL2 3 +#define MDIV_SHIFT_TMR 3 +#define DIV_SHIFT_TMR 6 + +#define TIMER1_CLK_CFG (0 << DIV_SHIFT_TMR \ + | 0 << MDIV_SHIFT_TMR | CLK_TMR_MCLK) + +/* Clock Enable/Disable */ + +#define TIMER1_CLK_EN (1 << 15) + +/* CGU Uart config */ +#define CLK_UART_MCLK 0 +#define CLK_UART_PLL1 1 +#define CLK_UART_PLL2 2 + +#define MDIV_SHIFT_UART 3 +#define DIV_SHIFT_UART 6 + +#define UART_CLK_CFG (4 << DIV_SHIFT_UART \ + | 1 << MDIV_SHIFT_UART | CLK_UART_MCLK) + +#endif diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_creg.h b/arch/arm/include/asm/arch-stv0991/stv0991_creg.h new file mode 100644 index 0000000..045dbfe --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/stv0991_creg.h @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _STV0991_CREG_H +#define _STV0991_CREG_H + +struct stv0991_creg { + u32 version; /* offset 0x0 */ + u32 hdpctl; /* offset 0x4 */ + u32 hdpval; /* offset 0x8 */ + u32 hdpgposet; /* offset 0xc */ + u32 hdpgpoclr; /* offset 0x10 */ + u32 hdpgpoval; /* offset 0x14 */ + u32 stm_mux; /* offset 0x18 */ + u32 sysctrl_1; /* offset 0x1c */ + u32 sysctrl_2; /* offset 0x20 */ + u32 sysctrl_3; /* offset 0x24 */ + u32 sysctrl_4; /* offset 0x28 */ + u32 reserved_1[0x35]; /* offset 0x2C-0xFC */ + u32 mux1; /* offset 0x100 */ + u32 mux2; /* offset 0x104 */ + u32 mux3; /* offset 0x108 */ + u32 mux4; /* offset 0x10c */ + u32 mux5; /* offset 0x110 */ + u32 mux6; /* offset 0x114 */ + u32 mux7; /* offset 0x118 */ + u32 mux8; /* offset 0x11c */ + u32 mux9; /* offset 0x120 */ + u32 mux10; /* offset 0x124 */ + u32 mux11; /* offset 0x128 */ + u32 mux12; /* offset 0x12c */ + u32 mux13; /* offset 0x130 */ + u32 reserved_2[0x33]; /* offset 0x134-0x1FC */ + u32 cfg_pad1; /* offset 0x200 */ + u32 cfg_pad2; /* offset 0x204 */ + u32 cfg_pad3; /* offset 0x208 */ + u32 cfg_pad4; /* offset 0x20c */ + u32 cfg_pad5; /* offset 0x210 */ + u32 cfg_pad6; /* offset 0x214 */ + u32 cfg_pad7; /* offset 0x218 */ + u32 reserved_3[0x39]; /* offset 0x21C-0x2FC */ + u32 vdd_pad1; /* offset 0x300 */ + u32 vdd_pad2; /* offset 0x304 */ + u32 reserved_4[0x3e]; /* offset 0x308-0x3FC */ + u32 vdd_comp1; /* offset 0x400 */ +}; + +/* CREG MUX 12 register */ +#define GPIOC_30_MUX_SHIFT 24 +#define GPIOC_30_MUX_MASK ~(1 << GPIOC_30_MUX_SHIFT) +#define CFG_GPIOC_30_UART_TX (1 << GPIOC_30_MUX_SHIFT) + +#define GPIOC_31_MUX_SHIFT 28 +#define GPIOC_31_MUX_MASK ~(1 << GPIOC_31_MUX_SHIFT) +#define CFG_GPIOC_31_UART_RX (1 << GPIOC_31_MUX_SHIFT) + +/* CREG MUX 7 register */ +#define GPIOB_16_MUX_SHIFT 0 +#define GPIOB_16_MUX_MASK ~(1 << GPIOB_16_MUX_SHIFT) +#define CFG_GPIOB_16_UART_TX (1 << GPIOB_16_MUX_SHIFT) + +#define GPIOB_17_MUX_SHIFT 4 +#define GPIOB_17_MUX_MASK ~(1 << GPIOB_17_MUX_SHIFT) +#define CFG_GPIOB_17_UART_RX (1 << GPIOB_17_MUX_SHIFT) + +/* CREG CFG_PAD6 register */ + +#define GPIOC_31_MODE_SHIFT 30 +#define GPIOC_31_MODE_MASK ~(1 << GPIOC_31_MODE_SHIFT) +#define CFG_GPIOC_31_MODE_OD (0 << GPIOC_31_MODE_SHIFT) +#define CFG_GPIOC_31_MODE_PP (1 << GPIOC_31_MODE_SHIFT) + +#define GPIOC_30_MODE_SHIFT 28 +#define GPIOC_30_MODE_MASK ~(1 << GPIOC_30_MODE_SHIFT) +#define CFG_GPIOC_30_MODE_LOW (0 << GPIOC_30_MODE_SHIFT) +#define CFG_GPIOC_30_MODE_HIGH (1 << GPIOC_30_MODE_SHIFT) + +#endif diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_defs.h b/arch/arm/include/asm/arch-stv0991/stv0991_defs.h new file mode 100644 index 0000000..1151378 --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/stv0991_defs.h @@ -0,0 +1,16 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __STV0991_DEFS_H__ +#define __STV0991_DEFS_H__ +#include <asm/arch/stv0991_periph.h> + +extern int stv0991_pinmux_config(enum periph_id); +extern int clock_setup(enum periph_clock); + +#endif + diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h new file mode 100644 index 0000000..abd7257 --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h @@ -0,0 +1,43 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _STV0991_GPT_H +#define _STV0991_GPT_H + +#include <asm/arch-stv0991/hardware.h> + +struct gpt_regs { + u32 cr1; + u32 cr2; + u32 reserved_1; + u32 dier; /* dma_int_en */ + u32 sr; /* status reg */ + u32 egr; /* event gen */ + u32 reserved_2[3]; /* offset 0x18--0x20*/ + u32 cnt; + u32 psc; + u32 arr; +}; + +struct gpt_regs *const gpt1_regs_ptr = + (struct gpt_regs *) GPTIMER1_BASE_ADDR; + +/* Timer control1 register */ +#define GPT_CR1_CEN 0x0001 +#define GPT_MODE_AUTO_RELOAD (1 << 7) + +/* Timer prescalar reg */ +#define GPT_PRESCALER_128 0x128 + +/* Auto reload register for free running config */ +#define GPT_FREE_RUNNING 0xFFFF + +/* Timer, HZ specific defines */ +#define CONFIG_STV0991_HZ 1000 +#define CONFIG_STV0991_HZ_CLOCK (27*1000*1000)/GPT_PRESCALER_128 + +#endif diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_periph.h b/arch/arm/include/asm/arch-stv0991/stv0991_periph.h new file mode 100644 index 0000000..f723771 --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/stv0991_periph.h @@ -0,0 +1,43 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARM_ARCH_PERIPH_H +#define __ASM_ARM_ARCH_PERIPH_H + +/* + * Peripherals required for pinmux configuration. List will + * grow with support for more devices getting added. + * Numbering based on interrupt table. + * + */ +enum periph_id { + UART_GPIOC_30_31 = 0, + UART_GPIOB_16_17, + PERIPH_ID_I2C0, + PERIPH_ID_I2C1, + PERIPH_ID_I2C2, + PERIPH_ID_I2C3, + PERIPH_ID_I2C4, + PERIPH_ID_I2C5, + PERIPH_ID_I2C6, + PERIPH_ID_I2C7, + PERIPH_ID_SPI0, + PERIPH_ID_SPI1, + PERIPH_ID_SPI2, + PERIPH_ID_SDMMC0, + PERIPH_ID_SDMMC1, + PERIPH_ID_SDMMC2, + PERIPH_ID_SDMMC3, + PERIPH_ID_I2S1, +}; + +enum periph_clock { + UART_CLOCK_CFG = 0, + ETH_CLOCK_CFG, +}; + +#endif /* __ASM_ARM_ARCH_PERIPH_H */ diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_wdru.h b/arch/arm/include/asm/arch-stv0991/stv0991_wdru.h new file mode 100644 index 0000000..7e555a2 --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/stv0991_wdru.h @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _STV0991_WD_RST_H +#define _STV0991_WD_RST_H +#include <asm/arch-stv0991/hardware.h> + +struct stv0991_wd_ru { + u32 wdru_config; + u32 wdru_ctrl1; + u32 wdru_ctrl2; + u32 wdru_tim; + u32 wdru_count; + u32 wdru_stat; + u32 wdru_wrlock; +}; + +struct stv0991_wd_ru *const stv0991_wd_ru_ptr = \ + (struct stv0991_wd_ru *)WDRU_BASE_ADDR; + +/* Watchdog control register */ +#define WDRU_RST_SYS 0x1 + +#endif diff --git a/board/st/stv0991/Kconfig b/board/st/stv0991/Kconfig new file mode 100644 index 0000000..8bda349 --- /dev/null +++ b/board/st/stv0991/Kconfig @@ -0,0 +1,23 @@ +if TARGET_STV0991 + +config SYS_CPU + string + default "armv7" + +config SYS_BOARD + string + default "stv0991" + +config SYS_VENDOR + string + default "st" + +config SYS_SOC + string + default "stv0991" + +config SYS_CONFIG_NAME + string + default "stv0991" + +endif diff --git a/board/st/stv0991/Makefile b/board/st/stv0991/Makefile new file mode 100644 index 0000000..fb5169a --- /dev/null +++ b/board/st/stv0991/Makefile @@ -0,0 +1,8 @@ +# +# (C) Copyright 2014 +# Vikas Manocha, ST Microelectronics, vikas.manocha@stcom +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := stv0991.o diff --git a/board/st/stv0991/stv0991.c b/board/st/stv0991/stv0991.c new file mode 100644 index 0000000..bdeb53c --- /dev/null +++ b/board/st/stv0991/stv0991.c @@ -0,0 +1,54 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/stv0991_periph.h> +#include <asm/arch/stv0991_defs.