[U-Boot] [PATCH v1] spl: eMMC/SD: Provide one __weak spl_boot_mode() function
The goal of this patch is to clean up the code related to choosing spl MMC boot mode.
The spl_boot_mode() now is called only in spl_mmc_load_image() function, which is only compiled in if CONFIG_SPL_MMC_SUPPORT is enabled.
To achieve the goal, all per mach/arch implementations eligible for unification has been replaced with one __weak implementation.
Signed-off-by: Lukasz Majewski lukma@denx.de
--- Comments regarding cleanup (to help maintainers assessment if those changes break anything):
Implementations necessary to stay as is: ---------------------------------------- - SW fix for broken ROM boot code arch/arm/mach-uniphier/mmc-boot-mode.c
- Omap specific adjustments: arch/arm/mach-omap2/boot-common.c
Below archs had a bit off-standard approach, but were eligible for using the __weak function: -------------------- - at91 -> check if proper configs flags in the weak function are set: arch/arm/mach-at91/spl.c
- zyncmp -> the BOOT_DEVICE_RAM return of spl_boot_mode seems like an error (will hang in spl_mmc_load_image() anyway) arch/arm/cpu/armv8/zynqmp/spl.c
- fsl -> here we had a return of BOOT_DEVICE_NAND, but the spl_boot_mode is eMMC/SD card specific (will hang in spl_mmc_load_image() anyway)
arch/arm/cpu/armv8/fsl-layerscape/spl.c arch/arm/cpu/armv7/ls102xa/spl.c arch/arm/cpu/arm1136/mx35/generic.c
Test HW:
iMX6Q - display5 board
--- arch/arm/cpu/arm1136/mx35/generic.c | 21 --------------------- arch/arm/cpu/armv7/ls102xa/spl.c | 17 ----------------- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 17 ----------------- arch/arm/cpu/armv8/zynqmp/spl.c | 14 -------------- arch/arm/mach-at91/spl.c | 15 --------------- arch/arm/mach-davinci/spl.c | 5 ----- arch/arm/mach-imx/spl.c | 23 ----------------------- arch/arm/mach-mvebu/spl.c | 7 ------- arch/arm/mach-rockchip/rk3188-board-spl.c | 5 ----- arch/arm/mach-rockchip/rk3288-board-spl.c | 5 ----- arch/arm/mach-rockchip/rk3368-board-spl.c | 5 ----- arch/arm/mach-rockchip/rk3399-board-spl.c | 5 ----- arch/arm/mach-socfpga/spl.c | 11 ----------- arch/arm/mach-sunxi/board.c | 6 ------ arch/arm/mach-zynq/spl.c | 7 ------- common/spl/spl_mmc.c | 11 +++++++++++ 16 files changed, 11 insertions(+), 163 deletions(-)
diff --git a/arch/arm/cpu/arm1136/mx35/generic.c b/arch/arm/cpu/arm1136/mx35/generic.c index 5297d62d00..4dcfc72656 100644 --- a/arch/arm/cpu/arm1136/mx35/generic.c +++ b/arch/arm/cpu/arm1136/mx35/generic.c @@ -524,24 +524,3 @@ u32 spl_boot_device(void)
return BOOT_DEVICE_NONE; } - -#ifdef CONFIG_SPL_BUILD -u32 spl_boot_mode(const u32 boot_device) -{ - switch (spl_boot_device()) { - case BOOT_DEVICE_MMC1: -#ifdef CONFIG_SPL_FAT_SUPPORT - return MMCSD_MODE_FS; -#else - return MMCSD_MODE_RAW; -#endif - break; - case BOOT_DEVICE_NAND: - return 0; - break; - default: - puts("spl: ERROR: unsupported device\n"); - hang(); - } -} -#endif diff --git a/arch/arm/cpu/armv7/ls102xa/spl.c b/arch/arm/cpu/armv7/ls102xa/spl.c index 1246eed2ca..1e4a1641cb 100644 --- a/arch/arm/cpu/armv7/ls102xa/spl.c +++ b/arch/arm/cpu/armv7/ls102xa/spl.c @@ -14,20 +14,3 @@ u32 spl_boot_device(void) #endif return BOOT_DEVICE_NAND; } - -u32 spl_boot_mode(const u32 boot_device) -{ - switch (spl_boot_device()) { - case BOOT_DEVICE_MMC1: -#ifdef CONFIG_SPL_FAT_SUPPORT - return MMCSD_MODE_FS; -#else - return MMCSD_MODE_RAW; -#endif - case BOOT_DEVICE_NAND: - return 0; - default: - puts("spl: error: unsupported device\n"); - hang(); - } -} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index 4093d15e56..3a74040b97 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -26,23 +26,6 @@ u32 spl_boot_device(void) return 0; }
