[PATCH v2] ram: stm32mp1: Conditionally enable ASR
Enable DRAM ASR, auto self-refresh, conditionally, based on DT PWRCTL register bits. While ASR does save considerable amount of power at runtime automatically, it also causes LTDC underruns on large panels. Let user select whether or not ASR is required or not, generally ASR should be enabled on portable and battery operated devices.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Patrice Chotard patrice.chotard@foss.st.com --- V2: Infer ASR settings from DT PWRCTL --- drivers/ram/stm32mp1/stm32mp1_ddr.c | 14 +++++++++++--- 1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/drivers/ram/stm32mp1/stm32mp1_ddr.c b/drivers/ram/stm32mp1/stm32mp1_ddr.c index 528a171b454..ab913a68761 100644 --- a/drivers/ram/stm32mp1/stm32mp1_ddr.c +++ b/drivers/ram/stm32mp1/stm32mp1_ddr.c @@ -653,10 +653,14 @@ static void stm32mp1_refresh_restore(struct stm32mp1_ddrctl *ctl, wait_sw_done_ack(ctl); }
-static void stm32mp1_asr_enable(struct ddr_info *priv) +static void stm32mp1_asr_enable(struct ddr_info *priv, const u32 pwrctl) { struct stm32mp1_ddrctl *ctl = priv->ctl;
+ /* SSR is the best we can do. */ + if (!(pwrctl & DDRCTRL_PWRCTL_EN_DFI_DRAM_CLK_DISABLE)) + return; + clrsetbits_le32(priv->rcc + RCC_DDRITFCR, RCC_DDRITFCR_DDRCKMOD_MASK, RCC_DDRITFCR_DDRCKMOD_ASR);
@@ -666,8 +670,12 @@ static void stm32mp1_asr_enable(struct ddr_info *priv) writel(DDRCTRL_PWRTMG_POWERDOWN_TO_X32(0x10) | DDRCTRL_PWRTMG_SELFREF_TO_X32(0x01), &ctl->pwrtmg); + + /* HSR we can do. */ setbits_le32(&ctl->pwrctl, DDRCTRL_PWRCTL_EN_DFI_DRAM_CLK_DISABLE); - setbits_le32(&ctl->pwrctl, DDRCTRL_PWRCTL_SELFREF_EN); + + if (pwrctl & DDRCTRL_PWRCTL_SELFREF_EN) /* ASR we can do. */ + setbits_le32(&ctl->pwrctl, DDRCTRL_PWRCTL_SELFREF_EN);
setbits_le32(&ctl->dfimisc, DDRCTRL_DFIMISC_DFI_INIT_COMPLETE_EN); wait_sw_done_ack(ctl); @@ -845,7 +853,7 @@ start: config->c_reg.pwrctl);
/* Enable auto-self-refresh, which saves a bit of power at runtime. */ - stm32mp1_asr_enable(priv); + stm32mp1_asr_enable(priv, config->c_reg.pwrctl);
/* enable uMCTL2 AXI port 0 and 1 */ setbits_le32(&priv->ctl->pctrl_0, DDRCTRL_PCTRL_N_PORT_EN);
Adding also Nicolas,
- /* SSR is the best we can do. */
- if (!(pwrctl & DDRCTRL_PWRCTL_EN_DFI_DRAM_CLK_DISABLE))
return;
- clrsetbits_le32(priv->rcc + RCC_DDRITFCR, RCC_DDRITFCR_DDRCKMOD_MASK, RCC_DDRITFCR_DDRCKMOD_ASR);
- /* HSR we can do. */ setbits_le32(&ctl->pwrctl, DDRCTRL_PWRCTL_EN_DFI_DRAM_CLK_DISABLE);
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
return;
Applied to u-boot-stm32
Thanks Patrice
Patrice CHOTARD
Patrick DELAUNAY
