[U-Boot] [PATCH v3 0/6] arm: tegra: apalis-tk1, mmc and ext clock loopback
This series adds support for the Toradex Apalis TK1 as well as moves the CONFIG_TEGRA_MMC to Kconfig and introduces a new option to disable the external clock loopback on SDMMC3.
The whole series is also available here:
http://git.toradex.com/cgit/u-boot-toradex.git/log/?h=for-next
Changes in v3: - My recent fresh install of Fedora 25 was missing an aarch64 toolchain which made moveconfig.py not properly handle the 6 newer Tegras. I now re-run moveconfig.py after installing an aarch64 toolchain and it all looks sane. Sorry about that, Tom. - Cleaned-up defconfig using savedefconfig.
Changes in v2: - Added Simon's reviewed-by. - Added Simon's reviewed-by. - Added Simon's reviewed-by. - Added Simon's reviewed-by. - Added TODO(email) as suggested by Simon so it is clear this is temporary and will be moved to device tree controlled approach once proper kernel integration made it mainline.
Marcel Ziswiler (6): arm: tegra: initial support for apalis tk1 mmc: tegra: introduce CONFIG_TEGRA_MMC to Kconfig mmc: tegra: move CONFIG_TEGRA_MMC from headers to defconfigs mmc: tegra: allow disabling external clock loopback apalis-tk1: disable external clock loopback on SDMMC3 apalis-tk1: clean-up defconfig
arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-apalis.dts | 2203 ++++++++++++++++++++ arch/arm/include/asm/arch-tegra/tegra_mmc.h | 2 + arch/arm/mach-tegra/tegra124/Kconfig | 7 + board/toradex/apalis-tk1/Kconfig | 30 + board/toradex/apalis-tk1/MAINTAINERS | 7 + board/toradex/apalis-tk1/Makefile | 5 + board/toradex/apalis-tk1/apalis-tk1.c | 175 ++ board/toradex/apalis-tk1/as3722_init.c | 117 ++ board/toradex/apalis-tk1/as3722_init.h | 41 + .../toradex/apalis-tk1/pinmux-config-apalis-tk1.h | 287 +++ configs/apalis-tk1_defconfig | 46 + configs/apalis_t30_defconfig | 1 + configs/beaver_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/e2220-1170_defconfig | 9 +- configs/harmony_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/p2371-0000_defconfig | 9 +- configs/p2371-2180_defconfig | 9 +- configs/p2571_defconfig | 9 +- configs/p2771-0000-000_defconfig | 9 +- configs/p2771-0000-500_defconfig | 9 +- configs/paz00_defconfig | 1 + configs/plutux_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/whistler_defconfig | 1 + drivers/mmc/Kconfig | 17 + drivers/mmc/tegra_mmc.c | 16 + include/configs/apalis-tk1.h | 180 ++ include/configs/apalis_t30.h | 1 - include/configs/beaver.h | 1 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/colibri_t20.h | 1 - include/configs/colibri_t30.h | 1 - include/configs/dalmore.h | 1 - include/configs/e2220-1170.h | 1 - include/configs/harmony.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/medcom-wide.h | 1 - include/configs/nyan-big.h | 1 - include/configs/p2371-0000.h | 1 - include/configs/p2371-2180.h | 1 - include/configs/p2571.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/paz00.h | 1 - include/configs/plutux.h | 1 - include/configs/seaboard.h | 1 - include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/trimslice.h | 1 - include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/whistler.h | 1 - scripts/config_whitelist.txt | 1 - 67 files changed, 3160 insertions(+), 74 deletions(-) create mode 100644 arch/arm/dts/tegra124-apalis.dts create mode 100644 board/toradex/apalis-tk1/Kconfig create mode 100644 board/toradex/apalis-tk1/MAINTAINERS create mode 100644 board/toradex/apalis-tk1/Makefile create mode 100644 board/toradex/apalis-tk1/apalis-tk1.c create mode 100644 board/toradex/apalis-tk1/as3722_init.c create mode 100644 board/toradex/apalis-tk1/as3722_init.h create mode 100644 board/toradex/apalis-tk1/pinmux-config-apalis-tk1.h create mode 100644 configs/apalis-tk1_defconfig create mode 100644 include/configs/apalis-tk1.h
This patch adds board support for the Toradex Apalis TK1 a computer on module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec. Furthermore, there is a Kinetis MK20DN512 companion micro controller for analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different carrier boards for now as the base module features are deemed sufficient enough for regular booting.
The following functionality is working so far: - eMMC boot, environment storage and Toradex factory config block - Gigabit Ethernet - MMC/SD cards (both MMC1 as well as SD1 slot) - USB client/host (dual role OTG port as client e.g. for DFU/UMS or host, other two ports as host)
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v3: None Changes in v2: - Added Simon's reviewed-by.
arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-apalis.dts | 2203 ++++++++++++++++++++ arch/arm/mach-tegra/tegra124/Kconfig | 7 + board/toradex/apalis-tk1/Kconfig | 30 + board/toradex/apalis-tk1/MAINTAINERS | 7 + board/toradex/apalis-tk1/Makefile | 5 + board/toradex/apalis-tk1/apalis-tk1.c | 175 ++ board/toradex/apalis-tk1/as3722_init.c | 117 ++ board/toradex/apalis-tk1/as3722_init.h | 41 + .../toradex/apalis-tk1/pinmux-config-apalis-tk1.h | 287 +++ configs/apalis-tk1_defconfig | 53 + include/configs/apalis-tk1.h | 181 ++ 12 files changed, 3107 insertions(+) create mode 100644 arch/arm/dts/tegra124-apalis.dts create mode 100644 board/toradex/apalis-tk1/Kconfig create mode 100644 board/toradex/apalis-tk1/MAINTAINERS create mode 100644 board/toradex/apalis-tk1/Makefile create mode 100644 board/toradex/apalis-tk1/apalis-tk1.c create mode 100644 board/toradex/apalis-tk1/as3722_init.c create mode 100644 board/toradex/apalis-tk1/as3722_init.h create mode 100644 board/toradex/apalis-tk1/pinmux-config-apalis-tk1.h create mode 100644 configs/apalis-tk1_defconfig create mode 100644 include/configs/apalis-tk1.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3ee608b..dd2a2d8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -57,6 +57,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra30-colibri.dtb \ tegra30-tec-ng.dtb \ tegra114-dalmore.dtb \ + tegra124-apalis.dtb \ tegra124-jetson-tk1.dtb \ tegra124-nyan-big.dtb \ tegra124-cei-tk1-som.dtb \ diff --git a/arch/arm/dts/tegra124-apalis.dts b/arch/arm/dts/tegra124-apalis.dts new file mode 100644 index 0000000..3853a28 --- /dev/null +++ b/arch/arm/dts/tegra124-apalis.dts @@ -0,0 +1,2203 @@ +/* + * Copyright 2016 Toradex AG + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include "tegra124.dtsi" + +/ { + model = "Toradex Apalis TK1 on Apalis Evaluation Board"; + compatible = "toradex,apalis-tk1-eval", "toradex,apalis-tk1", + "nvidia,tegra124"; + + aliases { + i2c0 = "/i2c@7000d000"; + i2c1 = "/i2c@7000c000"; + i2c2 = "/i2c@7000c400"; + i2c3 = "/i2c@7000c500"; + mmc0 = "/sdhci@700b0600"; + mmc1 = "/sdhci@700b0000"; + mmc2 = "/sdhci@700b0400"; + rtc0 = "/i2c@7000c000/rtc@68"; + rtc1 = "/i2c@7000d000/pmic@40"; + rtc2 = "/rtc@7000e000"; + serial0 = &uarta; + serial1 = &uartb; + serial2 = &uartc; + serial3 = &uartd; + usb0 = "/usb@7d000000"; + usb1 = "/usb@7d004000"; + usb2 = "/usb@7d008000"; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory { + reg = <0x0 0x80000000 0x0 0x80000000>; + }; + + pcie-controller@01003000 { + status = "okay"; + avddio-pex-supply = <&vdd_1v05>; + avdd-pex-pll-supply = <&vdd_1v05>; + avdd-pll-erefe-supply = <&avdd_1v05>; + dvddio-pex-supply = <&vdd_1v05>; + hvdd-pex-pll-e-supply = <®_3v3>; + hvdd-pex-supply = <®_3v3>; + vddio-pex-ctl-supply = <®_3v3>; + + /* Apalis PCIe (additional lane Apalis type specific) */ + pci@1,0 { + /* PCIE1_RX/TX and TS_DIFF1/2 left disabled */ + }; + + /* I210 Gigabit Ethernet Controller (On-module) */ + pci@2,0 { + status = "okay"; + }; + }; + + host1x@50000000 { + hdmi@54280000 { + pll-supply = <®_1v05_avdd_hdmi_pll>; + vdd-supply = <®_3v3_avdd_hdmi>; + nvidia,ddc-i2c-bus = <&hdmi_ddc>; + nvidia,hpd-gpio = + <&gpio TEGRA_GPIO(N, 7) GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + }; + + gpu@0,57000000 { + /* + * Node left disabled on purpose - the bootloader will enable + * it after having set the VPR up + */ + vdd-supply = <&vdd_gpu>; + }; + + pinmux: pinmux@70000868 { + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pinmux { + /* Analogue Audio (On-module) */ + dap3_fs_pp0 { + nvidia,pins = "dap3_fs_pp0"; + nvidia,function = "i2s2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap3_din_pp1 { + nvidia,pins = "dap3_din_pp1"; + nvidia,function = "i2s2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + dap3_dout_pp2 { + nvidia,pins = "dap3_dout_pp2"; + nvidia,function = "i2s2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap3_sclk_pp3 { + nvidia,pins = "dap3_sclk_pp3"; + nvidia,function = "i2s2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap_mclk1_pw4 { + nvidia,pins = "dap_mclk1_pw4"; + nvidia,function = "extperiph1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis BKL1_ON */ + pbb5 { + nvidia,pins = "pbb5"; + nvidia,function = "vgp5"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis BKL1_PWM */ + pu6 { + nvidia,pins = "pu6"; + nvidia,function = "pwm3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis CAM1_MCLK */ + cam_mclk_pcc0 { + nvidia,pins = "cam_mclk_pcc0"; + nvidia,function = "vi_alt3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis Digital Audio */ + dap2_fs_pa2 { + nvidia,pins = "dap2_fs_pa2"; + nvidia,function = "hda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + dap2_sclk_pa3 { + nvidia,pins = "dap2_sclk_pa3"; + nvidia,function = "hda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + dap2_din_pa4 { + nvidia,pins = "dap2_din_pa4"; + nvidia,function = "hda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + dap2_dout_pa5 { + nvidia,pins = "dap2_dout_pa5"; + nvidia,function = "hda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pbb3 { /* DAP1_RESET */ + nvidia,pins = "pbb3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + clk3_out_pee0 { + nvidia,pins = "clk3_out_pee0"; + nvidia,function = "extperiph3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis GPIO */ + ddc_scl_pv4 { + nvidia,pins = "ddc_scl_pv4"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + ddc_sda_pv5 { + nvidia,pins = "ddc_sda_pv5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pex_l0_rst_n_pdd1 { + nvidia,pins = "pex_l0_rst_n_pdd1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pex_l0_clkreq_n_pdd2 { + nvidia,pins = "pex_l0_clkreq_n_pdd2"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pex_l1_rst_n_pdd5 { + nvidia,pins = "pex_l1_rst_n_pdd5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pex_l1_clkreq_n_pdd6 { + nvidia,pins = "pex_l1_clkreq_n_pdd6"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + dp_hpd_pff0 { + nvidia,pins = "dp_hpd_pff0"; + nvidia,function = "dp"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pff2 { + nvidia,pins = "pff2"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + owr { /* PEX_L1_CLKREQ_N multiplexed GPIO6 */ + nvidia,pins = "owr"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + nvidia,rcv-sel = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis HDMI1_CEC */ + hdmi_cec_pee3 { + nvidia,pins = "hdmi_cec_pee3"; + nvidia,function = "cec"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis HDMI1_HPD */ + hdmi_int_pn7 { + nvidia,pins = "hdmi_int_pn7"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,rcv-sel = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis I2C1 */ + gen1_i2c_scl_pc4 { + nvidia,pins = "gen1_i2c_scl_pc4"; + nvidia,function = "i2c1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + gen1_i2c_sda_pc5 { + nvidia,pins = "gen1_i2c_sda_pc5"; + nvidia,function = "i2c1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis I2C2 (DDC) */ + gen2_i2c_scl_pt5 { + nvidia,pins = "gen2_i2c_scl_pt5"; + nvidia,function = "i2c2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + gen2_i2c_sda_pt6 { + nvidia,pins = "gen2_i2c_sda_pt6"; + nvidia,function = "i2c2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis I2C3 (CAM) */ + cam_i2c_scl_pbb1 { + nvidia,pins = "cam_i2c_scl_pbb1"; + nvidia,function = "i2c3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + cam_i2c_sda_pbb2 { + nvidia,pins = "cam_i2c_sda_pbb2"; + nvidia,function = "i2c3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis MMC1 */ + sdmmc1_cd_n_pv3 { /* CD# GPIO */ + nvidia,pins = "sdmmc1_wp_n_pv3"; + nvidia,function = "sdmmc1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + clk2_out_pw5 { /* D5 GPIO */ + nvidia,pins = "clk2_out_pw5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc1_dat3_py4 { + nvidia,pins = "sdmmc1_dat3_py4"; + nvidia,function = "sdmmc1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc1_dat2_py5 { + nvidia,pins = "sdmmc1_dat2_py5"; + nvidia,function = "sdmmc1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc1_dat1_py6 { + nvidia,pins = "sdmmc1_dat1_py6"; + nvidia,function = "sdmmc1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc1_dat0_py7 { + nvidia,pins = "sdmmc1_dat0_py7"; + nvidia,function = "sdmmc1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc1_clk_pz0 { + nvidia,pins = "sdmmc1_clk_pz0"; + nvidia,function = "sdmmc1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc1_cmd_pz1 { + nvidia,pins = "sdmmc1_cmd_pz1"; + nvidia,function = "sdmmc1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + clk2_req_pcc5 { /* D4 GPIO */ + nvidia,pins = "clk2_req_pcc5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3_clk_lb_in_pee5 { /* D6 GPIO */ + nvidia,pins = "sdmmc3_clk_lb_in_pee5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + usb_vbus_en2_pff1 { /* D7 GPIO */ + nvidia,pins = "usb_vbus_en2_pff1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis PWM */ + ph0 { + nvidia,pins = "ph0"; + nvidia,function = "pwm0"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ph1 { + nvidia,pins = "ph1"; + nvidia,function = "pwm1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ph2 { + nvidia,pins = "ph2"; + nvidia,function = "pwm2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + /* PWM3 active on pu6 being Apalis BKL1_PWM */ + ph3 { + nvidia,pins = "ph3"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis SATA1_ACT# */ + dap1_dout_pn2 { + nvidia,pins = "dap1_dout_pn2"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis SD1 */ + sdmmc3_clk_pa6 { + nvidia,pins = "sdmmc3_clk_pa6"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3_cmd_pa7 { + nvidia,pins = "sdmmc3_cmd_pa7"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3_dat3_pb4 { + nvidia,pins = "sdmmc3_dat3_pb4"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3_dat2_pb5 { + nvidia,pins = "sdmmc3_dat2_pb5"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3_dat1_pb6 { + nvidia,pins = "sdmmc3_dat1_pb6"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3_dat0_pb7 { + nvidia,pins = "sdmmc3_dat0_pb7"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3_cd_n_pv2 { /* CD# GPIO */ + nvidia,pins = "sdmmc3_cd_n_pv2"; + nvidia,function = "rsvd3"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis SPDIF */ + spdif_out_pk5 { + nvidia,pins = "spdif_out_pk5"; + nvidia,function = "spdif"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + spdif_in_pk6 { + nvidia,pins = "spdif_in_pk6"; + nvidia,function = "spdif"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis SPI1 */ + ulpi_clk_py0 { + nvidia,pins = "ulpi_clk_py0"; + nvidia,function = "spi1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_dir_py1 { + nvidia,pins = "ulpi_dir_py1"; + nvidia,function = "spi1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + ulpi_nxt_py2 { + nvidia,pins = "ulpi_nxt_py2"; + nvidia,function = "spi1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_stp_py3 { + nvidia,pins = "ulpi_stp_py3"; + nvidia,function = "spi1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis SPI2 */ + pg5 { + nvidia,pins = "pg5"; + nvidia,function = "spi4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pg6 { + nvidia,pins = "pg6"; + nvidia,function = "spi4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pg7 { + nvidia,pins = "pg7"; + nvidia,function = "spi4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pi3 { + nvidia,pins = "pi3"; + nvidia,function = "spi4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis UART1 */ + pb1 { /* DCD GPIO */ + nvidia,pins = "pb1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pk7 { /* RI GPIO */ + nvidia,pins = "pk7"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + uart1_txd_pu0 { + nvidia,pins = "pu0"; + nvidia,function = "uarta"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + uart1_rxd_pu1 { + nvidia,pins = "pu1"; + nvidia,function = "uarta"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + uart1_cts_n_pu2 { + nvidia,pins = "pu2"; + nvidia,function = "uarta"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + uart1_rts_n_pu3 { + nvidia,pins = "pu3"; + nvidia,function = "uarta"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + uart3_cts_n_pa1 { /* DSR GPIO */ + nvidia,pins = "uart3_cts_n_pa1"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + uart3_rts_n_pc0 { /* DTR GPIO */ + nvidia,pins = "uart3_rts_n_pc0"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis UART2 */ + uart2_txd_pc2 { + nvidia,pins = "uart2_txd_pc2"; + nvidia,function = "irda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + uart2_rxd_pc3 { + nvidia,pins = "uart2_rxd_pc3"; + nvidia,function = "irda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + uart2_cts_n_pj5 { + nvidia,pins = "uart2_cts_n_pj5"; + nvidia,function = "uartb"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + uart2_rts_n_pj6 { + nvidia,pins = "uart2_rts_n_pj6"; + nvidia,function = "uartb"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis UART3 */ + uart3_txd_pw6 { + nvidia,pins = "uart3_txd_pw6"; + nvidia,function = "uartc"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + uart3_rxd_pw7 { + nvidia,pins = "uart3_rxd_pw7"; + nvidia,function = "uartc"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis UART4 */ + uart4_rxd_pb0 { + nvidia,pins = "pb0"; + nvidia,function = "uartd"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + uart4_txd_pj7 { + nvidia,pins = "pj7"; + nvidia,function = "uartd"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis USBH_EN */ + usb_vbus_en1_pn5 { + nvidia,pins = "usb_vbus_en1_pn5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + nvidia,open-drain = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis USBH_OC# */ + pbb0 { + nvidia,pins = "pbb0"; + nvidia,function = "vgp6"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis USBO1_EN */ + usb_vbus_en0_pn4 { + nvidia,pins = "usb_vbus_en0_pn4"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + nvidia,open-drain = <TEGRA_PIN_DISABLE>; + }; + + /* Apalis USBO1_OC# */ + pbb4 { + nvidia,pins = "pbb4"; + nvidia,function = "vgp4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* Apalis WAKE1_MICO */ + pex_wake_n_pdd3 { + nvidia,pins = "pex_wake_n_pdd3"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* CORE_PWR_REQ */ + core_pwr_req { + nvidia,pins = "core_pwr_req"; + nvidia,function = "pwron"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* CPU_PWR_REQ */ + cpu_pwr_req { + nvidia,pins = "cpu_pwr_req"; + nvidia,function = "cpu"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* DVFS */ + dvfs_pwm_px0 { + nvidia,pins = "dvfs_pwm_px0"; + nvidia,function = "cldvfs"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dvfs_clk_px2 { + nvidia,pins = "dvfs_clk_px2"; + nvidia,function = "cldvfs"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* eMMC */ + sdmmc4_dat0_paa0 { + nvidia,pins = "sdmmc4_dat0_paa0"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_dat1_paa1 { + nvidia,pins = "sdmmc4_dat1_paa1"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_dat2_paa2 { + nvidia,pins = "sdmmc4_dat2_paa2"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_dat3_paa3 { + nvidia,pins = "sdmmc4_dat3_paa3"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_dat4_paa4 { + nvidia,pins = "sdmmc4_dat4_paa4"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_dat5_paa5 { + nvidia,pins = "sdmmc4_dat5_paa5"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_dat6_paa6 { + nvidia,pins = "sdmmc4_dat6_paa6"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_dat7_paa7 { + nvidia,pins = "sdmmc4_dat7_paa7"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_clk_pcc4 { + nvidia,pins = "sdmmc4_clk_pcc4"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4_cmd_pt7 { + nvidia,pins = "sdmmc4_cmd_pt7"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* JTAG_RTCK */ + jtag_rtck { + nvidia,pins = "jtag_rtck"; + nvidia,function = "rtck"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* LAN_DEV_OFF# */ + ulpi_data5_po6 { + nvidia,pins = "ulpi_data5_po6"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* LAN_RESET# */ + kb_row10_ps2 { + nvidia,pins = "kb_row10_ps2"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* LAN_WAKE# */ + ulpi_data4_po5 { + nvidia,pins = "ulpi_data4_po5"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* MCU_INT1# */ + pk2 { + nvidia,pins = "pk2"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* MCU_INT2# */ + pj2 { + nvidia,pins = "pj2"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* MCU_INT3# */ + pi5 { + nvidia,pins = "pi5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* MCU_INT4# */ + pj0 { + nvidia,pins = "pj0"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* MCU_RESET */ + pbb6 { + nvidia,pins = "pbb6"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* MCU SPI */ + gpio_x4_aud_px4 { + nvidia,pins = "gpio_x4_aud_px4"; + nvidia,function = "spi2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + gpio_x5_aud_px5 { + nvidia,pins = "gpio_x5_aud_px5"; + nvidia,function = "spi2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + gpio_x6_aud_px6 { /* MCU_CS */ + nvidia,pins = "gpio_x6_aud_px6"; + nvidia,function = "spi2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + gpio_x7_aud_px7 { + nvidia,pins = "gpio_x7_aud_px7"; + nvidia,function = "spi2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + gpio_w2_aud_pw2 { /* MCU_CSEZP */ + nvidia,pins = "gpio_w2_aud_pw2"; + nvidia,function = "spi2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* PMIC_CLK_32K */ + clk_32k_in { + nvidia,pins = "clk_32k_in"; + nvidia,function = "clk"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* PMIC_CPU_OC_INT */ + clk_32k_out_pa0 { + nvidia,pins = "clk_32k_out_pa0"; + nvidia,function = "soc"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* PWR_I2C */ + pwr_i2c_scl_pz6 { + nvidia,pins = "pwr_i2c_scl_pz6"; + nvidia,function = "i2cpwr"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + pwr_i2c_sda_pz7 { + nvidia,pins = "pwr_i2c_sda_pz7"; + nvidia,function = "i2cpwr"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <TEGRA_PIN_ENABLE>; + }; + + /* PWR_INT_N */ + pwr_int_n { + nvidia,pins = "pwr_int_n"; + nvidia,function = "pmi"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* RESET_MOCI_CTRL */ + pu4 { + nvidia,pins = "pu4"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* RESET_OUT_N */ + reset_out_n { + nvidia,pins = "reset_out_n"; + nvidia,function = "reset_out_n"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* SHIFT_CTRL_DIR_IN */ + kb_row0_pr0 { + nvidia,pins = "kb_row0_pr0"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row1_pr1 { + nvidia,pins = "kb_row1_pr1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Configure level-shifter as output for HDA */ + kb_row11_ps3 { + nvidia,pins = "kb_row11_ps3"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* SHIFT_CTRL_DIR_OUT */ + kb_col5_pq5 { + nvidia,pins = "kb_col5_pq5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_col6_pq6 { + nvidia,pins = "kb_col6_pq6"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_col7_pq7 { + nvidia,pins = "kb_col7_pq7"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* SHIFT_CTRL_OE */ + kb_col0_pq0 { + nvidia,pins = "kb_col0_pq0"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_col1_pq1 { + nvidia,pins = "kb_col1_pq1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_col2_pq2 { + nvidia,pins = "kb_col2_pq2"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_col4_pq4 { + nvidia,pins = "kb_col4_pq4"; + nvidia,function = "kbc"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row2_pr2 { + nvidia,pins = "kb_row2_pr2"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* GPIO_PI6 aka TMP451 ALERT#/THERM2# */ + pi6 { + nvidia,pins = "pi6"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* TOUCH_INT */ + gpio_w3_aud_pw3 { + nvidia,pins = "gpio_w3_aud_pw3"; + nvidia,function = "spi6"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + pc7 { /* NC */ + nvidia,pins = "pc7"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pg0 { /* NC */ + nvidia,pins = "pg0"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pg1 { /* NC */ + nvidia,pins = "pg1"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pg2 { /* NC */ + nvidia,pins = "pg2"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pg3 { /* NC */ + nvidia,pins = "pg3"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pg4 { /* NC */ + nvidia,pins = "pg4"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ph4 { /* NC */ + nvidia,pins = "ph4"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ph5 { /* NC */ + nvidia,pins = "ph5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ph6 { /* NC */ + nvidia,pins = "ph6"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ph7 { /* NC */ + nvidia,pins = "ph7"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pi0 { /* NC */ + nvidia,pins = "pi0"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pi1 { /* NC */ + nvidia,pins = "pi1"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pi2 { /* NC */ + nvidia,pins = "pi2"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pi4 { /* NC */ + nvidia,pins = "pi4"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pi7 { /* NC */ + nvidia,pins = "pi7"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pk0 { /* NC */ + nvidia,pins = "pk0"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pk1 { /* NC */ + nvidia,pins = "pk1"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pk3 { /* NC */ + nvidia,pins = "pk3"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pk4 { /* NC */ + nvidia,pins = "pk4"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap1_fs_pn0 { /* NC */ + nvidia,pins = "dap1_fs_pn0"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap1_din_pn1 { /* NC */ + nvidia,pins = "dap1_din_pn1"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap1_sclk_pn3 { /* NC */ + nvidia,pins = "dap1_sclk_pn3"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_data7_po0 { /* NC */ + nvidia,pins = "ulpi_data7_po0"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_data0_po1 { /* NC */ + nvidia,pins = "ulpi_data0_po1"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_data1_po2 { /* NC */ + nvidia,pins = "ulpi_data1_po2"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_data2_po3 { /* NC */ + nvidia,pins = "ulpi_data2_po3"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_data3_po4 { /* NC */ + nvidia,pins = "ulpi_data3_po4"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + ulpi_data6_po7 { /* NC */ + nvidia,pins = "ulpi_data6_po7"; + nvidia,function = "ulpi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap4_fs_pp4 { /* NC */ + nvidia,pins = "dap4_fs_pp4"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap4_din_pp5 { /* NC */ + nvidia,pins = "dap4_din_pp5"; + nvidia,function = "rsvd3"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap4_dout_pp6 { /* NC */ + nvidia,pins = "dap4_dout_pp6"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap4_sclk_pp7 { /* NC */ + nvidia,pins = "dap4_sclk_pp7"; + nvidia,function = "rsvd3"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_col3_pq3 { /* NC */ + nvidia,pins = "kb_col3_pq3"; + nvidia,function = "kbc"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row3_pr3 { /* NC */ + nvidia,pins = "kb_row3_pr3"; + nvidia,function = "kbc"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row4_pr4 { /* NC */ + nvidia,pins = "kb_row4_pr4"; + nvidia,function = "rsvd3"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row5_pr5 { /* NC */ + nvidia,pins = "kb_row5_pr5"; + nvidia,function = "rsvd3"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row6_pr6 { /* NC */ + nvidia,pins = "kb_row6_pr6"; + nvidia,function = "kbc"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row7_pr7 { /* NC */ + nvidia,pins = "kb_row7_pr7"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row8_ps0 { /* NC */ + nvidia,pins = "kb_row8_ps0"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row9_ps1 { /* NC */ + nvidia,pins = "kb_row9_ps1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row12_ps4 { /* NC */ + nvidia,pins = "kb_row12_ps4"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row13_ps5 { /* NC */ + nvidia,pins = "kb_row13_ps5"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row14_ps6 { /* NC */ + nvidia,pins = "kb_row14_ps6"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row15_ps7 { /* NC */ + nvidia,pins = "kb_row15_ps7"; + nvidia,function = "rsvd3"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row16_pt0 { /* NC */ + nvidia,pins = "kb_row16_pt0"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + kb_row17_pt1 { /* NC */ + nvidia,pins = "kb_row17_pt1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pu5 { /* NC */ + nvidia,pins = "pu5"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pv0 { /* NC */ + nvidia,pins = "pv0"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pv1 { /* NC */ + nvidia,pins = "pv1"; + nvidia,function = "rsvd1"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + gpio_x1_aud_px1 { /* NC */ + nvidia,pins = "gpio_x1_aud_px1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + gpio_x3_aud_px3 { /* NC */ + nvidia,pins = "gpio_x3_aud_px3"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pbb7 { /* NC */ + nvidia,pins = "pbb7"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pcc1 { /* NC */ + nvidia,pins = "pcc1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + pcc2 { /* NC */ + nvidia,pins = "pcc2"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + clk3_req_pee1 { /* NC */ + nvidia,pins = "clk3_req_pee1"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + dap_mclk1_req_pee2 { /* NC */ + nvidia,pins = "dap_mclk1_req_pee2"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + /* + * Leave SDMMC3_CLK_LB_OUT muxed as SDMMC3 with output + * driver enabled aka not tristated and input driver + * enabled as well as it features some magic properties + * even though the external loopback is disabled and the + * internal loopback used as per + * SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 + * bits being set to 0xfffd according to the TRM! + */ + sdmmc3_clk_lb_out_pee4 { /* NC */ + nvidia,pins = "sdmmc3_clk_lb_out_pee4"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + }; + }; + + /* Apalis UART1 */ + serial@70006000 { + status = "okay"; + }; + + /* Apalis UART2 */ + serial@70006040 { + compatible = "nvidia,tegra124-hsuart"; + status = "okay"; + }; + + /* Apalis UART3 */ + serial@70006200 { + compatible = "nvidia,tegra124-hsuart"; + status = "okay"; + }; + + /* Apalis UART4 */ + serial@70006300 { + compatible = "nvidia,tegra124-hsuart"; + status = "okay"; + }; + + pwm@7000a000 { + status = "okay"; + }; + + hdmi_ddc: i2c@7000c400 { + clock-frequency = <100000>; + }; + + /* + * GEN1_I2C: I2C1_SDA/SCL on MXM3 pin 209/211 (e.g. RTC on carrier + * board) + */ + i2c@7000c000 { + status = "okay"; + clock-frequency = <100000>; + + pcie-switch@58 { + compatible = "plx,pex8605"; + reg = <0x58>; + }; + + /* M41T0M6 real time clock on carrier board */ + rtc@68 { + compatible = "st,m41t00"; + reg = <0x68>; + }; + }; + + /* + * GEN2_I2C: I2C2_SDA/SCL (DDC) on MXM3 pin 205/207 (e.g. display EDID) + */ + hdmi_ddc: i2c@7000c400 { + status = "okay"; + clock-frequency = <100000>; + }; + + /* + * CAM_I2C: I2C3_SDA/SCL (CAM) on MXM3 pin 201/203 (e.g. camera sensor + * on carrier board) + */ + i2c@7000c500 { + status = "okay"; + clock-frequency = <100000>; + }; + + /* I2C4 (DDC): unused */ + + /* PWR_I2C: power I2C to audio codec, PMIC and temperature sensor */ + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + /* SGTL5000 audio codec */ + sgtl5000: codec@a { + compatible = "fsl,sgtl5000"; + reg = <0x0a>; + VDDA-supply = <®_3v3>; + VDDIO-supply = <&vddio_1v8>; + clocks = <&tegra_car TEGRA124_CLK_EXTERN1>; + }; + + pmic: pmic@40 { + compatible = "ams,as3722"; + reg = <0x40>; + interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; + ams,system-power-controller; + #interrupt-cells = <2>; + interrupt-controller; + gpio-controller; + #gpio-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&as3722_default>; + + as3722_default: pinmux { + gpio2_7 { + pins = "gpio2", /* PWR_EN_+V3.3 */ + "gpio7"; /* +V1.6_LPO */ + function = "gpio"; + bias-pull-up; + }; + + gpio1_3_4_5_6 { + pins = "gpio1", "gpio3", "gpio4", + "gpio5", "gpio6"; + bias-high-impedance; + }; + }; + + regulators { + vsup-sd2-supply = <®_3v3>; + vsup-sd3-supply = <®_3v3>; + vsup-sd4-supply = <®_3v3>; + vsup-sd5-supply = <®_3v3>; + vin-ldo0-supply = <&vddio_ddr_1v35>; + vin-ldo1-6-supply = <®_3v3>; + vin-ldo2-5-7-supply = <&vddio_1v8>; + vin-ldo3-4-supply = <®_3v3>; + vin-ldo9-10-supply = <®_3v3>; + vin-ldo11-supply = <®_3v3>; + + vdd_cpu: sd0 { + regulator-name = "+VDD_CPU_AP"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1400000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <2>; + }; + + sd1 { + regulator-name = "+VDD_CORE"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-min-microamp = <2500000>; + regulator-max-microamp = <4000000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <1>; + }; + + vddio_ddr_1v35: sd2 { + regulator-name = + "+V1.35_VDDIO_DDR(sd2)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + sd3 { + regulator-name = + "+V1.35_VDDIO_DDR(sd3)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_1v05: sd4 { + regulator-name = "+V1.05"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + vddio_1v8: sd5 { + regulator-name = "+V1.8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_gpu: sd6 { + regulator-name = "+VDD_GPU_AP"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <1200000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-boot-on; + regulator-always-on; + }; + + avdd_1v05: ldo0 { + regulator-name = "+V1.05_AVDD"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-boot-on; + regulator-always-on; + ams,ext-control = <1>; + }; + + vddio_sdmmc1: ldo1 { + regulator-name = "VDDIO_SDMMC1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + ldo2 { + regulator-name = "+V1.2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3 { + regulator-name = "+V1.05_RTC"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + ams,enable-tracking; + }; + + /* 1.8V for LVDS, 3.3V for eDP */ + ldo4 { + regulator-name = "AVDD_LVDS0_PLL"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + /* LDO5 not used */ + + vddio_sdmmc3: ldo6 { + regulator-name = "VDDIO_SDMMC3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + /* LDO7 not