-u32 spl_boot_mode(const u32 boot_device) -{ - switch (spl_boot_device()) { - case BOOT_DEVICE_MMC1: -#ifdef CONFIG_SPL_FAT_SUPPORT - return MMCSD_MODE_FS; -#else - return MMCSD_MODE_RAW; -#endif - case BOOT_DEVICE_NAND: - return 0; - default: - puts("spl: error: unsupported device\n"); - hang(); - } -} - #ifdef CONFIG_SPL_BUILD
void spl_board_init(void) diff --git a/arch/arm/cpu/armv8/zynqmp/spl.c b/arch/arm/cpu/armv8/zynqmp/spl.c index 41b0070a5e..970ac9b59b 100644 --- a/arch/arm/cpu/armv8/zynqmp/spl.c +++ b/arch/arm/cpu/armv8/zynqmp/spl.c @@ -115,20 +115,6 @@ u32 spl_boot_device(void) return 0; }
-u32 spl_boot_mode(const u32 boot_device) -{ - switch (boot_device) { - case BOOT_DEVICE_RAM: - return 0; - case BOOT_DEVICE_MMC1: - case BOOT_DEVICE_MMC2: - return MMCSD_MODE_FS; - default: - puts("spl: error: unsupported device\n"); - hang(); - } -} - __weak void psu_init(void) { /* diff --git a/arch/arm/mach-at91/spl.c b/arch/arm/mach-at91/spl.c index 7e7e24bbe6..91add921c6 100644 --- a/arch/arm/mach-at91/spl.c +++ b/arch/arm/mach-at91/spl.c @@ -87,18 +87,3 @@ u32 spl_boot_device(void) return BOOT_DEVICE_NONE; } #endif - -u32 spl_boot_mode(const u32 boot_device) -{ - switch (boot_device) { -#if defined(CONFIG_SYS_USE_MMC) || defined(CONFIG_SD_BOOT) - case BOOT_DEVICE_MMC1: - case BOOT_DEVICE_MMC2: - return MMCSD_MODE_FS; - break; -#endif - case BOOT_DEVICE_NONE: - default: - hang(); - } -} diff --git a/arch/arm/mach-davinci/spl.c b/arch/arm/mach-davinci/spl.c index 564c2008e0..4c74db9ed0 100644 --- a/arch/arm/mach-davinci/spl.c +++ b/arch/arm/mach-davinci/spl.c @@ -45,11 +45,6 @@ void spl_board_init(void) preloader_console_init(); }
-u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_RAW; -} - u32 spl_boot_device(void) { switch (davinci_syscfg_regs->bootcfg) { diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index 6c16872f59..08a7e0071f 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -130,29 +130,6 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) } #endif
-#if defined(CONFIG_SPL_MMC_SUPPORT) -/* called from spl_mmc to see type of boot mode for storage (RAW or FAT) */ -u32 spl_boot_mode(const u32 boot_device) -{ - switch (spl_boot_device()) { - /* for MMC return either RAW or FAT mode */ - case BOOT_DEVICE_MMC1: - case BOOT_DEVICE_MMC2: -#if defined(CONFIG_SPL_FAT_SUPPORT) - return MMCSD_MODE_FS; -#elif defined(CONFIG_SUPPORT_EMMC_BOOT) - return MMCSD_MODE_EMMCBOOT; -#else - return MMCSD_MODE_RAW; -#endif - break; - default: - puts("spl: ERROR: unsupported device\n"); - hang(); - } -} -#endif - #if defined(CONFIG_SECURE_BOOT)
/* diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index d16a62d2dd..a5086f16fb 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -70,13 +70,6 @@ u32 spl_boot_device(void) return get_boot_device(); }
-#ifdef CONFIG_SPL_MMC_SUPPORT -u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_RAW; -} -#endif - void board_init_f(ulong dummy) { int ret; diff --git a/arch/arm/mach-rockchip/rk3188-board-spl.c b/arch/arm/mach-rockchip/rk3188-board-spl.c index 8e3b8ae3ba..74771d3a0b 100644 --- a/arch/arm/mach-rockchip/rk3188-board-spl.c +++ b/arch/arm/mach-rockchip/rk3188-board-spl.c @@ -72,11 +72,6 @@ fallback: return BOOT_DEVICE_MMC1; }
-u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_RAW; -} - static int setup_arm_clock(void) { struct udevice *dev; diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index f64a54843f..f3ea624277 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -78,11 +78,6 @@ fallback: return BOOT_DEVICE_MMC1; }
