[U-Boot] [PATCH 1/2] Makefile: Allow arch post-link hook
This commit allows an architecture to provide a Makefile.postlink whose u-boot target gets invoked after the u-boot ELF is linked. This will be of use for MIPS in a following commit.
This mirrors Linux commit fbe6e37dab97 ("kbuild: add arch specific post-link Makefile").
Signed-off-by: Paul Burton paul.burton@imgtec.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: u-boot@lists.denx.de ---
Makefile | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index 62d0482bcf..3c3bbc5109 100644 --- a/Makefile +++ b/Makefile @@ -1215,13 +1215,16 @@ u-boot.elf: u-boot.bin $(Q)$(OBJCOPY) -I binary $(PLATFORM_ELFFLAGS) $< u-boot-elf.o $(call if_changed,u-boot-elf)
+ARCH_POSTLINK := $(wildcard $(srctree)/arch/$(ARCH)/Makefile.postlink) + # Rule to link u-boot # May be overridden by arch/$(ARCH)/config.mk quiet_cmd_u-boot__ ?= LD $@ cmd_u-boot__ ?= $(LD) $(LDFLAGS) $(LDFLAGS_u-boot) -o $@ \ -T u-boot.lds $(u-boot-init) \ --start-group $(u-boot-main) --end-group \ - $(PLATFORM_LIBS) -Map u-boot.map + $(PLATFORM_LIBS) -Map u-boot.map; \ + $(if $(ARCH_POSTLINK), $(MAKE) -f $(ARCH_POSTLINK) $@, true)
quiet_cmd_smap = GEN common/system_map.o cmd_smap = \ @@ -1231,7 +1234,7 @@ cmd_smap = \ -c $(srctree)/common/system_map.c -o common/system_map.o
u-boot: $(u-boot-init) $(u-boot-main) u-boot.lds FORCE - $(call if_changed,u-boot__) + +$(call if_changed,u-boot__) ifeq ($(CONFIG_KALLSYMS),y) $(call cmd,smap) $(call cmd,u-boot__) common/system_map.o
U-Boot has up until now built with -fpic for the MIPS architecture, producing position independent code which uses indirection through a global offset table, making relocation fairly straightforward as it simply involves patching up GOT entries.
Using -fpic does however have some downsides. The biggest of these is that generated code is bloated in various ways. For example, function calls are indirected through the GOT & the t9 register:
8f998064 lw t9,-32668(gp) 0320f809 jalr t9
Without -fpic the call is simply:
0f803f01 jal be00fc04 <puts>
This is more compact & faster (due to the lack of the load & the dependency the jump has on its result). It is also easier to read & debug because the disassembly shows what function is being called, rather than just an offset from gp which would then have to be looked up in the ELF to discover the target function.
Another disadvantage of -fpic is that each function begins with a sequence to calculate the value of the gp register, for example:
3c1c0004 lui gp,0x4 279c3384 addiu gp,gp,13188 0399e021 addu gp,gp,t9
Without using -fpic this sequence no longer appears at the start of each function, reducing code size considerably.
This patch switches U-Boot from building with -fpic to building with -fno-pic, in order to gain the benefits described above. The cost of this is an extra step during the build process to extract relocation data from the ELF & write it into a new .rel section in a compact format, plus the added complexity of dealing with multiple types of relocation rather than the single type that applied to the GOT. The benefit is smaller, cleaner, more debuggable code. The relocate_code() function is reimplemented in C to handle the new relocation scheme, which also makes it easier to read & debug.
Taking maltael_defconfig as an example the size of u-boot.bin built using the Codescape MIPS 2016.05-06 toolchain (gcc 4.9.2, binutils 2.24.90) shrinks from 254KiB to 224KiB.