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_SHOW_BOOT_PROGRESS +void show_boot_progress(int progress) +{ + printf("%i\n", progress); +} +#endif + +/* + * Miscellaneous platform dependent initialisations + */ +int board_init(void) +{ + return 0; +} + +int board_uart_init(void) +{ + stv0991_pinmux_config(UART_GPIOC_30_31); + clock_setup(UART_CLOCK_CFG); + return 0; +} +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + board_uart_init(); + return 0; +} +#endif + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_1_SIZE; + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; +} diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig new file mode 100644 index 0000000..a05e991 --- /dev/null +++ b/configs/stv0991_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="stv0991" +CONFIG_ARM=y +CONFIG_TARGET_STV0991=y diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h new file mode 100644 index 0000000..864a63f --- /dev/null +++ b/include/configs/stv0991.h @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, STMicroelectronics, vikas.manocha@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_STV0991_H +#define __CONFIG_STV0991_H + +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_EXCEPTION_VECTORS_HIGH +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SYS_CORTEX_R4 + +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_SYS_NO_FLASH + +/* ram memory-related information */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define PHYS_SDRAM_1_SIZE 0x00198000 + +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR \ + (PHYS_SDRAM_1_SIZE - CONFIG_ENV_SIZE) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 16 * 1024) + +/* serial port (PL011) configuration */ +#define CONFIG_SYS_SERIAL0 0x80406000 +#define CONFIG_PL011_SERIAL +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0} +#define CONFIG_PL011_CLOCK (2700 * 1000) + +/* user interface */ +#define CONFIG_SYS_PROMPT "STV0991> " +#define CONFIG_SYS_CBSIZE 256/* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + +sizeof(CONFIG_SYS_PROMPT) + 16) + +/* MISC */ +#define CONFIG_SYS_LOAD_ADDR 0x00000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 +#define CONFIG_SYS_INIT_RAM_ADDR 0x00190000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +/* U-boot Load Address */ +#define CONFIG_SYS_TEXT_BASE 0x00010000 +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#endif /* __CONFIG_H */
Hello Vikas,
On Mon, 17 Nov 2014 17:30:25 -0800, Vikas Manocha vikas.manocha@st.com wrote:
- Timer
- uart
Changes in v4:
I don't see the MAINTAINERS file added here; it is in 4/4 which (unless I've missed requests to the opposite effect) should be merged with 1/4.
Changes in v3:
Changes in v2:
- bool "Support stv0991"
- select CPU_V7
- (C) Copyright 2014
- Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com.
- switch (peripheral) {
- case UART_CLOCK_CFG:
break;
- case ETH_CLOCK_CFG:
break;
- default:
break;
- (C) Copyright 2014 stmicroelectronics
- mov pc, lr
- case UART_GPIOC_30_31:
break;
- case UART_GPIOB_16_17:
break;
- default:
break;
- puts("System is going to reboot ...\n");
- udelay((1000 * 1000));
- /* Setting bit 1 of the WDRU unit will reset the SoC */
- writel(WDRU_RST_SYS, &stv0991_wd_ru_ptr->wdru_ctrl1);
- /* system will restart */
- while (1)
- /* Timer1 clock configuration */
- writel(TIMER1_CLK_CFG, &stv0991_cgu_regs->tim_freq);
- writel(readl(&stv0991_cgu_regs->cgu_enable_2) |
- /* Stop the timer */
- writel(readl(&gpt1_regs_ptr->cr1) & ~GPT_CR1_CEN, &gpt1_regs_ptr->cr1);
- writel(GPT_PRESCALER_128, &gpt1_regs_ptr->psc);
- /* Configure timer for auto-reload */
- writel(readl(&gpt1_regs_ptr->cr1) | GPT_MODE_AUTO_RELOAD,
- /* load value for free running */
- writel(GPT_FREE_RUNNING, &gpt1_regs_ptr->arr);
- /* start timer */
- writel(readl(&gpt1_regs_ptr->cr1) | GPT_CR1_CEN,
- /* Reset the timer */
- lastdec = READ_TIMER();
- timestamp = 0;
- timer without interrupts
- return (get_timer_masked() / GPT_RESOLUTION) - base;
- ulong tmo;
- ulong start = get_timer_masked();
- ulong tenudelcnt = CONFIG_STV0991_HZ_CLOCK / (1000 * 100);
- ulong rndoff;
- rndoff = (usec % 10) ? 1 : 0;
- /* tenudelcnt timer tick gives 10 microsecconds delay */
- tmo = ((usec / 10) + rndoff) * tenudelcnt;
- while ((ulong) (get_timer_masked() - start) < tmo)
- ulong now = READ_TIMER();
- if (now >= lastdec) {
/* normal mode */
- } else {
- lastdec = now;
- return timestamp;
- return udelay(usec);
- This function is derived from PowerPC code (read timebase as long long).
- On ARM it just returns the timer value.
