[U-Boot] how does one "extend" the list of POST tests?
one more question, i think, on the framework of u-boot POST tests. the README.POST file states:
o) Extensibility
The framework shall allow adding/removing/replacing POST tests. Also, standalone POST tests shall be supported.
how many different ways are there to extend the list of POST tests?
given that post/tests.c defines the list of tests statically, you clearly can't *dynamically* add tests. i do see that that list of tests includes the generic tests:
#if CONFIG_POST & CONFIG_SYS_POST_BSPEC1 CONFIG_POST_BSPEC1, #endif #if CONFIG_POST & CONFIG_SYS_POST_BSPEC2 CONFIG_POST_BSPEC2, #endif #if CONFIG_POST & CONFIG_SYS_POST_BSPEC3 CONFIG_POST_BSPEC3, #endif #if CONFIG_POST & CONFIG_SYS_POST_BSPEC4 CONFIG_POST_BSPEC4, #endif #if CONFIG_POST & CONFIG_SYS_POST_BSPEC5 CONFIG_POST_BSPEC5, #endif
so, sure, one can take advantage of any of those five available test slots, but that's not really a general solution.
so other than editing post/tests.c and manually adding more tests, is there any other mechanism for adding POST tests?
rday
o) Extensibility
whoops, i just noticed the ability to add tests through the environment in post/post.c:
#ifndef CONFIG_POST_SKIP_ENV_FLAGS static void post_get_env_flags(int *test_flags) { int flag[] = { POST_POWERON, POST_NORMAL, POST_SLOWTEST, POST_CRITICAL }; char *var[] = { "post_poweron", "post_normal", "post_slowtest", "post_critical" };
as i read it, that still limits one to selecting tests already implemented, but it's still an increase in flexibility. will keep reading ...
rday
p.s. once i nail all this down, i plan on submitting a few more patches, and writing this up for public consumption on my wiki.
p.p.s. if anyone has a board-specific implementation of some POST tests they want to share, i can use all the examples i can get.
Robert P. J. Day