Signed-off-by: Paul Burton paul.burton@imgtec.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: u-boot@lists.denx.de ---
arch/mips/Makefile.postlink | 23 +++ arch/mips/config.mk | 19 +- arch/mips/cpu/start.S | 130 ------------- arch/mips/cpu/u-boot.lds | 41 +--- arch/mips/include/asm/relocs.h | 24 +++ arch/mips/lib/Makefile | 1 + arch/mips/lib/reloc.c | 164 ++++++++++++++++ common/board_f.c | 2 +- tools/.gitignore | 1 + tools/Makefile | 2 + tools/mips-relocs.c | 426 +++++++++++++++++++++++++++++++++++++++++ 11 files changed, 656 insertions(+), 177 deletions(-) create mode 100644 arch/mips/Makefile.postlink create mode 100644 arch/mips/include/asm/relocs.h create mode 100644 arch/mips/lib/reloc.c create mode 100644 tools/mips-relocs.c
diff --git a/arch/mips/Makefile.postlink b/arch/mips/Makefile.postlink new file mode 100644 index 0000000000..d6fbc0d404 --- /dev/null +++ b/arch/mips/Makefile.postlink @@ -0,0 +1,23 @@ +# +# Copyright (c) 2017 Imagination Technologies Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +PHONY := __archpost +__archpost: + +-include include/config/auto.conf +include scripts/Kbuild.include + +CMD_RELOCS = tools/mips-relocs +quiet_cmd_relocs = RELOCS $@ + cmd_relocs = $(CMD_RELOCS) $@ .$@.relocs + +u-boot: FORCE + @true + $(call if_changed,relocs) + +.PHONY: FORCE + +FORCE: diff --git a/arch/mips/config.mk b/arch/mips/config.mk index 2c72c1553d..56d150171e 100644 --- a/arch/mips/config.mk +++ b/arch/mips/config.mk @@ -56,25 +56,16 @@ PLATFORM_ELFFLAGS += -B mips $(OBJCOPYFLAGS) # LDFLAGS_vmlinux += -G 0 -static -n -nostdlib # MODFLAGS += -mlong-calls # -# On the other hand, we want PIC in the U-Boot code to relocate it from ROM -# to RAM. $28 is always used as gp. -# -ifdef CONFIG_SPL_BUILD -PF_ABICALLS := -mno-abicalls -PF_PIC := -fno-pic -PF_PIE := -else -PF_ABICALLS := -mabicalls -PF_PIC := -fpic -PF_PIE := -pie -PF_OBJCOPY := -j .got -j .rel.dyn -j .padding +ifndef CONFIG_SPL_BUILD +PF_OBJCOPY := -j .got -j .rel -j .padding PF_OBJCOPY += -j .dtb.init.rodata +LDFLAGS_FINAL += --emit-relocs endif
-PLATFORM_CPPFLAGS += -G 0 $(PF_ABICALLS) $(PF_PIC) +PLATFORM_CPPFLAGS += -G 0 -mno-abicalls -fno-pic PLATFORM_CPPFLAGS += -msoft-float PLATFORM_LDFLAGS += -G 0 -static -n -nostdlib PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections -LDFLAGS_FINAL += --gc-sections $(PF_PIE) +LDFLAGS_FINAL += --gc-sections OBJCOPYFLAGS += -j .text -j .rodata -j .data -j .u_boot_list OBJCOPYFLAGS += $(PF_OBJCOPY) diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index d01ee9f9bd..952c57afd7 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -221,18 +221,6 @@ wr_done: ehb #endif
- /* - * Initialize $gp, force pointer sized alignment of bal instruction to - * forbid the compiler to put nop's between bal and _gp. This is - * required to keep _gp and ra aligned to 8 byte. - */ - .align PTRLOG - bal 1f - nop - PTR _gp -1: - PTR_L gp, 0(ra) - #ifdef CONFIG_MIPS_CM PTR_LA t9, mips_cm_map jalr t9 @@ -291,121 +279,3 @@ wr_done: move ra, zero
