[PATCH 0/2] Keep PLL power on
There are several PLLs in AST2600 that provide clock sources for various hardware blocks. According to the PLL vendor, the setting sequence was incorrect, since the PLL power should kept on during initialization. This patch series fixes the PLL setting sequence, including the MPLL in the DRAM driver and the others in the clock driver.
Dylan Hung (2): ram: ast2600: Keep MPLL power on clk: ast2600: Keep PLL power on
drivers/clk/aspeed/clk_ast2600.c | 3 +-- drivers/ram/aspeed/sdram_ast2600.c | 6 +++--- 2 files changed, 4 insertions(+), 5 deletions(-)
According to the PLL vendor, we should keep the PLL power on, so we shouldn't toggle the power-down bit during PLL initialization.
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- drivers/ram/aspeed/sdram_ast2600.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/ram/aspeed/sdram_ast2600.c b/drivers/ram/aspeed/sdram_ast2600.c index 18767554123f..d463933363ee 100644 --- a/drivers/ram/aspeed/sdram_ast2600.c +++ b/drivers/ram/aspeed/sdram_ast2600.c @@ -1089,13 +1089,13 @@ static int ast2600_sdrammc_probe(struct udevice *dev) }
reg = readl(&priv->scu->mpll); - reg &= ~(SCU_PLL_BYPASS | SCU_PLL_DIV_MASK | + reg &= ~(SCU_PLL_BYPASS | SCU_PLL_OFF | SCU_PLL_DIV_MASK | SCU_PLL_DENUM_MASK | SCU_PLL_NUM_MASK); - reg |= (SCU_PLL_RST | SCU_PLL_OFF | SCU_MPLL_FREQ_CFG); + reg |= (SCU_PLL_RST | SCU_MPLL_FREQ_CFG); writel(reg, &priv->scu->mpll); writel(SCU_MPLL_EXT_CFG, &priv->scu->mpll_ext); udelay(100); - reg &= ~(SCU_PLL_RST | SCU_PLL_OFF); + reg &= ~SCU_PLL_RST; writel(reg, &priv->scu->mpll);
while ((readl(&priv->scu->mpll_ext) & BIT(31)) == 0)
Reviewed-by: Joel Stanley joel@jms.id.au
reg &= ~SCU_PLL_RST; writel(reg, &priv->scu->mpll); while ((readl(&priv->scu->mpll_ext) & BIT(31)) == 0)
-- 2.25.1
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com Reviewed-by: Joel Stanley joel@jms.id.au
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- drivers/clk/aspeed/clk_ast2600.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/clk/aspeed/clk_ast2600.c b/drivers/clk/aspeed/clk_ast2600.c index 0df1dc3718d3..e5ada5b6d49c 100644 --- a/drivers/clk/aspeed/clk_ast2600.c +++ b/drivers/clk/aspeed/clk_ast2600.c @@ -538,7 +538,7 @@ static uint32_t ast2600_configure_pll(struct ast2600_scu *scu, }
p_cfg->reg.b.bypass = 0; - p_cfg->reg.b.off = 1; + p_cfg->reg.b.off = 0; p_cfg->reg.b.reset = 1;
reg = readl(addr); @@ -549,7 +549,6 @@ static uint32_t ast2600_configure_pll(struct ast2600_scu *scu, /* write extend parameter */ writel(p_cfg->ext_reg, addr_ext); udelay(100); - p_cfg->reg.b.off = 0; p_cfg->reg.b.reset = 0; reg &= ~GENMASK(25, 0); reg |= p_cfg->reg.w;
p_cfg->reg.b.off = 0; p_cfg->reg.b.reset = 1; reg = readl(addr);
-- 2.25.1
Dylan Hung
Joel Stanley
