[PATCH v4 0/8] add the support of sha256_hmac and sha256_hkdf
This serie adds the support of sha256_hmac and sha256_hkdf. A first version was sent several months ago just before the integration of mbedtls. This new version is based on mbedtls.
The first patch of this serie add the support of hkdf using mbedtls.
v4: - fix computation of the hmac - add more test for hmac - move sha256 common functions to sha256_common.c - some cleanup
v3: - also define sha256_hmac for legacy sha256 - add some #if to define function only when needed
Philippe Reynes (8): tools: kwbimage.h: use linux/compiler_attributes.h tools: renesas_spkgimage.h: use linux/compiler_attributes.h mbedtls: enable support of hkdf lib: sha256: move common function to sha256_common.c lib: sha256: add feature sha256_hmac test: lib: add test for sha256_hmac lib: mbedtls: sha256: add support of key derivation test: lib: add test for key derivation
include/u-boot/sha256.h | 24 +++ lib/Makefile | 1 + lib/mbedtls/Kconfig | 14 ++ lib/mbedtls/Makefile | 2 + lib/mbedtls/mbedtls_def_config.h | 4 + lib/mbedtls/sha256.c | 43 ++--- lib/sha256.c | 36 ---- lib/sha256_common.c | 98 ++++++++++ test/lib/Makefile | 2 + test/lib/test_sha256_hkdf.c | 107 +++++++++++ test/lib/test_sha256_hmac.c | 296 +++++++++++++++++++++++++++++++ tools/Makefile | 1 + tools/kwbimage.h | 6 +- tools/renesas_spkgimage.h | 6 +- 14 files changed, 570 insertions(+), 70 deletions(-) create mode 100644 lib/sha256_common.c create mode 100644 test/lib/test_sha256_hkdf.c create mode 100644 test/lib/test_sha256_hmac.c
The attribute __packed was defined in the file tools/kwbimage.h but this attribute is already defined in linux/compiler_attributes.h. So we include <linux/compiler_attributes.h.h> and do not define __packed.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- tools/kwbimage.h | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/tools/kwbimage.h b/tools/kwbimage.h index 505522332bd..e1fa2e4e215 100644 --- a/tools/kwbimage.h +++ b/tools/kwbimage.h @@ -11,11 +11,7 @@ #include <compiler.h> #include <stdint.h>
-#ifdef __GNUC__ -#define __packed __attribute((packed)) -#else -#define __packed -#endif +#include <linux/compiler_attributes.h>
#define KWBIMAGE_MAX_CONFIG ((0x1dc - 0x20)/sizeof(struct reg_config)) #define MAX_TEMPBUF_LEN 32
The attribute __packed was defined in the file tools/renesas_spkgimage.h but this attribute is already defined in linux/compiler_attributes.h. So we include <linux/compiler_attributes.h.h> and do not define __packed.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- tools/renesas_spkgimage.h | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/tools/renesas_spkgimage.h b/tools/renesas_spkgimage.h index 367e113de9d..83ec567b0d4 100644 --- a/tools/renesas_spkgimage.h +++ b/tools/renesas_spkgimage.h @@ -11,11 +11,7 @@ #ifndef _SPKGIMAGE_H_ #define _SPKGIMAGE_H_
#define SPKG_HEADER_MARKER {'R', 'Z', 'N', '1'} #define SPKG_HEADER_SIZE 24
Adds the support of key derivation using the scheme hkdf.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- lib/mbedtls/Kconfig | 14 ++++++++++++++ lib/mbedtls/Makefile | 2 ++ lib/mbedtls/mbedtls_def_config.h | 4 ++++ 3 files changed, 20 insertions(+)
diff --git a/lib/mbedtls/Kconfig b/lib/mbedtls/Kconfig index 78167ffa252..aa82336ef14 100644 --- a/lib/mbedtls/Kconfig +++ b/lib/mbedtls/Kconfig @@ -297,6 +297,13 @@ config MD5_MBEDTLS This option enables support of hashing using MD5 algorithm with MbedTLS crypto library.
+config HKDF_MBEDTLS + bool "Enable HKDF support with MbedTLS crypto library" + depends on MBEDTLS_LIB_CRYPTO + help + This option enables support of key derivation using HKDF algorithm + with MbedTLS crypto library. + if SPL
config SPL_SHA1_MBEDTLS @@ -335,6 +342,13 @@ config SPL_MD5_MBEDTLS This option enables support of hashing using MD5 algorithm with MbedTLS crypto library.
+config SPL_HKDF_MBEDTLS + bool "Enable HKDF support in SPL with MbedTLS crypto library" + depends on MBEDTLS_LIB_CRYPTO + help + This option enables support of key derivation using HKDF algorithm + with MbedTLS crypto library. + endif # SPL
endif # MBEDTLS_LIB_CRYPTO diff --git a/lib/mbedtls/Makefile b/lib/mbedtls/Makefile index ce0a61e4054..e66c2018d97 100644 --- a/lib/mbedtls/Makefile +++ b/lib/mbedtls/Makefile @@ -33,6 +33,8 @@ mbedtls_lib_crypto-$(CONFIG_$(SPL_)SHA256_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/sha256.o mbedtls_lib_crypto-$(CONFIG_$(SPL_)SHA512_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/sha512.o +mbedtls_lib_crypto-$(CONFIG_$(SPL_)HKDF_MBEDTLS) += \ + $(MBEDTLS_LIB_DIR)/hkdf.o
# MbedTLS X509 library obj-$(CONFIG_MBEDTLS_LIB_X509) += mbedtls_lib_x509.o diff --git a/lib/mbedtls/mbedtls_def_config.h b/lib/mbedtls/mbedtls_def_config.h index 1d2314e90e4..fd440c392f9 100644 --- a/lib/mbedtls/mbedtls_def_config.h +++ b/lib/mbedtls/mbedtls_def_config.h @@ -56,6 +56,10 @@ #endif #endif
+#if CONFIG_IS_ENABLED(HKDF_MBEDTLS) +#define MBEDTLS_HKDF_C +#endif + #if defined CONFIG_MBEDTLS_LIB_X509
#if CONFIG_IS_ENABLED(X509_CERTIFICATE_PARSER)
Hi Philippe,
On Thu, 12 Dec 2024 at 08:37, Philippe Reynes < philippe.reynes@softathome.com> wrote:
help
algorithm
if SPL
help
algorithm
endif # SPL
2.25.1
Sounds good to me. Reviewed-by: Raymond Mao raymond.mao@linaro.org
Regards, Raymond
The function sha256_csum_wd is defined in lib/sha256.c and in lib/mbedtls/sha256.c. To avoid duplicating this function (and future function), we move this function to the file lib/sha256_common.c
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- lib/Makefile | 1 + lib/mbedtls/sha256.c | 27 ------------------------ lib/sha256.c | 36 ------------------------------- lib/sha256_common.c | 50 ++++++++++++++++++++++++++++++++++++++++++++ tools/Makefile | 1 + 5 files changed, 52 insertions(+), 63 deletions(-) create mode 100644 lib/sha256_common.c
diff --git a/lib/Makefile b/lib/Makefile index d24ed629732..17201f66798 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -77,6 +77,7 @@ obj-$(CONFIG_BLAKE2) += blake2/blake2b.o
obj-$(CONFIG_$(XPL_)MD5_LEGACY) += md5.o obj-$(CONFIG_$(XPL_)SHA1_LEGACY) += sha1.o +obj-$(CONFIG_$(XPL_)SHA256) += sha256_common.o obj-$(CONFIG_$(XPL_)SHA256_LEGACY) += sha256.o obj-$(CONFIG_$(XPL_)SHA512_LEGACY) += sha512.o