- return get_timer(0);
- This function is derived from PowerPC code (timebase clock frequency).
- On ARM it returns the number of timer ticks per second.
- return CONFIG_STV0991_HZ;
- Vikas Manocha, STMicroelectronics, vikas.manocha@st.com
- u32 cpu_freq; /* offset 0x0 */
- u32 icn2_freq; /* offset 0x4 */
- u32 dma_freq; /* offset 0x8 */
- u32 isp_freq; /* offset 0xc */
- u32 h264_freq; /* offset 0x10 */
- u32 osif_freq; /* offset 0x14 */
- u32 ren_freq; /* offset 0x18 */
- u32 tim_freq; /* offset 0x1c */
- u32 sai_freq; /* offset 0x20 */
- u32 eth_freq; /* offset 0x24 */
- u32 i2c_freq; /* offset 0x28 */
- u32 spi_freq; /* offset 0x2c */
- u32 uart_freq; /* offset 0x30 */
- u32 qspi_freq; /* offset 0x34 */
- u32 sdio_freq; /* offset 0x38 */
- u32 usi_freq; /* offset 0x3c */
- u32 can_line_freq; /* offset 0x40 */
- u32 debug_freq; /* offset 0x44 */
- u32 trace_freq; /* offset 0x48 */
- u32 stm_freq; /* offset 0x4c */
- u32 eth_ctrl; /* offset 0x50 */
- u32 reserved[3]; /* offset 0x54 */
- u32 osc_ctrl; /* offset 0x60 */
- u32 pll1_ctrl; /* offset 0x64 */
- u32 pll1_freq; /* offset 0x68 */
- u32 pll1_fract; /* offset 0x6c */
- u32 pll1_spread; /* offset 0x70 */
- u32 pll1_status; /* offset 0x74 */
- u32 pll2_ctrl; /* offset 0x78 */
- u32 pll2_freq; /* offset 0x7c */
- u32 pll2_fract; /* offset 0x80 */
- u32 pll2_spread; /* offset 0x84 */
- u32 pll2_status; /* offset 0x88 */
- u32 cgu_enable_1; /* offset 0x8c */
- u32 cgu_enable_2; /* offset 0x90 */
- u32 cgu_isp_pulse; /* offset 0x94 */
- u32 cgu_h264_pulse; /* offset 0x98 */
- u32 cgu_osif_pulse; /* offset 0x9c */
- u32 cgu_ren_pulse; /* offset 0xa0 */
- u32 version; /* offset 0x0 */
- u32 hdpctl; /* offset 0x4 */
- u32 hdpval; /* offset 0x8 */
- u32 hdpgposet; /* offset 0xc */
- u32 hdpgpoclr; /* offset 0x10 */
- u32 hdpgpoval; /* offset 0x14 */
- u32 stm_mux; /* offset 0x18 */
- u32 sysctrl_1; /* offset 0x1c */
- u32 sysctrl_2; /* offset 0x20 */
- u32 sysctrl_3; /* offset 0x24 */
- u32 sysctrl_4; /* offset 0x28 */
- u32 reserved_1[0x35]; /* offset 0x2C-0xFC */
- u32 mux1; /* offset 0x100 */
- u32 mux2; /* offset 0x104 */
- u32 mux3; /* offset 0x108 */
- u32 mux4; /* offset 0x10c */
- u32 mux5; /* offset 0x110 */
- u32 mux6; /* offset 0x114 */
- u32 mux7; /* offset 0x118 */
- u32 mux8; /* offset 0x11c */
- u32 mux9; /* offset 0x120 */
- u32 mux10; /* offset 0x124 */
- u32 mux11; /* offset 0x128 */
- u32 mux12; /* offset 0x12c */
- u32 mux13; /* offset 0x130 */
- u32 reserved_2[0x33]; /* offset 0x134-0x1FC */
- u32 cfg_pad1; /* offset 0x200 */
- u32 cfg_pad2; /* offset 0x204 */
- u32 cfg_pad3; /* offset 0x208 */
- u32 cfg_pad4; /* offset 0x20c */
- u32 cfg_pad5; /* offset 0x210 */
- u32 cfg_pad6; /* offset 0x214 */
- u32 cfg_pad7; /* offset 0x218 */
- u32 reserved_3[0x39]; /* offset 0x21C-0x2FC */
- u32 vdd_pad1; /* offset 0x300 */
- u32 vdd_pad2; /* offset 0x304 */
- u32 reserved_4[0x3e]; /* offset 0x308-0x3FC */
- u32 vdd_comp1; /* offset 0x400 */
+struct gpt_regs {
- u32 cr1;
- u32 cr2;
- u32 reserved_1;
- u32 dier; /* dma_int_en */
- u32 sr; /* status reg */
- u32 egr; /* event gen */
- u32 reserved_2[3]; /* offset 0x18--0x20*/
- u32 cnt;
- u32 psc;
- u32 arr;
- (struct gpt_regs *) GPTIMER1_BASE_ADDR;
- Peripherals required for pinmux configuration. List will
- grow with support for more devices getting added.
- Numbering based on interrupt table.
