[U-Boot] [PATCH v3 00/16] arm: k3: arm64: Initial support for Texas Instrument's J721E Platform
This series adds initial support for Texas Instruments' K3 architecture based J721E SoC. This series depends on the: - mmc series posted by Faiz: https://patchwork.ozlabs.org/project/uboot/list/?series=112948 - sysfw loader series posted by Andreas: https://patchwork.ozlabs.org/project/uboot/list/?series=111844 - exclusive device series posted: https://patchwork.ozlabs.org/project/uboot/list/?series=112440 - arm64 rproc cleanup series: https://patchwork.ozlabs.org/project/uboot/list/?series=112443
Changes since v2: - Dropped an unused macro from PATCH 2/16
Changes since v1: - Updated the DT nodes with exclusive permissions - Fixed up mmc boot mode definition - Added support for fixing up msmc sram - Added custom mmu for armv8 - Added sysfw loader support.
The entire series with all the dependencies is available at: https://github.com/lokeshvutla/u-boot/tree/j721e-initial-support
Andreas Dannenberg (3): armv7R: K3: j721e: Unlock all applicable control MMR registers armv7R: K3: j721e: Store boot index from ROM armv7R: K3: j721e: Load SYSFW binary and config from boot media
Faiz Abbas (1): mmc: am654_sdhci: Separate J721E compatible into 8bit and 4bit versions
Lokesh Vutla (10): arm: K3: j721e: Add basic support for J721E SoC definition armv7R: K3: j721e: Add support for boot device detection armv7R: K3: j721e: Shut down R5 core after ATF startup on A72 board: ti: j721e: Add board support for j721e evm dt-bindings: pinctrl: k3: Introduce pinmux definitions for J721E arm: dts: ti: Add Support for J721E SoC arm: dts: k3-j721e: Add initial support for common processor board arm: dts: k3-j721e: Add r5 specific dt support configs: j721e_evm_r5: Add initial support configs: j721e_evm_a72: Add initial support
Suman Anna (2): armv8: K3: j721e: Add custom MMU support board: ti: j721e: Enable fixing up msmc sram node
arch/arm/dts/Makefile | 2 + .../k3-j721e-common-proc-board-u-boot.dtsi | 75 ++++++ arch/arm/dts/k3-j721e-common-proc-board.dts | 63 +++++ arch/arm/dts/k3-j721e-main.dtsi | 231 ++++++++++++++++++ arch/arm/dts/k3-j721e-mcu-wakeup.dtsi | 72 ++++++ .../arm/dts/k3-j721e-r5-common-proc-board.dts | 141 +++++++++++ arch/arm/dts/k3-j721e-som-p0.dtsi | 29 +++ arch/arm/dts/k3-j721e.dtsi | 177 ++++++++++++++ arch/arm/mach-k3/Kconfig | 13 +- arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am6_init.c | 6 - arch/arm/mach-k3/arm64-mmu.c | 55 +++++ arch/arm/mach-k3/common.c | 6 + arch/arm/mach-k3/include/mach/hardware.h | 4 + .../arm/mach-k3/include/mach/j721e_hardware.h | 49 ++++ arch/arm/mach-k3/include/mach/j721e_spl.h | 31 +++ arch/arm/mach-k3/include/mach/spl.h | 4 + arch/arm/mach-k3/j721e_init.c | 228 +++++++++++++++++ board/ti/j721e/Kconfig | 55 +++++ board/ti/j721e/Makefile | 8 + board/ti/j721e/evm.c | 82 +++++++ configs/j721e_evm_a72_defconfig | 86 +++++++ configs/j721e_evm_r5_defconfig | 95 +++++++ drivers/mmc/am654_sdhci.c | 114 +++++---- include/configs/j721e_evm.h | 103 ++++++++ include/dt-bindings/pinctrl/k3.h | 3 + 26 files changed, 1682 insertions(+), 51 deletions(-) create mode 100644 arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-common-proc-board.dts create mode 100644 arch/arm/dts/k3-j721e-main.dtsi create mode 100644 arch/arm/dts/k3-j721e-mcu-wakeup.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-common-proc-board.dts create mode 100644 arch/arm/dts/k3-j721e-som-p0.dtsi create mode 100644 arch/arm/dts/k3-j721e.dtsi create mode 100644 arch/arm/mach-k3/include/mach/j721e_hardware.h create mode 100644 arch/arm/mach-k3/include/mach/j721e_spl.h create mode 100644 arch/arm/mach-k3/j721e_init.c create mode 100644 board/ti/j721e/Kconfig create mode 100644 board/ti/j721e/Makefile create mode 100644 board/ti/j721e/evm.c create mode 100644 configs/j721e_evm_a72_defconfig create mode 100644 configs/j721e_evm_r5_defconfig create mode 100644 include/configs/j721e_evm.h
The J721E SoC belongs to the K3 Multicore SoC architecture platform, providing advanced system integration to enable lower system costs of automotive applications such as infotainment, cluster, premium Audio, Gateway, industrial and a range of broad market applications. This SoC is designed around reducing the system cost by eliminating the need of an external system MCU and is targeted towards ASIL-B/C certification/requirements in addition to allowing complex software and system use-cases.
Some highlights of this SoC are: * Dual Cortex-A72s in a single cluster, three clusters of lockstep capable dual Cortex-R5F MCUs, Deep-learning Matrix Multiply Accelerator(MMA), C7x floating point Vector DSP, Two C66x floating point DSPs. * 3D GPU PowerVR Rogue 8XE GE8430 * Vision Processing Accelerator (VPAC) with image signal processor and Depth and Motion Processing Accelerator (DMPAC) * Two Gigabit Industrial Communication Subsystems (ICSSG), each with dual PRUs and dual RTUs * Two CSI2.0 4L RX plus one CSI2.0 4L TX, one eDP/DP, One DSI Tx, and up to two DPI interfaces. * Integrated Ethernet switch supporting up to a total of 8 external ports in addition to legacy Ethernet switch of up to 2 ports. * System MMU (SMMU) Version 3.0 and advanced virtualisation capabilities. * Upto 4 PCIe-GEN3 controllers, 2 USB3.0 Dual-role device subsystems, 16 MCANs, 12 McASP, eMMC and SD, UFS, OSPI/HyperBus memory controller, QSPI, I3C and I2C, eCAP/eQEP, eHRPWM, MLB among other peripherals. * Two hardware accelerator block containing AES/DES/SHA/MD5 called SA2UL management. * Configurable L3 Cache and IO-coherent architecture with high data throughput capable distributed DMA architecture under NAVSS * Centralized System Controller for Security, Power, and Resource Management (DMSC)
See J721E Technical Reference Manual (SPRUIL1, May 2019) for further details: http://www.ti.com/lit/pdf/spruil1
Add base support for J721E SoC
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/mach-k3/Kconfig | 12 ++++++++++-- arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am6_init.c | 6 ------ arch/arm/mach-k3/common.c | 6 ++++++ arch/arm/mach-k3/j721e_init.c | 34 ++++++++++++++++++++++++++++++++++ 5 files changed, 51 insertions(+), 8 deletions(-) create mode 100644 arch/arm/mach-k3/j721e_init.c
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index f25f822205..bf90d49b47 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -7,6 +7,9 @@ choice config SOC_K3_AM6 bool "TI's K3 based AM6 SoC Family Support"
+config SOC_K3_J721E + bool "TI's K3 based J721E SoC Family Support" + endchoice
config SYS_SOC @@ -14,7 +17,8 @@ config SYS_SOC
config SYS_K3_NON_SECURE_MSRAM_SIZE hex - default 0x80000 + default 0x80000 if SOC_K3_AM6 + default 0x100000 if SOC_K3_J721E help Describes the total size of the MCU MSRAM. This doesn't specify the total size of SPL as ROM can use some part @@ -23,7 +27,8 @@ config SYS_K3_NON_SECURE_MSRAM_SIZE
config SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE hex - default 0x58000 + default 0x58000 if SOC_K3_AM6 + default 0xc0000 if SOC_K3_J721E help Describes the maximum size of the image that ROM can download from any boot media. @@ -31,18 +36,21 @@ config SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE config SYS_K3_MCU_SCRATCHPAD_BASE hex default 0x40280000 if SOC_K3_AM6 + default 0x40280000 if SOC_K3_J721E help Describes the base address of MCU Scratchpad RAM.
