[U-Boot] [PATCH 0/4] MMC Fixes for dra7xx and am57xx boards
These patches implement some MMC related fixes for dra7xx and am57xx boards.
Faiz Abbas (4): ARM: dts: dra7-mmc-iodelay: Add a new pinctrl group for clk line without pullup ARM: dts: am574x-idk: Add pinmuxes for mmc1 and mmc2 ARM: dts: am57xx: Disable voltage switching for SD card ARM: dts: dra76x: Update MMC2_HS200_MANUAL1 iodelay values
arch/arm/dts/am571x-idk.dts | 10 ++---- arch/arm/dts/am572x-idk.dts | 10 ++---- arch/arm/dts/am574x-idk.dts | 15 ++++++++ arch/arm/dts/am57xx-beagle-x15-common.dtsi | 1 + arch/arm/dts/am57xx-beagle-x15-revb1.dts | 7 +--- arch/arm/dts/am57xx-beagle-x15-revc.dts | 7 +--- arch/arm/dts/am57xx-idk-common.dtsi | 1 + arch/arm/dts/dra7-mmc-iodelay.dtsi | 19 ++++++++++ arch/arm/dts/dra76x-mmc-iodelay.dtsi | 40 +++++++++++----------- 9 files changed, 64 insertions(+), 46 deletions(-) create mode 100644 arch/arm/dts/dra7-mmc-iodelay.dtsi
During a short period when the bus voltage is switched from 3.3v to 1.8v, (to enumerate UHS mode), the mmc module is disabled and the mmc IO lines are kept in a state according to the programmed pad mux pull type.
According to 4.2.4.2 Timing to Switch Signal Voltage in "SD Specifications Part 1 Physical Layer Specification Version 5.00 February 22, 2016", the host should hold CLK low for at least 5ms.
In order to keep the card line low during voltage switch, the pad mux of mmc1_clk line should be configured to pull down.
Add a new pinctrl group for clock line without pullup to be used in boards where mmc1_clk line is not connected to an external pullup.
Signed-off-by: Faiz Abbas faiz_abbas@ti.com --- arch/arm/dts/am571x-idk.dts | 3 ++- arch/arm/dts/am572x-idk.dts | 3 ++- arch/arm/dts/dra7-mmc-iodelay.dtsi | 19 +++++++++++++++++++ 3 files changed, 23 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/dra7-mmc-iodelay.dtsi
diff --git a/arch/arm/dts/am571x-idk.dts b/arch/arm/dts/am571x-idk.dts index debf946440..eb5fda81f5 100644 --- a/arch/arm/dts/am571x-idk.dts +++ b/arch/arm/dts/am571x-idk.dts @@ -11,6 +11,7 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> #include "am57xx-idk-common.dtsi" +#include "dra7-mmc-iodelay.dtsi" #include "dra72x-mmc-iodelay.dtsi"
/ { @@ -102,7 +103,7 @@
&mmc1 { pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104"; - pinctrl-0 = <&mmc1_pins_default>; + pinctrl-0 = <&mmc1_pins_default_no_clk_pu>; pinctrl-1 = <&mmc1_pins_hs>; pinctrl-2 = <&mmc1_pins_sdr12>; pinctrl-3 = <&mmc1_pins_sdr25>; diff --git a/arch/arm/dts/am572x-idk.dts b/arch/arm/dts/am572x-idk.dts index 9212931f25..2247948553 100644 --- a/arch/arm/dts/am572x-idk.dts +++ b/arch/arm/dts/am572x-idk.dts @@ -11,6 +11,7 @@ #include "dra74x.dtsi" #include "am572x-idk-common.dtsi" #include "am57xx-idk-common.dtsi" +#include "dra7-mmc-iodelay.dtsi" #include "dra74x-mmc-iodelay.dtsi"
/ { @@ -21,7 +22,7 @@
&mmc1 { pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104"; - pinctrl-0 = <&mmc1_pins_default>; + pinctrl-0 = <&mmc1_pins_default_no_clk_pu>; pinctrl-1 = <&mmc1_pins_hs>; pinctrl-2 = <&mmc1_pins_sdr12>; pinctrl-3 = <&mmc1_pins_sdr25>; diff --git a/arch/arm/dts/dra7-mmc-iodelay.dtsi b/arch/arm/dts/dra7-mmc-iodelay.dtsi new file mode 100644 index 0000000000..4acc215ba3 --- /dev/null +++ b/arch/arm/dts/dra7-mmc-iodelay.dtsi @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * MMC IOdelay values for TI's DRA7xx SoCs. + * Copyright (C) 2019 Texas Instruments + * Author: Faiz Abbas faiz_abbas@ti.com + */ + +&dra7_pmx_core { + mmc1_pins_default_no_clk_pu: mmc1_pins_default_no_clk_pu { + pinctrl-single,pins = < + DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLDOWN | MUX_MODE0) /* mmc1_clk.clk */ + DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ + DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ + DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ + DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ + DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ + >; + }; +};
Sync with kernel dts by adding pinmuxes for mmc1 and mmc2. This fixes an issue where mmc2 (eMMC) was coming up in HS52 mode instead of the highest DDR52 mode.