+enum periph_id {
- UART_GPIOC_30_31 = 0,
- UART_GPIOB_16_17,
- PERIPH_ID_I2C0,
- PERIPH_ID_I2C1,
- PERIPH_ID_I2C2,
- PERIPH_ID_I2C3,
- PERIPH_ID_I2C4,
- PERIPH_ID_I2C5,
- PERIPH_ID_I2C6,
- PERIPH_ID_I2C7,
- PERIPH_ID_SPI0,
- PERIPH_ID_SPI1,
- PERIPH_ID_SPI2,
- PERIPH_ID_SDMMC0,
- PERIPH_ID_SDMMC1,
- PERIPH_ID_SDMMC2,
- PERIPH_ID_SDMMC3,
- PERIPH_ID_I2S1,
- UART_CLOCK_CFG = 0,
- ETH_CLOCK_CFG,
- u32 wdru_config;
- u32 wdru_ctrl1;
- u32 wdru_ctrl2;
- u32 wdru_tim;
- u32 wdru_count;
- u32 wdru_stat;
- u32 wdru_wrlock;
+config SYS_CPU
- string
- default "armv7"
+config SYS_BOARD
- string
- default "stv0991"
+config SYS_VENDOR
- string
- default "st"
+config SYS_SOC
- string
- default "stv0991"
- string
- default "stv0991"
- printf("%i\n", progress);
+} +#endif
- Miscellaneous platform dependent initialisations
- stv0991_pinmux_config(UART_GPIOC_30_31);
- clock_setup(UART_CLOCK_CFG);
- board_uart_init();
+} +#endif
- gd->ram_size = PHYS_SDRAM_1_SIZE;
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
- (PHYS_SDRAM_1_SIZE - CONFIG_ENV_SIZE)
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
1.7.9.5
Amicalement,
Thanks Albert,
On 11/17/2014 11:21 PM, Albert ARIBAUD wrote:
Hello Vikas,
- Timer
- uart
Changes in v4:
You are right, it is mentioned here but actually is in 4/4. I will merge 4/4 with 1/4.
Rgds, Vikas
Changes in v3:
Changes in v2:
select CPU_V7
- config TARGET_X600 bool "Support x600" select CPU_ARM926EJS
break;
case ETH_CLOCK_CFG:
break;
default:
break;
mov pc, lr
break;
break;
default:
break;
while (1)
/* start timer */
timestamp = 0;
ulong tmo;
ulong rndoff;
/* normal mode */
} else {
lastdec = now;
return timestamp;
+struct gpt_regs {
u32 cr1;
u32 cr2;
u32 reserved_1;
u32 cnt;
u32 psc;
u32 arr;
+enum periph_id {
UART_GPIOB_16_17,
PERIPH_ID_I2C0,
PERIPH_ID_I2C1,
PERIPH_ID_I2C2,
PERIPH_ID_I2C3,
PERIPH_ID_I2C4,
PERIPH_ID_I2C5,
PERIPH_ID_I2C6,
PERIPH_ID_I2C7,
PERIPH_ID_SPI0,
PERIPH_ID_SPI1,
PERIPH_ID_SPI2,
PERIPH_ID_SDMMC0,
PERIPH_ID_SDMMC1,
PERIPH_ID_SDMMC2,
PERIPH_ID_SDMMC3,
PERIPH_ID_I2S1,
UART_CLOCK_CFG = 0,
ETH_CLOCK_CFG,
u32 wdru_config;
u32 wdru_ctrl1;
u32 wdru_ctrl2;
u32 wdru_tim;
u32 wdru_count;
u32 wdru_stat;
u32 wdru_wrlock;
+config SYS_CPU
string
default "armv7"
+config SYS_BOARD
string
default "stv0991"
+config SYS_VENDOR
string
default "st"
+config SYS_SOC
string
default "stv0991"
string
default "stv0991"
+} +#endif
board_uart_init();
+} +#endif
1.7.9.5
Amicalement,
Albert. .