config SYS_K3_MCU_SCRATCHPAD_SIZE hex default 0x200 if SOC_K3_AM6 + default 0x200 if SOC_K3_J721E help Describes the size of MCU Scratchpad RAM.
config SYS_K3_BOOT_PARAM_TABLE_INDEX hex default 0x41c7fbfc if SOC_K3_AM6 + default 0x41cffc00 if SOC_K3_J721E help Address at which ROM stores the value which determines if SPL is booted up by primary boot media or secondary boot media. diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index 3af7f2ec96..028015ed66 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -4,6 +4,7 @@ # Lokesh Vutla lokeshvutla@ti.com
obj-$(CONFIG_SOC_K3_AM6) += am6_init.o +obj-$(CONFIG_SOC_K3_J721E) += j721e_init.o obj-$(CONFIG_ARM64) += arm64-mmu.o obj-$(CONFIG_CPU_V7R) += r5_mpu.o lowlevel_init.o obj-$(CONFIG_TI_SECURE_DEVICE) += security.o diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index 31fa1c8803..6558fe0ef4 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -210,12 +210,6 @@ u32 spl_boot_device(void) } #endif
-#ifndef CONFIG_SYSRESET -void reset_cpu(ulong ignored) -{ -} -#endif - #ifdef CONFIG_SYS_K3_SPL_ATF
#define AM6_DEV_MCU_RTI0 134 diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 4e7fe2076c..bab5ffdf40 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -138,3 +138,9 @@ int fdt_fixup_msmc_ram(void *blob, char *parent_path, char *node_name) return 0; } #endif + +#ifndef CONFIG_SYSRESET +void reset_cpu(ulong ignored) +{ +} +#endif diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c new file mode 100644 index 0000000000..14b4881527 --- /dev/null +++ b/arch/arm/mach-k3/j721e_init.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * J721E: SoC specific initialization + * + * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla lokeshvutla@ti.com + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/armv7_mpu.h> +#include "common.h" + +#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong dummy) +{ + /* + * ToDo: + * - Store boot rom index. + * - unlock mmr. + */ + +#ifdef CONFIG_CPU_V7R + setup_k3_mpu_regions(); +#endif + + /* Init DM early */ + spl_early_init(); + + /* Prepare console output */ + preloader_console_init(); +} +#endif
- Dual Cortex-A72s in a single cluster, three clusters of lockstep capable dual Cortex-R5F MCUs, Deep-learning Matrix Multiply Accelerator(MMA), C7x floating point Vector DSP, Two C66x floating point DSPs.
- 3D GPU PowerVR Rogue 8XE GE8430
- Vision Processing Accelerator (VPAC) with image signal processor and Depth and Motion Processing Accelerator (DMPAC)
- Two Gigabit Industrial Communication Subsystems (ICSSG), each with dual PRUs and dual RTUs
- Two CSI2.0 4L RX plus one CSI2.0 4L TX, one eDP/DP, One DSI Tx, and up to two DPI interfaces.
- Integrated Ethernet switch supporting up to a total of 8 external ports in addition to legacy Ethernet switch of up to 2 ports.
- System MMU (SMMU) Version 3.0 and advanced virtualisation capabilities.
- Upto 4 PCIe-GEN3 controllers, 2 USB3.0 Dual-role device subsystems, 16 MCANs, 12 McASP, eMMC and SD, UFS, OSPI/HyperBus memory controller, QSPI, I3C and I2C, eCAP/eQEP, eHRPWM, MLB among other peripherals.
- Two hardware accelerator block containing AES/DES/SHA/MD5 called SA2UL management.
- Configurable L3 Cache and IO-coherent architecture with high data throughput capable distributed DMA architecture under NAVSS
- Centralized System Controller for Security, Power, and Resource Management (DMSC)
J721E allows for booting from primary or backup boot media. Both media can be chosen individually based on switch settings. ROM looks for a valid image in primary boot media, if not found then looks in backup boot media. In order to pass this boot media information to boot loader, ROM stores a value at a particular address. Add support for reading this information and determining the boot media correctly.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Faiz Abbas faiz_abbas@ti.com --- arch/arm/mach-k3/include/mach/hardware.h | 4 ++ .../arm/mach-k3/include/mach/j721e_hardware.h | 49 +++++++++++++++++ arch/arm/mach-k3/include/mach/j721e_spl.h | 31 +++++++++++ arch/arm/mach-k3/include/mach/spl.h | 4 ++ arch/arm/mach-k3/j721e_init.c | 53 +++++++++++++++++++ 5 files changed, 141 insertions(+) create mode 100644 arch/arm/mach-k3/include/mach/j721e_hardware.h create mode 100644 arch/arm/mach-k3/include/mach/j721e_spl.h
diff --git a/arch/arm/mach-k3/include/mach/hardware.h b/arch/arm/mach-k3/include/mach/hardware.h index b39f780d26..4e629822aa 100644 --- a/arch/arm/mach-k3/include/mach/hardware.h +++ b/arch/arm/mach-k3/include/mach/hardware.h @@ -9,4 +9,8 @@ #ifdef CONFIG_SOC_K3_AM6 #include "am6_hardware.h" #endif + +#ifdef CONFIG_SOC_K3_J721E +#include "j721e_hardware.h" +#endif #endif /* _ASM_ARCH_HARDWARE_H_ */ diff --git a/arch/arm/mach-k3/include/mach/j721e_hardware.h b/arch/arm/mach-k3/include/mach/j721e_hardware.h new file mode 100644 index 0000000000..8d429772b5 --- /dev/null +++ b/arch/arm/mach-k3/include/mach/j721e_hardware.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * K3: J721E SoC definitions, structures etc. + * + * (C) Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ + */ +#ifndef __ASM_ARCH_J721E_HARDWARE_H +#define __ASM_ARCH_J721E_HARDWARE_H + +#include <config.h> + +#define CTRL_MMR0_BASE 0x00100000 +#define CTRLMMR_MAIN_DEVSTAT (CTRL_MMR0_BASE + 0x30) + +#define MAIN_DEVSTAT_BOOT_MODE_B_MASK BIT(0) +#define MAIN_DEVSTAT_BOOT_MODE_B_SHIFT 0 +#define MAIN_DEVSTAT_BKUP_BOOTMODE_MASK GENMASK(3, 1) +#define MAIN_DEVSTAT_BKUP_BOOTMODE_SHIFT 1 +#define MAIN_DEVSTAT_PRIM_BOOTMODE_MMC_PORT_MASK BIT(6) +#define MAIN_DEVSTAT_PRIM_BOOTMODE_PORT_SHIFT 6 + +#define WKUP_CTRL_MMR0_BASE 0x43000000 +#define MCU_CTRL_MMR0_BASE 0x40f00000 + +#define CTRLMMR_WKUP_DEVSTAT (WKUP_CTRL_MMR0_BASE + 0x30) +#define WKUP_DEVSTAT_PRIMARY_BOOTMODE_MASK GENMASK(5, 3) +#define WKUP_DEVSTAT_PRIMARY_BOOTMODE_SHIFT 3 +#define WKUP_DEVSTAT_MCU_OMLY_MASK BIT(6) +#define WKUP_DEVSTAT_MCU_ONLY_SHIFT 6 + +/* + * The CTRL_MMR0 memory space is divided into several equally-spaced + * partitions, so defining the partition size allows us to determine + * register addresses common to those partitions. + */ +#define CTRL_MMR0_PARTITION_SIZE 0x4000 + +/* + * CTRL_MMR0, WKUP_CTRL_MMR0, and MCU_CTR_MMR0 lock/kick-mechanism + * shared register definitions. + */ +#define CTRLMMR_LOCK_KICK0 0x01008 +#define CTRLMMR_LOCK_KICK0_UNLOCK_VAL 0x68ef3490 +#define CTRLMMR_LOCK_KICK0_UNLOCKED_MASK BIT(0) +#define CTRLMMR_LOCK_KICK0_UNLOCKED_SHIFT 0 +#define CTRLMMR_LOCK_KICK1 0x0100c +#define CTRLMMR_LOCK_KICK1_UNLOCK_VAL 0xd172bc5a + +#endif /* __ASM_ARCH_J721E_HARDWARE_H */ diff --git a/arch/arm/mach-k3/include/mach/j721e_spl.h b/arch/arm/mach-k3/include/mach/j721e_spl.h new file mode 100644 index 0000000000..2b52faf944 --- /dev/null +++ b/arch/arm/mach-k3/include/mach/j721e_spl.