[U-Boot] [PATCH][iMX31] Change to use "do_div" macro
I tryed to build u-boot by Sourcery G++ Lite 2008q3-41 for ARM GNU/Linux. But, it was failed with some link error of divide function. Thus, I changed to use the "do_div" macro to calculate the dividing.
In my environment, the "next" branch with this patch worked correctly.
Signed-off-by: Tomohiro Masubuchi tomohiro_masubuchi@tripeaks.co.jp ---- Change to use the "do_div" macro.
cpu/arm1136/mx31/interrupts.c | 36 ++++++++++++++++++++++++++++++------ 1 files changed, 30 insertions(+), 6 deletions(-)
diff --git a/cpu/arm1136/mx31/interrupts.c b/cpu/arm1136/mx31/interrupts.c index b36c58c..807e791 100644 --- a/cpu/arm1136/mx31/interrupts.c +++ b/cpu/arm1136/mx31/interrupts.c @@ -23,6 +23,7 @@
#include <common.h> #include <asm/arch/mx31-regs.h> +#include <div64.h>
#define TIMER_BASE 0x53f90000 /* General purpose timer 1 */
@@ -41,17 +42,40 @@ /* "time" is measured in 1 / CONFIG_SYS_HZ seconds, "tick" is internal timer period */ #ifdef CONFIG_MX31_TIMER_HIGH_PRECISION /* ~0.4% error - measured with stop-watch on 100s boot-delay */ -#define TICK_TO_TIME(t) ((t) * CONFIG_SYS_HZ / CONFIG_MX31_CLK32) -#define TIME_TO_TICK(t) ((unsigned long long)(t) * CONFIG_MX31_CLK32 / CONFIG_SYS_HZ) -#define US_TO_TICK(t) (((unsigned long long)(t) * CONFIG_MX31_CLK32 + \ - 999999) / 1000000) +#define TICK_TO_TIME(t) ({ \ + unsigned long long tmp = (t); \ + t *= CONFIG_SYS_HZ; \ + do_div(tmp, CONFIG_MX31_CLK32); \ + tmp; \ + }) +#define TIME_TO_TICK(t) ({ \ + unsigned long long tmp = (t); \ + tmp *= CONFIG_MX31_CLK32; \ + do_div(tmp, CONFIG_SYS_HZ); \ + tmp; \ + }) +#define US_TO_TICK(t) ({ \ + unsigned long long tmp = (t); \ + tmp = tmp * CONFIG_MX31_CLK32 + 999999; \ + do_div(tmp, 1000000); \ + tmp; \ + }) #else /* ~2% error */ #define TICK_PER_TIME ((CONFIG_MX31_CLK32 + CONFIG_SYS_HZ / 2) / CONFIG_SYS_HZ) #define US_PER_TICK (1000000 / CONFIG_MX31_CLK32) -#define TICK_TO_TIME(t) ((t) / TICK_PER_TIME) +#define TICK_TO_TIME(t) ({ \ + unsigned long long tmp = (t); \ + do_div(tmp, TICK_PER_TIME); \ + tmp; \ + }) #define TIME_TO_TICK(t) ((unsigned long long)(t) * TICK_PER_TIME) -#define US_TO_TICK(t) (((t) + US_PER_TICK - 1) / US_PER_TICK) +#define US_TO_TICK(t) ({ \ + unsigned long long tmp = (t); \ + tmp += US_PER_TICK - 1; \ + do_div(tmp, US_PER_TICK); \ + tmp; \ + }) #endif
static ulong timestamp;
999999) / 1000000)
tmp; \
IMHO implement it as inline will be better : simple to maintain and to read
Best Regards, J.
I've fixed which Jean-Christophe pointed out.
