[U-Boot] [PATCH 00/08]: Config cleanups
Hey all,
As part of the RFC config cleanups I sent a while ago, I've come up with a number of related cleanups that should be done. This series does that. It's mostly OMAP* stuff except for the last one which fixes the case of using config_cmd_default.h and NOT setting CONFIG_SYS_NO_FLASH before then and having to manually undef CONFIG_CMD_(FLASH|IMLS). I can split that up if needed.
This is only used on !CONFIG_GENERIC_MMC which is false here.
Signed-off-by: Tom Rini trini@ti.com --- include/configs/omap4_common.h | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index 01b4d6c..4ace07b 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -106,7 +106,6 @@ #define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 #define CONFIG_OMAP_HSMMC 1 -#define CONFIG_SYS_MMC_SET_DEV 1 #define CONFIG_DOS_PARTITION 1
OMAP4/5 had an empty arch_cpu_init() so drop that along with CONFIG_ARCH_CPU_INIT
Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 10 ---------- include/configs/omap4_common.h | 1 - include/configs/omap5_evm.h | 1 - 3 files changed, 0 insertions(+), 12 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 10e7669..cf71ab4 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -203,16 +203,6 @@ int checkboard(void) }
/* -* This function is called by start_armboot. You can reliably use static -* data. Any boot-time function that require static data should be -* called from here -*/ -int arch_cpu_init(void) -{ - return 0; -} - -/* * get_device_type(): tell if GP/HS/EMU/TST */ u32 get_device_type(void) diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index 4ace07b..5507c8f 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -35,7 +35,6 @@ #define CONFIG_OMAP 1 /* in a TI OMAP core */ #define CONFIG_OMAP44XX 1 /* which is a 44XX */ #define CONFIG_OMAP4430 1 /* which is in a 4430 */ -#define CONFIG_ARCH_CPU_INIT
/* Get CPU defs */ #include <asm/arch/cpu.h> diff --git a/include/configs/omap5_evm.h b/include/configs/omap5_evm.h index 6c91ee8..38b5028 100644 --- a/include/configs/omap5_evm.h +++ b/include/configs/omap5_evm.h @@ -38,7 +38,6 @@ #define CONFIG_OMAP54XX /* which is a 54XX */ #define CONFIG_OMAP5430 /* which is in a 5430 */ #define CONFIG_5430EVM /* working with EVM */ -#define CONFIG_ARCH_CPU_INIT
We had a do-nothing misc_init_r, remove along with CONFIG_MISC_INIT_R
Signed-off-by: Tom Rini trini@ti.com --- board/ti/omap5912osk/omap5912osk.c | 7 ------- include/configs/omap5912osk.h | 2 -- 2 files changed, 0 insertions(+), 9 deletions(-)
diff --git a/board/ti/omap5912osk/omap5912osk.c b/board/ti/omap5912osk/omap5912osk.c index 6f0e763..fac683a 100644 --- a/board/ti/omap5912osk/omap5912osk.c +++ b/board/ti/omap5912osk/omap5912osk.c @@ -81,13 +81,6 @@ int board_init (void) return 0; }
- -int misc_init_r (void) -{ - /* currently empty */ - return (0); -} - /****************************** Routine: Description: diff --git a/include/configs/omap5912osk.h b/include/configs/omap5912osk.h index a8dfef3..d3a2438 100644 --- a/include/configs/omap5912osk.h +++ b/include/configs/omap5912osk.h @@ -44,8 +44,6 @@
#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
-#define CONFIG_MISC_INIT_R - #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1 /* Required for ramdisk support */
Signed-off-by: Tom Rini trini@ti.com --- board/ti/omap730p2/omap730p2.c | 6 ------ include/configs/omap730p2.h | 2 -- 2 files changed, 0 insertions(+), 8 deletions(-)
diff --git a/board/ti/omap730p2/omap730p2.c b/board/ti/omap730p2/omap730p2.c index 954ced5..36204b2 100644 --- a/board/ti/omap730p2/omap730p2.c +++ b/board/ti/omap730p2/omap730p2.c @@ -129,12 +129,6 @@ int board_init (void) return 0; }
-int misc_init_r (void) -{ - /* currently empty */ - return (0); -} - /****************************** Routine: Description: diff --git a/include/configs/omap730p2.h b/include/configs/omap730p2.h index 26e7e1f..f7900e0 100644 --- a/include/configs/omap730p2.h +++ b/include/configs/omap730p2.h @@ -49,8 +49,6 @@
Introduce a __weak misc_init_r function that just runs dieid_num_r(). Remove misc_init_r from cm_t35, mcx, omap3_logic and mt_ventoux as this was all they did for misc_init_r.