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla lokeshvutla@ti.com + */ +#ifndef _ASM_ARCH_J721E_SPL_H_ +#define _ASM_ARCH_J721E_SPL_H_ + +/* With BootMode B = 0 */ +#define BOOT_DEVICE_HYPERFLASH 0x00 +#define BOOT_DEVICE_OSPI 0x01 +#define BOOT_DEVICE_QSPI 0x02 +#define BOOT_DEVICE_SPI 0x03 +#define BOOT_DEVICE_ETHERNET 0x04 +#define BOOT_DEVICE_I2C 0x06 +#define BOOT_DEVICE_UART 0x07 + +/* With BootMode B = 1 */ +#define BOOT_DEVICE_MMC2 0x10 +#define BOOT_DEVICE_MMC1 0x11 +#define BOOT_DEVICE_USB 0x12 +#define BOOT_DEVICE_UFS 0x13 +#define BOOT_DEVIE_GPMC 0x14 +#define BOOT_DEVICE_PCIE 0x15 +#define BOOT_DEVICE_MMC2_2 0x16 +#define BOOT_DEVICE_RAM 0x17 + +#define BOOT_MODE_B_SHIFT 4 +#define BOOT_MODE_B_MASK BIT(4) + +#endif diff --git a/arch/arm/mach-k3/include/mach/spl.h b/arch/arm/mach-k3/include/mach/spl.h index 2d435aec17..a26c8ecdd5 100644 --- a/arch/arm/mach-k3/include/mach/spl.h +++ b/arch/arm/mach-k3/include/mach/spl.h @@ -9,4 +9,8 @@ #ifdef CONFIG_SOC_K3_AM6 #include "am6_spl.h" #endif + +#ifdef CONFIG_SOC_K3_J721E +#include "j721e_spl.h" +#endif #endif /* _ASM_ARCH_SPL_H_ */ diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index 14b4881527..80e88dd185 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -10,6 +10,7 @@ #include <spl.h> #include <asm/io.h> #include <asm/armv7_mpu.h> +#include <asm/arch/hardware.h> #include "common.h"
#ifdef CONFIG_SPL_BUILD @@ -31,4 +32,56 @@ void board_init_f(ulong dummy) /* Prepare console output */ preloader_console_init(); } + +u32 spl_boot_mode(const u32 boot_device) +{ + switch (boot_device) { + case BOOT_DEVICE_MMC1: + return MMCSD_MODE_EMMCBOOT; + case BOOT_DEVICE_MMC2: + return MMCSD_MODE_FS; + default: + return MMCSD_MODE_RAW; + } +} + +static u32 __get_primary_bootmedia(u32 main_devstat, u32 wkup_devstat) +{ + + u32 bootmode = (wkup_devstat & WKUP_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> + WKUP_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; + + bootmode |= (main_devstat & MAIN_DEVSTAT_BOOT_MODE_B_MASK) << + BOOT_MODE_B_SHIFT; + + if (bootmode == BOOT_DEVICE_OSPI || bootmode == BOOT_DEVICE_QSPI) + bootmode = BOOT_DEVICE_SPI; + + if (bootmode == BOOT_DEVICE_MMC2) { + u32 port = (main_devstat & + MAIN_DEVSTAT_PRIM_BOOTMODE_MMC_PORT_MASK) >> + MAIN_DEVSTAT_PRIM_BOOTMODE_PORT_SHIFT; + if (port == 0x0) + bootmode = BOOT_DEVICE_MMC1; + } + + return bootmode; +} + +u32 spl_boot_device(void) +{ + u32 wkup_devstat = readl(CTRLMMR_WKUP_DEVSTAT); + u32 main_devstat; + + if (wkup_devstat & WKUP_DEVSTAT_MCU_OMLY_MASK) { + printf("ERROR: MCU only boot is not yet supported\n"); + return BOOT_DEVICE_RAM; + } + + /* MAIN CTRL MMR can only be read if MCU ONLY is 0 */ + main_devstat = readl(CTRLMMR_MAIN_DEVSTAT); + + /* ToDo: Add support for backup boot media */ + return __get_primary_bootmedia(main_devstat, wkup_devstat); +} #endif
To access various control MMR functionality the registers need to be unlocked. Do that for all control MMR regions in the MCU and MAIN domains. We may want to go back later and limit the unlocking that's being done.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/j721e_init.c | 43 ++++++++++++++++++++++++++++++++++- 1 file changed, 42 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index 80e88dd185..ba6a1cf0e6 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -14,14 +14,55 @@ #include "common.h"
#ifdef CONFIG_SPL_BUILD +static void mmr_unlock(u32 base, u32 partition) +{ + /* Translate the base address */ + phys_addr_t part_base = base + partition * CTRL_MMR0_PARTITION_SIZE; + + /* Unlock the requested partition if locked using two-step sequence */ + writel(CTRLMMR_LOCK_KICK0_UNLOCK_VAL, part_base + CTRLMMR_LOCK_KICK0); + writel(CTRLMMR_LOCK_KICK1_UNLOCK_VAL, part_base + CTRLMMR_LOCK_KICK1); +} + +static void ctrl_mmr_unlock(void) +{ + /* Unlock all WKUP_CTRL_MMR0 module registers */ + mmr_unlock(WKUP_CTRL_MMR0_BASE, 0); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 1); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 2); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 3); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 4); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 6); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 7); + + /* Unlock all MCU_CTRL_MMR0 module registers */ + mmr_unlock(MCU_CTRL_MMR0_BASE, 0); + mmr_unlock(MCU_CTRL_MMR0_BASE, 1); + mmr_unlock(MCU_CTRL_MMR0_BASE, 2); + mmr_unlock(MCU_CTRL_MMR0_BASE, 3); + mmr_unlock(MCU_CTRL_MMR0_BASE, 4); + + /* Unlock all CTRL_MMR0 module registers */ + mmr_unlock(CTRL_MMR0_BASE, 0); + mmr_unlock(CTRL_MMR0_BASE, 1); + mmr_unlock(CTRL_MMR0_BASE, 2); + mmr_unlock(CTRL_MMR0_BASE, 3); + mmr_unlock(CTRL_MMR0_BASE, 4); + mmr_unlock(CTRL_MMR0_BASE, 5); + mmr_unlock(CTRL_MMR0_BASE, 6); + mmr_unlock(CTRL_MMR0_BASE, 7); +} + void board_init_f(ulong dummy) { /* * ToDo: * - Store boot rom index. - * - unlock mmr. */
+ /* Make all control module registers accessible */ + ctrl_mmr_unlock(); + #ifdef CONFIG_CPU_V7R setup_k3_mpu_regions(); #endif
Obtain the boot index as left behind by the device boot ROM and store it in scratch pad SRAM for later use before it may get overwritten.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/j721e_init.c | 17 +++++++++++++++-- 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index ba6a1cf0e6..b7f0546dd7 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -53,12 +53,25 @@ static void ctrl_mmr_unlock(void) mmr_unlock(CTRL_MMR0_BASE, 7); }
+/* + * This uninitialized global variable would normal end up in the .bss section, + * but the .bss is cleared between writing and reading this variable, so move + * it to the .data section. + */ +u32 bootindex __attribute__((section(".data"))); + +static void store_boot_index_from_rom(void) +{ + bootindex = *(u32 *)(CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX); +} + void board_init_f(ulong dummy) { /* - * ToDo: - * - Store boot rom index. + * Cannot delay this further as there is a chance that + * K3_BOOT_PARAM_TABLE_INDEX can be over written by SPL MALLOC section. */ + store_boot_index_from_rom();
/* Make all control module registers accessible */ ctrl_mmr_unlock();
Populate the release_resources_for_core_shutdown() api with shutting down r5 cores so that it will by called just after jumping to ATF.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-k3/j721e_init.c | 57 +++++++++++++++++++++++++++++++++++ 1 file changed, 57 insertions(+)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index b7f0546dd7..5514dc963e 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -12,6 +12,8 @@ #include <asm/armv7_mpu.h> #include <asm/arch/hardware.h> #include "common.h" +#include <asm/arch/sys_proto.h> +#include <linux/soc/ti/ti_sci_protocol.h>
