[PATCH] mx7ulp_evk_plugin: Disable CONFIG_NET
Currently the following build warning is seen:
===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ===================================================
Since the mx7ulp-evk board does not have networking support, explicitly disable networking.
Signed-off-by: Fabio Estevam festevam@gmail.com --- configs/mx7ulp_evk_plugin_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index 1c37d6bc02..54ff93ea5e 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx7ulp-evk" CONFIG_ENV_IS_IN_MMC=y +# CONFIG_NET is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DM_GPIO=y
Currently the following build warning is seen: ===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. =================================================== Since the mx7ulp-evk board does not have networking support, explicitly disable networking. Signed-off-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