Cc: Igor Grinberg grinberg@compulab.co.il Cc: Ilya Yanok yanok@emcraft.com Cc: Peter Barada peter.barada@logicpd.com Cc: Stefano Babic sbabic@denx.de Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/omap3/board.c | 12 ++++++++++++ board/cm_t35/cm_t35.c | 11 ----------- board/htkw/mcx/mcx.c | 11 ----------- board/logicpd/omap3som/omap3logic.c | 11 ----------- board/teejet/mt_ventoux/mt_ventoux.c | 7 ------- 5 files changed, 12 insertions(+), 40 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/board.c b/arch/arm/cpu/armv7/omap3/board.c index 1fee574..f2e52e9 100644 --- a/arch/arm/cpu/armv7/omap3/board.c +++ b/arch/arm/cpu/armv7/omap3/board.c @@ -41,6 +41,7 @@ #include <asm/arch/gpio.h> #include <asm/omap_common.h> #include <i2c.h> +#include <linux/compiler.h>
/* Declarations */ extern omap3_sysinfo sysinfo; @@ -244,6 +245,17 @@ void s_init(void) mem_init(); }
+/* + * Routine: misc_init_r + * Description: A basic misc_init_r that just displays the die ID + */ +int __weak misc_init_r(void) +{ + dieid_num_r(); + + return 0; +} + /****************************************************************************** * Routine: wait_for_command_complete * Description: Wait for posting to finish on watchdog diff --git a/board/cm_t35/cm_t35.c b/board/cm_t35/cm_t35.c index 7a2fed7..b5d2800 100644 --- a/board/cm_t35/cm_t35.c +++ b/board/cm_t35/cm_t35.c @@ -100,17 +100,6 @@ int board_init(void) }
/* - * Routine: misc_init_r - * Description: display die ID - */ -int misc_init_r(void) -{ - dieid_num_r(); - - return 0; -} - -/* * Routine: set_muxconf_regs * Description: Setting up the configuration Mux registers specific to the * hardware. Many pins need to be moved from protect to primary diff --git a/board/htkw/mcx/mcx.c b/board/htkw/mcx/mcx.c index 8f0b527..8f75af1 100644 --- a/board/htkw/mcx/mcx.c +++ b/board/htkw/mcx/mcx.c @@ -69,17 +69,6 @@ int board_init(void) }
/* - * Routine: misc_init_r - * Description: late init. - */ -int misc_init_r(void) -{ - dieid_num_r(); - - return 0; -} - -/* * Routine: set_muxconf_regs * Description: Setting up the configuration Mux registers specific to the * hardware. Many pins need to be moved from protect to primary diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 89b114b..12bcfcb 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -144,17 +144,6 @@ int board_mmc_init(bd_t *bis) } #endif
-/* - * Routine: misc_init_r - * Description: display die ID register - */ -int misc_init_r(void) -{ - dieid_num_r(); - - return 0; -} - #ifdef CONFIG_SMC911X /* GPMC CS1 settings for Logic SOM LV/Torpedo LAN92xx Ethernet chip */ static const u32 gpmc_lan92xx_config[] = { diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index c7aedc9..9fbaedd 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -196,13 +196,6 @@ int board_init(void) return 0; }
-int misc_init_r(void) -{ - dieid_num_r(); - - return 0; -} - /* * Routine: set_muxconf_regs * Description: Setting up the configuration Mux registers specific to the
Acked-by: Igor Grinberg grinberg@compulab.co.il
Thanks for the patch.
Am 14/04/2012 00:20, schrieb Tom Rini:
Acked-by : Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
This define does not control anything, remove it.
Signed-off-by: Tom Rini trini@ti.com --- include/configs/P1023RDS.h | 1 - include/configs/P2020COME.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 2 -- include/configs/at91sam9263ek.h | 2 -- include/configs/da830evm.h | 1 - include/configs/ea20.h | 1 - include/configs/eb_cpux9k2.h | 2 -- include/configs/flea3.h | 2 -- include/configs/hawkboard.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/mcx.h | 2 -- include/configs/meesc.h | 1 - include/configs/mv-common.h | 1 - include/configs/mx25pdk.h | 1 - include/configs/mx35pdk.h | 2 -- include/configs/otc570.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/spear-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tx25.h | 2 -- include/configs/zmx25.h | 2 -- 22 files changed, 0 insertions(+), 30 deletions(-)
diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h index e057b1f..b7236b2 100644 --- a/include/configs/P1023RDS.h +++ b/include/configs/P1023RDS.h @@ -310,7 +310,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_OF_BOARD_SETUP #define CONFIG_OF_STDOUT_VIA_ALIAS
-#define CONFIG_SYS_64BIT_VSPRINTF #define CONFIG_SYS_64BIT_STRTOUL
/* new uImage format support */ diff --git a/include/configs/P2020COME.h b/include/configs/P2020COME.h index 365322c..12f9860 100644 --- a/include/configs/P2020COME.h +++ b/include/configs/P2020COME.h @@ -416,7 +416,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif
/* Misc Extra Settings */ -#define CONFIG_SYS_64BIT_VSPRINTF 1 #define CONFIG_SYS_64BIT_STRTOUL 1 #define CONFIG_CMD_DHCP 1
diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index b0dd2f0..71321f3 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -174,7 +174,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */
#define CONFIG_JFFS2_NAND /* nand device jffs2 lives on */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index b5f75d1..bbd19de 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -173,8 +173,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ - #define CONFIG_JFFS2_NAND /* nand device jffs2 lives on */ #define CONFIG_JFFS2_DEV "nand0" diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 8399246..f424e5a 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -283,8 +283,6 @@ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 - -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* Ethernet */ diff --git a/include/configs/da830evm.h b/include/configs/da830evm.h index 4532e4f..781878e 100644 --- a/include/configs/da830evm.h +++ b/include/configs/da830evm.h @@ -111,7 +111,6 @@ #define CONFIG_SYS_NAND_CS 3 #define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE #define CONFIG_SYS_NAND_PAGE_2K -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #define CONFIG_SYS_CLE_MASK 0x10 #define CONFIG_SYS_ALE_MASK 0x8 #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index e059b30..04e7a2d 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -203,7 +203,6 @@ #define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST #define CONFIG_SYS_NAND_USE_FLASH_BBT #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* SPI Flash */ diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index 9046cf0..1fcd0c8 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -274,8 +274,6 @@ #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_NAND_DBW_8 1