Signed-off-by: Faiz Abbas faiz_abbas@ti.com --- arch/arm/dts/am574x-idk.dts | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/dts/am574x-idk.dts b/arch/arm/dts/am574x-idk.dts index 41e12a382d..0de73616b5 100644 --- a/arch/arm/dts/am574x-idk.dts +++ b/arch/arm/dts/am574x-idk.dts @@ -7,6 +7,8 @@ /dts-v1/;
#include "dra76x.dtsi" +#include "dra7-mmc-iodelay.dtsi" +#include "dra76x-mmc-iodelay.dtsi" #include "am572x-idk-common.dtsi"
/ { @@ -20,3 +22,16 @@ spi-max-frequency = <96000000>; }; }; + +&mmc1 { + pinctrl-names = "default", "hs"; + pinctrl-0 = <&mmc1_pins_default_no_clk_pu>; + pinctrl-1 = <&mmc1_pins_hs>; +}; + +&mmc2 { + pinctrl-names = "default", "hs", "ddr_1_8v"; + pinctrl-0 = <&mmc2_pins_default>; + pinctrl-1 = <&mmc2_pins_default>; + pinctrl-2 = <&mmc2_pins_default>; +};
If UHS speed modes are enabled, a compatible SD card switches down to 1.8V during enumeration. If after this a software reboot/crash takes place and on-chip ROM tries to enumerate the SD card, the difference in IO voltages (host @ 3.3V and card @ 1.8V) may end up damaging the card.
The fix for this is to have support for power cycling the card in hardware (with a PORz/soft-reset line causing a power cycle of the card). Because the beaglebone X15 (rev A,B and C), am57xx-evms and am57xx-idks don't have this capability, disable voltage switching for these boards.
The major effect of this is that the maximum supported speed mode is now high speed(50 MHz) down from SDR104(200 MHz).
Signed-off-by: Faiz Abbas faiz_abbas@ti.com --- arch/arm/dts/am571x-idk.dts | 7 +------ arch/arm/dts/am572x-idk.dts | 7 +------ arch/arm/dts/am57xx-beagle-x15-common.dtsi | 1 + arch/arm/dts/am57xx-beagle-x15-revb1.dts | 7 +------ arch/arm/dts/am57xx-beagle-x15-revc.dts | 7 +------ arch/arm/dts/am57xx-idk-common.dtsi | 1 + 6 files changed, 6 insertions(+), 24 deletions(-)
diff --git a/arch/arm/dts/am571x-idk.dts b/arch/arm/dts/am571x-idk.dts index eb5fda81f5..798fbfe19d 100644 --- a/arch/arm/dts/am571x-idk.dts +++ b/arch/arm/dts/am571x-idk.dts @@ -102,14 +102,9 @@ };
&mmc1 { - pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104"; + pinctrl-names = "default", "hs"; pinctrl-0 = <&mmc1_pins_default_no_clk_pu>; pinctrl-1 = <&mmc1_pins_hs>; - pinctrl-2 = <&mmc1_pins_sdr12>; - pinctrl-3 = <&mmc1_pins_sdr25>; - pinctrl-4 = <&mmc1_pins_sdr50>; - pinctrl-5 = <&mmc1_pins_ddr50_rev20 &mmc1_iodelay_ddr50_conf>; - pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>; };
&mmc2 { diff --git a/arch/arm/dts/am572x-idk.dts b/arch/arm/dts/am572x-idk.dts index 2247948553..42e88c1bc0 100644 --- a/arch/arm/dts/am572x-idk.dts +++ b/arch/arm/dts/am572x-idk.dts @@ -21,14 +21,9 @@ };
