[U-Boot] [RFC] [PATCH] DaVinci/i2c: allow multiple buses
Hi Tom,
I'm requesting comments on the following (untested) patch. It adds support for multiple i2c buses on davinci_i2c, without altering one line of code. What I don't like is that I'm doing a bit of macro black magic to transform constants into variables. But I don't know whether refactoring the code would be accepted, so this is a first shot.
Regards,
On Wed, Dec 21, 2011 at 10:36 PM, Jérôme Carretero cJ-uboot@zougloub.eu wrote:
Hi Tom,
So, this follows the example of other i2c drivers, but as Wolfgang likes to point out, following another bad example isn't a valid reason to do something. So, is this the right way or a bad example to follow, Wolfgang or Heiko? Thanks!
Regards,
-- cJ
commit 53d99d331dc7fc4bf3384a59bbca564bf1b85f6b Author: Jerome Carretero cJ-uboot@zougloub.eu Date: Thu Dec 22 00:26:13 2011 -0500
DaVinci/i2c: Support for multiple buses
diff --git a/arch/arm/include/asm/arch-davinci/i2c_defs.h b/arch/arm/include/asm/arch-davinci/i2c_defs.h index 24cd268..1d24fbf 100644 --- a/arch/arm/include/asm/arch-davinci/i2c_defs.h +++ b/arch/arm/include/asm/arch-davinci/i2c_defs.h @@ -25,13 +25,18 @@ #ifndef _DAVINCI_I2C_H_ #define _DAVINCI_I2C_H_
+#include <asm/arch/hardware.h>
#define I2C_WRITE 0 #define I2C_READ 1
#ifndef CONFIG_SOC_DA8XX -#define I2C_BASE 0x01c21000 +# define I2C_BASE DAVINCI_I2C_BASE +# define I2C_DEFAULT_BASE I2C_BASE #else -#define I2C_BASE 0x01c22000 +# define I2C_BASE0 DAVINCI_I2C0_BASE +# define I2C_BASE1 DAVINCI_I2C1_BASE +# define I2C_DEFAULT_BASE I2C_BASE0 #endif
#define I2C_OA (I2C_BASE + 0x00) diff --git a/drivers/i2c/davinci_i2c.c b/drivers/i2c/davinci_i2c.c index 2abddfb..be7fb7a 100644 --- a/drivers/i2c/davinci_i2c.c +++ b/drivers/i2c/davinci_i2c.c @@ -29,6 +29,44 @@ #include <asm/arch/hardware.h> #include <asm/arch/i2c_defs.h>
+#if defined(CONFIG_I2C_MULTI_BUS)
+static unsigned int bus_initialized[I2C_BUS_MAX]; +static unsigned int current_bus; +static unsigned long i2c_base = I2C_DEFAULT_BASE;
+#ifndef I2C_BASE +# define I2C_BASE i2c_base +#else +# error CONFIG_I2C_MULTI_BUS *and* I2C_BASE defined ! +#endif
+int i2c_set_bus_num(unsigned int bus) +{
- if ((bus < 0) || (bus >= I2C_BUS_MAX)) { // TODO where to put I2C_BUS_MAX ?
- printf("Bad bus: %d\n", bus);
- return -1;
- if (bus == 1)
- i2c_base = I2C_BASE1;
- else
- i2c_base = I2C_BASE0;
- current_bus = bus;
- if (!bus_initialized[current_bus])
- i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
+unsigned int i2c_get_bus_num(void) +{
- return current_bus;
#define CHECK_NACK() \ do {\ if (tmp & (I2C_TIMEOUT | I2C_STAT_NACK)) {\
Hello Tom, Jérôme,
Sorry for the late reply, but I just starting to look through my backlog, after my vacation ...
Hi Tom,
Yes, that is the actual (not really nice) state to implement the "multibus" feature for i2c. The better way would be to go this way:
http://git.denx.de/?p=u-boot/u-boot-i2c.git;a=shortlog;h=refs/heads/multibus...
but this branch is not up to date, some test on at last powerpc and arm architectures should be done, and there are a lof of checkpatch errors in this branch (any help is welcome ;-) ... so there is some work to do, before this can go to mainline ...
bye, Heiko
Thanks for the pointer. I'll parse that code and do some testing on ARM (DaVinci).
Regards,
Heiko Schocher
Jérôme Carretero