used */ + + ldo9 { + regulator-name = "+V3.3_ETH(ldo9)"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo10 { + regulator-name = "+V3.3_ETH(ldo10)"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo11 { + regulator-name = "+V1.8_VPP_FUSE"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; + }; + + /* + * TMP451 temperature sensor + * Note: THERM_N directly connected to AS3722 PMIC THERM + */ + temperature-sensor@4c { + compatible = "ti,tmp451"; + reg = <0x4c>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(I, 6) IRQ_TYPE_LEVEL_LOW>; + #thermal-sensor-cells = <1>; + }; + }; + + /* SPI1: Apalis SPI1 */ + spi@7000d400 { + status = "okay"; + spi-max-frequency = <50000000>; + + spidev0: spidev@0 { + compatible = "spidev"; + reg = <0>; + spi-max-frequency = <50000000>; + }; + }; + + /* SPI2: MCU SPI */ + spi@7000d600 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + /* SPI4: Apalis SPI2 */ + spi@7000da00 { + status = "okay"; + spi-max-frequency = <50000000>; + + spidev1: spidev@0 { + compatible = "spidev"; + reg = <0>; + spi-max-frequency = <50000000>; + }; + }; + + pmc@7000e400 { + nvidia,invert-interrupt; + nvidia,suspend-mode = <1>; + nvidia,cpu-pwr-good-time = <500>; + nvidia,cpu-pwr-off-time = <300>; + nvidia,core-pwr-good-time = <641 3845>; + nvidia,core-pwr-off-time = <61036>; + nvidia,core-power-req-active-high; + nvidia,sys-clock-req-active-high; + + /* Set power_off bit in ResetControl register of AS3722 PMIC */ + i2c-thermtrip { + nvidia,i2c-controller-id = <4>; + nvidia,bus-addr = <0x40>; + nvidia,reg-addr = <0x36>; + nvidia,reg-data = <0x2>; + }; + }; + + /* Apalis Serial ATA */ + sata@70020000 { + avdd-supply = <&vdd_1v05>; + hvdd-supply = <®_3v3>; + vddio-supply = <&vdd_1v05>; + status = "okay"; + }; + + hda@70030000 { + status = "okay"; + }; + + usb@70090000 { + /* USBO1, USBO1 (SS), USBH2, USBH4 and USBH4 (SS) */ + avddio-pex-supply = <&vdd_1v05>; + avdd-pll-erefe-supply = <&avdd_1v05>; + avdd-pll-utmip-supply = <&vddio_1v8>; + avdd-usb-ss-pll-supply = <&vdd_1v05>; + avdd-usb-supply = <®_3v3>; + dvddio-pex-supply = <&vdd_1v05>; + hvdd-usb-ss-pll-e-supply = <®_3v3>; + hvdd-usb-ss-supply = <®_3v3>; + status = "okay"; + }; + + padctl@7009f000 { + pinctrl-0 = <&padctl_default>; + pinctrl-names = "default"; + + padctl_default: pinmux { + usb3 { + nvidia,lanes = "pcie-0", "pcie-1"; + nvidia,function = "usb3"; + nvidia,iddq = <0>; + }; + + pcie { + nvidia,lanes = "pcie-2", "pcie-3", + "pcie-4"; + nvidia,function = "pcie"; + nvidia,iddq = <0>; + }; + + sata { + nvidia,lanes = "sata-0"; + nvidia,function = "sata"; + nvidia,iddq = <0>; + }; + }; + }; + + /* Apalis MMC1 */ + sdhci@700b0000 { + status = "okay"; + /* MMC1_CD# */ + cd-gpios = <&gpio TEGRA_GPIO(V, 3) GPIO_ACTIVE_LOW>; + bus-width = <4>; + vqmmc-supply = <&vddio_sdmmc1>; + }; + + /* Apalis SD1 */ + sdhci@700b0400 { + status = "okay"; + /* SD1_CD# */ + cd-gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + bus-width = <4>; + vqmmc-supply = <&vddio_sdmmc3>; + }; + + /* eMMC */ + sdhci@700b0600 { + status = "okay"; + bus-width = <8>; + non-removable; + }; + + /* CPU DFLL clock */ + clock@70110000 { + status = "okay"; + vdd-cpu-supply = <&vdd_cpu>; + nvidia,i2c-fs-rate = <400000>; + }; + + ahub@70300000 { + i2s@70301200 { + status = "okay"; + }; + }; + + /* EHCI instance 0: USB1_DP/N -> USBO1_DP/N */ + usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + }; + + usb-phy@7d000000 { + status = "okay"; + vbus-supply = <®_usbo1_vbus>; + }; + + /* EHCI instance 1: USB2_DP/N -> USBH2_DP/N */ + usb@7d004000 { + status = "okay"; + }; + + usb-phy@7d004000 { + status = "okay"; + vbus-supply = <®_usbh_vbus>; + }; + + /* EHCI instance 2: USB3_DP/N -> USBH4_DP/N */ + usb@7d008000 { + status = "okay"; + }; + + usb-phy@7d008000 { + status = "okay"; + vbus-supply = <®_usbh_vbus>; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + /* BKL1_PWM */ + pwms = <&pwm 3 5000000>; + brightness-levels = <255 231 223 207 191 159 127 0>; + default-brightness-level = <6>; + /* BKL1_ON */ + enable-gpios = <&gpio TEGRA_GPIO(BB, 5) GPIO_ACTIVE_HIGH>; + }; + + clocks { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + clk32k_in: clock@0 { + compatible = "fixed-clock"; + reg = <0>; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + }; + + cpus { + cpu@0 { + vdd-cpu-supply = <&vdd_cpu>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + wakeup { + label = "WAKE1_MICO"; + gpios = <&gpio TEGRA_GPIO(DD, 3) GPIO_ACTIVE_LOW>; + linux,code = <KEY_WAKEUP>; + debounce-interval = <10>; + wakeup-source; + }; + }; + + reg_1v05_avdd_hdmi_pll: regulator-1v05-avdd-hdmi-pll { + compatible = "regulator-fixed"; + regulator-name = "+V1.05_AVDD_HDMI_PLL"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + gpio = <&gpio TEGRA_GPIO(H, 7) GPIO_ACTIVE_LOW>; + vin-supply = <&vdd_1v05>; + }; + + reg_3v3_mxm: regulator-3v3-mxm { + compatible = "regulator-fixed"; + regulator-name = "+V3.3_MXM"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_3v3: regulator-3v3 { + compatible = "regulator-fixed"; + regulator-name = "+V3.3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + /* PWR_EN_+V3.3 */ + gpio = <&pmic 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_3v3_mxm>; + }; + + reg_3v3_avdd_hdmi: regulator-3v3-avdd-hdmi { + compatible = "regulator-fixed"; + regulator-name = "+V3.3_AVDD_HDMI"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vdd_1v05>; + }; + + reg_5v0: regulator-5v0 { + compatible = "regulator-fixed"; + regulator-name = "5V_SW"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + /* USBO1_EN */ + reg_usbo1_vbus: regulator-usbo1-vbus { + compatible = "regulator-fixed"; + regulator-name = "VCC_USBO1"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(N, 4) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_5v0>; + }; + + /* USBH_EN */ + reg_usbh_vbus: regulator-usbh-vbus { + compatible = "regulator-fixed"; + regulator-name = "VCC_USBH(2A|2C|2D|3|4)"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(N, 5) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_5v0>; + }; + + sound { + compatible = "toradex,tegra-audio-sgtl5000-apalis_tk1", + "nvidia,tegra-audio-sgtl5000"; + nvidia,model = "Toradex Apalis TK1"; + nvidia,audio-routing = + "Headphone Jack", "HP_OUT", + "LINE_IN", "Line In Jack", + "MIC_IN", "Mic Jack"; + nvidia,i2s-controller = <&tegra_i2s2>; + nvidia,audio-codec = <&sgtl5000>; + clocks = <&tegra_car TEGRA124_CLK_PLL_A>, + <&tegra_car TEGRA124_CLK_PLL_A_OUT0>, + <&tegra_car TEGRA124_CLK_EXTERN1>; + clock-names = "pll_a", "pll_a_out0", "mclk"; + }; + + thermal-zones { + cpu { + trips { + trip@0 { + temperature = <101000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + /* + * There are currently no cooling maps because + * there are no cooling devices + */ + }; + }; + + mem { + trips { + trip@0 { + temperature = <101000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + /* + * There are currently no cooling maps because + * there are no cooling devices + */ + }; + }; + + gpu { + trips { + trip@0 { + temperature = <101000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + /* + * There are currently no cooling maps because + * there are no cooling devices + */ + }; + }; + }; +}; diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index df77462..443bfeb 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -4,6 +4,12 @@ choice prompt "Tegra124 board select" optional
+config TARGET_APALIS_TK1 + bool "Toradex Apalis TK1 module" + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select ARCH_SUPPORT_PSCI + config TARGET_JETSON_TK1 bool "NVIDIA Tegra124 Jetson TK1 board" select CPU_V7_HAS_NONSEC @@ -42,5 +48,6 @@ source "board/cei/cei-tk1-som/Kconfig" source "board/nvidia/jetson-tk1/Kconfig" source "board/nvidia/nyan-big/Kconfig" source "board/nvidia/venice2/Kconfig" +source "board/toradex/apalis-tk1/Kconfig"
endif diff --git a/board/toradex/apalis-tk1/Kconfig b/board/toradex/apalis-tk1/Kconfig new file mode 100644 index 0000000..05407ad --- /dev/null +++ b/board/toradex/apalis-tk1/Kconfig @@ -0,0 +1,30 @@ +if TARGET_APALIS_TK1 + +config SYS_BOARD + default "apalis-tk1" + +config SYS_VENDOR + default "toradex" + +config SYS_CONFIG_NAME + default "apalis-tk1" + +config TDX_CFG_BLOCK + default y + +config TDX_HAVE_MMC + default y + +config TDX_CFG_BLOCK_DEV + default "0" + +config TDX_CFG_BLOCK_PART + default "1" + +# Toradex config block in eMMC, at the end of 1st "boot sector" +config TDX_CFG_BLOCK_OFFSET + default "-512" + +source "board/toradex/common/Kconfig" + +endif diff --git a/board/toradex/apalis-tk1/MAINTAINERS b/board/toradex/apalis-tk1/MAINTAINERS new file mode 100644 index 0000000..3c908e1 --- /dev/null +++ b/board/toradex/apalis-tk1/MAINTAINERS @@ -0,0 +1,7 @@ +Apalis TK1 +M: Marcel Ziswiler marcel.ziswiler@toradex.com +S: Maintained +F: board/toradex/apalis-tk1/ +F: include/configs/apalis-tk1.h +F: configs/apalis-tk1_defconfig +F: arch/arm/dts/tegra124-apalis.dtb diff --git a/board/toradex/apalis-tk1/Makefile b/board/toradex/apalis-tk1/Makefile new file mode 100644 index 0000000..9ef06dd --- /dev/null +++ b/board/toradex/apalis-tk1/Makefile @@ -0,0 +1,5 @@ +# Copyright (c) 2016 Toradex, Inc. +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += as3722_init.o +obj-y += apalis-tk1.o diff --git a/board/toradex/apalis-tk1/apalis-tk1.c b/board/toradex/apalis-tk1/apalis-tk1.c new file mode 100644 index 0000000..c7e519c --- /dev/null +++ b/board/toradex/apalis-tk1/apalis-tk1.c @@ -0,0 +1,175 @@ +/* + * Copyright (c) 2016 Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch-tegra/ap.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include <power/as3722.h> + +#include "../common/tdx-common.h" +#include "pinmux-config-apalis-tk1.h" + +#define LAN_RESET_N TEGRA_GPIO(S, 2) + +int arch_misc_init(void) +{ + if (readl(NV_PA_BASE_SRAM + NVBOOTINFOTABLE_BOOTTYPE) == + NVBOOTTYPE_RECOVERY) + printf("USB recovery mode\n"); + + return 0; +} + +int checkboard(void) +{ + puts("Model: Toradex Apalis TK1 2GB\n"); + + return 0; +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + return ft_common_board_setup(blob, bd); +} +#endif + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_clear_tristate_input_clamping(); + + gpio_config_table(apalis_tk1_gpio_inits, + ARRAY_SIZE(apalis_tk1_gpio_inits)); + + pinmux_config_pingrp_table(apalis_tk1_pingrps, + ARRAY_SIZE(apalis_tk1_pingrps)); + + pinmux_config_drvgrp_table(apalis_tk1_drvgrps, + ARRAY_SIZE(apalis_tk1_drvgrps)); +} + +#ifdef CONFIG_PCI_TEGRA +int tegra_pcie_board_init(void) +{ + struct udevice *pmic; + int err; + + err = as3722_init(&pmic); + if (err) { + error("failed to initialize AS3722 PMIC: %d\n", err); + return err; + } + + err = as3722_sd_enable(pmic, 4); + if (err < 0) { + error("failed to enable SD4: %d\n", err); + return err; + } + + err = as3722_sd_set_voltage(pmic, 4, 0x24); + if (err < 0) { + error("failed to set SD4 voltage: %d\n", err); + return err; + } + + err = as3722_gpio_configure(pmic, 1, AS3722_GPIO_OUTPUT_VDDH | + AS3722_GPIO_INVERT); + if (err < 0) { + error("failed to configure GPIO#1 as output: %d\n", err); + return err; + } + + err = as3722_gpio_direction_output(pmic, 2, 1); + if (err < 0) { + error("failed to set GPIO#2 high: %d\n", err); + return err; + } + + /* Reset I210 Gigabit Ethernet Controller */ + gpio_request(LAN_RESET_N, "LAN_RESET_N"); + gpio_direction_output(LAN_RESET_N, 0); + + /* + * Make sure we don't get any back feeding from LAN_WAKE_N resp. + * DEV_OFF_N + */ + gpio_request(TEGRA_GPIO(O, 5), "LAN_WAKE_N"); + gpio_direction_output(TEGRA_GPIO(O, 5), 0); + + gpio_request(TEGRA_GPIO(O, 6), "LAN_DEV_OFF_N"); + gpio_direction_output(TEGRA_GPIO(O, 6), 0); + + /* Make sure LDO9 and LDO10 are initially enabled @ 0V */ + err = as3722_ldo_enable(pmic, 9); + if (err < 0) { + error("failed to enable LDO9: %d\n", err); + return err; + } + err = as3722_ldo_enable(pmic, 10); + if (err < 0) { + error("failed to enable LDO10: %d\n", err); + return err; + } + err = as3722_ldo_set_voltage(pmic, 9, 0x80); + if (err < 0) { + error("failed to set LDO9 voltage: %d\n", err); + return err; + } + err = as3722_ldo_set_voltage(pmic, 10, 0x80); + if (err < 0) { + error("failed to set LDO10 voltage: %d\n", err); + return err; + } + + mdelay(100); + + /* Make sure controller gets enabled by disabling DEV_OFF_N */ + gpio_set_value(TEGRA_GPIO(O, 6), 1); + + /* Enable LDO9 and LDO10 for +V3.3_ETH on patched prototypes */ + err = as3722_ldo_set_voltage(pmic, 9, 0xff); + if (err < 0) { + error("failed to set LDO9 voltage: %d\n", err); + return err; + } + err = as3722_ldo_set_voltage(pmic, 10, 0xff); + if (err < 0) { + error("failed to set LDO10 voltage: %d\n", err); + return err; + } + + mdelay(100); + gpio_set_value(LAN_RESET_N, 1); + +#ifdef APALIS_TK1_PCIE_EVALBOARD_INIT +#define PEX_PERST_N TEGRA_GPIO(DD, 1) /* Apalis GPIO7 */ +#define RESET_MOCI_CTRL TEGRA_GPIO(U, 4) + + /* Reset PLX PEX 8605 PCIe Switch plus PCIe devices on Apalis Evaluation + Board */ + gpio_request(PEX_PERST_N, "PEX_PERST_N"); + gpio_request(RESET_MOCI_CTRL, "RESET_MOCI_CTRL"); + gpio_direction_output(PEX_PERST_N, 0); + gpio_direction_output(RESET_MOCI_CTRL, 0); + /* Must be asserted for 100 ms after power and clocks are stable */ + mdelay(100); + gpio_set_value(PEX_PERST_N, 1); + /* Err_5: PEX_REFCLK_OUTpx/nx Clock Outputs is not Guaranteed Until + 900 us After PEX_PERST# De-assertion */ + mdelay(1); + gpio_set_value(RESET_MOCI_CTRL, 1); +#endif /* APALIS_T30_PCIE_EVALBOARD_INIT */ + + return 0; +} +#endif /* CONFIG_PCI_TEGRA */ diff --git a/board/toradex/apalis-tk1/as3722_init.c b/board/toradex/apalis-tk1/as3722_init.c new file mode 100644 index 0000000..4917034 --- /dev/null +++ b/board/toradex/apalis-tk1/as3722_init.c @@ -0,0 +1,117 @@ +/* + * Copyright (c) 2012-2016 Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch-tegra/tegra_i2c.h> +#include "as3722_init.h" + +/* AS3722-PMIC-specific early init code - get CPU rails up, etc */ + +void tegra_i2c_ll_write_addr(uint addr, uint config) +{ + struct i2c_ctlr *reg = (struct i2c_ctlr *)TEGRA_DVC_BASE; + + writel(addr, ®->cmd_addr0); + writel(config, ®->cnfg); +} + +void tegra_i2c_ll_write_data(uint data, uint config) +{ + struct i2c_ctlr *reg = (struct i2c_ctlr *)TEGRA_DVC_BASE; + + writel(data, ®->cmd_data1); + writel(config, ®->cnfg); +} + +void pmic_enable_cpu_vdd(void) +{ + debug("%s entry\n", __func__); + +#ifdef AS3722_SD1VOLTAGE_DATA + /* Set up VDD_CORE, for boards where OTP is incorrect*/ + debug("%s: Setting VDD_CORE via AS3722 reg 1\n", __func__); + /* Configure VDD_CORE via the AS3722 PMIC on the PWR I2C bus */ + tegra_i2c_ll_write_addr(AS3722_I2C_ADDR, 2); + tegra_i2c_ll_write_data(AS3722_SD1VOLTAGE_DATA, I2C_SEND_2_BYTES); + /* + * Don't write SDCONTROL - it's already 0x7F, i.e. all SDs enabled. + * tegra_i2c_ll_write_data(AS3722_SD1CONTROL_DATA, I2C_SEND_2_BYTES); + */ + udelay(10 * 1000); +#endif + + debug("%s: Setting VDD_CPU to 1.0V via AS3722 reg 0/4D\n", __func__); + /* + * Bring up VDD_CPU via the AS3722 PMIC on the PWR I2C bus. + * First set VDD to 1.0V, then enable the VDD regulator. + */ + tegra_i2c_ll_write_addr(AS3722_I2C_ADDR, 2); + tegra_i2c_ll_write_data(AS3722_SD0VOLTAGE_DATA, I2C_SEND_2_BYTES); + /* + * Don't write SDCONTROL - it's already 0x7F, i.e. all SDs enabled. + * tegra_i2c_ll_write_data(AS3722_SD0CONTROL_DATA, I2C_SEND_2_BYTES); + */ + udelay(10 * 1000); + + debug("%s: Setting VDD_GPU to 1.0V via AS3722 reg 6/4D\n", __func__); + /* + * Bring up VDD_GPU via the AS3722 PMIC on the PWR I2C bus. + * First set VDD to 1.0V, then enable the VDD regulator. + */ + tegra_i2c_ll_write_addr(AS3722_I2C_ADDR, 2); + tegra_i2c_ll_write_data(AS3722_SD6VOLTAGE_DATA, I2C_SEND_2_BYTES); + /* + * Don't write SDCONTROL - it's already 0x7F, i.e. all SDs enabled. + * tegra_i2c_ll_write_data(AS3722_SD6CONTROL_DATA, I2C_SEND_2_BYTES); + */ + udelay(10 * 1000); + + debug("%s: Set VPP_FUSE to 1.2V via AS3722 reg 0x12/4E\n", __func__); + /* + * Bring up VPP_FUSE via the AS3722 PMIC on the PWR I2C bus. + * First set VDD to 1.2V, then enable the VDD regulator. + */ + tegra_i2c_ll_write_addr(AS3722_I2C_ADDR, 2); + tegra_i2c_ll_write_data(AS3722_LDO2VOLTAGE_DATA, I2C_SEND_2_BYTES); + /* + * Don't write LDCONTROL - it's already 0xFF, i.e. all LDOs enabled. + * tegra_i2c_ll_write_data(AS3722_LDO2CONTROL_DATA, I2C_SEND_2_BYTES); + */ + udelay(10 * 1000); + + debug("%s: Set VDD_SDMMC1 to 3.3V via AS3722 reg 0x11/4E\n", __func__); + /* + * Bring up VDD_SDMMC1 via the AS3722 PMIC on the PWR I2C bus. + * First set it to value closest to 3.3V, then enable the regulator + * + * NOTE: We do this early because doing it later seems to hose the CPU + * power rail/partition startup. Need to debug. + */ + tegra_i2c_ll_write_addr(AS3722_I2C_ADDR, 2); + tegra_i2c_ll_write_data(AS3722_LDO1VOLTAGE_DATA, I2C_SEND_2_BYTES); + /* + * Don't write LDCONTROL - it's already 0xFF, i.e. all LDOs enabled. + * tegra_i2c_ll_write_data(AS3722_LDO1CONTROL_DATA, I2C_SEND_2_BYTES); + */ + udelay(10 * 1000); + + debug("%s: Set VDD_SDMMC3 to 3.3V via AS3722 reg 0x16/4E\n", __func__); + /* + * Bring up VDD_SDMMC3 via the AS3722 PMIC on the PWR I2C bus. + * First set it to bypass 3.3V straight thru, then enable the regulator + * + * NOTE: We do this early because doing it later seems to hose the CPU + * power rail/partition startup. Need to debug. + */ + tegra_i2c_ll_write_addr(AS3722_I2C_ADDR, 2); + tegra_i2c_ll_write_data(AS3722_LDO6VOLTAGE_DATA, I2C_SEND_2_BYTES); + /* + * Don't write LDCONTROL - it's already 0xFF, i.e. all LDOs enabled. + * tegra_i2c_ll_write_data(AS3722_LDO6CONTROL_DATA, I2C_SEND_2_BYTES); + */ + udelay(10 * 1000); +} diff --git a/board/toradex/apalis-tk1/as3722_init.h b/board/toradex/apalis-tk1/as3722_init.h new file mode 100644 index 0000000..64898a3 --- /dev/null +++ b/board/toradex/apalis-tk1/as3722_init.h @@ -0,0 +1,41 @@ +/* + * Copyright (c) 2012-2016 Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* AS3722-PMIC-specific early init regs */ + +#define AS3722_I2C_ADDR 0x80 + +#define AS3722_SD0VOLTAGE_REG 0x00 /* CPU */ +#define AS3722_SD1VOLTAGE_REG 0x01 /* CORE, already set by OTP */ +#define AS3722_SD6VOLTAGE_REG 0x06 /* GPU */ +#define AS3722_SDCONTROL_REG 0x4D + +#define AS3722_LDO1VOLTAGE_REG 0x11 /* VDD_SDMMC1 */ +#define AS3722_LDO2VOLTAGE_REG 0x12 /* VPP_FUSE */ +#define AS3722_LDO6VOLTAGE_REG 0x16 /* VDD_SDMMC3 */ +#define AS3722_LDCONTROL_REG 0x4E + +#define AS3722_SD0VOLTAGE_DATA (0x3C00 | AS3722_SD0VOLTAGE_REG) +#define AS3722_SD0CONTROL_DATA (0x0100 | AS3722_SDCONTROL_REG) + +#define AS3722_SD1VOLTAGE_DATA (0x3200 | AS3722_SD1VOLTAGE_REG) +#define AS3722_SD1CONTROL_DATA (0x0200 | AS3722_SDCONTROL_REG) + +#define AS3722_SD6CONTROL_DATA (0x4000 | AS3722_SDCONTROL_REG) +#define AS3722_SD6VOLTAGE_DATA (0x2800 | AS3722_SD6VOLTAGE_REG) + +#define AS3722_LDO1CONTROL_DATA (0x0200 | AS3722_LDCONTROL_REG) +#define AS3722_LDO1VOLTAGE_DATA (0x7F00 | AS3722_LDO1VOLTAGE_REG) + +#define AS3722_LDO2CONTROL_DATA (0x0400 | AS3722_LDCONTROL_REG) +#define AS3722_LDO2VOLTAGE_DATA (0x1000 | AS3722_LDO2VOLTAGE_REG) + +#define AS3722_LDO6CONTROL_DATA (0x4000 | AS3722_LDCONTROL_REG) +#define AS3722_LDO6VOLTAGE_DATA (0x3F00 | AS3722_LDO6VOLTAGE_REG) + +#define I2C_SEND_2_BYTES 0x0A02 + +void pmic_enable_cpu_vdd(void); diff --git a/board/toradex/apalis-tk1/pinmux-config-apalis-tk1.h b/board/toradex/apalis-tk1/pinmux-config-apalis-tk1.h new file mode 100644 index 0000000..5ed0da3 --- /dev/null +++ b/board/toradex/apalis-tk1/pinmux-config-apalis-tk1.h @@ -0,0 +1,287 @@ +/* + * Copyright (c) 2016, Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _PINMUX_CONFIG_APALIS_TK1_H_ +#define _PINMUX_CONFIG_APALIS_TK1_H_ + +#define GPIO_INIT(_port, _gpio, _init) \ + { \ + .gpio = TEGRA_GPIO(_port, _gpio), \ + .init = TEGRA_GPIO_INIT_##_init, \ + } + +static const struct tegra_gpio_config apalis_tk1_gpio_inits[] = { + /* port, pin, init_val */ + GPIO_INIT(A, 1, IN), + GPIO_INIT(B, 1, IN), + GPIO_INIT(C, 0, OUT0), + GPIO_INIT(I, 5, IN), + GPIO_INIT(I, 6, IN), + GPIO_INIT(J, 0, IN), + GPIO_INIT(J, 2, IN), + GPIO_INIT(K, 2, IN), + GPIO_INIT(K, 7, IN), + GPIO_INIT(N, 2, OUT1), + GPIO_INIT(N, 4, OUT1), + GPIO_INIT(N, 5, OUT1), + GPIO_INIT(N, 7, IN), + GPIO_INIT(O, 5, IN), + GPIO_INIT(Q, 0, OUT0), /* Shift_CTRL_OE[0] */ + GPIO_INIT(Q, 1, OUT0), /* Shift_CTRL_OE[1] */ + GPIO_INIT(Q, 2, OUT0), /* Shift_CTRL_OE[2] */ + GPIO_INIT(Q, 4, OUT0), /* Shift_CTRL_OE[4] */ + GPIO_INIT(Q, 5, OUT1), /* Shift_CTRL_Dir_Out[0] */ + GPIO_INIT(Q, 6, OUT1), /* Shift_CTRL_Dir_Out[1] */ + GPIO_INIT(Q, 7, OUT1), /* Shift_CTRL_Dir_Out[2] */ + GPIO_INIT(R, 0, OUT0), /* Shift_CTRL_Dir_In[0] */ + GPIO_INIT(R, 1, OUT0), /* Shift_CTRL_Dir_In[1] */ + GPIO_INIT(R, 2, OUT0), /* Shift_CTRL_OE[3] */ + GPIO_INIT(S, 3, OUT0), /* Shift_CTRL_Dir_In[2] */ + GPIO_INIT(U, 4, OUT1), + GPIO_INIT(W, 3, IN), + GPIO_INIT(W, 5, IN), + GPIO_INIT(BB, 0, IN), + GPIO_INIT(BB, 3, OUT0), + GPIO_INIT(BB, 4, IN), + GPIO_INIT(BB, 5, OUT1), + GPIO_INIT(BB, 6, OUT0), + GPIO_INIT(CC, 5, IN), + GPIO_INIT(DD, 3, IN), + GPIO_INIT(EE, 3, IN), + GPIO_INIT(EE, 5, IN), + GPIO_INIT(FF, 1, IN), +}; + +#define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .od = PMUX_PIN_OD_##_od, \ + .rcv_sel = PMUX_PIN_RCV_SEL_##_rcv_sel, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +static const struct pmux_pingrp_config apalis_tk1_pingrps[] = { + /* pingrp, mux, pull, tri, e_input, od, rcv_sel */ + PINCFG(CLK_32K_OUT_PA0, SOC, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_CTS_N_PA1, GMI, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_FS_PA2, HDA, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_SCLK_PA3, HDA, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DIN_PA4, HDA, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DOUT_PA5, HDA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB0, UARTD, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PB1, RSVD2, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RTS_N_PC0, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_TXD_PC2, IRDA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RXD_PC3, IRDA, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PC7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG0, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG2, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG3, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG4, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG7, SPI4, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PH0, PWM0, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH1, PWM1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, PWM2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH3, PWM3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH7, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI0, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI3, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI4, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI5, RSVD2, UP, TRISTATE, INPUT, ENABLE, DEFAULT), + PINCFG(PI6, RSVD1, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PI7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, RSVD1, UP, TRISTATE, INPUT, ENABLE, DEFAULT), + PINCFG(PJ2, RSVD1, UP, TRISTATE, INPUT, ENABLE, DEFAULT), + PINCFG(UART2_CTS_N_PJ5, UARTB, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK0, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK1, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