Regards, Tomohiro
cpu/arm1136/mx31/interrupts.c | 58 +++++++++++++++++++++++++++++++--------- 1 files changed, 45 insertions(+), 13 deletions(-)
diff --git a/cpu/arm1136/mx31/interrupts.c b/cpu/arm1136/mx31/interrupts.c index b36c58c..ab7202f 100644 --- a/cpu/arm1136/mx31/interrupts.c +++ b/cpu/arm1136/mx31/interrupts.c @@ -23,6 +23,7 @@
@@ -38,24 +39,55 @@ #define GPTCR_CLKSOURCE_32 (4 << 6) /* Clock source */ #define GPTCR_TEN 1 /* Timer enable */
+static ulong timestamp; +static ulong lastinc; + /* "time" is measured in 1 / CONFIG_SYS_HZ seconds, "tick" is internal timer period */ #ifdef CONFIG_MX31_TIMER_HIGH_PRECISION /* ~0.4% error - measured with stop-watch on 100s boot-delay */ -#define TICK_TO_TIME(t) ((t) * CONFIG_SYS_HZ / CONFIG_MX31_CLK32) -#define TIME_TO_TICK(t) ((unsigned long long)(t) * CONFIG_MX31_CLK32 / CONFIG_SYS_HZ) -#define US_TO_TICK(t) (((unsigned long long)(t) * CONFIG_MX31_CLK32 + \ - 999999) / 1000000) +static inline unsigned long long tick_to_time(unsigned long long tick) +{ + tick *= CONFIG_SYS_HZ; + do_div(tick, CONFIG_MX31_CLK32); + return tick; +} + +static inline unsigned long long time_to_tick(unsigned long long time) +{ + time *= CONFIG_MX31_CLK32; + do_div(time, CONFIG_SYS_HZ); + return time; +} + +static inline unsigned long long us_to_tick(unsigned long long us) +{ + us = us * CONFIG_MX31_CLK32 + 999999; + do_div(us, 1000000); + return us; +} #else /* ~2% error */ #define TICK_PER_TIME ((CONFIG_MX31_CLK32 + CONFIG_SYS_HZ / 2) / CONFIG_SYS_HZ) #define US_PER_TICK (1000000 / CONFIG_MX31_CLK32) -#define TICK_TO_TIME(t) ((t) / TICK_PER_TIME) -#define TIME_TO_TICK(t) ((unsigned long long)(t) * TICK_PER_TIME) -#define US_TO_TICK(t) (((t) + US_PER_TICK - 1) / US_PER_TICK) -#endif
-static ulong timestamp; -static ulong lastinc; +static inline unsigned long long tick_to_time(unsigned long long tick) +{ + do_div(tick, TICK_PER_TIME); + return tick; +} + +static inline unsigned long long time_to_tick(unsigned long long time) +{ + return time * TICK_PER_TIME; +} + +static inline unsigned long long us_to_tick(unsigned long long us) +{ + us += US_PER_TICK - 1; + do_div(us, US_PER_TICK); + return us; +} +#endif
/* nothing really to do with interrupts, just starts up a counter. */ /* The 32768Hz 32-bit timer overruns in 131072 seconds */ @@ -107,7 +139,7 @@ ulong get_timer_masked (void) * 5 * 10^9 days... and get_ticks() * CONFIG_SYS_HZ wraps in * 5 * 10^6 days - long enough. */ - return TICK_TO_TIME(get_ticks()); + return tick_to_time(get_ticks()); }
ulong get_timer (ulong base) @@ -117,7 +149,7 @@ ulong get_timer (ulong base)
void set_timer (ulong t) { - timestamp = TIME_TO_TICK(t); + timestamp = time_to_tick(t); }
/* delay x useconds AND perserve advance timstamp value */ @@ -126,7 +158,7 @@ void udelay (unsigned long usec) unsigned long long tmp; ulong tmo;
- tmo = US_TO_TICK(usec); + tmo = us_to_tick(usec); tmp = get_ticks() + tmo; /* get current timestamp */
while (get_ticks() < tmp) /* loop till event */
Jean-Christophe PLAGNIOL-VILLARD
Tomohiro Masubuchi
