[U-Boot] [PULL] u-boot-atmel/master -> u-boot-arm/master
Dear Albert Aribaud,
please pull u-boot-atmel/master into u-boot-arm/master. This PR supersedes http://patchwork.ozlabs.org/patch/291044/
The following changes since commit 56eb3da43fab5990a4b7bc118b76c7cae2ceb140:
arm, am335x: update for the siemens boards (2013-11-12 09:53:59 -0500)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to d07e2b598a690d6eb75019b379fc4933affe3d2c:
arm: atmel: eb_cpux9k2: config clean up (2013-12-01 22:38:53 +0100)
---------------------------------------------------------------- Andreas Bießmann (6): video: remove AT91 legacy API from bus_vcxk i2c: switch from AT91 legacy to ATMEL legacy at91sam9m10g45ek: remove unused CONFIG_AT91_LEGACY snapper9260: remove unused AT91_LEGACY net: remove unused CONFIG_AT91_LEGACY at91: remove all occourances of CONFIG_AT91_LEGACY
Bo Shen (8): arm: atmel: sama5d3: correct the ID for DBGU and PIT arm: at91: pm9261: remove undefined bit in mckr arm: atmel: sama5d3: correct the error define of DIV arm: atmel: sama5d3: the offset of MULA is 18 arm: atmel: sama5d3: early enable PIO peripherals arm: atmel: add ddr2 initialization function arm: atmel: sama5d3: spl boot from fat fs SD card arm: atmel: sam9m10g45ek: let CONFIG_SYS_NO_FLASH at proper position
Heiko Schocher (1): arm926ejs, at91: add common phy_reset function
Jens Scharsig (BuS Elektronik) (1): arm: atmel: eb_cpux9k2: config clean up
Wu, Josh (1): ARM: at91: sama5d3: add support for sama5d36 chip
arch/arm/cpu/Makefile | 1 + arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/at91/sama5d3_devices.c | 6 +- arch/arm/cpu/armv7/at91/timer.c | 2 +- arch/arm/cpu/at91-common/Makefile | 12 +++ arch/arm/cpu/at91-common/mpddrc.c | 124 +++++++++++++++++++++++ arch/arm/cpu/at91-common/phy.c | 57 +++++++++++ arch/arm/cpu/at91-common/spl.c | 90 ++++++++++++++++ arch/arm/cpu/at91-common/u-boot-spl.lds | 50 +++++++++ arch/arm/include/asm/arch-at91/at91_common.h | 5 + arch/arm/include/asm/arch-at91/at91_pio.h | 33 ------ arch/arm/include/asm/arch-at91/at91_pit.h | 16 --- arch/arm/include/asm/arch-at91/at91_pmc.h | 59 ++--------- arch/arm/include/asm/arch-at91/at91_spi.h | 2 +- arch/arm/include/asm/arch-at91/at91_wdt.h | 21 ---- arch/arm/include/asm/arch-at91/at91cap9.h | 69 ------------- arch/arm/include/asm/arch-at91/at91sam9_smc.h | 60 ----------- arch/arm/include/asm/arch-at91/atmel_mpddrc.h | 115 +++++++++++++++++++++ arch/arm/include/asm/arch-at91/sama5d3.h | 3 + arch/arm/include/asm/arch-at91/spl.h | 20 ++++ board/BuS/vl_ma2sc/vl_ma2sc.c | 18 +--- board/afeb9260/afeb9260.c | 18 +--- board/atmel/at91sam9260ek/at91sam9260ek.c | 19 +--- board/atmel/at91sam9263ek/at91sam9263ek.c | 19 +--- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 19 +--- board/atmel/sama5d3xek/sama5d3xek.c | 91 +++++++++++++++++ board/bluewater/snapper9260/snapper9260.c | 16 +-- board/calao/sbc35_a9g20/sbc35_a9g20.c | 19 +--- board/eukrea/cpu9260/cpu9260.c | 18 +--- board/taskit/stamp9g20/stamp9g20.c | 31 +----- doc/README.at91-soc | 7 ++ drivers/i2c/soft_i2c.c | 2 +- drivers/net/at91_emac.c | 9 -- drivers/video/bus_vcxk.c | 15 --- include/configs/afeb9260.h | 2 +- include/configs/at91sam9260ek.h | 1 + include/configs/at91sam9263ek.h | 1 + include/configs/at91sam9m10g45ek.h | 9 +- include/configs/cpu9260.h | 1 + include/configs/eb_cpux9k2.h | 4 - include/configs/pm9261.h | 6 +- include/configs/sama5d3xek.h | 34 +++++++ include/configs/sbc35_a9g20.h | 1 + include/configs/snapper9260.h | 2 +- include/configs/stamp9g20.h | 1 + include/configs/vl_ma2sc.h | 1 + include/i2c.h | 2 +- 47 files changed, 655 insertions(+), 458 deletions(-) create mode 100644 arch/arm/cpu/at91-common/Makefile create mode 100644 arch/arm/cpu/at91-common/mpddrc.c create mode 100644 arch/arm/cpu/at91-common/phy.c create mode 100644 arch/arm/cpu/at91-common/spl.c create mode 100644 arch/arm/cpu/at91-common/u-boot-spl.lds create mode 100644 arch/arm/include/asm/arch-at91/atmel_mpddrc.h create mode 100644 arch/arm/include/asm/arch-at91/spl.h
Hi Andreas,
On Sun, 1 Dec 2013 22:50:12 +0100, Andreas Bießmann andreas.devel@googlemail.com wrote:
Applied to u-boot-arm/master, thanks! And apologies for the delay.
Amicalement,
Albert ARIBAUD
Andreas Bießmann