diff --git a/lib/mbedtls/sha256.c b/lib/mbedtls/sha256.c index 24aa58fa674..2128e598834 100644 --- a/lib/mbedtls/sha256.c +++ b/lib/mbedtls/sha256.c @@ -33,30 +33,3 @@ void sha256_finish(sha256_context *ctx, uint8_t digest[SHA256_SUM_LEN]) mbedtls_sha256_finish(ctx, digest); mbedtls_sha256_free(ctx); } - -void sha256_csum_wd(const unsigned char *input, unsigned int ilen, - unsigned char *output, unsigned int chunk_sz) -{ - sha256_context ctx; - - sha256_starts(&ctx); - - if (IS_ENABLED(CONFIG_HW_WATCHDOG) || IS_ENABLED(CONFIG_WATCHDOG)) { - const unsigned char *curr = input; - const unsigned char *end = input + ilen; - int chunk; - - while (curr < end) { - chunk = end - curr; - if (chunk > chunk_sz) - chunk = chunk_sz; - sha256_update(&ctx, curr, chunk); - curr += chunk; - schedule(); - } - } else { - sha256_update(&ctx, input, ilen); - } - - sha256_finish(&ctx, output); -} diff --git a/lib/sha256.c b/lib/sha256.c index fb195d988f1..827bd9a872b 100644 --- a/lib/sha256.c +++ b/lib/sha256.c @@ -264,39 +264,3 @@ void sha256_finish(sha256_context * ctx, uint8_t digest[32]) PUT_UINT32_BE(ctx->state[6], digest, 24); PUT_UINT32_BE(ctx->state[7], digest, 28); } - -/* - * Output = SHA-256( input buffer ). Trigger the watchdog every 'chunk_sz' - * bytes of input processed. - */ -void sha256_csum_wd(const unsigned char *input, unsigned int ilen, - unsigned char *output, unsigned int chunk_sz) -{ - sha256_context ctx; -#if !defined(USE_HOSTCC) && \ - (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) - const unsigned char *end; - unsigned char *curr; - int chunk; -#endif - - sha256_starts(&ctx); - -#if !defined(USE_HOSTCC) && \ - (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) - curr = (unsigned char *)input; - end = input + ilen; - while (curr < end) { - chunk = end - curr; - if (chunk > chunk_sz) - chunk = chunk_sz; - sha256_update(&ctx, curr, chunk); - curr += chunk; - schedule(); - } -#else - sha256_update(&ctx, input, ilen); -#endif - - sha256_finish(&ctx, output); -} diff --git a/lib/sha256_common.c b/lib/sha256_common.c new file mode 100644 index 00000000000..7041abd26d9 --- /dev/null +++ b/lib/sha256_common.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * FIPS-180-2 compliant SHA-256 implementation + * + * Copyright (C) 2001-2003 Christophe Devine + */ + +#ifndef USE_HOSTCC +#include <u-boot/schedule.h> +#endif /* USE_HOSTCC */ +#include <string.h> +#include <u-boot/sha256.h> + +#include <linux/compiler_attributes.h> + +/* + * Output = SHA-256( input buffer ). Trigger the watchdog every 'chunk_sz' + * bytes of input processed. + */ +void sha256_csum_wd(const unsigned char *input, unsigned int ilen, + unsigned char *output, unsigned int chunk_sz) +{ + sha256_context ctx; +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) + const unsigned char *end; + unsigned char *curr; + int chunk; +#endif + + sha256_starts(&ctx); + +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) + curr = (unsigned char *)input; + end = input + ilen; + while (curr < end) { + chunk = end - curr; + if (chunk > chunk_sz) + chunk = chunk_sz; + sha256_update(&ctx, curr, chunk); + curr += chunk; + schedule(); + } +#else + sha256_update(&ctx, input, ilen); +#endif + + sha256_finish(&ctx, output); +} diff --git a/tools/Makefile b/tools/Makefile index ee08a9675df..237fa900a24 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -135,6 +135,7 @@ dumpimage-mkimage-objs := aisimage.o \ generated/lib/hash-checksum.o \ generated/lib/sha1.o \ generated/lib/sha256.o \ + generated/lib/sha256_common.o \ generated/lib/sha512.o \ generated/common/hash.o \ ublimage.o \
Hi Philippe,
sha256_context ctx;
int chunk;
chunk = end - curr;
chunk = chunk_sz;
curr += chunk;
schedule();
} else {
- Output = SHA-256( input buffer ). Trigger the watchdog every 'chunk_sz'
- bytes of input processed.
sha256_context ctx;
int chunk;
-#endif
end = input + ilen;
chunk = end - curr;
chunk = chunk_sz;
curr += chunk;
schedule();
-#else
-#endif
- FIPS-180-2 compliant SHA-256 implementation
- Copyright (C) 2001-2003 Christophe Devine
sha256_context ctx;
int chunk;
end = input + ilen;
chunk = end - curr;
chunk = chunk_sz;
curr += chunk;
schedule();
+#else
-- 2.25.1
Sounds good to me.
Regards, Raymond
Adds the support of the hmac based on sha256. This implementation is based on rfc2104.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- include/u-boot/sha256.h | 4 ++++ lib/sha256_common.c | 48 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 52 insertions(+)
diff --git a/include/u-boot/sha256.h b/include/u-boot/sha256.h index 44a9b528b48..2f12275b703 100644 --- a/include/u-boot/sha256.h +++ b/include/u-boot/sha256.h @@ -45,4 +45,8 @@ void sha256_finish(sha256_context * ctx, uint8_t digest[SHA256_SUM_LEN]); void sha256_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz);
+void sha256_hmac(const unsigned char *key, int keylen, + const unsigned char *input, unsigned int ilen, + unsigned char *output); + #endif /* _SHA256_H */ diff --git a/lib/sha256_common.c b/lib/sha256_common.c index 7041abd26d9..46262ea99a2 100644 --- a/lib/sha256_common.c +++ b/lib/sha256_common.c @@ -48,3 +48,51 @@ void sha256_csum_wd(const unsigned char *input, unsigned int ilen,
sha256_finish(&ctx, output); } + +void sha256_hmac(const unsigned char *key, int keylen, + const unsigned char *input, unsigned int ilen, + unsigned char *output) +{ + int i; + sha256_context ctx; + unsigned char keybuf[64]; + unsigned char k_ipad[64]; + unsigned char k_opad[64]; + unsigned char tmpbuf[32]; + int keybuf_len; + + if (keylen > 64) { + sha256_starts(&ctx); + sha256_update(&ctx, key, keylen); + sha256_finish(&ctx, keybuf); + + keybuf_len = 32; + } else { + memcpy(keybuf, key, keylen); + keybuf_len = keylen; + } + + memset(k_ipad, 0x36, 64); + memset(k_opad, 0x5C, 64); + + for (i = 0; i < keybuf_len; i++) { + k_ipad[i] ^= keybuf[i]; + k_opad[i] ^= keybuf[i]; + } + + sha256_starts(&ctx); + sha256_update(&ctx, k_ipad, sizeof(k_ipad)); + sha256_update(&ctx, input, ilen); + sha256_finish(&ctx, tmpbuf); + + sha256_starts(&ctx); + sha256_update(&ctx, k_opad, sizeof(k_opad)); + sha256_update(&ctx, tmpbuf, sizeof(tmpbuf)); + sha256_finish(&ctx, output); + + memset(k_ipad, 0, sizeof(k_ipad)); + memset(k_opad, 0, sizeof(k_opad)); + memset(tmpbuf, 0, sizeof(tmpbuf)); + memset(keybuf, 0, sizeof(keybuf)); + memset(&ctx, 0, sizeof(sha256_context)); +}
Hi Philippe,
int i;
sha256_context ctx;
int keybuf_len;
if (keylen > 64) {
keybuf_len = 32;
} else {
2.25.1
The sha256 hmac common implementation now sounds good.
Do you have a comparison of performance with the MbedTLS high-level API mbedtls_md_hmac()? I am wondering if it is worth using this API specially when MbedTLS is enabled, since it significantly simplifies the implementation.