-u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_RAW; -} - #ifdef CONFIG_SPL_MMC_SUPPORT static int configure_emmc(struct udevice *pinctrl) { diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c index 72d2c97d36..8055ae538f 100644 --- a/arch/arm/mach-rockchip/rk3368-board-spl.c +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -57,11 +57,6 @@ void board_init_f(ulong dummy) } }
-u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_RAW; -} - u32 spl_boot_device(void) { return BOOT_DEVICE_MMC1; diff --git a/arch/arm/mach-rockchip/rk3399-board-spl.c b/arch/arm/mach-rockchip/rk3399-board-spl.c index b96903e70f..d35990efd6 100644 --- a/arch/arm/mach-rockchip/rk3399-board-spl.c +++ b/arch/arm/mach-rockchip/rk3399-board-spl.c @@ -60,11 +60,6 @@ u32 spl_boot_device(void) return boot_device; }
-u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_RAW; -} - #define TIMER_CHN10_BASE 0xff8680a0 #define TIMER_END_COUNT_L 0x00 #define TIMER_END_COUNT_H 0x04 diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl.c index 71bae827a1..9bf3b9a446 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -66,17 +66,6 @@ u32 spl_boot_device(void) } }
-#ifdef CONFIG_SPL_MMC_SUPPORT -u32 spl_boot_mode(const u32 boot_device) -{ -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) - return MMCSD_MODE_FS; -#else - return MMCSD_MODE_RAW; -#endif -} -#endif - #if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 0c60ee04da..1753faec1d 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -260,12 +260,6 @@ u32 spl_boot_device(void) return sunxi_get_boot_device(); }
-/* No confirmation data available in SPL yet. Hardcode bootmode */ -u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_RAW; -} - void board_init_f(ulong dummy) { spl_init(); diff --git a/arch/arm/mach-zynq/spl.c b/arch/arm/mach-zynq/spl.c index 1672fa05c2..32db076409 100644 --- a/arch/arm/mach-zynq/spl.c +++ b/arch/arm/mach-zynq/spl.c @@ -69,13 +69,6 @@ u32 spl_boot_device(void) return mode; }
-#ifdef CONFIG_SPL_MMC_SUPPORT -u32 spl_boot_mode(const u32 boot_device) -{ - return MMCSD_MODE_FS; -} -#endif - #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index b57e0b04e4..351f4edd41 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -281,6 +281,17 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) } #endif
+u32 __weak spl_boot_mode(const u32 boot_device) +{ +#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) + return MMCSD_MODE_FS; +#elif defined(CONFIG_SUPPORT_EMMC_BOOT) + return MMCSD_MODE_EMMCBOOT; +#else + return MMCSD_MODE_RAW; +#endif +} + int spl_mmc_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) {
It always was ;-)
You should run it through Travis at least, to detect if something stopped building.
Test HW:
Hi Marek,
It always was ;-)
But some way forgotten :-)
https://travis-ci.org/lmajewski/u-boot-dfu
All "green".
Test HW:
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
zynqmp
Changes look reasonable.
Acked-by: Michal Simek michal.simek@xilinx.com (For ZynqMP)
M
Test HW:
-#else
-#endif
break;
break;
- default:
hang();
-#else
-#endif
- default:
hang();
-#else
-#endif
- default:
hang();
- default:
hang();
break;
-#endif
- default:
hang();
-#else
-#endif
break;
- default:
hang();
-} -#endif
-} -#endif
-#else
-#endif -} -#endif
-} -#endif
+#else
+#endif +}
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Lukasz Majewski
Michal Simek
Stefano Babic