#ifdef CONFIG_SPL_BUILD static void mmr_unlock(u32 base, u32 partition) @@ -139,3 +141,58 @@ u32 spl_boot_device(void) return __get_primary_bootmedia(main_devstat, wkup_devstat); } #endif + +#ifdef CONFIG_SYS_K3_SPL_ATF + +#define J721E_DEV_MCU_RTI0 262 +#define J721E_DEV_MCU_RTI1 263 +#define J721E_DEV_MCU_ARMSS0_CPU0 250 +#define J721E_DEV_MCU_ARMSS0_CPU1 251 + +void release_resources_for_core_shutdown(void) +{ + struct ti_sci_handle *ti_sci; + struct ti_sci_dev_ops *dev_ops; + struct ti_sci_proc_ops *proc_ops; + int ret; + u32 i; + + const u32 put_device_ids[] = { + J721E_DEV_MCU_RTI0, + J721E_DEV_MCU_RTI1, + }; + + ti_sci = get_ti_sci_handle(); + dev_ops = &ti_sci->ops.dev_ops; + proc_ops = &ti_sci->ops.proc_ops; + + /* Iterate through list of devices to put (shutdown) */ + for (i = 0; i < ARRAY_SIZE(put_device_ids); i++) { + u32 id = put_device_ids[i]; + + ret = dev_ops->put_device(ti_sci, id); + if (ret) + panic("Failed to put device %u (%d)\n", id, ret); + } + + const u32 put_core_ids[] = { + J721E_DEV_MCU_ARMSS0_CPU1, + J721E_DEV_MCU_ARMSS0_CPU0, /* Handle CPU0 after CPU1 */ + }; + + /* Iterate through list of cores to put (shutdown) */ + for (i = 0; i < ARRAY_SIZE(put_core_ids); i++) { + u32 id = put_core_ids[i]; + + /* + * Queue up the core shutdown request. Note that this call + * needs to be followed up by an actual invocation of an WFE + * or WFI CPU instruction. + */ + ret = proc_ops->proc_shutdown_no_wait(ti_sci, id); + if (ret) + panic("Failed sending core %u shutdown message (%d)\n", + id, ret); + } +} +#endif
Use the System Firmware (SYSFW) loader framework to load and start the SYSFW as part of the J721E early initialization sequence. While at it also initialize the MCU_UART0 pinmux as it is used by SYSFW to print diagnostic messages.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-k3/j721e_init.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index 5514dc963e..733e414654 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -11,9 +11,13 @@ #include <asm/io.h> #include <asm/armv7_mpu.h> #include <asm/arch/hardware.h> +#include <asm/arch/sysfw-loader.h> #include "common.h" #include <asm/arch/sys_proto.h> #include <linux/soc/ti/ti_sci_protocol.h> +#include <dm.h> +#include <dm/uclass-internal.h> +#include <dm/pinctrl.h>
#ifdef CONFIG_SPL_BUILD static void mmr_unlock(u32 base, u32 partition) @@ -69,6 +73,10 @@ static void store_boot_index_from_rom(void)
void board_init_f(ulong dummy) { +#if defined(CONFIG_K3_LOAD_SYSFW) + struct udevice *dev; + int ret; +#endif /* * Cannot delay this further as there is a chance that * K3_BOOT_PARAM_TABLE_INDEX can be over written by SPL MALLOC section. @@ -85,8 +93,30 @@ void board_init_f(ulong dummy) /* Init DM early */ spl_early_init();
+#ifdef CONFIG_K3_LOAD_SYSFW + /* + * Process pinctrl for the serial0 a.k.a. MCU_UART0 module and continue + * regardless of the result of pinctrl. Do this without probing the + * device, but instead by searching the device that would request the + * given sequence number if probed. The UART will be used by the system + * firmware (SYSFW) image for various purposes and SYSFW depends on us + * to initialize its pin settings. + */ + ret = uclass_find_device_by_seq(UCLASS_SERIAL, 0, true, &dev); + if (!ret) + pinctrl_select_state(dev, "default"); + + /* + * Load, start up, and configure system controller firmware. Provide + * the U-Boot console init function to the SYSFW post-PM configuration + * callback hook, effectively switching on (or over) the console + * output. + */ + k3_sysfw_loader(preloader_console_init); +#else /* Prepare console output */ preloader_console_init(); +#endif }
The A72 U-Boot code loads and boots a number of remote processors including the C71x DSP, both the C66_0 and C66_1 DSPs, and the various Main R5FSS Cores. Change the memory attributes for the DDR regions used by the remote processors so that the cores can see and execute the proper code.
A separate table based on the current AM65x table is added for J721E SoCs, since the number of remote processors and their DDR usage will be different between the two SoC families.
Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-k3/arm64-mmu.c | 55 ++++++++++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/arch/arm/mach-k3/arm64-mmu.c b/arch/arm/mach-k3/arm64-mmu.c index a75ba1ffdb..82778d2197 100644 --- a/arch/arm/mach-k3/arm64-mmu.c +++ b/arch/arm/mach-k3/arm64-mmu.c @@ -12,6 +12,7 @@ #include <asm/system.h> #include <asm/armv8/mmu.h>
+#ifdef CONFIG_SOC_K3_AM6 /* NR_DRAM_BANKS + 32bit IO + 64bit IO + terminator */ #define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 3)
@@ -43,3 +44,57 @@ struct mm_region am654_mem_map[NR_MMU_REGIONS] = { };
struct mm_region *mem_map = am654_mem_map; +#endif /* CONFIG_SOC_K3_AM6 */ + +#ifdef CONFIG_SOC_K3_J721E +/* NR_DRAM_BANKS + 32bit IO + 64bit IO + terminator */ +#define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 5) + +/* ToDo: Add 64bit IO */ +struct mm_region j721e_mem_map[NR_MMU_REGIONS] = { + { + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x20000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xa0000000UL, + .phys = 0xa0000000UL, + .size = 0x0bc00000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL_NC) | + PTE_BLOCK_NON_SHARE + }, { + .virt = 0xabc00000UL, + .phys = 0xabc00000UL, + .size = 0x54400000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x880000000UL, + .phys = 0x880000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x500000000UL, + .phys = 0x500000000UL, + .size = 0x400000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = j721e_mem_map; +#endif /* CONFIG_SOC_K3_J721E */
Add board specific initialization for j721e evm
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/Kconfig | 1 + board/ti/j721e/Kconfig | 55 +++++++++++++++++++ board/ti/j721e/Makefile | 8 +++ board/ti/j721e/evm.c | 68 ++++++++++++++++++++++++ include/configs/j721e_evm.h | 103 ++++++++++++++++++++++++++++++++++++ 5 files changed, 235 insertions(+) create mode 100644 board/ti/j721e/Kconfig create mode 100644 board/ti/j721e/Makefile create mode 100644 board/ti/j721e/evm.c create mode 100644 include/configs/j721e_evm.h
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index bf90d49b47..9652c96a78 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -113,4 +113,5 @@ config SYS_K3_SPL_ATF after SPL from R5.