-#define CONFIG_SYS_64BIT_VSPRINTF 1 - /* Status LED's */
#define CONFIG_STATUS_LED 1 diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 649e272..e860837 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -47,8 +47,6 @@ /* Set TEXT at the beginning of the NOR flash */ #define CONFIG_SYS_TEXT_BASE 0xA0000000
-#define CONFIG_SYS_64BIT_VSPRINTF - /* This is required to setup the ESDC controller */ #define CONFIG_BOARD_EARLY_INIT_F
diff --git a/include/configs/hawkboard.h b/include/configs/hawkboard.h index 50a1c17..959f9cf 100644 --- a/include/configs/hawkboard.h +++ b/include/configs/hawkboard.h @@ -126,7 +126,6 @@ #define CFG_DAVINCI_STD_NAND_LAYOUT #define CONFIG_SYS_NAND_CS 3 #define CONFIG_SYS_NAND_PAGE_2K -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ /* Max number of NAND devices */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE_LIST { 0x62000000, } diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 2af4e7a..c1f1aa6 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -153,7 +153,6 @@ #define CONFIG_SYS_NAND_BASE 0xd8000000 #define CONFIG_JFFS2_NAND #define CONFIG_MXC_NAND_HWECC -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */
/* * SD/MMC diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 1315c3c..e190e3e 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -171,8 +171,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ - #define CONFIG_JFFS2_NAND /* nand device jffs2 lives on */ #define CONFIG_JFFS2_DEV "nand0" diff --git a/include/configs/meesc.h b/include/configs/meesc.h index d6197bc..db1e87d 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -164,7 +164,6 @@ # define CONFIG_SYS_NAND_MASK_CLE (1 << 22) # define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIO_PORTD, 15 # define CONFIG_SYS_NAND_READY_PIN AT91_PIO_PORTA, 22 -# define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* Ethernet */ diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index 1a63791..27b4899 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -132,7 +132,6 @@ */ #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index d1ba02b..7210b6e 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -65,7 +65,6 @@ #define CONFIG_ENV_IS_NOWHERE
#define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_64BIT_VSPRINTF
/* U-Boot general configuration */ #define CONFIG_SYS_PROMPT "MX25PDK U-Boot > " diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 0c62b9f..07973f4 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -39,8 +39,6 @@ /* Set TEXT at the beginning of the NOR flash */ #define CONFIG_SYS_TEXT_BASE 0xA0000000
-#define CONFIG_SYS_64BIT_VSPRINTF - #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT
diff --git a/include/configs/otc570.h b/include/configs/otc570.h index b322c77..8599378 100644 --- a/include/configs/otc570.h +++ b/include/configs/otc570.h @@ -215,7 +215,6 @@ # define CONFIG_SYS_NAND_MASK_CLE (1 << 22) # define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIO_PORTD, 15 # define CONFIG_SYS_NAND_READY_PIN AT91_PIO_PORTA, 22 -# define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #endif
/* Ethernet */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 3098c5a..c52f070 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -534,7 +534,6 @@ #define CONFIG_OF_BOARD_SETUP #define CONFIG_OF_STDOUT_VIA_ALIAS
/* new uImage format support */ diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 5fef8cc..58d9fab 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -196,7 +196,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LOAD_ADDR 0x00800000 #define CONFIG_SYS_CONSOLE_INFO_QUIET 1 -#define CONFIG_SYS_64BIT_VSPRINTF 1
#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_EXTRA_ENV_USBTTY
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 4c4321d..37eb87b 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -146,7 +146,6 @@
#define CONFIG_AUTO_COMPLETE
diff --git a/include/configs/tx25.h b/include/configs/tx25.h index 87bd8a6..3dfafa5 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -117,8 +117,6 @@ #define CONFIG_MXC_NAND_HWECC #define CONFIG_SYS_NAND_LARGEPAGE
-#define CONFIG_SYS_64BIT_VSPRINTF - /* U-Boot general configuration */ #define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 599d5bb..d7ce6c6 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -93,8 +93,6 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_CACHE
-#define CONFIG_SYS_64BIT_VSPRINTF - /* * Additional command */
Signed-off-by: Tom Rini trini@ti.com --- include/configs/P1023RDS.h | 2 -- include/configs/P2020COME.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 -- 3 files changed, 0 insertions(+), 5 deletions(-)
diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h index b7236b2..e632d1b 100644 --- a/include/configs/P1023RDS.h +++ b/include/configs/P1023RDS.h @@ -310,8 +310,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_OF_BOARD_SETUP #define CONFIG_OF_STDOUT_VIA_ALIAS
-#define CONFIG_SYS_64BIT_STRTOUL - /* new uImage format support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ diff --git a/include/configs/P2020COME.h b/include/configs/P2020COME.h index 12f9860..28122ec 100644 --- a/include/configs/P2020COME.h +++ b/include/configs/P2020COME.h @@ -416,7 +416,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif
/* Misc Extra Settings */ -#define CONFIG_SYS_64BIT_STRTOUL 1 #define CONFIG_CMD_DHCP 1
#define CONFIG_CMD_DATE 1 diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index c52f070..2d68d2e 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -534,8 +534,6 @@ #define CONFIG_OF_BOARD_SETUP #define CONFIG_OF_STDOUT_VIA_ALIAS
In config files which it is clear when CONFIG_SYS_NO_FLASH will be set (either unconditionally or based on logic that can happen early in the config file), ensure that we set that _before_ we include config_cmd_default.h so that the logic in that file will not enable CONFIG_CMD_(FLASH|IMLS). This saves us from having to undef it in the board files.
