[U-Boot-Users] Status of u-boot-fdt
Hi All,
I've updated my simple message improvement patch per Kim's suggestion and reposted. I've rebased against The Master (u-boot, not Wolfgang ;-).
I believe the u-boot-fdt repo is ready to be pulled and will call for Wolfgang to pull it, probably tomorrow morning. Holler now or squeal after the fact.
Missing patches: * Andy Fleming's patch WRT making sure the blob is in the lower portion (16GB at the moment) of memory. Still being discussed.
* Unpublished patch of mine, implementing a suggestion by Scott Wood to make the /chosen handling finer grained: if the /chosen node exists, currently u-boot-fdt bails out. A better methodology is to not overwrite pre-existing properties on a per-property basis, so if /chosen exists but a necessary /chosen/property doesn't, it gets created. Good idea, but not published and poorly tested at the moment.
Best regards, gvb
Jerry Van Baren