source "board/ti/am65x/Kconfig" +source "board/ti/j721e/Kconfig" endif diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig new file mode 100644 index 0000000000..c2deb6916a --- /dev/null +++ b/board/ti/j721e/Kconfig @@ -0,0 +1,55 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ +# Lokesh Vutla lokeshvutla@ti.com + +choice + prompt "K3 J721E based boards" + optional + +config TARGET_J721E_A72_EVM + bool "TI K3 based J721E EVM running on A72" + select ARM64 + select SOC_K3_J721E + select SYS_DISABLE_DCACHE_OPS + +config TARGET_J721E_R5_EVM + bool "TI K3 based J721E EVM running on R5" + select CPU_V7R + select SYS_THUMB_BUILD + select SOC_K3_J721E + select K3_LOAD_SYSFW + select RAM + select SPL_RAM + imply SYS_K3_SPL_ATF + +endchoice + +if TARGET_J721E_A72_EVM + +config SYS_BOARD + default "j721e" + +config SYS_VENDOR + default "ti" + +config SYS_CONFIG_NAME + default "j721e_evm" + +endif + +if TARGET_J721E_R5_EVM + +config SYS_BOARD + default "j721e" + +config SYS_VENDOR + default "ti" + +config SYS_CONFIG_NAME + default "j721e_evm" + +config SPL_LDSCRIPT + default "arch/arm/mach-omap2/u-boot-spl.lds" + +endif diff --git a/board/ti/j721e/Makefile b/board/ti/j721e/Makefile new file mode 100644 index 0000000000..97535f5d86 --- /dev/null +++ b/board/ti/j721e/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ +# Lokesh Vutla lokeshvutla@ti.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += evm.o diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c new file mode 100644 index 0000000000..43d502b6ca --- /dev/null +++ b/board/ti/j721e/evm.c @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Board specific initialization for J721E EVM + * + * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla lokeshvutla@ti.com + * + */ + +#include <common.h> +#include <asm/io.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ +#ifdef CONFIG_PHYS_64BIT + gd->ram_size = 0x100000000; +#else + gd->ram_size = 0x80000000; +#endif + + return 0; +} + +ulong board_get_usable_ram_top(ulong total_size) +{ +#ifdef CONFIG_PHYS_64BIT + /* Limit RAM used by U-Boot to the DDR low region */ + if (gd->ram_top > 0x100000000) + return 0x100000000; +#endif + + return gd->ram_top; +} + +int dram_init_banksize(void) +{ + /* Bank 0 declares the memory available in the DDR low region */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = 0x80000000; + gd->ram_size = 0x80000000; + +#ifdef CONFIG_PHYS_64BIT + /* Bank 1 declares the memory available in the DDR high region */ + gd->bd->bi_dram[1].start = CONFIG_SYS_SDRAM_BASE1; + gd->bd->bi_dram[1].size = 0x80000000; + gd->ram_size = 0x100000000; +#endif + + return 0; +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + if (!strcmp(name, "k3-j721e-common-proc-board")) + return 0; + + return -1; +} +#endif diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h new file mode 100644 index 0000000000..5b35e22c85 --- /dev/null +++ b/include/configs/j721e_evm.h @@ -0,0 +1,103 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration header file for K3 J721E EVM + * + * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla lokeshvutla@ti.com + */ + +#ifndef __CONFIG_J721E_EVM_H +#define __CONFIG_J721E_EVM_H + +#include <linux/sizes.h> +#include <config_distro_bootcmd.h> +#include <environment/ti/mmc.h> + +#define CONFIG_ENV_SIZE (128 << 10) + +/* DDR Configuration */ +#define CONFIG_SYS_SDRAM_BASE1 0x880000000 + +/* SPL Loader Configuration */ +#ifdef CONFIG_TARGET_J721E_A72_EVM +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ + CONFIG_SYS_K3_NON_SECURE_MSRAM_SIZE) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x280000 +#else +/* + * Maximum size in memory allocated to the SPL BSS. Keep it as tight as + * possible (to allow the build to go through), as this directly affects + * our memory footprint. The less we use for BSS the more we have available + * for everything else. + */ +#define CONFIG_SPL_BSS_MAX_SIZE 0xA000 +/* + * Link BSS to be within SPL in a dedicated region located near the top of + * the MCU SRAM, this way making it available also before relocation. Note + * that we are not using the actual top of the MCU SRAM as there is a memory + * location filled in by the boot ROM that we want to read out without any + * interference from the C context. + */ +#define CONFIG_SPL_BSS_START_ADDR (CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX -\ + CONFIG_SPL_BSS_MAX_SIZE) +/* Set the stack right below the SPL BSS section */ +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SPL_BSS_START_ADDR +/* Configure R5 SPL post-relocation malloc pool in DDR */ +#define CONFIG_SYS_SPL_MALLOC_START 0x84000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x80000 +#endif + +#ifdef CONFIG_SYS_K3_SPL_ATF +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" +#endif + +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE + +#define CONFIG_SYS_BOOTM_LEN SZ_64M +#define CONFIG_CQSPI_REF_CLK 133333333 + +/* U-Boot general configuration */ +#define EXTRA_ENV_J721E_BOARD_SETTINGS \ + "default_device_tree=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "findfdt=" \ + "setenv fdtfile ${default_device_tree};" \ + "setenv overlay_files ${name_overlays}\0" \ + "loadaddr=0x80080000\0" \ + "fdtaddr=0x82000000\0" \ + "overlayaddr=0x83000000\0" \ + "name_kern=Image\0" \ + "console=ttyS2,115200n8\0" \ + "args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000\0" \ + "run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0" + +/* U-Boot MMC-specific configuration */ +#define EXTRA_ENV_J721E_BOARD_SETTINGS_MMC \ + "boot=mmc\0" \ + "mmcdev=1\0" \ + "bootpart=1:2\0" \ + "bootdir=/boot\0" \ + "rd_spec=-\0" \ + "init_mmc=run args_all args_mmc\0" \ + "get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ + "get_overlay_mmc=" \ + "fdt address ${fdtaddr};" \ + "fdt resize 0x100000;" \ + "for overlay in $overlay_files;" \ + "do;" \ + "load mmc ${bootpart} ${overlayaddr} ${bootdir}/${overlay} && " \ + "fdt apply ${overlayaddr};" \ + "done;\0" \ + "get_kern_mmc=load mmc ${bootpart} ${loadaddr} " \ + "${bootdir}/${name_kern}\0" + +/* Incorporate settings into the U-Boot environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + DEFAULT_MMC_TI_ARGS \ + EXTRA_ENV_J721E_BOARD_SETTINGS \ + EXTRA_ENV_J721E_BOARD_SETTINGS_MMC + +/* Now for the remaining common defines */ +#include <configs/ti_armv7_common.h> + +#endif /* __CONFIG_J721E_EVM_H */
Create a ft_board_setup() api that gets called as part of DT fixup before jumping to kernel. In this ft_board_setup() call fdt_fixup_msmc_ram that update msmc sram node.
Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/j721e/evm.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 43d502b6ca..db5d7b8834 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -10,6 +10,7 @@ #include <common.h> #include <asm/io.h> #include <spl.h> +#include <asm/arch/sys_proto.h>
@@ -66,3 +67,16 @@ int board_fit_config_name_match(const char *name) return -1; } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + int ret; + + ret = fdt_fixup_msmc_ram(blob, "/interconnect@100000", "sram@70000000"); + if (ret) + printf("%s: fixing up msmc ram failed %d\n", __func__, ret); + + return ret; +} +#endif
The j721e 4 bit instances don't have a hard DLL and therefore don't need any DLL related configurations. Split the compatibles into an 8 bit and a 4 bit one. Add a private flags field which can be used to check if the DLL is present and don't register the set_ios_post callback for the 4 bit compatible instances.
Also update the compatibles in k3-j721e-main.dtsi to avoid breaking boot with the new compatibles.