Signed-off-by: Tom Rini trini@ti.com --- include/configs/PN62.h | 5 +--- include/configs/SIMPC8313.h | 5 +--- include/configs/afeb9260.h | 5 +--- include/configs/am3517_crane.h | 4 +-- include/configs/am3517_evm.h | 4 +-- include/configs/at91sam9260ek.h | 5 +--- include/configs/at91sam9261ek.h | 5 +--- include/configs/at91sam9m10g45ek.h | 5 +--- include/configs/at91sam9rlek.h | 5 +--- include/configs/bf525-ucr2.h | 5 +--- include/configs/bf537-minotaur.h | 11 +--------- include/configs/bf537-srv1.h | 11 +--------- include/configs/blackstamp.h | 15 +++++-------- include/configs/blackvme.h | 13 ++++------- include/configs/cm_t35.h | 4 +-- include/configs/coreboot.h | 11 +--------- include/configs/davinci_schmoogie.h | 2 - include/configs/davinci_sffsdr.h | 2 - include/configs/devkit8000.h | 2 +- include/configs/dig297.h | 4 +-- include/configs/igep00x0.h | 5 +--- include/configs/mcx.h | 4 +-- include/configs/meesc.h | 5 +--- include/configs/mx31pdk.h | 10 +-------- include/configs/mx51evk.h | 6 +--- include/configs/mx53ard.h | 5 +--- include/configs/mx53evk.h | 5 +--- include/configs/mx53loco.h | 5 +--- include/configs/mx53smd.h | 5 +--- include/configs/mx6qarm2.h | 5 +--- include/configs/mx6qsabrelite.h | 5 +--- include/configs/nhk8815.h | 5 +--- include/configs/omap3_beagle.h | 4 +-- include/configs/omap3_logic.h | 5 +--- include/configs/omap3_mvblx.h | 5 +--- include/configs/omap3_overo.h | 4 +-- include/configs/omap3_pandora.h | 4 +-- include/configs/omap3_zoom1.h | 4 +-- include/configs/omap3_zoom2.h | 4 +-- include/configs/omap4_common.h | 5 +--- include/configs/omap5_evm.h | 5 +--- include/configs/origen.h | 3 +- include/configs/otc570.h | 5 +--- include/configs/pm9g45.h | 6 +---- include/configs/sbc35_a9g20.h | 5 +--- include/configs/smdk5250.h | 3 +- include/configs/smdkc100.h | 5 +--- include/configs/snapper9260.h | 1 - include/configs/tam3517-common.h | 5 +--- include/configs/tegra2-common.h | 5 +--- include/configs/tny_a9260.h | 5 +--- include/configs/vct.h | 5 ---- include/configs/vision2.h | 4 +-- include/configs/xilinx-ppc.h | 38 ++++++++++++++++------------------ 54 files changed, 77 insertions(+), 241 deletions(-)
diff --git a/include/configs/PN62.h b/include/configs/PN62.h index dae4577..ddaffc1 100644 --- a/include/configs/PN62.h +++ b/include/configs/PN62.h @@ -56,13 +56,12 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* There is no FLASH memory */ #include <config_cmd_default.h>
#define CONFIG_CMD_PCI #define CONFIG_CMD_BSP
-#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SAVEENV #undef CONFIG_CMD_SOURCE @@ -157,8 +156,6 @@ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SYS_NO_FLASH 1 /* There is no FLASH memory */ - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_OFFSET 0x00004000 /* Offset of Environment Sector */ #define CONFIG_ENV_SIZE 0x00002000 /* Total Size of Environment Sector */ diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 0976077..8b51f6c 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -105,8 +105,6 @@ /* * FLASH on the Local Bus */ -#define CONFIG_SYS_NO_FLASH - #if !defined(CONFIG_NAND_SPL) #define CONFIG_SYS_RAMBOOT #endif @@ -347,9 +345,8 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH #include <config_cmd_default.h> -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_FLASH
#define CONFIG_CMD_PING #define CONFIG_CMD_DHCP diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 2adf8f9..23506af 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -72,11 +72,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* NOR flash - no real flash on this board */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
@@ -117,9 +117,6 @@
#endif
-/* NOR flash - no real flash on this board */ -#define CONFIG_SYS_NO_FLASH - /* Ethernet */ #define CONFIG_MACB #define CONFIG_RESET_PHY_R diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 71321f3..904e143 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -136,6 +136,7 @@ #endif /* CONFIG_USB_AM35X */
/* commands to include */ +#define CONFIG_SYS_NO_FLASH /* No CFI flash */ #include <config_cmd_default.h>
#define CONFIG_CMD_EXT2 /* EXT2 Support */ @@ -148,12 +149,9 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING
-#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ #undef CONFIG_CMD_IMI /* iminfo */ -#undef CONFIG_CMD_IMLS /* List all found images */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index bbd19de..1cab76a 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -135,6 +135,7 @@ #endif /* CONFIG_USB_AM35X */
#define CONFIG_CMD_EXT2 /* EXT2 Support */ @@ -147,12 +148,9 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index db52ee6..7376e16 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -93,11 +93,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* NOR flash - no real flash on this board */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
@@ -155,9 +155,6 @@ #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 #endif
-/* NOR flash - no real flash on this board */ -#define CONFIG_SYS_NO_FLASH 1 - /* Ethernet */ #define CONFIG_MACB 1 #define CONFIG_RMII 1 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 5140b26..4dc617a 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -103,11 +103,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* NOR flash - no real flash on this board */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
@@ -149,9 +149,6 @@
#endif
-/* NOR flash - no real flash on this board */ -#define CONFIG_SYS_NO_FLASH - /* Ethernet */ #define CONFIG_DRIVER_DM9000 #define CONFIG_DM9000_BASE 0x30000000 diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 6a02188..c685573 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -102,11 +102,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* No NOR flash */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_LOADS
@@ -123,9 +123,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
-/* No NOR flash */ -#define CONFIG_SYS_NO_FLASH - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 79ea1f2..f502a6b 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -90,11 +90,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* NOR flash - not present */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS @@ -121,9 +121,6 @@ #define DATAFLASH_TCSS (0x1a << 16) #define DATAFLASH_TCHS (0x1 << 24)