&mmc1 { - pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104"; + pinctrl-names = "default", "hs"; pinctrl-0 = <&mmc1_pins_default_no_clk_pu>; pinctrl-1 = <&mmc1_pins_hs>; - pinctrl-2 = <&mmc1_pins_sdr12>; - pinctrl-3 = <&mmc1_pins_sdr25>; - pinctrl-4 = <&mmc1_pins_sdr50>; - pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr_rev20_conf>; - pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>; };
&mmc2 { diff --git a/arch/arm/dts/am57xx-beagle-x15-common.dtsi b/arch/arm/dts/am57xx-beagle-x15-common.dtsi index 49aeecd312..d6b94d528f 100644 --- a/arch/arm/dts/am57xx-beagle-x15-common.dtsi +++ b/arch/arm/dts/am57xx-beagle-x15-common.dtsi @@ -433,6 +433,7 @@
bus-width = <4>; cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */ + no-1-8-v; };
&mmc2 { diff --git a/arch/arm/dts/am57xx-beagle-x15-revb1.dts b/arch/arm/dts/am57xx-beagle-x15-revb1.dts index 5a77b33492..34c6996582 100644 --- a/arch/arm/dts/am57xx-beagle-x15-revb1.dts +++ b/arch/arm/dts/am57xx-beagle-x15-revb1.dts @@ -19,14 +19,9 @@ };
&mmc1 { - pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104"; + pinctrl-names = "default", "hs"; pinctrl-0 = <&mmc1_pins_default>; pinctrl-1 = <&mmc1_pins_hs>; - pinctrl-2 = <&mmc1_pins_sdr12>; - pinctrl-3 = <&mmc1_pins_sdr25>; - pinctrl-4 = <&mmc1_pins_sdr50>; - pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr_rev11_conf>; - pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev11_conf>; vmmc-supply = <&vdd_3v3>; vqmmc-supply = <&ldo1_reg>; }; diff --git a/arch/arm/dts/am57xx-beagle-x15-revc.dts b/arch/arm/dts/am57xx-beagle-x15-revc.dts index 17c41da3b5..ccd99160bb 100644 --- a/arch/arm/dts/am57xx-beagle-x15-revc.dts +++ b/arch/arm/dts/am57xx-beagle-x15-revc.dts @@ -19,14 +19,9 @@ };
&mmc1 { - pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104"; + pinctrl-names = "default", "hs"; pinctrl-0 = <&mmc1_pins_default>; pinctrl-1 = <&mmc1_pins_hs>; - pinctrl-2 = <&mmc1_pins_sdr12>; - pinctrl-3 = <&mmc1_pins_sdr25>; - pinctrl-4 = <&mmc1_pins_sdr50>; - pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr_rev20_conf>; - pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>; vmmc-supply = <&vdd_3v3>; vqmmc-supply = <&ldo1_reg>; }; diff --git a/arch/arm/dts/am57xx-idk-common.dtsi b/arch/arm/dts/am57xx-idk-common.dtsi index fa5a078b27..fdb4e0e47c 100644 --- a/arch/arm/dts/am57xx-idk-common.dtsi +++ b/arch/arm/dts/am57xx-idk-common.dtsi @@ -405,6 +405,7 @@ vqmmc-supply = <&ldo1_reg>; bus-width = <4>; cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */ + no-1-8-v; };
&mmc2 {
Update the MMC2_HS200_MANUAL1 iodelay values to match with the latest dra76x data manual[1].
Also this particular pinctrl-array is using spaces instead of tabs for spacing between the values and the comments. Fix this as well.
[1] http://www.ti.com/lit/ds/symlink/dra76p.pdf
