[U-Boot] [PATCH v4 1/1] tegra: usb: Fix device enumeration problem of USB1
A known hardware issue of USB1 port where bit 1 (connect status change) of PORTSC register will be set after issuing Port Reset (like "usb reset" in u-boot command line). This will be treated as an error and stops later device enumeration.
Therefore we clear that bit after Port Reset in order to proceed later device enumeration.
Signed-off-by: Jim Lin jilin@nvidia.com --- To reproduce this issue, you can modify board .dts file to set as the following to build u-boot binary. " usb0 = "/usb@c5000000"; usb1 = "/usb@c5008000"; " Install device on USB1 port (address at 0xc5000000). And run "usb reset" in u-boot console to enumerate device.
Before adding this patch, we could see problem every time. After adding, tried 10 times of "usb reset", "usb tree", "usb stop" , without seeing issue.
Changes in v4: - Add comment to describe replacing weak function ehci_powerup_fixup of ehci-hcd.c - Remove using variable my_reg
Changes in v3: - Move patch for USB1 controller into ehci_powerup_fixup of ehci-tegra.c - Update copyright year to 2012
Changes in v2: - Change config name - Add a callback function at the end of ehci_submit_root() function
drivers/usb/host/ehci-tegra.c | 18 +++++++++++++++++- 1 files changed, 17 insertions(+), 1 deletions(-)
diff --git a/drivers/usb/host/ehci-tegra.c b/drivers/usb/host/ehci-tegra.c index a7e105b..6646d3a 100644 --- a/drivers/usb/host/ehci-tegra.c +++ b/drivers/usb/host/ehci-tegra.c @@ -1,5 +1,5 @@ /* - * Copyright (c) 2009 NVIDIA Corporation + * Copyright (c) 2009-2012 NVIDIA Corporation * * See file CREDITS for list of people who contributed to this * project. @@ -29,6 +29,22 @@ #include <asm/errno.h> #include <asm/arch/usb.h>
+/* + * A known hardware issue where Connect Status Change bit of PORTSC register + * of USB1 controller will be set after Port Reset. + * We have to clear it in order for later device enumeration to proceed. + * This ehci_powerup_fixup overrides the weak function ehci_powerup_fixup + * in "ehci-hcd.c". + */ +void ehci_powerup_fixup(uint32_t *status_reg, uint32_t *reg) +{ + mdelay(50); + if (((u32) status_reg & 0xFFFFC000) != TEGRA_USB1_BASE) + return; + /* For EHCI_PS_CSC to be cleared in ehci_hcd.c */ + if (ehci_readl(status_reg) & EHCI_PS_CSC) + *reg |= EHCI_PS_CSC; +}
/* * Create the appropriate control structures to manage
Acked-by: Stephen Warren swarren@wwwdotorg.org
Dear Jim Lin,
Changes in v4:
Changes in v3:
Changes in v2:
- Copyright (c) 2009 NVIDIA Corporation
- Copyright (c) 2009-2012 NVIDIA Corporation
- project.
- A known hardware issue where Connect Status Change bit of PORTSC
- We have to clear it in order for later device enumeration to proceed.
- This ehci_powerup_fixup overrides the weak function ehci_powerup_fixup
- in "ehci-hcd.c".
So it was even enough to use the already preinstalled callback? :-)
- mdelay(50);
- if (((u32) status_reg & 0xFFFFC000) != TEGRA_USB1_BASE)
What's this magic number here?
return;
- /* For EHCI_PS_CSC to be cleared in ehci_hcd.c */
- if (ehci_readl(status_reg) & EHCI_PS_CSC)
writel()
- Create the appropriate control structures to manage
Best regards, Marek Vasut
From: Marek Vasut [mailto:marek.vasut@gmail.com] Sent: Thursday, June 21, 2012 6:16 PM
- project.
- in "ehci-hcd.c".
Yes.
- mdelay(50);
Address Mask value, any suggestion?
return;
writel()
The real IO write (ehci_writel) is done in ehci-hcd.c after calling of ehci_powerup_fixup. Any suggestion? ----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Dear Jim Lin,
project.
@@ -29,6 +29,22 @@
Yes.
- mdelay(50);
I wonder ... either comment or #define it somewhere, the later is favorable.
return;
writel()
Good, leave it at that.
^^ The above is nvidia bullshit, please remove it, it doesn't make sense here.
Jim Lin
Stephen Warren