-/* NOR flash - not present */ -#define CONFIG_SYS_NO_FLASH 1 - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL diff --git a/include/configs/bf525-ucr2.h b/include/configs/bf525-ucr2.h index 1f65130..01af7bf 100644 --- a/include/configs/bf525-ucr2.h +++ b/include/configs/bf525-ucr2.h @@ -62,9 +62,6 @@ #define CONFIG_SYS_MONITOR_LEN (320 * 1024) #define CONFIG_SYS_MALLOC_LEN (320 * 1024)
-/* We don't have a parallel flash chip */ -#define CONFIG_SYS_NO_FLASH - /* support for serial flash */ #define CONFIG_BFIN_SPI #define CONFIG_SPI_FLASH @@ -94,9 +91,9 @@ "bootm 0x1000000\0"
/* this sets up the default list of enabled commands */ +#define CONFIG_SYS_NO_FLASH /* We don't have a parallel flash chip */ #include <config_cmd_default.h> #undef CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #undef CONFIG_CMD_NFS -#undef CONFIG_CMD_IMLS
#endif diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index ef9d236..033125e 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -89,14 +89,6 @@ /* Uncomment next line to use fixed MAC address */ /* #define CONFIG_ETHADDR 02:80:ad:20:31:42 */
- -/* - * Flash Settings - */ -/* We don't have a parallel flash chip there */ -#define CONFIG_SYS_NO_FLASH - - /* * SPI Settings */ @@ -148,6 +140,7 @@ # define CONFIG_BOOTDELAY 5 #endif
+#define CONFIG_SYS_NO_FLASH /* We don't have a parallel flash chip there */ #include <config_cmd_default.h>
#ifdef CONFIG_BFIN_MAC @@ -162,9 +155,7 @@ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_ELF -#undef CONFIG_CMD_FLASH #define CONFIG_CMD_I2C -#undef CONFIG_CMD_IMLS #define CONFIG_CMD_SF
#define CONFIG_BOOTCOMMAND "run ramboot" diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index 52d5d97..ffa195c 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -89,14 +89,6 @@ /* Uncomment next line to use fixed MAC address */ /* #define CONFIG_ETHADDR 02:80:ad:20:31:42 */
#define CONFIG_BOOTCOMMAND "run flashboot" diff --git a/include/configs/blackstamp.h b/include/configs/blackstamp.h index 64fce30..ca1e237 100644 --- a/include/configs/blackstamp.h +++ b/include/configs/blackstamp.h @@ -106,6 +106,12 @@ #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_ENV_OVERWRITE 1
+/* Even though Rev C boards have Parallel Flash + * We aren't supporting it. Newer versions of the + * hardware don't support Parallel Flash at all. + */ +#define CONFIG_SYS_NO_FLASH + #include <config_cmd_default.h>
#ifdef CONFIG_SMC91111 @@ -236,13 +242,4 @@ #define CONFIG_EBIU_SDRRC_VAL 0x268 #define CONFIG_EBIU_SDGCTL_VAL 0x911109
-/* Even though Rev C boards have Parallel Flash - * We aren't supporting it. Newer versions of the - * hardware don't support Parallel Flash at all. - */ -#define CONFIG_SYS_NO_FLASH -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_JFFS2 -#undef CONFIG_CMD_FLASH - #endif diff --git a/include/configs/blackvme.h b/include/configs/blackvme.h index f2dc6aa..6429413 100644 --- a/include/configs/blackvme.h +++ b/include/configs/blackvme.h @@ -156,6 +156,11 @@ #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_AUTO_COMPLETE 1
+/* + * No Parallel Flash on this board + */ +#define CONFIG_SYS_NO_FLASH + #include <config_cmd_default.h>
#define CONFIG_CMD_BOOTLDR @@ -232,12 +237,4 @@ # define CONFIG_SYS_I2C_SLAVE 0xFE #endif
-/* - * No Parallel Flash on this board - */ -#define CONFIG_SYS_NO_FLASH -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_JFFS2 -#undef CONFIG_CMD_FLASH - #endif diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index fe91c10..90af9db 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -124,6 +124,7 @@ #define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_CMD_CACHE @@ -143,11 +144,8 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING
-#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ -#undef CONFIG_CMD_IMLS /* List all found images */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h index 2c65d74..121f2cd 100644 --- a/include/configs/coreboot.h +++ b/include/configs/coreboot.h @@ -103,6 +103,7 @@ /*----------------------------------------------------------------------- * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH #include <config_cmd_default.h>
#define CONFIG_CMD_BDI @@ -110,10 +111,8 @@ #define CONFIG_CMD_CONSOLE #define CONFIG_CMD_DATE #define CONFIG_CMD_ECHO -#undef CONFIG_CMD_FLASH #define CONFIG_CMD_FPGA #define CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #define CONFIG_CMD_IRQ #define CONFIG_CMD_ITEST #define CONFIG_CMD_LOADB @@ -198,14 +197,6 @@ #define CONFIG_ENV_OVERWRITE
/*----------------------------------------------------------------------- - * FLASH configuration - */ -#define CONFIG_SYS_NO_FLASH -#undef CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_MAX_FLASH_SECT 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 1 - -/*----------------------------------------------------------------------- * Environment configuration */ #define CONFIG_ENV_IS_NOWHERE diff --git a/include/configs/davinci_schmoogie.h b/include/configs/davinci_schmoogie.h index 949174a..19a185f 100644 --- a/include/configs/davinci_schmoogie.h +++ b/include/configs/davinci_schmoogie.h @@ -145,8 +145,6 @@ #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_SETGETDCR -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS
#ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS diff --git a/include/configs/davinci_sffsdr.h b/include/configs/davinci_sffsdr.h index c931ede..2f95adc 100644 --- a/include/configs/davinci_sffsdr.h +++ b/include/configs/davinci_sffsdr.h @@ -138,8 +138,6 @@ #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_SETGETDCR -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS
#ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index eb7c376..9f521c8 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -116,7 +116,6 @@ #define CONFIG_TWL4030_LED 1
/* Board NAND Info */ -#define CONFIG_SYS_NO_FLASH /* no NOR flash */ #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define MTDIDS_DEFAULT "nand0=nand" #define MTDPARTS_DEFAULT "mtdparts=nand:" \ @@ -145,6 +144,7 @@ /* partition */
/* commands to include */ +#define CONFIG_SYS_NO_FLASH /* no NOR flash */ #include <config_cmd_default.h>