Signed-off-by: Faiz Abbas faiz_abbas@ti.com --- arch/arm/dts/dra76x-mmc-iodelay.dtsi | 40 ++++++++++++++-------------- 1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/arch/arm/dts/dra76x-mmc-iodelay.dtsi b/arch/arm/dts/dra76x-mmc-iodelay.dtsi index baba7b00ec..fdca481869 100644 --- a/arch/arm/dts/dra76x-mmc-iodelay.dtsi +++ b/arch/arm/dts/dra76x-mmc-iodelay.dtsi @@ -22,7 +22,7 @@ * * Datamanual Revisions: * - * DRA76x Silicon Revision 1.0: SPRS993A, Revised July 2017 + * DRA76x Silicon Revision 1.0: SPRS993E, Revised December 2018 * */
@@ -169,25 +169,25 @@ /* Corresponds to MMC2_HS200_MANUAL1 in datamanual */ mmc2_iodelay_hs200_conf: mmc2_iodelay_hs200_conf { pinctrl-pin-array = < - 0x190 A_DELAY_PS(384) G_DELAY_PS(0) /* CFG_GPMC_A19_OEN */ - 0x194 A_DELAY_PS(0) G_DELAY_PS(174) /* CFG_GPMC_A19_OUT */ - 0x1a8 A_DELAY_PS(410) G_DELAY_PS(0) /* CFG_GPMC_A20_OEN */ - 0x1ac A_DELAY_PS(85) G_DELAY_PS(0) /* CFG_GPMC_A20_OUT */ - 0x1b4 A_DELAY_PS(468) G_DELAY_PS(0) /* CFG_GPMC_A21_OEN */ - 0x1b8 A_DELAY_PS(139) G_DELAY_PS(0) /* CFG_GPMC_A21_OUT */ - 0x1c0 A_DELAY_PS(676) G_DELAY_PS(0) /* CFG_GPMC_A22_OEN */ - 0x1c4 A_DELAY_PS(69) G_DELAY_PS(0) /* CFG_GPMC_A22_OUT */ - 0x1d0 A_DELAY_PS(1062) G_DELAY_PS(154) /* CFG_GPMC_A23_OUT */ - 0x1d8 A_DELAY_PS(640) G_DELAY_PS(0) /* CFG_GPMC_A24_OEN */ - 0x1dc A_DELAY_PS(0) G_DELAY_PS(0) /* CFG_GPMC_A24_OUT */ - 0x1e4 A_DELAY_PS(356) G_DELAY_PS(0) /* CFG_GPMC_A25_OEN */ - 0x1e8 A_DELAY_PS(0) G_DELAY_PS(0) /* CFG_GPMC_A25_OUT */ - 0x1f0 A_DELAY_PS(579) G_DELAY_PS(0) /* CFG_GPMC_A26_OEN */ - 0x1f4 A_DELAY_PS(0) G_DELAY_PS(0) /* CFG_GPMC_A26_OUT */ - 0x1fc A_DELAY_PS(435) G_DELAY_PS(0) /* CFG_GPMC_A27_OEN */ - 0x200 A_DELAY_PS(36) G_DELAY_PS(0) /* CFG_GPMC_A27_OUT */ - 0x364 A_DELAY_PS(759) G_DELAY_PS(0) /* CFG_GPMC_CS1_OEN */ - 0x368 A_DELAY_PS(72) G_DELAY_PS(0) /* CFG_GPMC_CS1_OUT */ + 0x190 A_DELAY_PS(384) G_DELAY_PS(0) /* CFG_GPMC_A19_OEN */ + 0x194 A_DELAY_PS(350) G_DELAY_PS(174) /* CFG_GPMC_A19_OUT */ + 0x1a8 A_DELAY_PS(410) G_DELAY_PS(0) /* CFG_GPMC_A20_OEN */ + 0x1ac A_DELAY_PS(335) G_DELAY_PS(0) /* CFG_GPMC_A20_OUT */ + 0x1b4 A_DELAY_PS(468) G_DELAY_PS(0) /* CFG_GPMC_A21_OEN */ + 0x1b8 A_DELAY_PS(339) G_DELAY_PS(0) /* CFG_GPMC_A21_OUT */ + 0x1c0 A_DELAY_PS(676) G_DELAY_PS(0) /* CFG_GPMC_A22_OEN */ + 0x1c4 A_DELAY_PS(219) G_DELAY_PS(0) /* CFG_GPMC_A22_OUT */ + 0x1d0 A_DELAY_PS(1062) G_DELAY_PS(154) /* CFG_GPMC_A23_OUT */ + 0x1d8 A_DELAY_PS(640) G_DELAY_PS(0) /* CFG_GPMC_A24_OEN */ + 0x1dc A_DELAY_PS(150) G_DELAY_PS(0) /* CFG_GPMC_A24_OUT */ + 0x1e4 A_DELAY_PS(356) G_DELAY_PS(0) /* CFG_GPMC_A25_OEN */ + 0x1e8 A_DELAY_PS(150) G_DELAY_PS(0) /* CFG_GPMC_A25_OUT */ + 0x1f0 A_DELAY_PS(579) G_DELAY_PS(0) /* CFG_GPMC_A26_OEN */ + 0x1f4 A_DELAY_PS(200) G_DELAY_PS(0) /* CFG_GPMC_A26_OUT */ + 0x1fc A_DELAY_PS(435) G_DELAY_PS(0) /* CFG_GPMC_A27_OEN */ + 0x200 A_DELAY_PS(236) G_DELAY_PS(0) /* CFG_GPMC_A27_OUT */ + 0x364 A_DELAY_PS(759) G_DELAY_PS(0) /* CFG_GPMC_CS1_OEN */ + 0x368 A_DELAY_PS(372) G_DELAY_PS(0) /* CFG_GPMC_CS1_OUT */ >; };
Faiz Abbas