Regards, Raymond
Hi Raymond,
Le 13/12/2024 à 17:49, Raymond Mao a écrit :
*This Mail comes from Outside of SoftAtHome: *Do not answer, click links or open attachments unless you recognize the sender and know the content is safe.**
Hi Philippe,
On Thu, 12 Dec 2024 at 08:37, Philippe Reynes philippe.reynes@softathome.com wrote:
Adds the support of the hmac based on sha256. This implementation is based on rfc2104. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> --- include/u-boot/sha256.h | 4 ++++ lib/sha256_common.c | 48 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 52 insertions(+) diff --git a/include/u-boot/sha256.h b/include/u-boot/sha256.h index 44a9b528b48..2f12275b703 100644 --- a/include/u-boot/sha256.h +++ b/include/u-boot/sha256.h @@ -45,4 +45,8 @@ void sha256_finish(sha256_context * ctx, uint8_t digest[SHA256_SUM_LEN]); void sha256_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz); +void sha256_hmac(const unsigned char *key, int keylen, + const unsigned char *input, unsigned int ilen, + unsigned char *output); + #endif /* _SHA256_H */ diff --git a/lib/sha256_common.c b/lib/sha256_common.c index 7041abd26d9..46262ea99a2 100644 --- a/lib/sha256_common.c +++ b/lib/sha256_common.c @@ -48,3 +48,51 @@ void sha256_csum_wd(const unsigned char *input, unsigned int ilen, sha256_finish(&ctx, output); } + +void sha256_hmac(const unsigned char *key, int keylen, + const unsigned char *input, unsigned int ilen, + unsigned char *output) +{ + int i; + sha256_context ctx; + unsigned char keybuf[64]; + unsigned char k_ipad[64]; + unsigned char k_opad[64]; + unsigned char tmpbuf[32]; + int keybuf_len; + + if (keylen > 64) { + sha256_starts(&ctx); + sha256_update(&ctx, key, keylen); + sha256_finish(&ctx, keybuf); + + keybuf_len = 32; + } else { + memcpy(keybuf, key, keylen); + keybuf_len = keylen; + } + + memset(k_ipad, 0x36, 64); + memset(k_opad, 0x5C, 64); + + for (i = 0; i < keybuf_len; i++) { + k_ipad[i] ^= keybuf[i]; + k_opad[i] ^= keybuf[i]; + } + + sha256_starts(&ctx); + sha256_update(&ctx, k_ipad, sizeof(k_ipad)); + sha256_update(&ctx, input, ilen); + sha256_finish(&ctx, tmpbuf); + + sha256_starts(&ctx); + sha256_update(&ctx, k_opad, sizeof(k_opad)); + sha256_update(&ctx, tmpbuf, sizeof(tmpbuf)); + sha256_finish(&ctx, output); + + memset(k_ipad, 0, sizeof(k_ipad)); + memset(k_opad, 0, sizeof(k_opad)); + memset(tmpbuf, 0, sizeof(tmpbuf)); + memset(keybuf, 0, sizeof(keybuf)); + memset(&ctx, 0, sizeof(sha256_context)); +} -- 2.25.1
The sha256 hmac common implementation now sounds good. Do you have a comparison of performance with the MbedTLS high-level API mbedtls_md_hmac()? I am wondering if it is worth using this API specially when MbedTLS is enabled, since it significantly simplifies the implementation.
I have done some test, and the legacy implementation is the fastest. To do my test, I have run 1 000 000 times the unit test for hmac. here the result: common + legacy => 7 seconds common + mbedtls => 17 seconds mbedtls => 17 seconds
I have kept common + mbedtls for the v5. But I may use a pure mbedtls if you prefer.
Regards, Raymond
Regards,
Philippe
Hi Philippe,
On Mon, 16 Dec 2024 at 07:48, Philippe REYNES < philippe.reynes@softathome.com> wrote:
Hi Raymond,
*This Mail comes from Outside of SoftAtHome: *Do not answer, click links or open attachments unless you recognize the sender and know the content is safe. Hi Philippe,
int i;
sha256_context ctx;
int keybuf_len;
if (keylen > 64) {
keybuf_len = 32;
} else {
2.25.1
If my understanding is correct, "common + mbedtls => 17 seconds" means
mbedtls enabled and with your patch, while "mbedtls => 17 seconds" means using mbedtls_md_hmac(), right?
If this is the case, I would prefer to use mbedtls_md_hmac() since it brings more simplicity.
Regards, Raymond
Hi Raymond,
Le 16/12/2024 à 16:01, Raymond Mao a écrit :
Hi Philippe,
On Mon, 16 Dec 2024 at 07:48, Philippe REYNES philippe.reynes@softathome.com wrote:
Hi Raymond, Le 13/12/2024 à 17:49, Raymond Mao a écrit :
*This Mail comes from Outside of SoftAtHome: *Do not answer, click links or open attachments unless you recognize the sender and know the content is safe. Hi Philippe, On Thu, 12 Dec 2024 at 08:37, Philippe Reynes <philippe.reynes@softathome.com> wrote: Adds the support of the hmac based on sha256. This implementation is based on rfc2104. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> --- include/u-boot/sha256.h | 4 ++++ lib/sha256_common.c | 48 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 52 insertions(+) diff --git a/include/u-boot/sha256.h b/include/u-boot/sha256.h index 44a9b528b48..2f12275b703 100644 --- a/include/u-boot/sha256.h +++ b/include/u-boot/sha256.h @@ -45,4 +45,8 @@ void sha256_finish(sha256_context * ctx, uint8_t digest[SHA256_SUM_LEN]); void sha256_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz); +void sha256_hmac(const unsigned char *key, int keylen, + const unsigned char *input, unsigned int ilen, + unsigned char *output); + #endif /* _SHA256_H */ diff --git a/lib/sha256_common.c b/lib/sha256_common.c index 7041abd26d9..46262ea99a2 100644 --- a/lib/sha256_common.c +++ b/lib/sha256_common.c @@ -48,3 +48,51 @@ void sha256_csum_wd(const unsigned char *input, unsigned int ilen, sha256_finish(&ctx, output); } + +void sha256_hmac(const unsigned char *key, int keylen, + const unsigned char *input, unsigned int ilen, + unsigned char *output) +{ + int i; + sha256_context ctx; + unsigned char keybuf[64]; + unsigned char k_ipad[64]; + unsigned char k_opad[64]; + unsigned char tmpbuf[32]; + int keybuf_len; + + if (keylen > 64) { + sha256_starts(&ctx); + sha256_update(&ctx, key, keylen); + sha256_finish(&ctx, keybuf); + + keybuf_len = 32; + } else { + memcpy(keybuf, key, keylen); + keybuf_len = keylen; + } + + memset(k_ipad, 0x36, 64); + memset(k_opad, 0x5C, 64); + + for (i = 0; i < keybuf_len; i++) { + k_ipad[i] ^= keybuf[i]; + k_opad[i] ^= keybuf[i]; + } + + sha256_starts(&ctx); + sha256_update(&ctx, k_ipad, sizeof(k_ipad)); + sha256_update(&ctx, input, ilen); + sha256_finish(&ctx, tmpbuf); + + sha256_starts(&ctx); + sha256_update(&ctx, k_opad, sizeof(k_opad)); + sha256_update(&ctx, tmpbuf, sizeof(tmpbuf)); + sha256_finish(&ctx, output); + + memset(k_ipad, 0, sizeof(k_ipad)); + memset(k_opad, 0, sizeof(k_opad)); + memset(tmpbuf, 0, sizeof(tmpbuf)); + memset(keybuf, 0, sizeof(keybuf)); + memset(&ctx, 0, sizeof(sha256_context)); +} -- 2.25.1 The sha256 hmac common implementation now sounds good. Do you have a comparison of performance with the MbedTLS high-level API mbedtls_md_hmac()? I am wondering if it is worth using this API specially when MbedTLS is enabled, since it significantly simplifies the implementation.