#define CONFIG_CMD_DHCP /* DHCP support */ diff --git a/include/configs/dig297.h b/include/configs/dig297.h index 1626b0e..4e4b7a3 100644 --- a/include/configs/dig297.h +++ b/include/configs/dig297.h @@ -115,6 +115,7 @@ #define CONFIG_LZO
#define CONFIG_CMD_FAT /* FAT support */ @@ -130,14 +131,11 @@ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */
-#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ #undef CONFIG_CMD_IMI /* iminfo */ -#undef CONFIG_CMD_IMLS /* List all found images */ #define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #undef CONFIG_CMD_NFS /* NFS support */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/igep00x0.h b/include/configs/igep00x0.h index d2b4b84..37630e2 100644 --- a/include/configs/igep00x0.h +++ b/include/configs/igep00x0.h @@ -98,6 +98,7 @@ #define CONFIG_USBD_PRODUCT_NAME "IGEP"
#define CONFIG_CMD_CACHE @@ -113,10 +114,6 @@ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ #define CONFIG_MTD_DEVICE
-#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ -#undef CONFIG_CMD_IMLS /* List all found images */ - -#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/mcx.h b/include/configs/mcx.h index e190e3e..c839030 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -118,6 +118,7 @@ #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3
#define CONFIG_CMD_EXT2 /* EXT2 Support */ @@ -141,12 +142,9 @@ #define CONFIG_MTD_DEVICE #define CONFIG_CMD_MTDPARTS
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/meesc.h b/include/configs/meesc.h index db1e87d..2f69995 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -105,11 +105,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* NOR flash is not populated, disable it */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_IMLS
#define CONFIG_CMD_PING #define CONFIG_CMD_DHCP @@ -151,9 +151,6 @@ # define DATAFLASH_TCHS (0x1 << 24) #endif
-/* NOR flash is not populated, disable it */ -#define CONFIG_SYS_NO_FLASH - /* NAND flash */ #ifdef CONFIG_CMD_NAND # define CONFIG_NAND_ATMEL diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 49d440b..7e3ad93 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -91,6 +91,7 @@ * Command definition ***********************************************************/
+#define CONFIG_SYS_NO_FLASH /* No NOR flash present */ #include <config_cmd_default.h>
#define CONFIG_CMD_MII @@ -100,12 +101,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_NAND
-/* - * Disabled due to compilation errors in cmd_bootm.c (IMLS seems to require - * that CFG_NO_FLASH is undefined). - */ -#undef CONFIG_CMD_IMLS - #define CONFIG_BOARD_LATE_INIT
#define CONFIG_BOOTDELAY 3 @@ -176,9 +171,6 @@ /*----------------------------------------------------------------------- * FLASH and environment organization */ -/* No NOR flash present */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_OFFSET_REDUND 0x60000 diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 1477b21..537883f 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -133,9 +133,9 @@ * Command definition ***********************************************************/
-#include <config_cmd_default.h> +#define CONFIG_SYS_NO_FLASH
-#undef CONFIG_CMD_IMLS +#include <config_cmd_default.h>
@@ -237,8 +237,6 @@ /*----------------------------------------------------------------------- * FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index f48a41e..22d0af7 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -83,10 +83,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
/* Command definition */ +#define CONFIG_SYS_NO_FLASH #include <config_cmd_default.h>
-#undef CONFIG_CMD_IMLS - #define CONFIG_BOOTDELAY 3
#define CONFIG_ETHPRIME "smc911x" @@ -179,8 +178,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index a77e5b2..7174b5f 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -97,10 +97,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
#define CONFIG_ETHPRIME "FEC0" @@ -186,8 +185,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 34a4edd..d02dff4 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -92,10 +92,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
#define CONFIG_ETHPRIME "FEC0" @@ -184,8 +183,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index a04db3f..d60d1a9 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -86,10 +86,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
#define CONFIG_ETHPRIME "FEC0" @@ -177,8 +176,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index 0962d3c..9570edb 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -73,10 +73,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
#define CONFIG_LOADADDR 0x10800000 @@ -160,8 +159,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 8bc8a83..0471394 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -104,10 +104,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
#define CONFIG_LOADADDR 0x10800000 @@ -191,8 +190,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_ENV_SIZE (8 * 1024)
#define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/nhk8815.h b/include/configs/nhk8815.h index 20db397..9e09b8c 100644 --- a/include/configs/nhk8815.h +++ b/include/configs/nhk8815.h @@ -36,16 +36,13 @@ #define CONFIG_SKIP_LOWLEVEL_INIT /* we have already been loaded to RAM */
/* commands */ +#define CONFIG_SYS_NO_FLASH /* There is no NOR flash */ #include <config_cmd_default.h>
#define CONFIG_CMD_NET #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP #define CONFIG_CMD_NFS -/* There is no NOR flash, so undefine these commands */ -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS -#define CONFIG_SYS_NO_FLASH /* There is NAND storage */ #define CONFIG_NAND_NOMADIK #define CONFIG_CMD_JFFS2 diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index d3a0122..d1a9e41 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -144,6 +144,7 @@
#define CONFIG_CMD_CACHE @@ -168,12 +169,9 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_SETEXPR /* Evaluate expressions */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 01360f6..d16a994 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -102,6 +102,7 @@ #define CONFIG_DOS_PARTITION
#define CONFIG_CMD_CACHE @@ -124,12 +125,8 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_SETECPR /* Evaluate expressions */