, RSVD1, UP, TRISTATE, INPUT, ENABLE, DEFAULT), + PINCFG(PK3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK4, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, SPDIF, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, SPDIF, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PK7, RSVD2, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_FS_PN0, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DIN_PN1, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DOUT_PN2, SATA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_SCLK_PN3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN0_PN4, RSVD2, NORMAL, NORMAL, OUTPUT, DISABLE, DEFAULT), + PINCFG(USB_VBUS_EN1_PN5, RSVD2, NORMAL, NORMAL, OUTPUT, DISABLE, DEFAULT), + PINCFG(HDMI_INT_PN7, RSVD1, DOWN, TRISTATE, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, ULPI, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, ULPI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, I2S2, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, I2S2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_SCLK_PP3, I2S2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_FS_PP4, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DIN_PP5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DOUT_PP6, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_SCLK_PP7, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL3_PQ3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL4_PQ4, KBC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW3_PR3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW6_PR6, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW9_PS1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW10_PS2, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW15_PS7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, UARTA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, UARTA, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PU2, UARTA, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PU3, UARTA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU5, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU6, PWM3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PV0, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PV1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CD_N_PV2, RSVD3, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_WP_N_PV3, SDMMC1, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SCL_PV4, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SDA_PV5, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W2_AUD_PW2, SPI2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, SPI6, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_OUT_PW5, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RXD_PW7, UARTC, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, SPI2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, SPI2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, SPI2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, SPI2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DIR_PY1, SPI1, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB0, VGP6, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PBB3, VGP3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB4, VGP4, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, VGP5, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_RST_N_PDD1, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_CLKREQ_N_PDD2, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_WAKE_N_PDD3, RSVD2, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_RST_N_PDD5, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_CLKREQ_N_PDD6, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_REQ_PEE2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + /* + * Leave SDMMC3_CLK_LB_OUT muxed as SDMMC3 with output driver enabled aka not + * tristated and input driver enabled as well as it features some magic + * properties even though the external loopback is disabled and the internal + * loopback used as per SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits + * being set to 0xfffd according to the TRM! + */ + PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_LB_IN_PEE5, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DP_HPD_PFF0, DP, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(PFF2, RSVD2, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CPU_PWR_REQ, CPU, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_INT_N, PMI, UP, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(OWR, RSVD2, NORMAL, TRISTATE, OUTPUT, DEFAULT, NORMAL), + PINCFG(CLK_32K_IN, CLK, NORMAL, TRISTATE, INPUT, DEFAULT, DEFAULT), + PINCFG(JTAG_RTCK, RTCK, UP, NORMAL, OUTPUT, DEFAULT, DEFAULT), +}; + +#define DRVCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static const struct pmux_drvgrp_config apalis_tk1_drvgrps[] = { +}; + +#endif /* PINMUX_CONFIG_APALIS_TK1_H */ diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig new file mode 100644 index 0000000..ae95f6b --- /dev/null +++ b/configs/apalis-tk1_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_TEGRA=y +CONFIG_TEGRA124=y +CONFIG_TARGET_APALIS_TK1=y +CONFIG_DEFAULT_DEVICE_TREE="tegra124-apalis" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTDELAY=1 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Apalis TK1 # " +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y +# CONFIG_BLK is not set +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +# CONFIG_DM_MMC_OPS is not set +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Toradex" +CONFIG_G_DNL_VENDOR_NUM=0x1b67 +CONFIG_G_DNL_PRODUCT_NUM=0xffff diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h new file mode 100644 index 0000000..50e30b1 --- /dev/null +++ b/include/configs/apalis-tk1.h @@ -0,0 +1,181 @@ +/* + * Copyright (c) 2016 Toradex, Inc. + * + * Configuration settings for the Toradex Apalis TK1 modules. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +/* enable PMIC */ +#define CONFIG_AS3722_POWER + +#include "tegra124-common.h" + +#define CONFIG_ARCH_MISC_INIT + +/* High-level configuration options */ +#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */ + +/* Board-specific serial config */ +#define CONFIG_TEGRA_ENABLE_UARTA +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +/* I2C */ +#define CONFIG_SYS_I2C_TEGRA + +/* SD/MMC support */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +/* Environment in eMMC, before config block at the end of 1st "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ + CONFIG_TDX_CFG_BLOCK_OFFSET) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 1 + +/* USB host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA + +/* PCI host support */ +#undef CONFIG_PCI_SCAN_SHOW +#define CONFIG_CMD_PCI + +/* PCI networking support */ +#define CONFIG_E1000_NO_NVM + +/* General networking support */ +#define CONFIG_IP_DEFRAG +#define CONFIG_TFTP_BLOCKSIZE 16352 +#define CONFIG_TFTP_TSIZE + +/* Miscellaneous commands */ +#define CONFIG_FAT_WRITE + +#undef CONFIG_IPADDR +#define CONFIG_IPADDR 192.168.10.2 +#define CONFIG_NETMASK 255.255.255.0 +#undef CONFIG_SERVERIP +#define CONFIG_SERVERIP 192.168.10.1 + +#define CONFIG_BOOTCOMMAND \ + "run emmcboot; echo; echo emmcboot failed; " \ + "run sdboot; echo; echo sdboot failed; " \ + "run usbboot; echo; echo usbboot failed; " \ + "run nfsboot; echo; echo nfsboot failed" + +#define DFU_ALT_EMMC_INFO "apalis-tk1.img raw 0x0 0x500 mmcpart 1; " \ + "boot part 0 1 mmcpart 0; " \ + "rootfs part 0 2 mmcpart 0; " \ + "uImage fat 0 1 mmcpart 0; " \ + "tegra124-apalis-eval.dtb fat 0 1 mmcpart 0" + +#define EMMC_BOOTCMD \ + "emmcargs=ip=off root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait\0" \ + "emmcboot=run setup; setenv bootargs ${defargs} ${emmcargs} " \ + "${setupargs} ${vidargs}; echo Booting from internal eMMC " \ + "chip...; run emmcdtbload; load mmc 0:1 ${kernel_addr_r} " \ + "${boot_file} && run fdt_fixup && " \ + "bootm ${kernel_addr_r} - ${dtbparam}\0" \ + "emmcdtbload=setenv dtbparam; load mmc 0:1 ${fdt_addr_r} " \ + "${soc}-apalis-${fdt_board}.dtb && " \ + "setenv dtbparam ${fdt_addr_r}\0" + +#define NFS_BOOTCMD \ + "nfsargs=ip=:::::eth0:on root=/dev/nfs rw\0" \ + "nfsboot=pci enum; run setup; setenv bootargs ${defargs} ${nfsargs} " \ + "${setupargs} ${vidargs}; echo Booting via DHCP/TFTP/NFS...; " \ + "run nfsdtbload; dhcp ${kernel_addr_r} " \ + "&& run fdt_fixup && bootm ${kernel_addr_r} - ${dtbparam}\0" \ + "nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} " \ + "${soc}-apalis-${fdt_board}.dtb " \ + "&& setenv dtbparam ${fdt_addr_r}\0" + +#define SD_BOOTCMD \ + "sdargs=ip=off root=/dev/mmcblk1p2 rw rootfstype=ext3 rootwait\0" \ + "sdboot=run setup; setenv bootargs ${defargs} ${sdargs} ${setupargs} " \ + "${vidargs}; echo Booting from SD card in 8bit slot...; " \ + "run sddtbload; load mmc 1:1 ${kernel_addr_r} " \ + "${boot_file} && run fdt_fixup && " \ + "bootm ${kernel_addr_r} - ${dtbparam}\0" \ + "sddtbload=setenv dtbparam; load mmc 1:1 ${fdt_addr_r} " \ + "${soc}-apalis-${fdt_board}.dtb " \ + "&& setenv dtbparam ${fdt_addr_r}\0" + +#define USB_BOOTCMD \ + "usbargs=ip=off root=/dev/sda2 rw rootfstype=ext3 rootwait\0" \ + "usbboot=run setup; setenv bootargs ${defargs} ${setupargs} " \ + "${usbargs} ${vidargs}; echo Booting from USB stick...; " \ + "usb start && run usbdtbload; load usb 0:1 ${kernel_addr_r} " \ + "${boot_file} && run fdt_fixup && " \ + "bootm ${kernel_addr_r} - ${dtbparam}\0" \ + "usbdtbload=setenv dtbparam; load usb 0:1 ${fdt_addr_r} " \ + "${soc}-apalis-${fdt_board}.dtb " \ + "&& setenv dtbparam ${fdt_addr_r}\0" + +#define BOARD_EXTRA_ENV_SETTINGS \ + "boot_file=uImage\0" \ + "console=ttyS0\0" \ + "defargs=lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 " \ + "usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0\0" \ + "dfu_alt_info=" DFU_ALT_EMMC_INFO "\0" \ + EMMC_BOOTCMD \ + "fdt_board=eval\0" \ + "fdt_fixup=;\0" \ + NFS_BOOTCMD \ + SD_BOOTCMD \ + "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ + "00:14:2d:00:00:00; fi; pci enum && tftpboot ${loadaddr} " \ + "flash_eth.img && source ${loadaddr}\0" \ + "setsdupdate=setenv interface mmc; setenv drive 1; mmc rescan; " \ + "load ${interface} ${drive}:1 ${loadaddr} flash_blk.img " \ + "|| setenv drive 2; mmc rescan; load ${interface} ${drive}:1 " \ + "${loadaddr} flash_blk.img && " \ + "source ${loadaddr}\0" \ + "setup=setenv setupargs igb_mac=${ethaddr} " \ + "consoleblank=0 no_console_suspend=1 console=tty1 " \ + "console=${console},${baudrate}n8 debug_uartport=lsport,0 " \ + "${memargs}\0" \ + "setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ + "setusbupdate=usb start && setenv interface usb; setenv drive 0; " \ + "load ${interface} ${drive}:1 ${loadaddr} flash_blk.img && " \ + "source ${loadaddr}\0" \ + USB_BOOTCMD \ + "vidargs=video=tegrafb0:640x480-16@60 fbcon=map:1\0" + +/* Increase console I/O buffer size */ +#undef CONFIG_SYS_CBSIZE +#define CONFIG_SYS_CBSIZE 1024 + +/* Increase arguments buffer size */ +#undef CONFIG_SYS_BARGSIZE +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* Increase print buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Increase maximum number of arguments */ +#undef CONFIG_SYS_MAXARGS +#define CONFIG_SYS_MAXARGS 32 + +#define CONFIG_CMD_TIME + +#define CONFIG_SUPPORT_RAW_INITRD +#define CONFIG_SYS_BOOT_RAMDISK_HIGH + +#include "tegra-common-usb-gadget.h" +#include "tegra-common-post.h" + +/* Reserve top 1M for secure RAM */ +#define CONFIG_ARMV7_SECURE_BASE 0xfff00000 +#define CONFIG_ARMV7_SECURE_RESERVE_SIZE 0x00100000 + +#endif /* __CONFIG_H */
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v3: None Changes in v2: - Added Simon's reviewed-by.