I have done some test, and the legacy implementation is the fastest. To do my test, I have run 1 000 000 times the unit test for hmac. here the result: common + legacy => 7 seconds common + mbedtls => 17 seconds mbedtls => 17 seconds I have kept common + mbedtls for the v5. But I may use a pure mbedtls if you prefer.
If my understanding is correct, "common + mbedtls => 17 seconds" means mbedtls enabled and with your patch, while "mbedtls => 17 seconds" means using mbedtls_md_hmac(), right?
Correct
Ok, I do the change.
Thanks for this fast answer.
Regards, Raymond
Regards,
Philippe
Adds a test for the function sha256_hmac
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- test/lib/Makefile | 1 + test/lib/test_sha256_hmac.c | 296 ++++++++++++++++++++++++++++++++++++ 2 files changed, 297 insertions(+) create mode 100644 test/lib/test_sha256_hmac.c
diff --git a/test/lib/Makefile b/test/lib/Makefile index f516d001747..4c0abcba81a 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_ERRNO_STR) += test_errno_str.o obj-$(CONFIG_UT_LIB_ASN1) += asn1.o obj-$(CONFIG_UT_LIB_RSA) += rsa.o obj-$(CONFIG_AES) += test_aes.o +obj-$(CONFIG_SHA256) += test_sha256_hmac.o obj-$(CONFIG_GETOPT) += getopt.o obj-$(CONFIG_CRC8) += test_crc8.o obj-$(CONFIG_UT_LIB_CRYPT) += test_crypt.o diff --git a/test/lib/test_sha256_hmac.c b/test/lib/test_sha256_hmac.c new file mode 100644 index 00000000000..78b87ec98a8 --- /dev/null +++ b/test/lib/test_sha256_hmac.c @@ -0,0 +1,296 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024 Philippe Reynes philippe.reynes@softathome.com + * + * Unit tests for sha256_hmac functions + */ + +#include <command.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> +#include <u-boot/sha256.h> + +struct test_sha256_hmac_s { + unsigned char *key; + int keylen; + unsigned char *input; + int ilen; + unsigned char *expected; + int elen; +}; + +/* + * data comes from: + * https://datatracker.ietf.org/doc/html/rfc4231 + */ +static unsigned char key_test1[] = { + 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, + 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b }; + +static unsigned char input_test1[] = { + 0x48, 0x69, 0x20, 0x54, 0x68, 0x65, 0x72, 0x65 }; + +static unsigned char expected_test1[] = { + 0xb0, 0x34, 0x4c, 0x61, 0xd8, 0xdb, 0x38, 0x53, + 0x5c, 0xa8, 0xaf, 0xce, 0xaf, 0x0b, 0xf1, 0x2b, + 0x88, 0x1d, 0xc2, 0x00, 0xc9, 0x83, 0x3d, 0xa7, + 0x26, 0xe9, 0x37, 0x6c, 0x2e, 0x32, 0xcf, 0xf7 }; + +static unsigned char key_test2[] = { 0x4a, 0x65, 0x66, 0x65 }; + +static unsigned char input_test2[] = { + 0x77, 0x68, 0x61, 0x74, 0x20, 0x64, 0x6f, 0x20, + 0x79, 0x61, 0x20, 0x77, 0x61, 0x6e, 0x74, 0x20, + 0x66, 0x6f, 0x72, 0x20, 0x6e, 0x6f, 0x74, 0x68, + 0x69, 0x6e, 0x67, 0x3f }; + +static unsigned char expected_test2[] = { + 0x5b, 0xdc, 0xc1, 0x46, 0xbf, 0x60, 0x75, 0x4e, + 0x6a, 0x04, 0x24, 0x26, 0x08, 0x95, 0x75, 0xc7, + 0x5a, 0x00, 0x3f, 0x08, 0x9d, 0x27, 0x39, 0x83, + 0x9d, 0xec, 0x58, 0xb9, 0x64, 0xec, 0x38, 0x43 }; + +static unsigned char key_test3[] = { + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa }; + +static unsigned char input_test3[] = { + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd }; + +static unsigned char expected_test3[] = { + 0x77, 0x3e, 0xa9, 0x1e, 0x36, 0x80, 0x0e, 0x46, + 0x85, 0x4d, 0xb8, 0xeb, 0xd0, 0x91, 0x81, 0xa7, + 0x29, 0x59, 0x09, 0x8b, 0x3e, 0xf8, 0xc1, 0x22, + 0xd9, 0x63, 0x55, 0x14, 0xce, 0xd5, 0x65, 0xfe }; + +static unsigned char key_test4[] = { + 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, + 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f, 0x10, + 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, + 0x19, +}; + +static unsigned char input_test4[] = { + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, +}; + +static unsigned char expected_test4[] = { + 0x82, 0x55, 0x8a, 0x38, 0x9a, 0x44, 0x3c, 0x0e, + 0xa4, 0xcc, 0x81, 0x98, 0x99, 0xf2, 0x08, 0x3a, + 0x85, 0xf0, 0xfa, 0xa3, 0xe5, 0x78, 0xf8, 0x07, + 0x7a, 0x2e, 0x3f, 0xf4, 0x67, 0x29, 0x66, 0x5b, +}; + +static unsigned char key_test5[] = { + 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, + 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, + 0x0c, 0x0c, 0x0c, 0x0c, +}; + +static unsigned char input_test5[] = { + 0x54, 0x65, 0x73, 0x74, 0x20, 0x57, 0x69, 0x74, + 0x68, 0x20, 0x54, 0x72, 0x75, 0x6e, 0x63, 0x61, + 0x74, 0x69, 0x6f, 0x6e, +}; + +static unsigned char expected_test5[] = { + 0xa3, 0xb6, 0x16, 0x74, 0x73, 0x10, 0x0e, 0xe0, + 0x6e, 0x0c, 0x79, 0x6c, 0x29, 0x55, 0x55, 0x2b, +}; + +static unsigned char key_test6[] = { + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa }; + +static unsigned char input_test6[] = { + 0x54, 0x65, 0x73, 0x74, 0x20, 0x55, 0x73, 0x69, + 0x6e, 0x67, 0x20, 0x4c, 0x61, 0x72, 0x67, 0x65, + 0x72, 0x20, 0x54, 0x68, 0x61, 0x6e, 0x20, 0x42, + 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x53, 0x69, 0x7a, + 0x65, 0x20, 0x4b, 0x65, 0x79, 0x20, 0x2d, 0x20, + 0x48, 0x61, 0x73, 0x68, 0x20, 0x4b, 0x65, 0x79, + 0x20, 0x46, 0x69, 0x72, 0x73, 0x74 }; + +static unsigned char expected_test6[] = { + 0x60, 0xe4, 0x31, 0x59, 0x1e, 0xe0, 0xb6, 0x7f, + 0x0d, 0x8a, 0x26, 0xaa, 0xcb, 0xf5, 0xb7, 0x7f, + 0x8e, 0x0b, 0xc6, 0x21, 0x37, 0x28, 0xc5, 0x14, + 0x05, 0x46, 0x04, 0x0f, 0x0e, 0xe3, 0x7f, 0x54 }; + +static unsigned char key_test7[] = { + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, +}; + +static unsigned char input_test7[] = { + 0x54, 0x68, 0x69, 0x73, 0x20, 0x69, 0x73, 0x20, + 0x61, 0x20, 0x74, 0x65, 0x73, 0x74, 0x20, 0x75, + 0x73, 0x69, 0x6e, 0x67, 0x20, 0x61, 0x20, 0x6c, + 0x61, 0x72, 0x67, 0x65, 0x72, 0x20, 0x74, 0x68, + 0x61, 0x6e, 0x20, 0x62, 0x6c, 0x6f, 0x63, 0x6b, + 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x20, 0x6b, 0x65, + 0x79, 0x20, 0x61, 0x6e, 0x64, 0x20, 0x61, 0x20, + 0x6c, 0x61, 0x72, 0x67, 0x65, 0x72, 0x20, 0x74, + 0x68, 0x61, 