[U-Boot] [PATCH v2 3/3] ppc/p1_p1_RDB: DDR Relocation support for NAND/SD/eSPI Boot
This patch adds support to boot from NAND/eSDHC/eSPI using DDR on P1 & P2 RDB platforms. Specifically this support needed when L2 Cache size is less than 512K.
For this one define "CONFIG_L2_RELOC" has added in platform config file.
Signed-off-by: Dipen Dudhat dipen.dudhat@freescale.com --- - Applies to http://git.denx.de/u-boot.git board/freescale/p1_p2_rdb/config.mk | 8 +++ board/freescale/p1_p2_rdb/ddr.c | 3 + board/freescale/p1_p2_rdb/tlb.c | 9 +++- include/configs/P1_P2_RDB.h | 27 +++++++++++ nand_spl/board/freescale/p1_p2_rdb/nand_boot.c | 59 ++++++++++++++++++++++++ 5 files changed, 105 insertions(+), 1 deletions(-)
diff --git a/board/freescale/p1_p2_rdb/config.mk b/board/freescale/p1_p2_rdb/config.mk index 0f7a048..e76b59c 100644 --- a/board/freescale/p1_p2_rdb/config.mk +++ b/board/freescale/p1_p2_rdb/config.mk @@ -33,12 +33,20 @@ endif
ifeq ($(CONFIG_MK_SDCARD), y) TEXT_BASE = $(CONFIG_RAMBOOT_TEXT_BASE) +ifdef CONFIG_L2_RELOC RESET_VECTOR_ADDRESS = 0xf8fffffc +else +RESET_VECTOR_ADDRESS = 0x1107F000 +endif endif
ifeq ($(CONFIG_MK_SPIFLASH), y) TEXT_BASE = $(CONFIG_RAMBOOT_TEXT_BASE) +ifdef CONFIG_L2_RELOC RESET_VECTOR_ADDRESS = 0xf8fffffc +else +RESET_VECTOR_ADDRESS = 0x1107F000 +endif endif
ifndef TEXT_BASE diff --git a/board/freescale/p1_p2_rdb/ddr.c b/board/freescale/p1_p2_rdb/ddr.c index 37c4b0a..884ff3f 100644 --- a/board/freescale/p1_p2_rdb/ddr.c +++ b/board/freescale/p1_p2_rdb/ddr.c @@ -246,6 +246,9 @@ phys_size_t initdram(int board_type) { phys_size_t dram_size = 0;
+#if defined(CONFIG_SYS_RAMBOOT) && !defined(CONFIG_L2_RELOC) + return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; +#endif dram_size = fixed_sdram(); set_ddr_laws(0, dram_size, LAW_TRGT_IF_DDR_1);
diff --git a/board/freescale/p1_p2_rdb/tlb.c b/board/freescale/p1_p2_rdb/tlb.c index 0009913..c250e3e 100644 --- a/board/freescale/p1_p2_rdb/tlb.c +++ b/board/freescale/p1_p2_rdb/tlb.c @@ -78,7 +78,8 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 6, BOOKE_PAGESZ_1M, 1),
-#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L2_ADDR) +#if defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_SYS_INIT_L2_ADDR) /* *I*G - L2SRAM */ SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR, CONFIG_SYS_INIT_L2_ADDR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -87,6 +88,12 @@ struct fsl_e_tlb_entry tlb_table[] = { CONFIG_SYS_INIT_L2_ADDR_PHYS + 0x40000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 8, BOOKE_PAGESZ_256K, 1), +#else + /* *I*G - DDR */ + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 7, BOOKE_PAGESZ_1G, 1) +#endif #endif };
diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 310242e..e8cf902 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -43,20 +43,35 @@ #define CONFIG_P2020 #endif
+/* Remove this define to Boot using DDR instead of L2 SRAM */ +#define CONFIG_L2_RELOC + #ifdef CONFIG_MK_NAND #define CONFIG_NAND_U_BOOT 1 #define CONFIG_RAMBOOT_NAND 1 +#ifdef CONFIG_L2_RELOC #define CONFIG_RAMBOOT_TEXT_BASE 0xf8f82000 +#else +#define CONFIG_RAMBOOT_TEXT_BASE 0x01001000 +#endif #endif
#ifdef CONFIG_MK_SDCARD #define CONFIG_RAMBOOT_SDCARD 1 +#ifdef CONFIG_L2_RELOC #define CONFIG_RAMBOOT_TEXT_BASE 0xf8f80000 +#else +#define CONFIG_RAMBOOT_TEXT_BASE 0x11000000 +#endif #endif
#ifdef CONFIG_MK_SPIFLASH #define CONFIG_RAMBOOT_SPIFLASH 1 +#ifdef CONFIG_L2_RELOC #define CONFIG_RAMBOOT_TEXT_BASE 0xf8f80000 +#else +#define CONFIG_RAMBOOT_TEXT_BASE 0x11000000 +#endif #endif
/* High Level Configuration Options */ @@ -101,6 +116,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Config the L2 Cache as L2 SRAM */ +#ifdef CONFIG_L2_RELOC #define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_INIT_L2_ADDR_PHYS 0xff8f80000ull @@ -109,6 +125,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif #define CONFIG_SYS_L2_SIZE (512 << 10) #define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) +#endif