Signed-off-by: Faiz Abbas faiz_abbas@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- drivers/mmc/am654_sdhci.c | 114 ++++++++++++++++++++++++-------------- 1 file changed, 71 insertions(+), 43 deletions(-)
diff --git a/drivers/mmc/am654_sdhci.c b/drivers/mmc/am654_sdhci.c index fb0fb58070..1793a3f99a 100644 --- a/drivers/mmc/am654_sdhci.c +++ b/drivers/mmc/am654_sdhci.c @@ -72,6 +72,8 @@ struct am654_sdhci_plat { u32 otap_del_sel; u32 trm_icp; u32 drv_strength; + u32 flags; +#define DLL_PRESENT (1 << 0) bool dll_on; };
@@ -162,6 +164,10 @@ const struct sdhci_ops am654_sdhci_ops = { .set_control_reg = &am654_sdhci_set_control_reg, };
+const struct sdhci_ops j721e_4bit_sdhci_ops = { + .set_control_reg = &am654_sdhci_set_control_reg, +}; + int am654_sdhci_init(struct am654_sdhci_plat *plat) { u32 ctl_cfg_2 = 0; @@ -172,24 +178,28 @@ int am654_sdhci_init(struct am654_sdhci_plat *plat) mask = OTAPDLYENA_MASK | OTAPDLYSEL_MASK; regmap_update_bits(plat->base, PHY_CTRL4, mask, 0x0);
- regmap_read(plat->base, PHY_STAT1, &val); - if (~val & CALDONE_MASK) { - /* Calibrate IO lines */ - regmap_update_bits(plat->base, PHY_CTRL1, PDB_MASK, PDB_MASK); - ret = regmap_read_poll_timeout(plat->base, PHY_STAT1, val, - val & CALDONE_MASK, 1, 20); - if (ret) - return ret; - } + if (plat->flags & DLL_PRESENT) { + regmap_read(plat->base, PHY_STAT1, &val); + if (~val & CALDONE_MASK) { + /* Calibrate IO lines */ + regmap_update_bits(plat->base, PHY_CTRL1, PDB_MASK, + PDB_MASK); + ret = regmap_read_poll_timeout(plat->base, PHY_STAT1, + val, val & CALDONE_MASK, + 1, 20); + if (ret) + return ret; + }
- /* Configure DLL TRIM */ - mask = DLL_TRIM_ICP_MASK; - val = plat->trm_icp << DLL_TRIM_ICP_SHIFT; + /* Configure DLL TRIM */ + mask = DLL_TRIM_ICP_MASK; + val = plat->trm_icp << DLL_TRIM_ICP_SHIFT;
- /* Configure DLL driver strength */ - mask |= DR_TY_MASK; - val |= plat->drv_strength << DR_TY_SHIFT; - regmap_update_bits(plat->base, PHY_CTRL1, mask, val); + /* Configure DLL driver strength */ + mask |= DR_TY_MASK; + val |= plat->drv_strength << DR_TY_SHIFT; + regmap_update_bits(plat->base, PHY_CTRL1, mask, val); + }
/* Enable pins by setting IO mux to 0 */ regmap_update_bits(plat->base, PHY_CTRL1, IOMUX_ENABLE_MASK, 0); @@ -245,7 +255,7 @@ static int am654_sdhci_probe(struct udevice *dev) AM654_SDHCI_MIN_FREQ); if (ret) return ret; - host->ops = &am654_sdhci_ops; + host->ops = (struct sdhci_ops *)dev_get_driver_data(dev); host->mmc->priv = host; upriv->mmc = host->mmc;
@@ -268,37 +278,44 @@ static int am654_sdhci_ofdata_to_platdata(struct udevice *dev) host->ioaddr = (void *)dev_read_addr(dev); plat->non_removable = dev_read_bool(dev, "non-removable");
- ret = dev_read_u32(dev, "ti,trm-icp", &plat->trm_icp); - if (ret) - return ret; + if (device_is_compatible(dev, "ti,am654-sdhci-5.1") || + device_is_compatible(dev, "ti,j721e-sdhci-8bit")) + plat->flags |= DLL_PRESENT;
ret = dev_read_u32(dev, "ti,otap-del-sel", &plat->otap_del_sel); if (ret) return ret;
- ret = dev_read_u32(dev, "ti,driver-strength-ohm", &drv_strength); - if (ret) - return ret; + if (plat->flags & DLL_PRESENT) { + ret = dev_read_u32(dev, "ti,trm-icp", &plat->trm_icp); + if (ret) + return ret; + + ret = dev_read_u32(dev, "ti,driver-strength-ohm", + &drv_strength); + if (ret) + return ret;
- switch (drv_strength) { - case 50: - plat->drv_strength = DRIVER_STRENGTH_50_OHM; - break; - case 33: - plat->drv_strength = DRIVER_STRENGTH_33_OHM; - break; - case 66: - plat->drv_strength = DRIVER_STRENGTH_66_OHM; - break; - case 100: - plat->drv_strength = DRIVER_STRENGTH_100_OHM; - break; - case 40: - plat->drv_strength = DRIVER_STRENGTH_40_OHM; - break; - default: - dev_err(dev, "Invalid driver strength\n"); - return -EINVAL; + switch (drv_strength) { + case 50: + plat->drv_strength = DRIVER_STRENGTH_50_OHM; + break; + case 33: + plat->drv_strength = DRIVER_STRENGTH_33_OHM; + break; + case 66: + plat->drv_strength = DRIVER_STRENGTH_66_OHM; + break; + case 100: + plat->drv_strength = DRIVER_STRENGTH_100_OHM; + break; + case 40: + plat->drv_strength = DRIVER_STRENGTH_40_OHM; + break; + default: + dev_err(dev, "Invalid driver strength\n"); + return -EINVAL; + } }
ret = mmc_of_parse(dev, cfg); @@ -316,7 +333,18 @@ static int am654_sdhci_bind(struct udevice *dev) }
static const struct udevice_id am654_sdhci_ids[] = { - { .compatible = "ti,am654-sdhci-5.1" }, + { + .compatible = "ti,am654-sdhci-5.1", + .data = (ulong)&am654_sdhci_ops, + }, + { + .compatible = "ti,j721e-sdhci-8bit", + .data = (ulong)&am654_sdhci_ops, + }, + { + .compatible = "ti,j721e-sdhci-4bit", + .data = (ulong)&j721e_4bit_sdhci_ops, + }, { } };
Add pinctrl macros for J721E SoC. These macro definitions are similar to that of AM6, but adding new definitions to avoid any naming confusions in the soc dts files.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- include/dt-bindings/pinctrl/k3.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/dt-bindings/pinctrl/k3.h b/include/dt-bindings/pinctrl/k3.h index a67521cdc4..ce0cd38f56 100644 --- a/include/dt-bindings/pinctrl/k3.h +++ b/include/dt-bindings/pinctrl/k3.h @@ -35,4 +35,7 @@ #define AM65X_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) #define AM65X_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode))
+#define J721E_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define J721E_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + #endif
Add initial SoC definition for J721E SoC. Kernel dts posted here: https://lore.kernel.org/lkml/20190522161921.20750-1-nm@ti.com/
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/k3-j721e-main.dtsi | 231 ++++++++++++++++++++++++++ arch/arm/dts/k3-j721e-mcu-wakeup.dtsi | 72 ++++++++ arch/arm/dts/k3-j721e.dtsi | 177 ++++++++++++++++++++ 3 files changed, 480 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-main.dtsi create mode 100644 arch/arm/dts/k3-j721e-mcu-wakeup.dtsi create mode 100644 arch/arm/dts/k3-j721e.dtsi
diff --git a/arch/arm/dts/k3-j721e-main.dtsi b/arch/arm/dts/k3-j721e-main.dtsi new file mode 100644 index 0000000000..3445784293 --- /dev/null +++ b/arch/arm/dts/k3-j721e-main.dtsi @@ -0,0 +1,231 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for J721E SoC Family Main Domain peripherals + * + * Copyright (C) 2016-2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +&cbass_main { + msmc_ram: sram@70000000 { + compatible = "mmio-sram"; + reg = <0x0 0x70000000 0x0 0x800000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x70000000 0x800000>; + + atf-sram@0 { + reg = <0x0 0x20000>; + }; + }; + + gic500: interrupt-controller@1800000 { + compatible = "arm,gic-v3"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ + <0x00 0x01900000 0x00 0x100000>; /* GICR */ + + /* vcpumntirq: virtual CPU interface maintenance interrupt */ + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + + gic_its: gic-its@18200000 { + compatible = "arm,gic-v3-its"; + reg = <0x00 0x01820000 0x00 0x10000>; + socionext,synquacer-pre-its = <0x1000000 0x400000>; + msi-controller; + #msi-cells = <1>; + }; + }; + + smmu0: smmu@36600000 { + compatible = "arm,smmu-v3"; + reg = <0x0 0x36600000 0x0 0x100000>; + interrupt-parent = <&gic500>; + interrupts = <GIC_SPI 772 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 768 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "eventq", "gerror"; + #iommu-cells = <1>; + }; + + secure_proxy_main: mailbox@32c00000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x00 0x32c00000 0x00 0x100000>, + <0x00 0x32400000 0x00 0x100000>, + <0x00 0x32800000 0x00 0x100000>; + interrupt-names = "rx_011"; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + }; + + main_pmx0: pinmux@11c000 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x0 0x11c000 0x0 0x2b4>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + main_uart0: serial@2800000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02800000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 146 0>; + clock-names = "fclk"; + }; + + main_uart1: serial@2810000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02810000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 278 0>; + clock-names = "fclk"; + }; + + main_uart2: serial@2820000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02820000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 279 0>; + clock-names = "fclk"; + }; + + main_uart3: serial@2830000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02830000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 280 0>; + clock-names = "fclk"; + }; + + main_uart4: serial@2840000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02840000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 281 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 281 0>; + clock-names = "fclk"; + }; + + main_uart5: serial@2850000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02850000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 282 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 282 0>; + clock-names = "fclk"; + }; + + main_uart6: serial@2860000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02860000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 283 0>; + clock-names = "fclk"; + }; + + main_uart7: