[U-Boot] [PATCH] timer: dw-apb: Add missing 64bit up-conversion
The generic timer count is an incrementing 64bit value and a timer driver must return an incrementing 64bit value. The DW APB timer only provides a 32bit timer counting down, thus the result must be inverted and converted to a 64bit value. The current implementation is however missing the 64bit up-conversion and this results in random timer roll-overs, which in turn triggers random timeouts throughout the codebase.
This patch adds the missing 64bit up-conversion to fix the issue.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Ley Foon Tan ley.foon.tan@intel.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com --- drivers/timer/dw-apb-timer.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/timer/dw-apb-timer.c b/drivers/timer/dw-apb-timer.c index 085bfb02c5..cb48801af1 100644 --- a/drivers/timer/dw-apb-timer.c +++ b/drivers/timer/dw-apb-timer.c @@ -32,7 +32,7 @@ static int dw_apb_timer_get_count(struct udevice *dev, u64 *count) * requires the count to be incrementing. Invert the * result. */ - *count = ~readl(priv->regs + DW_APB_CURR_VAL); + *count = timer_conv_64(~readl(priv->regs + DW_APB_CURR_VAL));
return 0; }
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
*count = timer_conv_64(~readl(priv->regs + DW_APB_CURR_VAL)); return 0;
2.20.1
Maybe it's time to convert Gen5 to this timer driver too :)
Yes, well, let's see when I find the time. Converting clock and pinctrl to devicetree is on my list as well...
Simon Goldschmidt