drivers/mmc/Kconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 5e84a41..18f0e97 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -110,4 +110,10 @@ config SANDBOX_MMC improves build coverage for sandbox and makes it easier to detect MMC build errors with sandbox.
+config TEGRA_MMC + bool "Tegra SDHCI aka MMC support" + depends on DM_MMC && TEGRA + help + This selects support for SDHCI on Tegra SoCs. + endmenu
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
+config TEGRA_MMC
- bool "Tegra SDHCI aka MMC support"
- depends on DM_MMC && TEGRA
- help
endmenu
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in include/configs/tegra-common-post.h unchanged.
Changes in v3: - My recent fresh install of Fedora 25 was missing an aarch64 toolchain which made moveconfig.py not properly handle the 6 newer Tegras. I now re-run moveconfig.py after installing an aarch64 toolchain and it all looks sane. Sorry about that, Tom.
BTW: I will look at converting tegra to use CONFIG_BLK and CONFIG_DM_MMC_OPS in a later separate step.
--- configs/apalis-tk1_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/beaver_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/e2220-1170_defconfig | 9 +-------- configs/harmony_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/p2371-0000_defconfig | 9 +-------- configs/p2371-2180_defconfig | 9 +-------- configs/p2571_defconfig | 9 +-------- configs/p2771-0000-000_defconfig | 9 +-------- configs/p2771-0000-500_defconfig | 9 +-------- configs/paz00_defconfig | 1 + configs/plutux_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/whistler_defconfig | 1 + include/configs/apalis-tk1.h | 1 - include/configs/apalis_t30.h | 1 - include/configs/beaver.h | 1 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/colibri_t20.h | 1 - include/configs/colibri_t30.h | 1 - include/configs/dalmore.h | 1 - include/configs/e2220-1170.h | 1 - include/configs/harmony.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/medcom-wide.h | 1 - include/configs/nyan-big.h | 1 - include/configs/p2371-0000.h | 1 - include/configs/p2371-2180.h | 1 - include/configs/p2571.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/paz00.h | 1 - include/configs/plutux.h | 1 - include/configs/seaboard.h | 1 - include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/trimslice.h | 1 - include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/whistler.h | 1 - scripts/config_whitelist.txt | 1 - 54 files changed, 27 insertions(+), 75 deletions(-)
diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index ae95f6b..c1caef1 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -36,6 +36,7 @@ CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 691148c..0822e2e 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 5cb73c0..69c9ccd 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -28,6 +28,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 0214758..e8e8b20 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index 909b367..57b87c9 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -28,6 +28,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index a543246..3a4dc31 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 2ab6764..724a600 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 0db2d1d..285785d 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -28,6 +28,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index c88cd36..1adbee9 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -5,7 +5,6 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra210-e2220-1170" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (E2220-1170) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -20,20 +19,14 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index d8712d5..8ce493f 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index b0aa3c7..5ee5372 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -28,6 +28,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index a65c3ad..4d99925 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index e6f862d..106a1a6 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -36,6 +36,7 @@ CONFIG_CROS_EC_KEYB=y CONFIG_CROS_EC=y CONFIG_CROS_EC_SPI=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_PMIC=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 0b074ec..ecae270 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -6,7 +6,6 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-0000" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-0000) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -21,20 +20,14 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 70e43a1..79c84a5 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -6,7 +6,6 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-2180" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-2180) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -21,20 +20,14 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index a114ce3..67aba9f 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -6,7 +6,6 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2571" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2571) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -21,20 +20,14 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index 61bb3a1..309a505 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -5,7 +5,6 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra186-p2771-0000-000" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra186 (P2771-0000-000) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -18,18 +17,12 @@ CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set CONFIG_TEGRA186_BPMP_I2C=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_DWC_ETH_QOS=y CONFIG_E1000=y CONFIG_RTL8169=y diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index 79f4808..90aead6 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -5,7 +5,6 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra186-p2771-0000-500" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra186 (P2771-0000-500) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -18,18 +17,12 @@ CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_BLK is not set CONFIG_TEGRA186_BPMP_I2C=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_DWC_ETH_QOS=y CONFIG_E1000=y CONFIG_RTL8169=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index b3d6f90..e1b33e3 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 3c45b9d..dabbc09 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index c3119dc..78dd24b 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index f52f19b..7e1e3f3 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 1ccec73..2f3d131 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index a145ff8..aa0da8f 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 8ff879f..022b4ef 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -28,6 +28,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 1f2809a..7021b62 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index b7c3ed9..221e520 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_DM=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set +CONFIG_TEGRA_MMC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index 50e30b1..a38f5d5 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -31,7 +31,6 @@ /* SD/MMC support */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC #define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index f2a24c1..b3c6e20 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -30,7 +30,6 @@ /* SD/MMC support */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/beaver.h b/include/configs/beaver.h index ab1ab14..ffa2909 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -30,7 +30,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index 462b784..29a74c7 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -33,7 +33,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/cei-tk1-som.h b/include/configs/cei-tk1-som.h index f3bb279..4688b33 100644 --- a/include/configs/cei-tk1-som.h +++ b/include/configs/cei-tk1-som.h @@ -32,7 +32,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index 6a52869..3c917b0 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -29,7 +29,6 @@ /* SD/MMC support */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* USB host support */ #define CONFIG_USB_EHCI diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index e8b3f99..cb1488f 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -30,7 +30,6 @@ /* SD/MMC support */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index b0311bf..45576f4 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -26,7 +26,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/e2220-1170.h b/include/configs/e2220-1170.h index c9e8c8e..3de36d7 100644 --- a/include/configs/e2220-1170.h +++ b/include/configs/e2220-1170.h @@ -24,7 +24,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/harmony.h b/include/configs/harmony.h index 3d6b5fc..784fffa 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -29,7 +29,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 90e282f..a00f9fa 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -28,7 +28,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/medcom-wide.h b/include/configs/medcom-wide.h index ae7ca3b..d3d0b15 100644 --- a/include/configs/medcom-wide.h +++ b/include/configs/medcom-wide.h @@ -22,7 +22,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/nyan-big.h b/include/configs/nyan-big.h index c548ee1..95324d8 100644 --- a/include/configs/nyan-big.h +++ b/include/configs/nyan-big.h @@ -27,7 +27,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/p2371-0000.h b/include/configs/p2371-0000.h index 968b89e..b200dc4 100644 --- a/include/configs/p2371-0000.h +++ b/include/configs/p2371-0000.h @@ -24,7 +24,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/p2371-2180.h b/include/configs/p2371-2180.h index 9cf697f..03cbf72 100644 --- a/include/configs/p2371-2180.h +++ b/include/configs/p2371-2180.h @@ -24,7 +24,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/p2571.h b/include/configs/p2571.h index 4fa345d..7ab3c78 100644 --- a/include/configs/p2571.h +++ b/include/configs/p2571.h @@ -25,7 +25,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/p2771-0000.h b/include/configs/p2771-0000.h index 67a1603..1bba51e 100644 --- a/include/configs/p2771-0000.h +++ b/include/configs/p2771-0000.h @@ -20,7 +20,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/paz00.h b/include/configs/paz00.h index a8bb3ff..36a1bb5 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -25,7 +25,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/plutux.h b/include/configs/plutux.h index 635e439..39e4e4f 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -22,7 +22,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 2b6509a..099b2c9 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -34,7 +34,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/tec-ng.h b/include/configs/tec-ng.h index 0e9d98c..953b196 100644 --- a/include/configs/tec-ng.h +++ b/include/configs/tec-ng.h @@ -23,7 +23,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/tec.h b/include/configs/tec.h index 7b14299..0386071 100644 --- a/include/configs/tec.h +++ b/include/configs/tec.h @@ -22,7 +22,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index cfc8451..e78a5e6 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -30,7 +30,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in SPI */ #define CONFIG_ENV_IS_IN_SPI_FLASH diff --git a/include/configs/venice2.h b/include/configs/venice2.h index 72fa973..f2c8f22 100644 --- a/include/configs/venice2.h +++ b/include/configs/venice2.h @@ -25,7 +25,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/ventana.h b/include/configs/ventana.h index 7a38869..2c88d64 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -23,7 +23,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/whistler.h b/include/configs/whistler.h index 0cd892e..1c2e166 100644 --- a/include/configs/whistler.h +++ b/include/configs/whistler.h @@ -27,7 +27,6 @@ /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_TEGRA_MMC
/* * Environment in eMMC, at the end of 2nd "boot sector". Note: This assumes diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8814841..ae6882b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -7819,7 +7819,6 @@ CONFIG_TEGRA_ENABLE_UARTE CONFIG_TEGRA_GPU CONFIG_TEGRA_KEYBOARD CONFIG_TEGRA_LP0 -CONFIG_TEGRA_MMC CONFIG_TEGRA_NAND CONFIG_TEGRA_PMU CONFIG_TEGRA_SLINK_CTRLS
Changes in v3:
Changes in v2:
- Environment in eMMC, at the end of 2nd "boot sector". Note: This assumes
Introduce CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK to disable the external clock loopback and use the internal one on SDMMC3 as per the SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits being set to 0xfffd according to the TRM.