-#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ #undef CONFIG_CMD_IMI /* iminfo */ -#undef CONFIG_CMD_IMLS /* List all found images */ - -#define CONFIG_SYS_NO_FLASH
/* * I2C diff --git a/include/configs/omap3_mvblx.h b/include/configs/omap3_mvblx.h index b819d21..42665ba 100644 --- a/include/configs/omap3_mvblx.h +++ b/include/configs/omap3_mvblx.h @@ -119,10 +119,8 @@ #define CONFIG_USBD_MANUFACTURER "MATRIX VISION GmbH" #define CONFIG_USBD_PRODUCT_NAME "mvBlueLYNX-X"
-/* no FLASH available */ -#define CONFIG_SYS_NO_FLASH - /* commands to include */ +#define CONFIG_SYS_NO_FLASH /* No CFI flash */ #include <config_cmd_default.h>
#define CONFIG_CMD_CACHE @@ -132,7 +130,6 @@ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_IMI /* iminfo */ -#undef CONFIG_CMD_IMLS /* List all found images */ #define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #define CONFIG_CMD_NFS /* NFS support */ #define CONFIG_CMD_DHCP diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 64adc74..b3fcd9c 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -90,6 +90,7 @@ #define CONFIG_DOS_PARTITION
#define CONFIG_CMD_CACHE @@ -101,14 +102,11 @@ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */
-#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ #undef CONFIG_CMD_IMI /* iminfo */ -#undef CONFIG_CMD_IMLS /* List all found images */ #undef CONFIG_CMD_NFS /* NFS support */ #define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index d02f338..4fc131f 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -105,6 +105,7 @@ #define CONFIG_DOS_PARTITION 1
#define CONFIG_CMD_EXT2 /* EXT2 Support */ @@ -115,14 +116,11 @@ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_CACHE /* Cache control */
-#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ #undef CONFIG_CMD_IMI /* iminfo */ -#undef CONFIG_CMD_IMLS /* List all found images */ #undef CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #undef CONFIG_CMD_NFS /* NFS support */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 17608f5..f3c3b49 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -115,6 +115,7 @@ #define CONFIG_USBD_PRODUCT_NAME "Zoom1"
/* commands to include */ +#define CONFIG_SYS_NO_FLASH #include <config_cmd_default.h>
#define CONFIG_CMD_EXT2 /* EXT2 Support */ @@ -126,14 +127,11 @@ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* Enable lock/unlock support */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index b60ece3..cf83201 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -138,6 +138,7 @@ #define CONFIG_USBD_PRODUCT_NAME "Zoom2"
#define CONFIG_CMD_FAT /* FAT support */ @@ -146,14 +147,11 @@ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* Enable lock/unlock support */
-#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index 5507c8f..f00f2de 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -117,13 +117,11 @@ #define CONFIG_USB_TTY 1 #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
-/* Flash */ -#define CONFIG_SYS_NO_FLASH 1 - /* clocks */ #define CONFIG_SYS_CLOCKS_ENABLE_ALL
/* Enabled commands */ @@ -136,7 +134,6 @@ #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ -#undef CONFIG_CMD_IMLS /* List all found images */
/* * Environment setup diff --git a/include/configs/omap5_evm.h b/include/configs/omap5_evm.h index 38b5028..dc12e31 100644 --- a/include/configs/omap5_evm.h +++ b/include/configs/omap5_evm.h @@ -117,14 +117,12 @@
-/* Flash */ -#define CONFIG_SYS_NO_FLASH - /* Cache */ #define CONFIG_SYS_CACHELINE_SIZE 64 #define CONFIG_SYS_CACHELINE_SHIFT 6
/* Enabled commands */ @@ -138,7 +136,6 @@ #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ -#undef CONFIG_CMD_IMLS /* List all found images */
/* * Environment setup diff --git a/include/configs/origen.h b/include/configs/origen.h index 8ede825..7baa2cf 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -80,6 +80,7 @@ #define CONFIG_ENV_OVERWRITE
/* Command definition*/ +#define CONFIG_SYS_NO_FLASH #include <config_cmd_default.h>
#define CONFIG_CMD_PING @@ -135,8 +136,6 @@ #define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH 1 -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for ORIGEN"
#ifdef CONFIG_USE_IRQ diff --git a/include/configs/otc570.h b/include/configs/otc570.h index 8599378..39fcd13 100644 --- a/include/configs/otc570.h +++ b/include/configs/otc570.h @@ -155,10 +155,10 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* NOR flash is not populated */ #include <config_cmd_default.h> #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_IMLS
#define CONFIG_CMD_PING #define CONFIG_CMD_DHCP @@ -202,9 +202,6 @@ # define DATAFLASH_TCHS (0x1 << 24) #endif
-/* NOR flash is not populated, disable it */ -#define CONFIG_SYS_NO_FLASH - /* NAND flash */ #ifdef CONFIG_CMD_NAND # define CONFIG_NAND_ATMEL diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 4779878..263a85b 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -87,9 +87,9 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* NOR flash is not available */ #include <config_cmd_default.h> #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_IMLS
#define CONFIG_CMD_CACHE #define CONFIG_CMD_PING 1 @@ -109,10 +109,6 @@ #define PHYS_SDRAM 0x70000000 #define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */
-/* NOR flash, not available */ -#define CONFIG_SYS_NO_FLASH 1 -#undef CONFIG_CMD_FLASH - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL diff --git a/include/configs/sbc35_a9g20.h b/include/configs/sbc35_a9g20.h index cdf8659..1577e2a 100644 --- a/include/configs/sbc35_a9g20.h +++ b/include/configs/sbc35_a9g20.h @@ -76,11 +76,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* No NOR flash */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
@@ -125,9 +125,6 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13
-/* NOR flash - no real flash on this board */ -#define CONFIG_SYS_NO_FLASH 1 - /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 9659f9e..4977ba2 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -89,6 +89,7 @@ #define CONFIG_ENV_OVERWRITE
#define CONFIG_CMD_PING @@ -155,8 +156,6 @@ #define CONFIG_SYS_MONITOR_BASE 0x00000000
/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for SMDK5250"
