[U-Boot] [PATCH] arm: socfpga: improve raw MMC SPL boot
Before this patch, when booting from MMC (no filesystem), the SPL loaded U-Boot from a fixed offset. It will now load U-Boot from an offset of 256kB (which is 4 times the padded SPL image) in the third partition.
This behaviour is similar to what the vendor SPL (based on U-Boot 2013.01) does, and allows to directly 'dd' the u-boot-with-spl.sfp file to the A2 partition.
Signed-off-by: Sylvain Lesne lesne@alse-fr.com ---
As discussed previously, this change relies on a tiny sprintf() implementation to be provided to be able to build and boot correctly.
Also, I removed CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS, but I plan to send a patch removing this obsolete define from all the configs, so there might be a merge conflict, sorry...
I completely missed a previous occurrence of this problem (http://lists.denx.de/pipermail/u-boot/2016-May/254492.html), so I'm adding the previous reporter as Cc.
include/configs/socfpga_common.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index f657766..e5972e6 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -349,9 +349,9 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" #define CONFIG_SPL_LIBDISK_SUPPORT #else -#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 3 -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0xa00 /* offset 2560 sect (1M+256k) */ -#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 800 /* 400 KB */ +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION 3 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x200 /* offset 512 sect (256k) */ +#define CONFIG_SPL_LIBDISK_SUPPORT #endif #endif
Looks fine, applied, thanks.
Sylvain Lesne