Changes in v3: None Changes in v2: - Added Simon's reviewed-by. - Added TODO(email) as suggested by Simon so it is clear this is temporary and will be moved to device tree controlled approach once proper kernel integration made it mainline.
arch/arm/include/asm/arch-tegra/tegra_mmc.h | 2 ++ drivers/mmc/Kconfig | 11 +++++++++++ drivers/mmc/tegra_mmc.c | 16 ++++++++++++++++ 3 files changed, 29 insertions(+)
diff --git a/arch/arm/include/asm/arch-tegra/tegra_mmc.h b/arch/arm/include/asm/arch-tegra/tegra_mmc.h index 64c848a..c40599a 100644 --- a/arch/arm/include/asm/arch-tegra/tegra_mmc.h +++ b/arch/arm/include/asm/arch-tegra/tegra_mmc.h @@ -108,6 +108,8 @@ struct tegra_mmc { #define TEGRA_MMC_CLKCON_SDCLK_FREQ_SEL_SHIFT 8 #define TEGRA_MMC_CLKCON_SDCLK_FREQ_SEL_MASK (0xff << 8)
+#define TEGRA_MMC_MISCON_ENABLE_EXT_LOOPBACK (1 << 17) + #define TEGRA_MMC_SWRST_SW_RESET_FOR_ALL (1 << 0) #define TEGRA_MMC_SWRST_SW_RESET_FOR_CMD_LINE (1 << 1) #define TEGRA_MMC_SWRST_SW_RESET_FOR_DAT_LINE (1 << 2) diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 18f0e97..6372876 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -116,4 +116,15 @@ config TEGRA_MMC help This selects support for SDHCI on Tegra SoCs.
+config TEGRA124_MMC_DISABLE_EXT_LOOPBACK + bool "Disable external clock loopback" + depends on TEGRA_MMC && TEGRA124 + help + Disable the external clock loopback and use the internal one on SDMMC3 + as per the SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits + being set to 0xfffd according to the TRM. + + TODO(marcel.ziswiler@toradex.com): Move to device tree controlled + approach once proper kernel integration made it mainline. + endmenu diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index 97b1154..839b15d 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -511,6 +511,22 @@ static int tegra_mmc_init(struct mmc *mmc)
tegra_mmc_reset(priv, mmc);
+#if defined(CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK) + /* + * Disable the external clock loopback and use the internal one on + * SDMMC3 as per the SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 + * bits being set to 0xfffd according to the TRM. + * + * TODO(marcel.ziswiler@toradex.com): Move to device tree controlled + * approach once proper kernel integration made it mainline. + */ + if (priv->reg == (void *)0x700b0400) { + mask = readl(&priv->reg->venmiscctl); + mask &= ~TEGRA_MMC_MISCON_ENABLE_EXT_LOOPBACK; + writel(mask, &priv->reg->venmiscctl); + } +#endif + priv->version = readw(&priv->reg->hcver); debug("host version = %x\n", priv->version);
- bool "Disable external clock loopback"
- depends on TEGRA_MMC && TEGRA124
- help
- if (priv->reg == (void *)0x700b0400) {
- priv->version = readw(&priv->reg->hcver); debug("host version = %x\n", priv->version);
Actually make use of that shiny new CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
configs/apalis-tk1_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index c1caef1..204137b 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -37,6 +37,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y # CONFIG_DM_MMC_OPS is not set CONFIG_TEGRA_MMC=y +CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK=y CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y
Use make savedefconfig to clean-up defconfig.
Changes in v3: - Cleaned-up defconfig using savedefconfig.
Changes in v2: None
configs/apalis-tk1_defconfig | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 204137b..4204e7f 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -9,9 +9,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis TK1 # " -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -22,15 +20,8 @@ CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y
Marcel,
-----Original Message----- From: Marcel Ziswiler [mailto:marcel@ziswiler.com] Sent: Wednesday, December 21, 2016 9:26 PM To: u-boot@lists.denx.de Cc: Max Krummenacher max.krummenacher@toradex.com; Stefan Agner stefan.agner@toradex.com; Marcel Ziswiler marcel.ziswiler@toradex.com; York Sun york.sun@nxp.com; Peter.Chubb@data61.csiro.au; Lokesh Vutla lokeshvutla@ti.com; Jaehoon Chung jh80.chung@samsung.com; Hans de Goede hdegoede@redhat.com; Heiko Schocher hs@denx.de; Albert Aribaud albert.u.boot@aribaud.net; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Stephen Warren swarren@nvidia.com; Jagan Teki jteki@openedev.com; Alexander Graf agraf@suse.de; Tom Warren TWarren@nvidia.com; Joe Hershberger joe.hershberger@ni.com; Lucas Stach dev@lynxeye.de; Allen Martin AMartin@nvidia.com; Stefan Roese sr@denx.de; Alban Bedel alban.bedel@avionic-design.de; Simon Glass sjg@chromium.org; Masahiro Yamada yamada.masahiro@socionext.com; Ian Campbell ijc@hellion.org.uk Subject: [PATCH v3 0/6] arm: tegra: apalis-tk1, mmc and ext clock loopback
This series adds support for the Toradex Apalis TK1 as well as moves the CONFIG_TEGRA_MMC to Kconfig and introduces a new option to disable the external clock loopback on SDMMC3.
The whole series is also available here:
http://git.toradex.com/cgit/u-boot-toradex.git/log/?h=for-next
Changes in v3:
With Mashiro's recent 'mmc: move more driver config options to Kconfig' patchset (which is in TOT U-Boot now), your v3 patchset no longer applies cleanly.
I'll rebase u-boot-tegra/master against u-boot/master and push a new repo to Denx so you can get your Apalis-TK1 patchset to work w/all of the recent changes.
Thanks, and sorry for the extra work!
Tom -- nvpublic
Changes in v2:
Marcel Ziswiler (6): arm: tegra: initial support for apalis tk1 mmc: tegra: introduce CONFIG_TEGRA_MMC to Kconfig mmc: tegra: move CONFIG_TEGRA_MMC from headers to defconfigs mmc: tegra: allow disabling external clock loopback apalis-tk1: disable external clock loopback on SDMMC3 apalis-tk1: clean-up defconfig
arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-apalis.dts | 2203 ++++++++++++++++++++ arch/arm/include/asm/arch-tegra/tegra_mmc.h | 2 + arch/arm/mach-tegra/tegra124/Kconfig | 7 + board/toradex/apalis-tk1/Kconfig | 30 + board/toradex/apalis-tk1/MAINTAINERS | 7 + board/toradex/apalis-tk1/Makefile | 5 + board/toradex/apalis-tk1/apalis-tk1.c | 175 ++ board/toradex/apalis-tk1/as3722_init.c | 117 ++ board/toradex/apalis-tk1/as3722_init.h | 41 + .../toradex/apalis-tk1/pinmux-config-apalis-tk1.h | 287 +++ configs/apalis-tk1_defconfig | 46 + configs/apalis_t30_defconfig | 1 + configs/beaver_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/e2220-1170_defconfig | 9 +- configs/harmony_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/p2371-0000_defconfig | 9 +- configs/p2371-2180_defconfig | 9 +- configs/p2571_defconfig | 9 +- configs/p2771-0000-000_defconfig | 9 +- configs/p2771-0000-500_defconfig | 9 +- configs/paz00_defconfig | 1 + configs/plutux_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/whistler_defconfig | 1 + drivers/mmc/Kconfig | 17 + drivers/mmc/tegra_mmc.c | 16 + include/configs/apalis-tk1.h | 180 ++ include/configs/apalis_t30.h | 1 - include/configs/beaver.h | 1 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/colibri_t20.h | 1 - include/configs/colibri_t30.h | 1 - include/configs/dalmore.h | 1 - include/configs/e2220-1170.h | 1 - include/configs/harmony.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/medcom-wide.h | 1 - include/configs/nyan-big.h | 1 - include/configs/p2371-0000.h | 1 - include/configs/p2371-2180.h | 1 - include/configs/p2571.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/paz00.h | 1 - include/configs/plutux.h | 1 - include/configs/seaboard.h | 1 - include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/trimslice.h | 1 - include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/whistler.h | 1 - scripts/config_whitelist.txt | 1 - 67 files changed, 3160 insertions(+), 74 deletions(-) create mode 100644 arch/arm/dts/tegra124-apalis.dts create mode 100644 board/toradex/apalis- tk1/Kconfig create mode 100644 board/toradex/apalis-tk1/MAINTAINERS create mode 100644 board/toradex/apalis-tk1/Makefile create mode 100644 board/toradex/apalis-tk1/apalis-tk1.c create mode 100644 board/toradex/apalis-tk1/as3722_init.c create mode 100644 board/toradex/apalis-tk1/as3722_init.h create mode 100644 board/toradex/apalis-tk1/pinmux-config-apalis-tk1.h create mode 100644 configs/apalis-tk1_defconfig create mode 100644 include/configs/apalis-tk1.h
-- 2.9.3
2017-01-04 4:40 GMT+09:00 Tom Warren TWarren@nvidia.com:
Marcel,
Changes in v3:
Marcel,
Sorry, I did not notice you were moving CONFIG_TEGRA_MMC.
Moreover, I am moving CONFIG_TEGRA_MMC
Marcel,
Changes in v3:
(Sorry, the previous mail had been sent before I completed it)
Marcel,
Moreover, I am moving CONFIG_TEGRA_MMC and renaming in the following patch:
http://patchwork.ozlabs.org/patch/710054/
My goal is all MMC driver options prefixed with CONFIG_MMC_. (and SDHCI variants with CONFIG_MMC_SDHCI_, DesignWare variants with CONFIG_MMC_DW_ )
Here is a question about the Tegra MMC driver.
From the compatible strings in drivers/mmc/tegra-mmc.c,
I suspect this driver is based on SDHCI and in Linux, the option name is CONFIG_MMC_SDHCI_TEGRA.
Why doesn't the driver re-use driver/mmc/sdhci.c ?
Mashiro,
-----Original Message----- From: Masahiro Yamada [mailto:yamada.masahiro@socionext.com] Sent: Wednesday, January 04, 2017 3:07 AM To: Tom Warren TWarren@nvidia.com; Marcel Ziswiler marcel@ziswiler.com; Marcel Ziswiler marcel.ziswiler@toradex.com Cc: u-boot@lists.denx.de; Lucas Stach dev@lynxeye.de; Joe Hershberger joe.hershberger@ni.com; Max Krummenacher max.krummenacher@toradex.com; Jagan Teki jteki@openedev.com; Stefan Roese sr@denx.de; Stephen Warren swarren@nvidia.com; Ian Campbell ijc@hellion.org.uk; tomcwarren3959@gmail.com; Stefan Agner stefan.agner@toradex.com; Hans de Goede hdegoede@redhat.com; Albert Aribaud albert.u.boot@aribaud.net; Alban Bedel alban.bedel@avionic-design.de; Jaehoon Chung jh80.chung@samsung.com Subject: Re: [U-Boot] [PATCH v3 0/6] arm: tegra: apalis-tk1, mmc and ext clock loopback
Marcel,
Changes in v3:
Marcel,
From the compatible strings in drivers/mmc/tegra-mmc.c, I suspect this driver is based on SDHCI and in Linux, the option name is CONFIG_MMC_SDHCI_TEGRA.
I created the tegra_mmc.c driver for Seaboard/Tegra20 way back in May of 2011 (commit 21ef6a1). I don't remember what I based it on - I assume another extant U-Boot mmc driver like mmc.c from Andy Fleming. It looks like Lei Wen created the sdhci.c driver in June of 2011 (commit af62a557), so it wasn't available when I created tegra_mmc.c.
It's unlikely that we'll take a working driver and rewrite it based on sdhci.c. If someone else wants to shoulder that burden, and does adequate testing to prove its fully compatible across all Tegra chipsets (including owning any future work), I won't object.
Tom -- nvpublic
-- Best Regards Masahiro Yamada
Jaehoon Chung
Marcel Ziswiler
Masahiro Yamada
Tom Warren