#define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 6663629..4d7b3ae 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -76,10 +76,9 @@ /*********************************************************** * Command definition ***********************************************************/ +#define CONFIG_SYS_NO_FLASH #include <config_cmd_default.h>
-#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_NAND
#define CONFIG_CMD_CACHE @@ -203,8 +202,6 @@ /*----------------------------------------------------------------------- * FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH 1 - #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* 256 KiB */ #define CONFIG_IDENT_STRING " for SMDKC100"
diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index cb3c674..c5dc48a 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -172,7 +172,6 @@ #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 37eb87b..0e03cf4 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -109,6 +109,7 @@ /* #define CONFIG_EHCI_DCACHE */
#define CONFIG_CMD_CACHE @@ -125,10 +126,6 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_USB
-#undef CONFIG_CMD_FLASH /* only NAND on the SOM */ -#undef CONFIG_CMD_IMLS - -#define CONFIG_SYS_NO_FLASH #define CONFIG_HARD_I2C #define CONFIG_SYS_I2C_SPEED 400000 #define CONFIG_SYS_I2C_SLAVE 1 diff --git a/include/configs/tegra2-common.h b/include/configs/tegra2-common.h index 837f859..ac5f05f 100644 --- a/include/configs/tegra2-common.h +++ b/include/configs/tegra2-common.h @@ -98,13 +98,12 @@ #define TEGRA_I2C_NUM_CONTROLLERS 4
/* include default commands */ +#define CONFIG_SYS_NO_FLASH #include <config_cmd_default.h>
/* remove unused commands */ -#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration support */ #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_NFS /* NFS support */ #undef CONFIG_CMD_NET /* network support */
@@ -113,8 +112,6 @@ #define CONFIG_COMMAND_HISTORY #define CONFIG_AUTO_COMPLETE
-#define CONFIG_SYS_NO_FLASH - /* Environment information */ #define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttyS0,115200n8\0" \ diff --git a/include/configs/tny_a9260.h b/include/configs/tny_a9260.h index 0043926..078b9cc 100644 --- a/include/configs/tny_a9260.h +++ b/include/configs/tny_a9260.h @@ -82,11 +82,11 @@ /* * Command line configuration. */ +#define CONFIG_SYS_NO_FLASH /* No NOR flash */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS @@ -124,9 +124,6 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13
-/* NOR flash - no real flash on this board */ -#define CONFIG_SYS_NO_FLASH - #define CONFIG_DOS_PARTITION #define CONFIG_CMD_FAT
diff --git a/include/configs/vct.h b/include/configs/vct.h index 9ddc7b1..5116e18 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -145,11 +145,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* re-init HCD after CMD_RESET */ #endif /* CONFIG_CMD_USB */
-#if !defined(CONFIG_VCT_NOR) -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS -#endif - #if defined(CONFIG_VCT_NAND) #define CONFIG_CMD_NAND #endif diff --git a/include/configs/vision2.h b/include/configs/vision2.h index f6904f3..946fe61 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -142,10 +142,10 @@ * Command definition ***********************************************************/
#define CONFIG_CMD_SPI -#undef CONFIG_CMD_IMLS
@@ -207,8 +207,6 @@ #define CONFIG_SYS_DDR_CLKSEL 0 #define CONFIG_SYS_CLKTL_CBCDR 0x19239100
-#define CONFIG_SYS_NO_FLASH - /* * Framebuffer and LCD */ diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index bd7bac0..43308fd 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -32,26 +32,6 @@ #define CONFIG_SYS_MONITOR_LEN (192 * 1024) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024)
-/*Cmd*/ -#include <config_cmd_default.h> -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DIAG -#define CONFIG_CMD_ELF -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_REGINFO -#undef CONFIG_CMD_JFFS2 -#undef CONFIG_CMD_MTDPARTS -#undef CONFIG_CMD_SPI -#undef CONFIG_CMD_I2C -#undef CONFIG_CMD_DTT -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_PING -#undef CONFIG_CMD_DHCP -#undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_NFS - /*Misc*/ #define CONFIG_BOOTDELAY 5/* autoboot after 5 seconds */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ @@ -135,4 +115,22 @@ #endif #endif
+/*Cmd*/ +#include <config_cmd_default.h> +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_REGINFO +#undef CONFIG_CMD_MTDPARTS +#undef CONFIG_CMD_SPI +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_DTT +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_PING +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_NFS + #endif /* __CONFIG_H */
Dear Tom Rini,
s/which it is clear when/where it is clear that/ ?
I'm not sure if I like that. It makes the code not easier to understand, but actually less obvious.
- Command line configuration.
Logically, it makes more sense to me to look for the NO_FLASH setting close to where we are dfinging such things - the relation to the "Command line configuration" is pretty obscure.
- FLASH on the Local Bus
That's even worse here.
I actually tend to believe it is a bad idea to have the #ifdef for CONFIG_SYS_NO_FLASH in <config_cmd_default.h>
Sorry, but I don't think this patch is a good idea.
On 04/13/2012 11:22 PM, Wolfgang Denk wrote:
Dear Tom Rini,
So, at the end of the day it's an artifact of using cpp to make our configs rather than something like Kconfig.
*/ +#define CONFIG_SYS_NO_FLASH /* There is no FLASH memory */ #include<config_cmd_default.h>
I agree. Some boards are laid out like this already, and in my re-factoring of some of the TI parts config files,
*/ +#define CONFIG_SYS_NO_FLASH #include<config_cmd_default.h> -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_FLASH
I actually tend to believe it is a bad idea to have the #ifdef for CONFIG_SYS_NO_FLASH in<config_cmd_default.h>
And perhaps we should drop IMLS/FLASH from config_cmd_default these days?
OK, I'll drop it from the general clean-ups and re-factor the configs I'm focusing on to have cmds done near the end. Thanks!
Dear Tom Rini,
No. Rather I'd like to see "imls" extended to support NAND as well :-)
Thank you for all the work!
On 04/16/2012 01:56 PM, Wolfgang Denk wrote:
Dear Tom Rini,
To be a little serious, with NAND shouldn't one be using ubifs/ubiload?
Igor Grinberg
stefano babic
