[PATCH] imx: fdt: fix cooling-device property corruption
The function disable_thermal_cpu_nodes() corrupts the cooling-device property. For example, booting an i.MX93 devices with only one A55 core (IMX93x1) with the cooling-device property set to:
$ dtc -I dtb foo.dtb | grep cooling-device cooling-device = <0x08 0xffffffff 0xffffffff 0x09 0xffffffff 0xffffffff>;
Linux shows the following error at boot:
[ 1.715189] OF: /thermal-zones/cpu-thermal/cooling-maps/map0: could not find phandle 1083699869 [ 1.723977] thermal_sys: Add a cooling_device property with at least one device [ 1.731285] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-devfreq-0 failed:-2
because the cooling-device property in the device tree passed to the kernel is
$ dtc -I dtb /sys/firmware/fdt | grep cooling-device cooling-device = <0x4097f29d 0x00 0xb05aef9d>;
The issue is because the wrong variable type is passed to the function fdt_setprop() called in the function disable_thermal_cpu_nodes(). With the variable type fixed, the error at boot is gone and the property is properly set:
$ dtc -I dtb /sys/firmware/fdt | grep cooling-device cooling-device = <0x08 0xffffffff 0xffffffff>;
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- arch/arm/mach-imx/fdt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/fdt.c b/arch/arm/mach-imx/fdt.c index 103c1fc5968afb46efc8e8ecf9038fd93af3cac1..f19ab9edce496606ba99c80f6a53ff45d596f00e 100644 --- a/arch/arm/mach-imx/fdt.c +++ b/arch/arm/mach-imx/fdt.c @@ -39,7 +39,7 @@ static void disable_thermal_cpu_nodes(void *blob, u32 num_disabled_cores, u32 ma for (j = 0; j < cnt; j++) cooling_dev[j] = cpu_to_fdt32(cooling_dev[j]);
- ret = fdt_setprop(blob, nodeoff, "cooling-device", &cooling_dev, + ret = fdt_setprop(blob, nodeoff, "cooling-device", cooling_dev, sizeof(__le32) * (num_le32 - num_disabled_cores * 3)); if (ret < 0) { printf("Warning: %s, cooling-device setprop failed %d\n",
--- base-commit: 6a0db9ee030f634731b792d864fc7a9df6cc6b80 change-id: 20250114-imx93-boot-dtb-fixes-8bd66b58453b
On Wed, Jan 15, 2025 at 12:41 PM Sébastien Szymanski sebastien.szymanski@armadeus.com wrote:
Great work! Applied, thanks.
Fabio Estevam
Sébastien Szymanski