serial@2870000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02870000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 284 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 284 0>; + clock-names = "fclk"; + }; + + main_uart8: serial@2880000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02880000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 285 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 285 0>; + clock-names = "fclk"; + }; + + main_uart9: serial@2890000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x02890000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 286 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 286 0>; + clock-names = "fclk"; + }; + + main_sdhci0: sdhci@4f80000 { + compatible = "ti,j721e-sdhci-8bit"; + reg = <0x0 0x4f80000 0x0 0x1000>, <0x0 0x4f88000 0x0 0x400>; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 91 TI_SCI_PD_EXCLUSIVE>; + clock-names = "clk_xin", "clk_ahb"; + clocks = <&k3_clks 91 1>, <&k3_clks 91 0>; + assigned-clocks = <&k3_clks 91 1>; + assigned-clock-parents = <&k3_clks 91 2>; + bus-width = <8>; + ti,otap-del-sel = <0x2>; + ti,trm-icp = <0x8>; + dma-coherent; + }; + + main_sdhci1: sdhci@4fb0000 { + compatible = "ti,j721e-sdhci-4bit"; + reg = <0x0 0x04fb0000 0x0 0x1000>, <0x0 0x4fb8000 0x0 0x400>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 92 TI_SCI_PD_EXCLUSIVE>; + clock-names = "clk_xin", "clk_ahb"; + clocks = <&k3_clks 92 0>, <&k3_clks 92 5>; + assigned-clocks = <&k3_clks 92 0>; + assigned-clock-parents = <&k3_clks 92 1>; + ti,otap-del-sel = <0x2>; + ti,trm-icp = <0x8>; + dma-coherent; + }; +}; diff --git a/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi b/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi new file mode 100644 index 0000000000..1175fa9a50 --- /dev/null +++ b/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for J721E SoC Family MCU/WAKEUP Domain peripherals + * + * Copyright (C) 2016-2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +&cbass_mcu_wakeup { + dmsc: dmsc@44083000 { + compatible = "ti,k2g-sci"; + ti,host-id = <12>; + + mbox-names = "rx", "tx"; + + mboxes= <&secure_proxy_main 11>, + <&secure_proxy_main 13>; + + reg-names = "debug_messages"; + reg = <0x00 0x44083000 0x0 0x1000>; + + k3_pds: power-controller { + compatible = "ti,sci-pm-domain"; + #power-domain-cells = <2>; + }; + + k3_clks: clocks { + compatible = "ti,k2g-sci-clk"; + #clock-cells = <2>; + ti,scan-clocks-from-dt; + }; + + k3_reset: reset-controller { + compatible = "ti,sci-reset"; + #reset-cells = <2>; + }; + }; + + wkup_pmx0: pinmux@4301c000 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c000 0x00 0x178>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_uart0: serial@42300000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x42300000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 897 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 287 0>; + clock-names = "fclk"; + }; + + mcu_uart0: serial@40a00000 { + compatible = "ti,j721e-uart", "ti,am654-uart"; + reg = <0x00 0x40a00000 0x00 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 846 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <96000000>; + current-speed = <115200>; + power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 149 0>; + clock-names = "fclk"; + }; +}; diff --git a/arch/arm/dts/k3-j721e.dtsi b/arch/arm/dts/k3-j721e.dtsi new file mode 100644 index 0000000000..aea17e25a2 --- /dev/null +++ b/arch/arm/dts/k3-j721e.dtsi @@ -0,0 +1,177 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for J721E SoC Family + * + * Copyright (C) 2016-2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/k3.h> +#include <dt-bindings/soc/ti,sci_pm_domain.h> + +/ { + model = "Texas Instruments K3 J721E SoC"; + compatible = "ti,j721e"; + interrupt-parent = <&gic500>; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + serial0 = &wkup_uart0; + serial1 = &mcu_uart0; + serial2 = &main_uart0; + serial3 = &main_uart1; + serial4 = &main_uart2; + serial5 = &main_uart3; + serial6 = &main_uart4; + serial7 = &main_uart5; + serial8 = &main_uart6; + serial9 = &main_uart7; + serial10 = &main_uart8; + serial11 = &main_uart9; + }; + + chosen { }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu-map { + cluster0: cluster0 { + core0 { + cpu = <&cpu0>; + }; + + core1 { + cpu = <&cpu1>; + }; + }; + + }; + + cpu0: cpu@0 { + compatible = "arm,cortex-a72"; + reg = <0x000>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0xC000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a72"; + reg = <0x001>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0xC000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + }; + + L2_0: l2-cache0 { + compatible = "cache"; + cache-level = <2>; + cache-size = <0x100000>; + cache-line-size = <64>; + cache-sets = <2048>; + next-level-cache = <&msmc_l3>; + }; + + msmc_l3: l3-cache0 { + compatible = "cache"; + cache-level = <3>; + }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + + psci: psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + }; + + a72_timer0: timer-cl0-cpu0 { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */ + <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */ + <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */ + <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */ + }; + + pmu: pmu { + compatible = "arm,armv8-pmuv3"; + /* Recommendation from GIC500 TRM Table A.3 */ + interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; + }; + + cbass_main: interconnect@100000 { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */ + <0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */ + <0x00 0x00900000 0x00 0x00900000 0x00 0x00012000>, /* serdes */ + <0x00 0x00A40000 0x00 0x00A40000 0x00 0x00000800>, /* timesync router */ + <0x00 0x01000000 0x00 0x01000000 0x00 0x0af02400>, /* Most peripherals */ + <0x00 0x30800000 0x00 0x30800000 0x00 0x0bc00000>, /* MAIN NAVSS */ + <0x00 0x0d000000 0x00 0x0d000000 0x00 0x01000000>, /* PCIe Core*/ + <0x00 0x10000000 0x00 0x10000000 0x00 0x10000000>, /* PCIe DAT */ + <0x00 0x64800000 0x00 0x64800000 0x00 0x00800000>, /* C71 */ + <0x4d 0x80800000 0x4d 0x80800000 0x00 0x00800000>, /* C66_0 */ + <0x4d 0x81800000 0x4d 0x81800000 0x00 0x00800000>, /* C66_1 */ + <0x4e 0x20000000 0x4e 0x20000000 0x00 0x00080000>, /* GPU */ + /* MCUSS_WKUP Range */ + <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, + <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>, + <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, + <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>, + <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>, + <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>, + <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, + <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, + <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, + <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, + <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>, + <0x00 0x70000000 0x00 0x70000000 0x00 0x00800000>, + <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, + <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; + + cbass_mcu_wakeup: interconnect@28380000 { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, /* MCU NAVSS*/ + <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>, /* First peripheral window */ + <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, /* CTRL_MMR0 */ + <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>, /* MCU R5F Core0 */ + <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>, /* MCU R5F Core1 */ + <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>, /* MCU SRAM */ + <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, /* WKUP peripheral window */ + <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, /* MMRs, remaining NAVSS */ + <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, /* CPSW */ + <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, /* OSPI register space */ + <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>, /* FSS OSPI0/1 data region 0 */ + <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS OSPI0 data region 3 */ + <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; /* FSS OSPI1 data region 3*/ + }; + }; +}; + +/* Now include the peripherals for each bus segments */ +#include "k3-j721e-main.dtsi" +#include "k3-j721e-mcu-wakeup.dtsi"
Common Processor board is the baseboard that has most of the actual connectors, power supply etc. A SOM (System on Module) is plugged on to the common processor board and this contains the SoC, PMIC, DDR and basic highspeed components necessary for functionality. Add initial dt support for this common processor board.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/k3-j721e-common-proc-board.dts | 63 +++++++++++++++++++++ arch/arm/dts/k3-j721e-som-p0.dtsi | 29 ++++++++++ 3 files changed, 93 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-common-proc-board.dts create mode 100644 arch/arm/dts/k3-j721e-som-p0.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e0c54bfa76..799fb8e646 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -755,6 +755,7 @@ dtb-$(CONFIG_TARGET_STM32MP1) += \ stm32mp157c-ev1.dtb
dtb-$(CONFIG_SOC_K3_AM6) += k3-am654-base-board.dtb k3-am654-r5-base-board.dtb +dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb
dtb-$(CONFIG_ARCH_MEDIATEK) += \ mt7623n-bananapi-bpi-r2.dtb \ diff --git a/arch/arm/dts/k3-j721e-common-proc-board.dts b/arch/arm/dts/k3-j721e-common-proc-board.dts new file mode 100644 index 0000000000..b5b8c3c5cc --- /dev/null +++ b/arch/arm/dts/k3-j721e-common-proc-board.dts @@ -0,0 +1,63 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-j721e-som-p0.dtsi" + +/ { + chosen { + stdout-path = "serial2:115200n8"; + bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; + }; +}; + +&wkup_uart0 { + /* Wakeup UART is used by System firmware */ + status = "disabled"; +}; + +&main_uart3 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart5 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart6 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart7 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart8 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart9 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_sdhci0 { + /* eMMC */ + voltage-ranges = <1800 1800>; + non-removable; + ti,driver-strength-ohm = <50>; +}; + +&main_sdhci1 { + /* SD/MMC */ + voltage-ranges = <1800 1800 3300 3300>; + ti,driver-strength-ohm = <50>; +}; diff --git a/arch/arm/dts/k3-j721e-som-p0.dtsi b/arch/arm/dts/k3-j721e-som-p0.dtsi new file mode 100644 index 0000000000..1884fc7014 --- /dev/null +++ b/arch/arm/dts/k3-j721e-som-p0.dtsi @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-j721e.dtsi" + +/ { + memory@80000000 { + device_type = "memory"; + /* 4G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>, + <0x00000008 0x80000000 0x00000000 0x80000000>; + }; + + reserved_memory: reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; + alignment = <0x1000>; + no-map; + }; + }; +};
Add initial support for dt that runs on r5.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/dts/Makefile | 3 +- .../k3-j721e-common-proc-board-u-boot.dtsi | 75 ++++++++++ .../arm/dts/k3-j721e-r5-common-proc-board.dts | 141 ++++++++++++++++++ 3 files changed, 218 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-common-proc-board.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 799fb8e646..5f37d15a22 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -755,7 +755,8 @@ dtb-$(CONFIG_TARGET_STM32MP1) += \ stm32mp157c-ev1.dtb
dtb-$(CONFIG_SOC_K3_AM6) += k3-am654-base-board.dtb k3-am654-r5-base-board.dtb -dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb +dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ + k3-j721e-r5-common-proc-board.dtb
dtb-$(CONFIG_ARCH_MEDIATEK) += \ mt7623n-bananapi-bpi-r2.dtb \ diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi new file mode 100644 index 0000000000..541da22c48 --- /dev/null +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/ { + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; +}; + +&cbass_main{ + u-boot,dm-spl; +}; + +&cbass_mcu_wakeup { + u-boot,dm-spl; + + timer1: timer@40400000 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x40400000 0x0 0x80>; + ti,timer-alwon; + clock-frequency = <25000000>; + u-boot,dm-spl; + }; +}; + +&secure_proxy_main { + u-boot,dm-spl; +}; + +&dmsc { + u-boot,dm-spl; + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + u-boot,dm-spl; + }; +}; + +&k3_pds { + u-boot,dm-spl; +}; + +&k3_clks { + u-boot,dm-spl; +}; + +&k3_reset { + u-boot,dm-spl; +}; + +&wkup_pmx0 { + u-boot,dm-spl; +}; + +&main_pmx0 { + u-boot,dm-spl; +}; + +&main_uart0 { + u-boot,dm-spl; +}; + +&mcu_uart0 { + u-boot,dm-spl; +}; + +&main_sdhci0 { + u-boot,dm-spl; +}; + +&main_sdhci1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts new file mode 100644 index 0000000000..815e334b2c --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-j721e-som-p0.dtsi" + +/ { + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a72_0; + }; + + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; + + a72_0: a72@0 { + compatible = "ti,am654-rproc"; + reg = <0x0 0x00a90000 0x0 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 202 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 202 0>; + assigned-clocks = <&k3_clks 202 2>, <&k3_clks 61 1>; + assigned-clock-rates = <2000000000>, <200000000>; + ti,sci = <&dmsc>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + u-boot,dm-spl; + }; + + clk_200mhz: dummy_clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + u-boot,dm-spl; + }; +}; + +&cbass_mcu_wakeup { + mcu_secproxy: secproxy@28380000 { + u-boot,dm-spl; + compatible = "ti,am654-secure-proxy"; + reg = <0x0 0x2a380000 0x0 0x80000>, + <0x0 0x2a400000 0x0 0x80000>, + <0x0 0x2a480000 0x0 0x80000>; + reg-names = "rt", "scfg", "target_data"; + #mbox-cells = <1>; + }; + + sysctrler: sysctrler { + u-boot,dm-spl; + compatible = "ti,am654-system-controller"; + mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>; + mbox-names = "tx", "rx"; + }; +}; + +&dmsc { + mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mbox-names = "tx", "rx", "notify"; + ti,host-id = <4>; + ti,secure-host; +}; + +&wkup_pmx0 { + wkup_uart0_pins_default: wkup_uart0_pins_default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xa0, PIN_INPUT, 0) /* (J29) WKUP_UART0_RXD */ + J721E_WKUP_IOPAD(0xa4, PIN_OUTPUT, 0) /* (J28) WKUP_UART0_TXD */ + >; + }; + + mcu_uart0_pins_default: mcu_uart0_pins_default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xe8, PIN_INPUT, 0) /* (H29) WKUP_GPIO0_14.MCU_UART0_CTSn */ + J721E_WKUP_IOPAD(0xec, PIN_OUTPUT, 0) /* (J27) WKUP_GPIO0_15.MCU_UART0_RTSn */ + J721E_WKUP_IOPAD(0xe4, PIN_INPUT, 0) /* (H28) WKUP_GPIO0_13.MCU_UART0_RXD */ + J721E_WKUP_IOPAD(0xe0, PIN_OUTPUT, 0) /* (G29) WKUP_GPIO0_12.MCU_UART0_TXD */ + >; + }; +}; + +&main_pmx0 { + main_uart0_pins_default: main_uart0_pins_default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721E_IOPAD(0x1d4, PIN_INPUT, 1) /* (Y3) SPI1_CS0.UART0_CTSn */ + J721E_IOPAD(0x1c0, PIN_OUTPUT, 1) /* (AA2) SPI0_CS0.UART0_RTSn */ + J721E_IOPAD(0x1e8, PIN_INPUT, 0) /* (AB2) UART0_RXD */ + J721E_IOPAD(0x1ec, PIN_OUTPUT, 0) /* (AB3) UART0_TXD */ + >; + }; +}; + +&wkup_uart0 { + u-boot,dm-spl; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; + status = "okay"; +}; + +&mcu_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; + status = "okay"; +}; + +&main_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; + status = "okay"; + power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; +}; + +&main_sdhci0 { + /delete-property/ power-domains; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + clock-names = "clk_xin"; + clocks = <&clk_200mhz>; + ti,driver-strength-ohm = <50>; + non-removable; + bus-width = <8>; +}; + +&main_sdhci1 { + /delete-property/ power-domains; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + clock-names = "clk_xin"; + clocks = <&clk_200mhz>; + ti,driver-strength-ohm = <50>; +}; + +#include "k3-j721e-common-proc-board-u-boot.dtsi"
Add initial defconfig support for J721e that runs on R5.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/j721e_evm_r5_defconfig | 95 ++++++++++++++++++++++++++++++++++ 1 file changed, 95 insertions(+) create mode 100644 configs/j721e_evm_r5_defconfig
diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig new file mode 100644 index 0000000000..d44e87cff6 --- /dev/null +++ b/configs/j721e_evm_r5_defconfig @@ -0,0 +1,95 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x55000 +CONFIG_SOC_K3_J721E=y +CONFIG_TARGET_J721E_R5_EVM=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_USE_BOOTCOMMAND=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0x41c00000 +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_REMOTEPROC=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_REMOTEPROC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="k3-j721e-r5-common-proc-board" +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_TI_SCI=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DM_GPIO=y +CONFIG_DA8XX_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_MISC=y +CONFIG_FS_LOADER=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_DM_RESET=y +CONFIG_RESET_TI_SCI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_TI_SCI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_FS_EXT4=y +CONFIG_FS_FAT=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=16384
Add initial defconfig support for J721e that runs on A72.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/j721e_evm_a72_defconfig | 86 +++++++++++++++++++++++++++++++++ 1 file changed, 86 insertions(+) create mode 100644 configs/j721e_evm_a72_defconfig
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig new file mode 100644 index 0000000000..237dc6b601 --- /dev/null +++ b/configs/j721e_evm_a72_defconfig @@ -0,0 +1,86 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SOC_K3_J721E=y +CONFIG_TARGET_J721E_A72_EVM=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_LOAD_FIT=y +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_REMOTEPROC=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_REMOTEPROC=y +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="k3-j721e-common-proc-board" +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_TI_SCI=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_DM_RESET=y +CONFIG_RESET_TI_SCI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_TI_SCI=y +CONFIG_OF_LIBFDT_OVERLAY=y
Lokesh Vutla