Changes in v4: None
Changes in v2: None
arch/arm/cpu/armv7/stv0991/clock.c | 14 ++++++++ arch/arm/cpu/armv7/stv0991/pinmux.c | 14 ++++++++ arch/arm/include/asm/arch-stv0991/gpio.h | 22 ++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_cgu.h | 36 +++++++++++++++++++ arch/arm/include/asm/arch-stv0991/stv0991_creg.h | 13 +++++++ arch/arm/include/asm/arch-stv0991/stv0991_periph.h | 1 + board/st/stv0991/stv0991.c | 37 ++++++++++++++++++++ include/configs/stv0991.h | 15 +++++++- 8 files changed, 151 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-stv0991/gpio.h
diff --git a/arch/arm/cpu/armv7/stv0991/clock.c b/arch/arm/cpu/armv7/stv0991/clock.c index aca6aba..70b8a8d 100644 --- a/arch/arm/cpu/armv7/stv0991/clock.c +++ b/arch/arm/cpu/armv7/stv0991/clock.c @@ -13,6 +13,13 @@ static struct stv0991_cgu_regs *const stv0991_cgu_regs = \ (struct stv0991_cgu_regs *) (CGU_BASE_ADDR);
+void enable_pll1(void) +{ + /* pll1 already configured for 1000Mhz, just need to enable it */ + writel(readl(&stv0991_cgu_regs->pll1_ctrl) & ~(0x01), + &stv0991_cgu_regs->pll1_ctrl); +} + void clock_setup(int peripheral) { switch (peripheral) { @@ -20,6 +27,13 @@ void clock_setup(int peripheral) writel(UART_CLK_CFG, &stv0991_cgu_regs->uart_freq); break; case ETH_CLOCK_CFG: + enable_pll1(); + writel(ETH_CLK_CFG, &stv0991_cgu_regs->eth_freq); + + /* Clock selection for ethernet tx_clk & rx_clk*/ + writel((readl(&stv0991_cgu_regs->eth_ctrl) & ETH_CLK_MASK) + | ETH_CLK_CTRL, &stv0991_cgu_regs->eth_ctrl); + break; default: break; diff --git a/arch/arm/cpu/armv7/stv0991/pinmux.c b/arch/arm/cpu/armv7/stv0991/pinmux.c index 6d4414a..1d086a2 100644 --- a/arch/arm/cpu/armv7/stv0991/pinmux.c +++ b/arch/arm/cpu/armv7/stv0991/pinmux.c @@ -41,6 +41,20 @@ int stv0991_pinmux_config(int peripheral) CFG_GPIOB_16_UART_TX, &stv0991_creg->mux7); break; + case ETH_GPIOB_10_31_C_0_4: + writel(readl(&stv0991_creg->mux6) & 0x000000FF, + &stv0991_creg->mux6); + writel(0x00000000, &stv0991_creg->mux7); + writel(0x00000000, &stv0991_creg->mux8); + writel(readl(&stv0991_creg->mux9) & 0xFFF00000, + &stv0991_creg->mux9); + /* Ethernet Voltage configuration to 1.8V*/ + writel((readl(&stv0991_creg->vdd_pad1) & VDD_ETH_PS_MASK) | + ETH_VDD_CFG, &stv0991_creg->vdd_pad1); + writel((readl(&stv0991_creg->vdd_pad1) & VDD_ETH_PS_MASK) | + ETH_M_VDD_CFG, &stv0991_creg->vdd_pad1); + + break; default: break; } diff --git a/arch/arm/include/asm/arch-stv0991/gpio.h b/arch/arm/include/asm/arch-stv0991/gpio.h new file mode 100644 index 0000000..9131ded --- /dev/null +++ b/arch/arm/include/asm/arch-stv0991/gpio.h @@ -0,0 +1,22 @@ +/* + * (C) Copyright 2014 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_STV0991_GPIO_H +#define __ASM_ARCH_STV0991_GPIO_H + +enum gpio_direction { + GPIO_DIRECTION_IN, + GPIO_DIRECTION_OUT, +}; + +struct gpio_regs { + u32 data; /* offset 0x0 */ + u32 reserved[0xff]; /* 0x4--0x3fc */ + u32 dir; /* offset 0x400 */ +}; + +#endif /* __ASM_ARCH_STV0991_GPIO_H */ diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_cgu.h b/arch/arm/include/asm/arch-stv0991/stv0991_cgu.h index 4926395..ddcbb57 100644 --- a/arch/arm/include/asm/arch-stv0991/stv0991_cgu.h +++ b/arch/arm/include/asm/arch-stv0991/stv0991_cgu.h @@ -77,4 +77,40 @@ struct stv0991_cgu_regs { #define UART_CLK_CFG (4 << DIV_SHIFT_UART \ | 1 << MDIV_SHIFT_UART | CLK_UART_MCLK)
+/* CGU Ethernet clock config */ +#define CLK_ETH_MCLK 0 +#define CLK_ETH_PLL1 1 +#define CLK_ETH_PLL2 2 + +#define MDIV_SHIFT_ETH 3 +#define DIV_SHIFT_ETH 6 +#define DIV_ETH_125 9 +#define DIV_ETH_50 12 +#define DIV_ETH_P2P 15 + +#define ETH_CLK_CFG (4 << DIV_ETH_P2P | 4 << DIV_ETH_50 \ + | 1 << DIV_ETH_125 \ + | 0 << DIV_SHIFT_ETH \ + | 3 << MDIV_SHIFT_ETH | CLK_ETH_PLL1) + /* CGU Ethernet control */ + +#define ETH_CLK_TX_EXT_PHY 0 +#define ETH_CLK_TX_125M 1 +#define ETH_CLK_TX_25M 2 +#define ETH_CLK_TX_2M5 3 +#define ETH_CLK_TX_DIS 7 + +#define ETH_CLK_RX_EXT_PHY 0 +#define ETH_CLK_RX_25M 1 +#define ETH_CLK_RX_2M5 2 +#define ETH_CLK_RX_DIS 3 +#define RX_CLK_SHIFT 3 +#define ETH_CLK_MASK ~(0x1F) + +#define ETH_PHY_MODE_GMII 0 +#define ETH_PHY_MODE_RMII 1 +#define ETH_PHY_CLK_DIS 1 + +#define ETH_CLK_CTRL (ETH_CLK_RX_EXT_PHY << RX_CLK_SHIFT \ + | ETH_CLK_TX_EXT_PHY) #endif diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_creg.h b/arch/arm/include/asm/arch-stv0991/stv0991_creg.h index 045dbfe..c804eb5 100644 --- a/arch/arm/include/asm/arch-stv0991/stv0991_creg.h +++ b/arch/arm/include/asm/arch-stv0991/stv0991_creg.h @@ -79,4 +79,17 @@ struct stv0991_creg { #define CFG_GPIOC_30_MODE_LOW (0 << GPIOC_30_MODE_SHIFT) #define CFG_GPIOC_30_MODE_HIGH (1 << GPIOC_30_MODE_SHIFT)