0x6e, 0x20, 0x62, 0x6c, 0x6f, 0x63, + 0x6b, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x20, 0x64, + 0x61, 0x74, 0x61, 0x2e, 0x20, 0x54, 0x68, 0x65, + 0x20, 0x6b, 0x65, 0x79, 0x20, 0x6e, 0x65, 0x65, + 0x64, 0x73, 0x20, 0x74, 0x6f, 0x20, 0x62, 0x65, + 0x20, 0x68, 0x61, 0x73, 0x68, 0x65, 0x64, 0x20, + 0x62, 0x65, 0x66, 0x6f, 0x72, 0x65, 0x20, 0x62, + 0x65, 0x69, 0x6e, 0x67, 0x20, 0x75, 0x73, 0x65, + 0x64, 0x20, 0x62, 0x79, 0x20, 0x74, 0x68, 0x65, + 0x20, 0x48, 0x4d, 0x41, 0x43, 0x20, 0x61, 0x6c, + 0x67, 0x6f, 0x72, 0x69, 0x74, 0x68, 0x6d, 0x2e, +}; + +static unsigned char expected_test7[] = { + 0x9b, 0x09, 0xff, 0xa7, 0x1b, 0x94, 0x2f, 0xcb, + 0x27, 0x63, 0x5f, 0xbc, 0xd5, 0xb0, 0xe9, 0x44, + 0xbf, 0xdc, 0x63, 0x64, 0x4f, 0x07, 0x13, 0x93, + 0x8a, 0x7f, 0x51, 0x53, 0x5c, 0x3a, 0x35, 0xe2, +}; + +static struct test_sha256_hmac_s test_sha256_hmac[] = { + { + .key = key_test1, + .keylen = sizeof(key_test1), + .input = input_test1, + .ilen = sizeof(input_test1), + .expected = expected_test1, + .elen = sizeof(expected_test1), + }, + { + .key = key_test2, + .keylen = sizeof(key_test2), + .input = input_test2, + .ilen = sizeof(input_test2), + .expected = expected_test2, + .elen = sizeof(expected_test2), + }, + { + .key = key_test3, + .keylen = sizeof(key_test3), + .input = input_test3, + .ilen = sizeof(input_test3), + .expected = expected_test3, + .elen = sizeof(expected_test3), + }, + { + .key = key_test4, + .keylen = sizeof(key_test4), + .input = input_test4, + .ilen = sizeof(input_test4), + .expected = expected_test4, + .elen = sizeof(expected_test4), + }, + { + .key = key_test5, + .keylen = sizeof(key_test5), + .input = input_test5, + .ilen = sizeof(input_test5), + .expected = expected_test5, + .elen = sizeof(expected_test5), + }, + { + .key = key_test6, + .keylen = sizeof(key_test6), + .input = input_test6, + .ilen = sizeof(input_test6), + .expected = expected_test6, + .elen = sizeof(expected_test6), + }, + { + .key = key_test7, + .keylen = sizeof(key_test7), + .input = input_test7, + .ilen = sizeof(input_test7), + .expected = expected_test7, + .elen = sizeof(expected_test7), + }, +}; + +static int _lib_test_sha256_hmac_run(struct unit_test_state *uts, + unsigned char *key, int keylen, + unsigned char *input, int ilen, + unsigned char *expected, int elen) +{ + unsigned char output[32]; + + sha256_hmac(key, keylen, input, ilen, output); + ut_asserteq_mem(expected, output, elen); + + return 0; +} + +static int lib_test_sha256_hmac_run(struct unit_test_state *uts, + struct test_sha256_hmac_s *test) +{ + unsigned char *key = test->key; + int keylen = test->keylen; + unsigned char *input = test->input; + int ilen = test->ilen; + unsigned char *expected = test->expected; + int elen = test->elen; + + return _lib_test_sha256_hmac_run(uts, key, keylen, input, ilen, expected, elen); +} + +static int lib_test_sha256_hmac(struct unit_test_state *uts) +{ + int i, ret = 0; + + for (i = 0; i < ARRAY_SIZE(test_sha256_hmac); i++) { + ret = lib_test_sha256_hmac_run(uts, &test_sha256_hmac[i]); + if (ret) + break; + } + + return ret; +} + +LIB_TEST(lib_test_sha256_hmac, 0);
Hi Philippe,
- Copyright (c) 2024 Philippe Reynes philippe.reynes@softathome.com
- Unit tests for sha256_hmac functions
unsigned char *key;
int keylen;
int ilen;
int elen;
- data comes from:
0xdd, 0xdd };
0x19,
0xcd, 0xcd,
0xaa, 0xaa, 0xaa };
0xaa, 0xaa, 0xaa,
.key = key_test1,
.key = key_test2,
.key = key_test3,
.key = key_test4,
.key = key_test5,
.key = key_test6,
.key = key_test7,
Please use SHA256_SUM_LEN to avoid magic numbers.
expected, elen);
Why we don't just: return _lib_test_sha256_hmac_run(uts, test->key, test->keylen, test->input, test->ilen, test->expected, test->elen);
int i, ret = 0;
if (ret)
break;
return ret;
This seems to be better: for (i = 0; i < ARRAY_SIZE(test_sha256_hmac); i++) { ret = lib_test_sha256_hmac_run(uts, &test_sha256_hmac[i]); if (ret) return ret; } return 0;
2.25.1
Regards, Raymond
Hi Raymond,
Hi Philippe,
Adds a test for the function sha256_hmac Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> --- test/lib/Makefile | 1 + test/lib/test_sha256_hmac.c | 296 ++++++++++++++++++++++++++++++++++++ 2 files changed, 297 insertions(+) create mode 100644 test/lib/test_sha256_hmac.c diff --git a/test/lib/Makefile b/test/lib/Makefile index f516d001747..4c0abcba81a 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_ERRNO_STR) += test_errno_str.o obj-$(CONFIG_UT_LIB_ASN1) += asn1.o obj-$(CONFIG_UT_LIB_RSA) += rsa.o obj-$(CONFIG_AES) += test_aes.o +obj-$(CONFIG_SHA256) += test_sha256_hmac.o obj-$(CONFIG_GETOPT) += getopt.o obj-$(CONFIG_CRC8) += test_crc8.o obj-$(CONFIG_UT_LIB_CRYPT) += test_crypt.o diff --git a/test/lib/test_sha256_hmac.c b/test/lib/test_sha256_hmac.c new file mode 100644 index 00000000000..78b87ec98a8 --- /dev/null +++ b/test/lib/test_sha256_hmac.c @@ -0,0 +1,296 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024 Philippe Reynes <philippe.reynes@softathome.com> + * + * Unit tests for sha256_hmac functions + */ + +#include <command.