/* * Base addresses -- Note these are effective addresses where the @@ -233,6 +250,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024)
/* NAND boot: 4K NAND loader config */ +#ifdef CONFIG_L2_RELOC #define CONFIG_SYS_NAND_SPL_SIZE 0x1000 #define CONFIG_SYS_NAND_U_BOOT_SIZE ((512 << 10) - 0x2000) #define CONFIG_SYS_NAND_U_BOOT_DST (CONFIG_SYS_INIT_L2_ADDR) @@ -240,6 +258,15 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_NAND_U_BOOT_OFFS (0) #define CONFIG_SYS_NAND_U_BOOT_RELOC (CONFIG_SYS_INIT_L2_END - 0x2000) #define CONFIG_SYS_NAND_U_BOOT_RELOC_SP ((CONFIG_SYS_INIT_L2_END - 1) & ~0xF) +#else +#define CONFIG_SYS_NAND_SPL_SIZE 0x1000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE ((512 << 10) + CONFIG_SYS_NAND_SPL_SIZE) +#define CONFIG_SYS_NAND_U_BOOT_DST (0x01000000 - CONFIG_SYS_NAND_SPL_SIZE) +#define CONFIG_SYS_NAND_U_BOOT_START 0x01000000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS (0) +#define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000 +#define CONFIG_SYS_NAND_U_BOOT_RELOC_SP (CONFIG_SYS_NAND_U_BOOT_RELOC + 0x10000) +#endif
/* NAND flash config */ #define CONFIG_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE_PHYS \ diff --git a/nand_spl/board/freescale/p1_p2_rdb/nand_boot.c b/nand_spl/board/freescale/p1_p2_rdb/nand_boot.c index bd513b8..23a92b4 100644 --- a/nand_spl/board/freescale/p1_p2_rdb/nand_boot.c +++ b/nand_spl/board/freescale/p1_p2_rdb/nand_boot.c @@ -39,6 +39,60 @@
DECLARE_GLOBAL_DATA_PTR;
+#if !defined(CONFIG_L2_RELOC) +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000003F +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014202 +#define CONFIG_SYS_DDR_CS0_CONFIG_2 0x00000000 +#define CONFIG_SYS_DDR_CONTROL 0x43000000 /* Type = DDR2*/ +#define CONFIG_SYS_DDR_CONTROL_2 0x24401000 + +#define CONFIG_SYS_DDR_TIMING_3_667 0x00030000 +#define CONFIG_SYS_DDR_TIMING_0_667 0x55770802 +#define CONFIG_SYS_DDR_TIMING_1_667 0x5f599543 +#define CONFIG_SYS_DDR_TIMING_2_667 0x0fa074d1 +#define CONFIG_SYS_DDR_CLK_CTRL_667 0x02800000 +#define CONFIG_SYS_DDR_MODE_1_667 0x00040852 +#define CONFIG_SYS_DDR_MODE_2_667 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL_667 0x0a280100 + +#define udelay(x) {int i, j; for (i = 0; i < x; i++) for (j = 0; j < 10000; j++); } + +void initsdram(void) +{ + + volatile ccsr_ddr_t *ddr= (ccsr_ddr_t *)CONFIG_SYS_MPC85xx_DDR_ADDR; + int d_init, dbw; + volatile ccsr_gpio_t *pgpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR); + unsigned int ddr_size; + sys_info_t sysinfo; + phys_size_t dram_size = 0; + + set_next_law(0,LAW_SIZE_1G , LAW_TRGT_IF_DDR_1); + + ddr->cs0_bnds = CONFIG_SYS_DDR_CS0_BNDS; + ddr->cs0_config = CONFIG_SYS_DDR_CS0_CONFIG; + ddr->cs0_config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2; + + ddr->timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_667; + ddr->timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_667; + ddr->timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_667; + ddr->timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_667; + ddr->sdram_mode = CONFIG_SYS_DDR_MODE_1_667; + ddr->sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_667; + ddr->sdram_interval = CONFIG_SYS_DDR_INTERVAL_667; + ddr->sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_667; + ddr->sdram_cfg = CONFIG_SYS_DDR_CONTROL; + ddr->sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2; + + asm("sync;isync"); + + udelay(500); + + ddr->sdram_cfg |= 0x80000000; + +} +#endif + void board_init_f(ulong bootflag) { uint plat_ratio, bus_clk, sys_clk; @@ -69,6 +123,11 @@ void board_init_f(ulong bootflag)
puts("\nNAND boot... ");
+#ifndef CONFIG_L2_RELOC + /* board specific DDR initialization */ + initsdram(); +#endif + /* copy code to DDR and jump to it - this should not return */ /* NOTE - code has to be copied out of NAND buffer before * other blocks can be read.