+/* CREG Ethernet pad config */ + +#define VDD_ETH_PS_1V8 0 +#define VDD_ETH_PS_2V5 2 +#define VDD_ETH_PS_3V3 3 +#define VDD_ETH_PS_MASK 0x3 + +#define VDD_ETH_PS_SHIFT 12 +#define ETH_VDD_CFG (VDD_ETH_PS_1V8 << VDD_ETH_PS_SHIFT) + +#define VDD_ETH_M_PS_SHIFT 28 +#define ETH_M_VDD_CFG (VDD_ETH_PS_1V8 << VDD_ETH_M_PS_SHIFT) + #endif diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_periph.h b/arch/arm/include/asm/arch-stv0991/stv0991_periph.h index f723771..f728c83 100644 --- a/arch/arm/include/asm/arch-stv0991/stv0991_periph.h +++ b/arch/arm/include/asm/arch-stv0991/stv0991_periph.h @@ -17,6 +17,7 @@ enum periph_id { UART_GPIOC_30_31 = 0, UART_GPIOB_16_17, + ETH_GPIOB_10_31_C_0_4, PERIPH_ID_I2C0, PERIPH_ID_I2C1, PERIPH_ID_I2C2, diff --git a/board/st/stv0991/stv0991.c b/board/st/stv0991/stv0991.c index bdeb53c..989fb5e 100644 --- a/board/st/stv0991/stv0991.c +++ b/board/st/stv0991/stv0991.c @@ -9,9 +9,16 @@ #include <miiphy.h> #include <asm/arch/stv0991_periph.h> #include <asm/arch/stv0991_defs.h> +#include <asm/arch/hardware.h> +#include <asm/arch/gpio.h> +#include <netdev.h> +#include <asm/io.h>
+struct gpio_regs *const gpioa_regs = + (struct gpio_regs *) GPIOA_BASE_ADDR; + #ifdef CONFIG_SHOW_BOOT_PROGRESS void show_boot_progress(int progress) { @@ -19,11 +26,26 @@ void show_boot_progress(int progress) } #endif
+void enable_eth_phy(void) +{ + /* Set GPIOA_06 pad HIGH (Appli board)*/ + writel(readl(&gpioa_regs->dir) | 0x40, &gpioa_regs->dir); + writel(readl(&gpioa_regs->data) | 0x40, &gpioa_regs->data); +} +int board_eth_enable(void) +{ + stv0991_pinmux_config(ETH_GPIOB_10_31_C_0_4); + clock_setup(ETH_CLOCK_CFG); + enable_eth_phy(); + return 0; +} + /* * Miscellaneous platform dependent initialisations */ int board_init(void) { + board_eth_enable(); return 0; }
@@ -33,6 +55,7 @@ int board_uart_init(void) clock_setup(UART_CLOCK_CFG); return 0; } + #ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { @@ -52,3 +75,17 @@ void dram_init_banksize(void) gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int ret = 0; + +#if defined(CONFIG_DESIGNWARE_ETH) + u32 interface = PHY_INTERFACE_MODE_MII; + if (designware_initialize(GMAC_BASE_ADDR, interface) >= 0) + ret++; +#endif + return ret; +} +#endif diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index 864a63f..a316f63 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -7,11 +7,11 @@
#ifndef __CONFIG_STV0991_H #define __CONFIG_STV0991_H - #define CONFIG_SYS_DCACHE_OFF #define CONFIG_SYS_ICACHE_OFF #define CONFIG_SYS_EXCEPTION_VECTORS_HIGH #define CONFIG_BOARD_EARLY_INIT_F + #define CONFIG_SYS_CORTEX_R4
#define CONFIG_SYS_GENERIC_BOARD @@ -55,4 +55,17 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
+/* GMAC related configs */ + +#define CONFIG_MII +#define CONFIG_PHYLIB +#define CONFIG_CMD_NET +#define CONFIG_DESIGNWARE_ETH +#define CONFIG_DW_ALTDESCRIPTOR +#define CONFIG_PHY_MICREL + +/* Command support defines */ +#define CONFIG_CMD_PING +#define CONFIG_PHY_RESET_DELAY 10000 /* in usec */ + #endif /* __CONFIG_H */
Changes in v4: None
Changes in v2: None
include/configs/stv0991.h | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index a316f63..f95de06 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -8,7 +8,6 @@ #ifndef __CONFIG_STV0991_H #define __CONFIG_STV0991_H #define CONFIG_SYS_DCACHE_OFF -#define CONFIG_SYS_ICACHE_OFF #define CONFIG_SYS_EXCEPTION_VECTORS_HIGH #define CONFIG_BOARD_EARLY_INIT_F
@@ -40,7 +39,7 @@
/* user interface */ #define CONFIG_SYS_PROMPT "STV0991> " -#define CONFIG_SYS_CBSIZE 256/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ +sizeof(CONFIG_SYS_PROMPT) + 16)
@@ -68,4 +67,22 @@ #define CONFIG_CMD_PING #define CONFIG_PHY_RESET_DELAY 10000 /* in usec */
+#include "config_cmd_default.h" +#undef CONFIG_CMD_SAVEENV + +#define CONFIG_SYS_MEMTEST_START 0x0000 +#define CONFIG_SYS_MEMTEST_END 1024*1024 +#define CONFIG_CMD_MEMTEST + +/* Misc configuration */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTCOMMAND "go 0x40040000" +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_STOP_STR " " +#define CONFIG_AUTOBOOT_PROMPT \ + "Hit SPACE in %d seconds to stop autoboot.\n", bootdelay + #endif /* __CONFIG_H */
Hello Vikas,
(nitpicking) can you replace '+' in the subject with 'and' ?