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> +#include <u-boot/sha256.h> + +struct test_sha256_hmac_s { + unsigned char *key; + int keylen; + unsigned char *input; + int ilen; + unsigned char *expected; + int elen; +}; + +/* + * data comes from: + * https://datatracker.ietf.org/doc/html/rfc4231 <https://datatracker.ietf.org/doc/html/rfc4231> + */ +static unsigned char key_test1[] = { + 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, + 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b }; + +static unsigned char input_test1[] = { + 0x48, 0x69, 0x20, 0x54, 0x68, 0x65, 0x72, 0x65 }; + +static unsigned char expected_test1[] = { + 0xb0, 0x34, 0x4c, 0x61, 0xd8, 0xdb, 0x38, 0x53, + 0x5c, 0xa8, 0xaf, 0xce, 0xaf, 0x0b, 0xf1, 0x2b, + 0x88, 0x1d, 0xc2, 0x00, 0xc9, 0x83, 0x3d, 0xa7, + 0x26, 0xe9, 0x37, 0x6c, 0x2e, 0x32, 0xcf, 0xf7 }; + +static unsigned char key_test2[] = { 0x4a, 0x65, 0x66, 0x65 }; + +static unsigned char input_test2[] = { + 0x77, 0x68, 0x61, 0x74, 0x20, 0x64, 0x6f, 0x20, + 0x79, 0x61, 0x20, 0x77, 0x61, 0x6e, 0x74, 0x20, + 0x66, 0x6f, 0x72, 0x20, 0x6e, 0x6f, 0x74, 0x68, + 0x69, 0x6e, 0x67, 0x3f }; + +static unsigned char expected_test2[] = { + 0x5b, 0xdc, 0xc1, 0x46, 0xbf, 0x60, 0x75, 0x4e, + 0x6a, 0x04, 0x24, 0x26, 0x08, 0x95, 0x75, 0xc7, + 0x5a, 0x00, 0x3f, 0x08, 0x9d, 0x27, 0x39, 0x83, + 0x9d, 0xec, 0x58, 0xb9, 0x64, 0xec, 0x38, 0x43 }; + +static unsigned char key_test3[] = { + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa }; + +static unsigned char input_test3[] = { + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, 0xdd, + 0xdd, 0xdd }; + +static unsigned char expected_test3[] = { + 0x77, 0x3e, 0xa9, 0x1e, 0x36, 0x80, 0x0e, 0x46, + 0x85, 0x4d, 0xb8, 0xeb, 0xd0, 0x91, 0x81, 0xa7, + 0x29, 0x59, 0x09, 0x8b, 0x3e, 0xf8, 0xc1, 0x22, + 0xd9, 0x63, 0x55, 0x14, 0xce, 0xd5, 0x65, 0xfe }; + +static unsigned char key_test4[] = { + 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, + 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f, 0x10, + 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, + 0x19, +}; + +static unsigned char input_test4[] = { + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, 0xcd, + 0xcd, 0xcd, +}; + +static unsigned char expected_test4[] = { + 0x82, 0x55, 0x8a, 0x38, 0x9a, 0x44, 0x3c, 0x0e, + 0xa4, 0xcc, 0x81, 0x98, 0x99, 0xf2, 0x08, 0x3a, + 0x85, 0xf0, 0xfa, 0xa3, 0xe5, 0x78, 0xf8, 0x07, + 0x7a, 0x2e, 0x3f, 0xf4, 0x67, 0x29, 0x66, 0x5b, +}; + +static unsigned char key_test5[] = { + 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, + 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, + 0x0c, 0x0c, 0x0c, 0x0c, +}; + +static unsigned char input_test5[] = { + 0x54, 0x65, 0x73, 0x74, 0x20, 0x57, 0x69, 0x74, + 0x68, 0x20, 0x54, 0x72, 0x75, 0x6e, 0x63, 0x61, + 0x74, 0x69, 0x6f, 0x6e, +}; + +static unsigned char expected_test5[] = { + 0xa3, 0xb6, 0x16, 0x74, 0x73, 0x10, 0x0e, 0xe0, + 0x6e, 0x0c, 0x79, 0x6c, 0x29, 0x55, 0x55, 0x2b, +}; + +static unsigned char key_test6[] = { + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa }; + +static unsigned char input_test6[] = { + 0x54, 0x65, 0x73, 0x74, 0x20, 0x55, 0x73, 0x69, + 0x6e, 0x67, 0x20, 0x4c, 0x61, 0x72, 0x67, 0x65, + 0x72, 0x20, 0x54, 0x68, 0x61, 0x6e, 0x20, 0x42, + 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x53, 0x69, 0x7a, + 0x65, 0x20, 0x4b, 0x65, 0x79, 0x20, 0x2d, 0x20, + 0x48, 0x61, 0x73, 0x68, 0x20, 0x4b, 0x65, 0x79, + 0x20, 0x46, 0x69, 0x72, 0x73, 0x74 }; + +static unsigned char expected_test6[] = { + 0x60, 0xe4, 0x31, 0x59, 0x1e, 0xe0, 0xb6, 0x7f, + 0x0d, 0x8a, 0x26, 0xaa, 0xcb, 0xf5, 0xb7, 0x7f, + 0x8e, 0x0b, 0xc6, 0x21, 0x37, 0x28, 0xc5, 0x14, + 0x05, 0x46, 0x04, 0x0f, 0x0e, 0xe3, 0x7f, 0x54 }; + +static unsigned char key_test7[] = { + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + 0xaa, 0xaa, 0xaa, +}; + +static unsigned char input_test7[] = { + 0x54, 0x68, 0x69, 0x73, 0x20, 0x69, 0x73, 0x20, + 0x61, 0x20, 0x74, 0x65, 0x73, 0x74, 0x20, 0x75, + 0x73, 0x69, 0x6e, 0x67, 0x20, 0x61, 0x20, 0x6c, + 0x61, 0x72, 0x67, 0x65, 0x72, 0x20, 0x74, 0x68, + 0x61, 0x6e, 0x20, 0x62, 0x6c, 0x6f, 0x63, 0x6b, + 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x20, 0x6b, 0x65, + 0x79, 0x20, 0x61, 0x6e, 0x64, 0x20, 0x61, 0x20, + 0x6c, 0x61, 0x72, 0x67, 0x65, 0x72, 0x20, 0x74, + 0x68, 0x61, 0x6e, 0x20, 0x62, 0x6c, 0x6f, 0x63, + 0x6b, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x20, 0x64, + 0x61, 0x74, 0x61, 0x2e, 0x20, 0x54, 0x68, 0x65, + 0x20, 0x6b, 0x65, 0x79, 0x20, 0x6e, 0x65, 0x65, + 0x64, 0x73, 0x20, 0x74, 0x6f, 0x20, 0x62, 0x65, + 0x20, 0x68, 0x61, 0x73, 0x68, 0x65, 0x64, 0x20, + 0x62, 0x65, 0x66, 0x6f, 0x72, 0x65, 0x20, 0x62, + 0x65, 0x69, 0x6e, 0x67, 0x20, 0x75, 0x73, 0x65, + 0x64, 0x20, 0x62, 0x79, 0x20, 0x74, 0x68, 0x65, + 0x20, 0x48, 0x4d, 0x41, 0x43, 0x20, 0x61, 0x6c, + 0x67, 0x6f, 0x72, 0x69, 0x74, 0x68, 0x6d, 0x2e, +}; + +static unsigned char expected_test7[] = { + 0x9b, 0x09, 0xff, 0xa7, 0x1b, 0x94, 0x2f, 0xcb, + 0x27, 0x63, 0x5f, 0xbc, 0xd5, 0xb0, 0xe9, 0x44, + 0xbf, 0xdc, 0x63, 0x64, 0x4f, 0x07, 0x13, 0x93, + 0x8a, 0x7f, 0x51, 0x53, 0x5c, 0x3a, 0x35, 0xe2, +}; + +static struct test_sha256_hmac_s test_sha256_hmac[] = { + { + .key = key_test1, + .keylen = sizeof(key_test1), + .input = input_test1, + .ilen = sizeof(input_test1), + .expected = expected_test1, + .elen = sizeof(expected_test1), + }, + { + .key = key_test2, + .keylen = sizeof(key_test2), + .input = input_test2, + .ilen = sizeof(input_test2), + .expected = expected_test2, + .elen = sizeof(expected_test2), + }, + { + .key = key_test3, + .keylen = sizeof(key_test3), + .input = input_test3, + .ilen = sizeof(input_test3), + .expected = expected_test3, + .elen = sizeof(expected_test3), + }, + { + .key = key_test4, + .keylen = sizeof(key_test4), + .input = input_test4, + .ilen = sizeof(input_test4), + .expected = expected_test4, + .elen = sizeof(expected_test4), + }, + { + .key = key_test5, + .keylen = sizeof(key_test5), + .input = input_test5, + .ilen = sizeof(input_test5), + .expected = expected_test5, + .elen = sizeof(expected_test5), + }, + { + .key = key_test6, + .keylen = sizeof(key_test6), + .input = input_test6, + .ilen = sizeof(input_test6), + .expected = expected_test6, + .elen = sizeof(expected_test6), + }, + { + .key = key_test7, + .keylen = sizeof(key_test7), + .input = input_test7, + .ilen = sizeof(input_test7), + .expected = expected_test7, + .elen = sizeof(expected_test7), + }, +}; + +static int _lib_test_sha256_hmac_run(struct unit_test_state *uts, + unsigned char *key, int keylen, + unsigned char *input, int ilen, + unsigned char *expected, int elen)
I have done this change in v5
I have done this change in v5.