END(_start) - -/* - * void relocate_code (addr_sp, gd, addr_moni) - * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * - * a0 = addr_sp - * a1 = gd - * a2 = destination address - */ -ENTRY(relocate_code) - move sp, a0 # set new stack pointer - move fp, sp - - move s0, a1 # save gd in s0 - move s2, a2 # save destination address in s2 - - PTR_LI t0, CONFIG_SYS_MONITOR_BASE - PTR_SUB s1, s2, t0 # s1 <-- relocation offset - - PTR_LA t2, __image_copy_end - move t1, a2 - - /* - * t0 = source address - * t1 = target address - * t2 = source end address - */ -1: - PTR_L t3, 0(t0) - PTR_S t3, 0(t1) - PTR_ADDU t0, PTRSIZE - blt t0, t2, 1b - PTR_ADDU t1, PTRSIZE - - /* - * Now we want to update GOT. - * - * GOT[0] is reserved. GOT[1] is also reserved for the dynamic object - * generated by GNU ld. Skip these reserved entries from relocation. - */ - PTR_LA t3, num_got_entries - PTR_LA t8, _GLOBAL_OFFSET_TABLE_ - PTR_ADD t8, s1 # t8 now holds relocated _G_O_T_ - PTR_ADDIU t8, t8, 2 * PTRSIZE # skipping first two entries - PTR_LI t2, 2 -1: - PTR_L t1, 0(t8) - beqz t1, 2f - PTR_ADD t1, s1 - PTR_S t1, 0(t8) -2: - PTR_ADDIU t2, 1 - blt t2, t3, 1b - PTR_ADDIU t8, PTRSIZE - - /* Update dynamic relocations */ - PTR_LA t1, __rel_dyn_start - PTR_LA t2, __rel_dyn_end - - b 2f # skip first reserved entry - PTR_ADDIU t1, 2 * PTRSIZE - -1: - lw t8, -4(t1) # t8 <-- relocation info - - PTR_LI t3, MIPS_RELOC - bne t8, t3, 2f # skip non-MIPS_RELOC entries - nop - - PTR_L t3, -(2 * PTRSIZE)(t1) # t3 <-- location to fix up in FLASH - - PTR_L t8, 0(t3) # t8 <-- original pointer - PTR_ADD t8, s1 # t8 <-- adjusted pointer - - PTR_ADD t3, s1 # t3 <-- location to fix up in RAM - PTR_S t8, 0(t3) - -2: - blt t1, t2, 1b - PTR_ADDIU t1, 2 * PTRSIZE # each rel.dyn entry is 2*PTRSIZE bytes - - /* - * Flush caches to ensure our newly modified instructions are visible - * to the instruction cache. We're still running with the old GOT, so - * apply the reloc offset to the start address. - */ - PTR_LA a0, __text_start - PTR_LA a1, __text_end - PTR_SUB a1, a1, a0 - PTR_LA t9, flush_cache - jalr t9 - PTR_ADD a0, s1 - - PTR_ADD gp, s1 # adjust gp - - /* - * Clear BSS - * - * GOT is now relocated. Thus __bss_start and __bss_end can be - * accessed directly via $gp. - */ - PTR_LA t1, __bss_start # t1 <-- __bss_start - PTR_LA t2, __bss_end # t2 <-- __bss_end - -1: - PTR_S zero, 0(t1) - blt t1, t2, 1b - PTR_ADDIU t1, PTRSIZE - - move a0, s0 # a0 <-- gd - move a1, s2 - PTR_LA t9, board_init_r - jr t9 - move ra, zero - - END(relocate_code) diff --git a/arch/mips/cpu/u-boot.lds b/arch/mips/cpu/u-boot.lds index 0129c99611..bd5536f013 100644 --- a/arch/mips/cpu/u-boot.lds +++ b/arch/mips/cpu/u-boot.lds @@ -34,15 +34,6 @@ SECTIONS *(.data*) }
- . = .; - _gp = ALIGN(16) + 0x7ff0; - - .got : { - *(.got) - } - - num_got_entries = SIZEOF(.got) >> PTR_COUNT_SHIFT; - . = ALIGN(4); .sdata : { *(.sdata*) @@ -57,33 +48,19 @@ SECTIONS __image_copy_end = .; __init_end = .;
- .rel.dyn : { - __rel_dyn_start = .; - *(.rel.dyn) - __rel_dyn_end = .; - } - - .padding : { - /* - * Workaround for a binutils feature (or bug?). - * - * The GNU ld from binutils puts the dynamic relocation - * entries into the .rel.dyn section. Sometimes it - * allocates more dynamic relocation entries than it needs - * and the unused slots are set to R_MIPS_NONE entries. - * - * However the size of the .rel.dyn section in the ELF - * section header does not cover the unused entries, so - * objcopy removes those during stripping. - * - * Create a small section here to avoid that. - */ - LONG(0xFFFFFFFF) + /* + * .rel must come last so that the mips-relocs tool can shrink + * the section size & the PT_LOAD program header filesz. + */ + .rel : { + __rel_start = .; + BYTE(0x0) + . += (32 * 1024) - 1; }
