[U-Boot] v2015.10-rc2: timer not initialized on Kirkwood
While testing U-Boot v2015.10-rc2 on the Kirkwood-based LaCie boards I noticed that the autoboot counter is not decrementing. It stays stuck at '3' endlessly. After some digging, I found out that this regression is due to the commit: ade741b3896b1a3872ff74437f04b50762d05849 "arm: mvebu: Call timer_init early before PHY and DDR init".
With this commit it appears that the timer initialization is skipped on Kirkwood boards. As a consequence the timer is not ticking and then all the features relying on the timer are most likely broken.
On the Kirkwood boards, the timer_init function is only called from from the ARM init_sequence. SPL support is disabled. The problem is that the patch introduces a static init_done variable (to prevent multiple timer initializations). But while debugging the timer_init function (via JTAG), I noticed that the init_done initial value is not zero. So the function exists without initializing the timer. A possible explanation is that timer_init is called before the U-Boot relocation, when the BSS segment is still not available...
Maybe we should use an initialized variable instead ?
Regards,
Simon
Hi Simon,
Sorry about that. Unfortunately I don't have a Kirkwood target here. So I can't test any of the MVEBU changes on this platform.
Hmmm. I thought that BSS should be available and cleared at that time. But this does not seem to be the case.
Could you please test the small attached patch? If this fixes the problem for you on your Kirkwood board?
If yes, I'll submit it officially to the list for inclusion.
Thanks, Stefan
Hi Stefan,
On Thu, Sep 03, 2015 at 07:28:01AM +0200, Stefan Roese wrote:
Hi Simon,
I can confirm that the attached patch does fix the issue.
Thanks for the quick reply.
Simon
Thanks, Stefan
From 9525d96509e36ae534a15f55afd2eae30f9e000a Mon Sep 17 00:00:00 2001
From: Stefan Roese sr@denx.de Date: Thu, 3 Sep 2015 07:22:42 +0200 Subject: [PATCH] arm: mvebu: timer.c: Explicitly move "init_done" var to data section
As reported by Simon Guinot, commit ade741b3 "arm: mvebu: Call timer_init early before PHY and DDR init" breaks Kirkwood platforms. As the static variable "init_done" is not available at that early boot time. This patch moves it to explicitly to the data section, making it available at that time.
Signed-off-by: Stefan Roese sr@denx.de Reported-by: Simon Guinot simon.guinot@sequanux.org Cc: Luka Perkov luka.perkov@sartura.hr
arch/arm/mach-mvebu/timer.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/timer.c b/arch/arm/mach-mvebu/timer.c index c516c41..5449a89 100644 --- a/arch/arm/mach-mvebu/timer.c +++ b/arch/arm/mach-mvebu/timer.c @@ -41,7 +41,7 @@ #define timestamp gd->arch.tbl #define lastdec gd->arch.lastinc
-static int init_done; +static int init_done __attribute__((section(".data"))) = 0;
/* Timer reload and current value registers */ struct kwtmr_val { -- 2.5.1
Simon Guinot
Stefan Roese
