[U-Boot] [U-BOOT][PATCH] mmc: remove the hard setting for tran_speed
mmc_set_clock is set to the hard-coding. But i think good that use the tran_speed value.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- drivers/mmc/mmc.c | 13 +++++++------ 1 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index e035012..cba96cf 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1124,9 +1124,9 @@ int mmc_startup(struct mmc *mmc) }
if (mmc->card_caps & MMC_MODE_HS) - mmc_set_clock(mmc, 50000000); + mmc->tran_speed = 50000000; else - mmc_set_clock(mmc, 25000000); + mmc->tran_speed = 25000000; } else { for (width = EXT_CSD_BUS_WIDTH_8; width >= 0; width--) { /* Set the card to use 4 bit*/ @@ -1161,13 +1161,14 @@ int mmc_startup(struct mmc *mmc)
if (mmc->card_caps & MMC_MODE_HS) { if (mmc->card_caps & MMC_MODE_HS_52MHz) - mmc_set_clock(mmc, 52000000); + mmc->tran_speed = 52000000; else - mmc_set_clock(mmc, 26000000); - } else - mmc_set_clock(mmc, 20000000); + mmc->tran_speed = 26000000; + } }
+ mmc_set_clock(mmc, mmc->tran_speed); + /* fill in device description */ mmc->block_dev.lun = 0; mmc->block_dev.type = 0;
Hi Andy.
How do you about this patch? I want to know your thinking. In my case, clock is set to 50MHz, but mmcinfo is produced the "25MHz". Because tran_speed is 25MHz. But mmc->card_caps is set to MMC_MODE_HS and MMC_MODE_HS_52MHZ. So we should be see the wrong information with mmcinfo.
Best Regards, Jaehoon Chung
2012/3/27 Jaehoon Chung jh80.chung@samsung.com:
- mmc->tran_speed = 50000000;
else
- mmc->tran_speed = 25000000;
- mmc->tran_speed = 52000000;
else
- } else
- mmc->tran_speed = 26000000;
- mmc_set_clock(mmc, mmc->tran_speed);
/* fill in device description */ mmc->block_dev.lun = 0; mmc->block_dev.type = 0; -- 1.7.4.1 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
else
- } else
Why did you remove the outer else clause, here (the one that set the speed to 20000000)?
Hi Andy.
} else
If card->caps didn't set MMC_MODE_HS, then it's set to mmc->tran_speed. That value is assigned from freq * mult.
I think that is reasonable..if set to 20000000 here, then why need freq & mult?
On Mon, May 7, 2012 at 9:51 PM, Jaehoon Chung jh80.chung@samsung.com wrote:
Hi Andy.
else
- } else
Ok, that's probably fine, then.
Andy Fleming
Jae hoon Chung
Jaehoon Chung