(nitpicking yet more) can you keep the "action" form for the subject rather than "action done", i.e., "stv0991: enable default and misc command configs"
Amicalement,
Hello Albert,
On 11/17/2014 11:29 PM, Albert ARIBAUD wrote:
Hello Vikas,
ok, i will submit the v5.
ok.
Amicalement,
Rgds, Vikas
MAINTAINERS | 6 ++++++ board/st/stv0991/MAINTAINERS | 5 +++++ 2 files changed, 11 insertions(+) create mode 100644 board/st/stv0991/MAINTAINERS
diff --git a/MAINTAINERS b/MAINTAINERS index c8386ab..950daf2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -128,6 +128,12 @@ T: git git://git.denx.de/u-boot-stm.git F: arch/arm/cpu/arm926ejs/spear/ F: arch/arm/include/asm/arch-spear/
+ARM STM STV0991 +M: Vikas Manocha vikas.manocha@st.com +S: Maintained +F: arch/arm/cpu/armv7/stv0991/ +F: arch/arm/include/asm/arch-stv0991/ + ARM SUNXI M: Ian Campbell ijc@hellion.org.uk M: Hans De Goede hdegoede@redhat.com diff --git a/board/st/stv0991/MAINTAINERS b/board/st/stv0991/MAINTAINERS new file mode 100644 index 0000000..87221e9 --- /dev/null +++ b/board/st/stv0991/MAINTAINERS @@ -0,0 +1,5 @@ +STV0991 APPLICATION BOARD +M: Vikas Manocha vikas.manocha@st.com +S: Maintained +F: board/st/stv0991/ +F: include/configs/stv0991.h
Hi Vikas,
Changes in v4:
Changes in v3:
Changes in v2:
Can you please look at using driver model for this board? It would be particularly valuable since it looks like you are using the pl011 UART which has not previously been tested with driver model (and it seems you found some problems).
To do this you probably only need to adjust a few defines and add platform data for serial. A patch for Raspberry Pi is here:
http://patchwork.ozlabs.org/patch/392180/
Hello Simon,
On 11/17/2014 09:19 PM, Simon Glass wrote:
Hi Vikas,
Changes in v4:
Changes in v3:
Changes in v2:
Sure, Simon. Infact i was also planning to use the driver model. Thanks for sharing the Raspberry patch link.
Rgds, Vikas
Hello Simon,
On 11/18/2014 10:17 AM, vikasm wrote:
Hello Simon,
Hi Vikas,
Changes in v4:
Changes in v3:
Changes in v2:
I tried using driver model but got into issue after relocation, figured out that it was because 0x0 location was being overwritten & pl011 base address was being stored here... After tracking "Raspberry Pi with driver model" discussion, seems like you are aware of it now, just wanted to provide this information on one more platform.
Rgds, Vikas
Hi Simon,
On 11/25/2014 11:50 AM, vikasm wrote:
Hello Simon,
Hello Simon,
Hi Vikas,
Changes in v4:
Changes in v3:
Changes in v2:
& with ".priv_auto_alloc_size = sizeof(struct pl01x_priv)," addition, the issue is fixed.
Rgds, Vikas
Rgds, Vikas
Hi Vikas,
On 25 November 2014 at 12:50, vikasm vikas.manocha@st.com wrote:
Hello Simon,
Hello Simon,
Hi Vikas,
Changes in v4:
Changes in v3:
Changes in v2:
Yes thanks, the patch is here:
http://patchwork.ozlabs.org/patch/414224/
Unfortunate that my test platform had RAM at 0!
Albert ARIBAUD
Vikas Manocha
vikasm