CONFIG_L2_RELOC doesn't make any sense. I think this should be CONFIG_SYS_FSL_BOOT_DDR or something like that.
Also should we set it explicitly based on which P1xxx or P2xxx we are since we know how much L2 they have.
board/freescale/p1_p2_rdb/config.mk | 8 +++ board/freescale/p1_p2_rdb/ddr.c | 3 + board/freescale/p1_p2_rdb/tlb.c | 9 +++- include/configs/P1_P2_RDB.h | 27 +++++++++++ nand_spl/board/freescale/p1_p2_rdb/nand_boot.c | 59 +++++++++++++++ +++++++++ 5 files changed, 105 insertions(+), 1 deletions(-)
diff --git a/board/freescale/p1_p2_rdb/config.mk b/board/freescale/ p1_p2_rdb/config.mk index 0f7a048..e76b59c 100644 --- a/board/freescale/p1_p2_rdb/config.mk +++ b/board/freescale/p1_p2_rdb/config.mk @@ -33,12 +33,20 @@ endif
ifndef TEXT_BASE diff --git a/board/freescale/p1_p2_rdb/ddr.c b/board/freescale/ p1_p2_rdb/ddr.c index 37c4b0a..884ff3f 100644 --- a/board/freescale/p1_p2_rdb/ddr.c +++ b/board/freescale/p1_p2_rdb/ddr.c @@ -246,6 +246,9 @@ phys_size_t initdram(int board_type) { phys_size_t dram_size = 0;
- return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024;
diff --git a/board/freescale/p1_p2_rdb/tlb.c b/board/freescale/ p1_p2_rdb/tlb.c index 0009913..c250e3e 100644 --- a/board/freescale/p1_p2_rdb/tlb.c +++ b/board/freescale/p1_p2_rdb/tlb.c @@ -78,7 +78,8 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 6, BOOKE_PAGESZ_1M, 1),
- /* *I*G - DDR */
- SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE,
+#endif #endif };
- Config the L2 Cache as L2 SRAM
- Base addresses -- Note these are effective addresses where the
- & ~0xF)
/* NAND flash config */ #define CONFIG_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE_PHYS \ diff --git a/nand_spl/board/freescale/p1_p2_rdb/nand_boot.c b/ nand_spl/board/freescale/p1_p2_rdb/nand_boot.c index bd513b8..23a92b4 100644 --- a/nand_spl/board/freescale/p1_p2_rdb/nand_boot.c +++ b/nand_spl/board/freescale/p1_p2_rdb/nand_boot.c @@ -39,6 +39,60 @@
- volatile ccsr_ddr_t *ddr= (ccsr_ddr_t *)CONFIG_SYS_MPC85xx_DDR_ADDR;
- int d_init, dbw;
- volatile ccsr_gpio_t *pgpio = (void *)
- unsigned int ddr_size;
- sys_info_t sysinfo;
- phys_size_t dram_size = 0;
- set_next_law(0,LAW_SIZE_1G , LAW_TRGT_IF_DDR_1);
Can we not use fsl_ddr_set_memctl_regs()? If not these should be using out_be32()
- ddr->cs0_bnds = CONFIG_SYS_DDR_CS0_BNDS;
- ddr->cs0_config = CONFIG_SYS_DDR_CS0_CONFIG;
- ddr->cs0_config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2;
- ddr->timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_667;
- ddr->timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_667;
- ddr->timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_667;
- ddr->timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_667;
- ddr->sdram_mode = CONFIG_SYS_DDR_MODE_1_667;
- ddr->sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_667;
- ddr->sdram_interval = CONFIG_SYS_DDR_INTERVAL_667;
- ddr->sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_667;
- ddr->sdram_cfg = CONFIG_SYS_DDR_CONTROL;
- ddr->sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2;
- asm("sync;isync");
- udelay(500);
- ddr->sdram_cfg |= 0x80000000;
+} +#endif
- /* board specific DDR initialization */
- initsdram();
- /* copy code to DDR and jump to it - this should not return */ /* NOTE - code has to be copied out of NAND buffer before
- other blocks can be read.
-- 1.5.6.3
-----Original Message----- From: Kumar Gala [mailto:galak@kernel.crashing.org] Sent: Thursday, October 08, 2009 7:33 PM To: Dudhat Dipen-B09055 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH v2 3/3] ppc/p1_p1_RDB: DDR Relocation support for NAND/SD/eSPI Boot
[snip]
- int d_init, dbw;
Why can't we use set_next_law / set_law function here??? I mean at the end they are using out_be32() for setting up LAW registers..
- Dipen
- udelay(500);
+} +#endif
- initsdram();
-- 1.5.6.3
- int d_init, dbw;
- Dipen
I'm confused about what you are saying here.
- k
How is this the RESET_VECTOR_ADDRESS? This makes no sense.
+endif endif
- k
Dipen Dudhat
Dudhat Dipen-B09055
Kumar Gala
