[U-Boot] [PATCH v4 1/2] mkimage: Fix missing free() in show_valid_options()
The allocated memory should be freed. Fix it.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Coverity (CID: 150963) Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
tools/mkimage.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/mkimage.c b/tools/mkimage.c index 3c594a0..521fa80 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -64,6 +64,7 @@ static int show_valid_options(enum ih_category category) genimg_get_cat_name(category, item)); } fprintf(stderr, "\n"); + free(order);
return 0; }
Coverity complains that this can overflow. If we later increase the size of one of the strings in the table, it could happen.
Adjust the code to protect against this.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Coverity (CID: 150964) ---
Changes in v4: - Add missing [] (tested)
Changes in v3: - Adjust to deal with what strncpy() actually does (I think)
Changes in v2: - Drop unwanted #include
common/image.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/common/image.c b/common/image.c index 0e86c13..7604494 100644 --- a/common/image.c +++ b/common/image.c @@ -587,10 +587,12 @@ const table_entry_t *get_table_entry(const table_entry_t *table, int id)
static const char *unknown_msg(enum ih_category category) { + static const char unknown_str[] = "Unknown "; static char msg[30];
- strcpy(msg, "Unknown "); - strcat(msg, table_info[category].desc); + strcpy(msg, unknown_str); + strncat(msg, table_info[category].desc, + sizeof(msg) - sizeof(unknown_str));
return msg; }