Usually, I try to have only one return per function. But I have done this change in v5
+} + +LIB_TEST(lib_test_sha256_hmac, 0); -- 2.25.1
Regards, Raymond
Regards, Philippe
Adds the support of key derivation using the scheme hkdf. This scheme is defined in rfc5869.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- include/u-boot/sha256.h | 20 ++++++++++++++++++++ lib/mbedtls/sha256.c | 22 ++++++++++++++++++++++ 2 files changed, 42 insertions(+)
diff --git a/include/u-boot/sha256.h b/include/u-boot/sha256.h index 2f12275b703..f21173305a6 100644 --- a/include/u-boot/sha256.h +++ b/include/u-boot/sha256.h @@ -1,6 +1,8 @@ #ifndef _SHA256_H #define _SHA256_H
+#include <linux/compiler_attributes.h> +#include <linux/errno.h> #include <linux/kconfig.h> #include <linux/types.h>
@@ -49,4 +51,22 @@ void sha256_hmac(const unsigned char *key, int keylen, const unsigned char *input, unsigned int ilen, unsigned char *output);
+#if CONFIG_IS_ENABLED(HKDF_MBEDTLS) +int sha256_hkdf(const unsigned char *salt, int saltlen, + const unsigned char *ikm, int ikmlen, + const unsigned char *info, int infolen, + unsigned char *output, int outputlen); +#else +static inline int sha256_hkdf(const unsigned char __always_unused *salt, + int __always_unused saltlen, + const unsigned char __always_unused *ikm, + int __always_unused ikmlen, + const unsigned char __always_unused *info, + int __always_unused infolen, + unsigned char __always_unused *output, + int __always_unused outputlen) { + return -EOPNOTSUPP; +} +#endif + #endif /* _SHA256_H */ diff --git a/lib/mbedtls/sha256.c b/lib/mbedtls/sha256.c index 2128e598834..b8bc43b612e 100644 --- a/lib/mbedtls/sha256.c +++ b/lib/mbedtls/sha256.c @@ -10,6 +10,11 @@ #endif /* USE_HOSTCC */ #include <u-boot/sha256.h>
+#if CONFIG_IS_ENABLED(HKDF_MBEDTLS) +#include <mbedtls/md.h> +#include <mbedtls/hkdf.h> +#endif + const u8 sha256_der_prefix[SHA256_DER_LEN] = { 0x30, 0x31, 0x30, 0x0d, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x05, @@ -33,3 +38,20 @@ void sha256_finish(sha256_context *ctx, uint8_t digest[SHA256_SUM_LEN]) mbedtls_sha256_finish(ctx, digest); mbedtls_sha256_free(ctx); } + +#if CONFIG_IS_ENABLED(HKDF_MBEDTLS) +int sha256_hkdf(const unsigned char *salt, int saltlen, + const unsigned char *ikm, int ikmlen, + const unsigned char *info, int infolen, + unsigned char *output, int outputlen) +{ + const mbedtls_md_info_t *md; + + md = mbedtls_md_info_from_type(MBEDTLS_MD_SHA256); + + return mbedtls_hkdf(md, salt, saltlen, + ikm, ikmlen, + info, infolen, + output, outputlen); +} +#endif
Hi Philippe,
return -EOPNOTSUPP;
+} +#endif
Please check if the return is not NULL.
ikm, ikmlen,
info, infolen,
output, outputlen);
2.25.1
Regards, Raymond
Hi Raymond,
Hi Philippe,
Adds the support of key derivation using the scheme hkdf. This scheme is defined in rfc5869. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> --- include/u-boot/sha256.h | 20 ++++++++++++++++++++ lib/mbedtls/sha256.c | 22 ++++++++++++++++++++++ 2 files changed, 42 insertions(+) diff --git a/include/u-boot/sha256.h b/include/u-boot/sha256.h index 2f12275b703..f21173305a6 100644 --- a/include/u-boot/sha256.h +++ b/include/u-boot/sha256.h @@ -1,6 +1,8 @@ #ifndef _SHA256_H #define _SHA256_H +#include <linux/compiler_attributes.h> +#include <linux/errno.h> #include <linux/kconfig.h> #include <linux/types.h> @@ -49,4 +51,22 @@ void sha256_hmac(const unsigned char *key, int keylen, const unsigned char *input, unsigned int ilen, unsigned char *output); +#if CONFIG_IS_ENABLED(HKDF_MBEDTLS) +int sha256_hkdf(const unsigned char *salt, int saltlen, + const unsigned char *ikm, int ikmlen, + const unsigned char *info, int infolen, + unsigned char *output, int outputlen); +#else +static inline int sha256_hkdf(const unsigned char __always_unused *salt, + int __always_unused saltlen, + const unsigned char __always_unused *ikm, + int __always_unused ikmlen, + const unsigned char __always_unused *info, + int __always_unused infolen, + unsigned char __always_unused *output, + int __always_unused outputlen) { + return -EOPNOTSUPP; +} +#endif + #endif /* _SHA256_H */ diff --git a/lib/mbedtls/sha256.c b/lib/mbedtls/sha256.c index 2128e598834..b8bc43b612e 100644 --- a/lib/mbedtls/sha256.c +++ b/lib/mbedtls/sha256.c @@ -10,6 +10,11 @@ #endif /* USE_HOSTCC */ #include <u-boot/sha256.h> +#if CONFIG_IS_ENABLED(HKDF_MBEDTLS) +#include <mbedtls/md.h> +#include <mbedtls/hkdf.h> +#endif + const u8 sha256_der_prefix[SHA256_DER_LEN] = { 0x30, 0x31, 0x30, 0x0d, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x05, @@ -33,3 +38,20 @@ void sha256_finish(sha256_context *ctx, uint8_t digest[SHA256_SUM_LEN]) mbedtls_sha256_finish(ctx, digest); mbedtls_sha256_free(ctx); } + +#if CONFIG_IS_ENABLED(HKDF_MBEDTLS) +int sha256_hkdf(const unsigned char *salt, int saltlen, + const unsigned char *ikm, int ikmlen, + const unsigned char *info, int infolen, + unsigned char *output, int outputlen) +{ + const mbedtls_md_info_t *md; + + md = mbedtls_md_info_from_type(MBEDTLS_MD_SHA256);
I have added check in v5
+ + return mbedtls_hkdf(md, salt, saltlen, + ikm, ikmlen, + info, infolen, + output, outputlen); +} +#endif -- 2.25.1
Regards, Raymond
Regards, Philippe
Adds a test for the function sha256_hkdf.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- test/lib/Makefile | 1 + test/lib/test_sha256_hkdf.c | 107 ++++++++++++++++++++++++++++++++++++ 2 files changed, 108 insertions(+) create mode 100644 test/lib/test_sha256_hkdf.c
diff --git a/test/lib/Makefile b/test/lib/Makefile index 4c0abcba81a..24ce6ed8f00 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_UT_LIB_ASN1) += asn1.o obj-$(CONFIG_UT_LIB_RSA) += rsa.o obj-$(CONFIG_AES) += test_aes.o obj-$(CONFIG_SHA256) += test_sha256_hmac.o +obj-$(CONFIG_HKDF_MBEDTLS) += test_sha256_hkdf.o obj-$(CONFIG_GETOPT) += getopt.o obj-$(CONFIG_CRC8) += test_crc8.o obj-$(CONFIG_UT_LIB_CRYPT) += test_crypt.o diff --git a/test/lib/test_sha256_hkdf.c b/test/lib/test_sha256_hkdf.c new file mode 100644 index 00000000000..00090ffbc24 --- /dev/null +++ b/test/lib/test_sha256_hkdf.c @@ -0,0 +1,107 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024 Philippe Reynes philippe.reynes@softathome.com + * + * Unit tests for sha256_hkdf functions + */ + +#include <command.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> +#include <u-boot/sha256.h> + +struct test_sha256_hkdf_s { + unsigned char *salt; + int saltlen; + unsigned char *ikm; + int ikmlen; + unsigned char *info; + int infolen; + unsigned char *expected; + int expectedlen; +}; + +/* + * data comes from: + * https://www.rfc-editor.org/rfc/rfc5869 + */ +static unsigned char salt_test1[] = { + 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, + 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c }; + +static unsigned char ikm_test1[] = { + 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, + 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b, 0x0b }; + +static unsigned char info_test1[] = { + 0xf0, 0xf1, 0xf2, 0xf3, 0xf4, 0xf5, 0xf6, 0xf7, 0xf8, 0xf9 }; + +static unsigned char expected_test1[] = { + 0x3c, 0xb2, 0x5f, 0x25, 0xfa, 0xac, 0xd5, 0x7a, + 0x90, 0x43, 0x4f, 0x64, 0xd0, 0x36, 0x2f, 0x2a, + 0x2d, 0x2d, 0x0a, 0x90, 0xcf, 0x1a, 0x5a, 0x4c, + 0x5d, 0xb0, 0x2d, 0x56, 0xec, 0xc4, 0xc5, 0xbf, + 0x34, 0x00, 0x72, 0x08, 0xd5, 0xb8, 0x87, 0x18, + 0x58, 0x65 }; + +static struct test_sha256_hkdf_s test_sha256_hkdf[] = { + { + .salt = salt_test1, + .saltlen = sizeof(salt_test1), + .ikm = ikm_test1, + .ikmlen = sizeof(ikm_test1), + .info = info_test1, + .infolen = sizeof(info_test1), + .expected = expected_test1, + .expectedlen = sizeof(expected_test1), + }, +}; + +static int _lib_test_sha256_hkdf_run(struct unit_test_state *uts, + unsigned char *salt, int saltlen, + unsigned char *ikm, int ikmlen, + unsigned char *info, int infolen, + unsigned char *expected, int expectedlen) +{ + unsigned char output[64]; + int ret; + + ut_assert(expectedlen <= sizeof(output)); + ret = sha256_hkdf(salt, saltlen, ikm, ikmlen, info, infolen, output, expectedlen); + ut_assert(!ret); + ut_asserteq_mem(expected, output, expectedlen); + + return 0; +} + +static int lib_test_sha256_hkdf_run(struct unit_test_state *uts, + struct test_sha256_hkdf_s *test) +{ + unsigned char *salt = test->salt; + int saltlen = test->saltlen; + unsigned char *ikm = test->ikm; + int ikmlen = test->ikmlen; + unsigned char *info = test->info; + int infolen = test->infolen; + unsigned char *expected = test->expected; + int expectedlen = test->expectedlen; + + return _lib_test_sha256_hkdf_run(uts, salt, saltlen, ikm, ikmlen, + info, infolen, expected, expectedlen); +} + +static int lib_test_sha256_hkdf(struct unit_test_state *uts) +{ + int i, ret = 0; + + for (i = 0; i < ARRAY_SIZE(test_sha256_hkdf); i++) { + ret = lib_test_sha256_hkdf_run(uts, &test_sha256_hkdf[i]); + if (ret) + break; + } + + return ret; +} + +LIB_TEST(lib_test_sha256_hkdf, 0);
Hi Philippe,
- Unit tests for sha256_hkdf functions
int saltlen;
unsigned char *ikm;
int ikmlen;
int infolen;
int expectedlen;
- data comes from:
Shall we consider more test vectors for: Zero-length salt. Zero-length info. Maximum-length output.
0x58, 0x65 };
.salt = salt_test1,
.ikm = ikm_test1,
.info = info_test1,
expectedlen) +{
Please use SHA512_SUM_LEN to avoid magic numbers.
int ret;
ut_assert(!ret);
expectedlen); +}
int i, ret = 0;
if (ret)
break;
return ret;
2.25.1
Regards, Raymond
Hi Raymond,
Hi Philippe,
Adds a test for the function sha256_hkdf. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> --- test/lib/Makefile | 1 + test/lib/test_sha256_hkdf.c | 107 ++++++++++++++++++++++++++++++++++++ 2 files changed, 108 insertions(+) create mode 100644 test/lib/test_sha256_hkdf.c diff --git a/test/lib/Makefile b/test/lib/Makefile index 4c0abcba81a..24ce6ed8f00 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_UT_LIB_ASN1) += asn1.o obj-$(CONFIG_UT_LIB_RSA) += rsa.o obj-$(CONFIG_AES) += test_aes.o obj-$(CONFIG_SHA256) += test_sha256_hmac.o +obj-$(CONFIG_HKDF_MBEDTLS) += test_sha256_hkdf.o obj-$(CONFIG_GETOPT) += getopt.o obj-$(CONFIG_CRC8) += test_crc8.o obj-$(CONFIG_UT_LIB_CRYPT) += test_crypt.o diff --git a/test/lib/test_sha256_hkdf.c b/test/lib/test_sha256_hkdf.c new file mode 100644 index 00000000000..00090ffbc24 --- /dev/null +++ b/test/lib/test_sha256_hkdf.c @@ -0,0 +1,107 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024 Philippe Reynes <philippe.reynes@softathome.com> + * + * Unit tests for sha256_hkdf functions + */ + +#include <command.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> +#include <u-boot/sha256.h> + +struct test_sha256_hkdf_s { + unsigned char *salt; + int saltlen; + unsigned char *ikm; + int ikmlen; + unsigned char *info; + int infolen; + unsigned char *expected; + int expectedlen; +}; + +/* + * data comes from: + * https://www.rfc-editor.org/rfc/rfc5869 <https://www.rfc-editor.org/rfc/rfc5869> + */
I have added all tests from the RFC. So now, there is 3 tests. The second test use longer input/output, and the third use empty salt and info.
For the second test, I have increased this 64 to 256, as the output must be bigger than the maximum output size of all tests. I don't really know which constant I can use... so I have kept 256.
+ int ret; + + ut_assert(expectedlen <= sizeof(output)); + ret = sha256_hkdf(salt, saltlen, ikm, ikmlen, info, infolen, output, expectedlen); + ut_assert(!ret); + ut_asserteq_mem(expected, output, expectedlen); + + return 0; +} + +static int lib_test_sha256_hkdf_run(struct unit_test_state *uts, + struct test_sha256_hkdf_s *test) +{ + unsigned char *salt = test->salt; + int saltlen = test->saltlen; + unsigned char *ikm = test->ikm; + int ikmlen = test->ikmlen; + unsigned char *info = test->info; + int infolen = test->infolen; + unsigned char *expected = test->expected; + int expectedlen = test->expectedlen; + + return _lib_test_sha256_hkdf_run(uts, salt, saltlen, ikm, ikmlen, + info, infolen, expected, expectedlen); +} + +static int lib_test_sha256_hkdf(struct unit_test_state *uts) +{ + int i, ret = 0; + + for (i = 0; i < ARRAY_SIZE(test_sha256_hkdf); i++) { + ret = lib_test_sha256_hkdf_run(uts, &test_sha256_hkdf[i]); + if (ret) + break; + } + + return ret; +} + +LIB_TEST(lib_test_sha256_hkdf, 0); -- 2.25.1
Regards, Raymond
btw, I have enabled mbedtls in the config sandbox to have at least one config with mbedtls and hkdf.
Regards, Philippe
Philippe REYNES
Philippe Reynes
Raymond Mao