_end = .;
- .bss __rel_dyn_start (OVERLAY) : { + .bss __rel_start (OVERLAY) : { __bss_start = .; *(.sbss.*) *(.bss.*) diff --git a/arch/mips/include/asm/relocs.h b/arch/mips/include/asm/relocs.h new file mode 100644 index 0000000000..92e9d04f7c --- /dev/null +++ b/arch/mips/include/asm/relocs.h @@ -0,0 +1,24 @@ +/* + * MIPS Relocations + * + * Copyright (c) 2017 Imagination Technologies Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MIPS_RELOCS_H__ +#define __ASM_MIPS_RELOCS_H__ + +#define R_MIPS_NONE 0 +#define R_MIPS_32 2 +#define R_MIPS_26 4 +#define R_MIPS_HI16 5 +#define R_MIPS_LO16 6 +#define R_MIPS_PC16 10 +#define R_MIPS_64 18 +#define R_MIPS_HIGHER 28 +#define R_MIPS_HIGHEST 29 +#define R_MIPS_PC21_S2 60 +#define R_MIPS_PC26_S2 61 + +#endif /* __ASM_MIPS_RELOCS_H__ */ diff --git a/arch/mips/lib/Makefile b/arch/mips/lib/Makefile index 659c6ad187..ef557c6932 100644 --- a/arch/mips/lib/Makefile +++ b/arch/mips/lib/Makefile @@ -8,6 +8,7 @@ obj-y += cache.o obj-y += cache_init.o obj-y += genex.o +obj-y += reloc.o obj-y += stack.o obj-y += traps.o
diff --git a/arch/mips/lib/reloc.c b/arch/mips/lib/reloc.c new file mode 100644 index 0000000000..b7ae56df5a --- /dev/null +++ b/arch/mips/lib/reloc.c @@ -0,0 +1,164 @@ +/* + * MIPS Relocation + * + * Copyright (c) 2017 Imagination Technologies Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/relocs.h> +#include <asm/sections.h> + +/* + * __rel_start: Relocation data generated by the mips-relocs tool + * + * This data, found in the .rel section, is generated by the mips-relocs tool & + * contains a record of all locations in the U-Boot binary that need to be + * fixed up during relocation. + * + * The data is a sequence of unsigned integers, which are of somewhat arbitrary + * size. This is achieved by encoding integers as a sequence of bytes, each of + * which contains 7 bits of data with the most significant bit indicating + * whether any further bytes need to be read. The least significant bits of the + * integer are found in the first byte - ie. it somewhat resembles little + * endian. + * + * Each pair of two integers represents a relocation that must be applied. The + * first integer represents the type of relocation as a standard ELF relocation + * type (ie. R_MIPS_*). The second integer represents the offset at which to + * apply the relocation, relative to the previous relocation or for the first + * relocation the start of the relocated .text section. + * + * The end of the relocation data is indicated when type R_MIPS_NONE (0) is + * read, at which point no further integers should be read. That is, the + * terminating R_MIPS_NONE reloc includes no offset. + */ +extern uint8_t __rel_start[]; + +/** + * read_uint() - Read an unsigned integer from the buffer + * @buf: pointer to a pointer to the reloc buffer + * + * Read one whole unsigned integer from the relocation data pointed to by @buf, + * advancing @buf past the bytes encoding the integer. + * + * Returns: the integer read from @buf + */ +static unsigned long read_uint(uint8_t **buf) +{ + unsigned long val = 0; + unsigned int shift = 0; + uint8_t new; + + do { + new = *(*buf)++; + val |= (new & 0x7f) << shift; + shift += 7; + } while (new & 0x80); + + return val; +} + +/** + * apply_reloc() - Apply a single relocation + * @type: the type of reloc (R_MIPS_*) + * @addr: the address that the reloc should be applied to + * @off: the relocation offset, ie. number of bytes we're moving U-Boot by + * + * Apply a single relocation of type @type at @addr. This function is + * intentionally simple, and does the bare minimum needed to fixup the + * relocated U-Boot - in particular, it does not check for overflows. + */ +static void apply_reloc(unsigned int type, void *addr, long off) +{ + switch (type) { + case R_MIPS_26: + *(uint32_t *)addr += (off >> 2) & 0x3ffffff; + break; + + case R_MIPS_32: + *(uint32_t *)addr += off; + break; + + case R_MIPS_64: + *(uint64_t *)addr += off; + break; + + case R_MIPS_HI16: + *(uint32_t *)addr += off >> 16; + break; + + default: + panic("Unhandled reloc type %u\n", type); + } +} + +/** + * relocate_code() - Relocate U-Boot, generally from flash to DDR + * @start_addr_sp: new stack pointer + * @new_gd: pointer to relocated global data + * @relocaddr: the address to relocate to + * + * Relocate U-Boot from its current location (generally in flash) to a new one + * (generally in DDR). This function will copy the U-Boot binary & apply + * relocations as necessary, then jump to board_init_r in the new build of + * U-Boot. As such, this function does not return. + */ +void relocate_code(ulong start_addr_sp, gd_t *new_gd, ulong relocaddr) +{ + unsigned long addr, length, bss_len; + uint8_t *buf, *bss_start; + unsigned int type; + long off; + + /* + * Ensure that we're relocating by an offset which is a multiple of + * 64KiB, ie. doesn't change the least significant 16 bits of any + * addresses. This allows us to discard R_MIPS_LO16 relocs, saving + * space in the U-Boot binary & complexity in handling them. + */ + off = relocaddr - (unsigned long)__text_start; + if (off & 0xffff) + panic("Mis-aligned relocation\n"); + + /* Copy U-Boot to RAM */ + length = __image_copy_end - __text_start; + memcpy((void *)relocaddr, __text_start, length); + + /* Now apply relocations to the copy in RAM */ + buf = __rel_start; + addr = relocaddr; + while (true) { + type = read_uint(&buf); + if (type == R_MIPS_NONE) + break; + + addr += read_uint(&buf) << 2; + apply_reloc(type, (void *)addr, off); + } + + /* Ensure the icache is coherent */ + flush_cache(relocaddr, length); + + /* Clear the .bss section */ + bss_start = (uint8_t *)((unsigned long)__bss_start + off); + bss_len = (unsigned long)&__bss_end - (unsigned long)__bss_start; + memset(bss_start, 0, bss_len); + + /* Jump to the relocated U-Boot */ + asm volatile( + "move $29, %0\n" + " move $4, %1\n" + " move $5, %2\n" + " move $31, $0\n" + " jr %3" + : /* no outputs */ + : "r"(start_addr_sp), + "r"(new_gd), + "r"(relocaddr), + "r"((unsigned long)board_init_r + off)); + + /* Since we jumped to the new U-Boot above, we won't get here */ + unreachable(); +} diff --git a/common/board_f.c b/common/board_f.c index 46e52849fb..5983bf62e7 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -418,7 +418,7 @@ static int reserve_uboot(void) */ gd->relocaddr -= gd->mon_len; gd->relocaddr &= ~(4096 - 1); -#ifdef CONFIG_E500 +#if defined(CONFIG_E500) || defined(CONFIG_MIPS) /* round down to next 64 kB limit so that IVPR stays aligned */ gd->relocaddr &= ~(65536 - 1); #endif diff --git a/tools/.gitignore b/tools/.gitignore index 6ec71f5c7f..ac0c979319 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -11,6 +11,7 @@ /img2srec /kwboot /dumpimage +/mips-relocs /mkenvimage /mkimage /mkexynosspl diff --git a/tools/Makefile b/tools/Makefile index cb1683e153..56098e6943 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -209,6 +209,8 @@ hostprogs-$(CONFIG_STATIC_RELA) += relocate-rela hostprogs-y += fdtgrep fdtgrep-objs += $(LIBFDT_OBJS) fdtgrep.o
+hostprogs-$(CONFIG_MIPS) += mips-relocs + # We build some files with extra pedantic flags to try to minimize things # that won't build on some weird host compiler -- though there are lots of # exceptions for files that aren't complaint. diff --git a/tools/mips-relocs.c b/tools/mips-relocs.c new file mode 100644 index 0000000000..b690fa53c4 --- /dev/null +++ b/tools/mips-relocs.c @@ -0,0 +1,426 @@ +/* + * MIPS Relocation Data Generator + * + * Copyright (c) 2017 Imagination Technologies Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <elf.h> +#include <errno.h> +#include <fcntl.h> +#include <limits.h> +#include <stdio.h> +#include <stdlib.h> +#include <sys/mman.h> +#include <sys/stat.h> +#include <unistd.h> + +#include <asm/relocs.h> + +#define hdr_field(pfx, idx, field) ({ \ + uint64_t _val; \ + unsigned int _size; \ + \ + if (is_64) { \ + _val = pfx##hdr64[idx].field; \ + _size = sizeof(pfx##hdr64[0].field); \ + } else { \ + _val = pfx##hdr32[idx].field; \ + _size = sizeof(pfx##hdr32[0].field); \ + } \ + \ + switch (_size) { \ + case 1: \ + break; \ + case 2: \ + _val = is_be ? be16toh(_val) : le16toh(_val); \ + break; \ + case 4: \ + _val = is_be ? be32toh(_val) : le32toh(_val); \ + break; \ + case 8: \ + _val = is_be ? be64toh(_val) : le64toh(_val); \ + break; \ + } \ + \ + _val; \ +}) + +#define set_hdr_field(pfx, idx, field, val) ({ \ + uint64_t _val; \ + unsigned int _size; \ + \ + if (is_64) \ + _size = sizeof(pfx##hdr64[0].field); \ + else \ + _size = sizeof(pfx##hdr32[0].field); \ + \ + switch (_size) { \ + case 1: \ + _val = val; \ + break; \ + case 2: \ + _val = is_be ? htobe16(val) : htole16(val); \ + break; \ + case 4: \ + _val = is_be ? htobe32(val) : htole32(val); \ + break; \ + case 8: \ + _val = is_be ? htobe64(val) : htole64(val); \ + break; \ + } \ + \ + if (is_64) \ + pfx##hdr64[idx].field = _val; \ + else \ + pfx##hdr32[idx].field = _val; \ +}) + +#define ehdr_field(field) \ + hdr_field(e, 0, field) +#define phdr_field(idx, field) \ + hdr_field(p, idx, field) +#define shdr_field(idx, field) \ + hdr_field(s, idx, field) + +#define set_phdr_field(idx, field, val) \ + set_hdr_field(p, idx, field, val) +#define set_shdr_field(idx, field, val) \ + set_hdr_field(s, idx, field, val) + +#define shstr(idx) (&shstrtab[idx]) + +bool is_64, is_be; +uint64_t text_base; + +struct mips_reloc { + uint8_t type; + uint64_t offset; +} *relocs; +size_t relocs_sz, relocs_idx; + +static int add_reloc(unsigned int type, uint64_t off) +{ + struct mips_reloc *new; + size_t new_sz; + + switch (type) { + case R_MIPS_NONE: + case R_MIPS_LO16: + case R_MIPS_PC16: + case R_MIPS_HIGHER: + case R_MIPS_HIGHEST: + case R_MIPS_PC21_S2: + case R_MIPS_PC26_S2: + /* Skip these relocs */ + return 0; + + default: + break; + } + + if (relocs_idx == relocs_sz) { + new_sz = relocs_sz ? relocs_sz * 2 : 128; + new = realloc(relocs, new_sz * sizeof(*relocs)); + if (!new) { + fprintf(stderr, "Out of memory\n"); + return -ENOMEM; + } + + relocs = new; + relocs_sz = new_sz; + } + + relocs[relocs_idx++] = (struct mips_reloc){ + .type = type, + .offset = off, + }; + + return 0; +} + +static int parse_mips32_rel(const void *_rel) +{ + const Elf32_Rel *rel = _rel; + uint32_t off, type; + + off = is_be ? be32toh(rel->r_offset) : le32toh(rel->r_offset); + off -= text_base; + + type = is_be ? be32toh(rel->r_info) : le32toh(rel->r_info); + type = ELF32_R_TYPE(type); + + return add_reloc(type, off); +} + +static int parse_mips64_rela(const void *_rel) +{ + const Elf64_Rela *rel = _rel; + uint64_t off, type; + + off = is_be ? be64toh(rel->r_offset) : le64toh(rel->r_offset); + off -= text_base; + + type = rel->r_info >> (64 - 8); + + return add_reloc(type, off); +} + +static void output_uint(uint8_t **buf, uint64_t val) +{ + uint64_t tmp; + + do { + tmp = val & 0x7f; + val >>= 7; + tmp |= !!val << 7; + *(*buf)++ = tmp; + } while (val); +} + +static int compare_relocs(const void *a, const void *b) +{ + const struct mips_reloc *ra = a, *rb = b; + + return ra->offset - rb->offset; +} + +int main(int argc, char *argv[]) +{ + unsigned int i, j, i_rel_shdr, sh_type, sh_entsize, sh_entries; + size_t rel_size, rel_actual_size, load_sz; + const char *shstrtab, *sh_name, *rel_pfx; + int (*parse_fn)(const void *rel); + uint8_t *buf_start, *buf; + const Elf32_Ehdr *ehdr32; + const Elf64_Ehdr *ehdr64; + uintptr_t sh_offset; + Elf32_Phdr *phdr32; + Elf64_Phdr *phdr64; + Elf32_Shdr *shdr32; + Elf64_Shdr *shdr64; + struct stat st; + int err, fd; + void *elf; + bool skip; + + fd = open(argv[1], O_RDWR); + if (fd == -1) { + fprintf(stderr, "Unable to open input file %s\n", argv[1]); + err = errno; + goto out_ret; + } + + err = fstat(fd, &st); + if (err) { + fprintf(stderr, "Unable to fstat() input file\n"); + goto out_close_fd; + } + + elf = mmap(NULL, st.st_size, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0); + if (elf == MAP_FAILED) { + fprintf(stderr, "Unable to mmap() input file\n"); + err = errno; + goto out_close_fd; + } + + ehdr32 = elf; + ehdr64 = elf; + + if (memcmp(&ehdr32->e_ident[EI_MAG0], ELFMAG, SELFMAG)) { + fprintf(stderr, "Input file is not an ELF\n"); + err = -EINVAL; + goto out_free_relocs; + } + + if (ehdr32->e_ident[EI_VERSION] != EV_CURRENT) { + fprintf(stderr, "Unrecognised ELF version\n"); + err = -EINVAL; + goto out_free_relocs; + } + + switch (ehdr32->e_ident[EI_CLASS]) { + case ELFCLASS32: + is_64 = false; + break; + case ELFCLASS64: + is_64 = true; + break; + default: + fprintf(stderr, "Unrecognised ELF class\n"); + err = -EINVAL; + goto out_free_relocs; + } + + switch (ehdr32->e_ident[EI_DATA]) { + case ELFDATA2LSB: + is_be = false; + break; + case ELFDATA2MSB: + is_be = true; + break; + default: + fprintf(stderr, "Unrecognised ELF data encoding\n"); + err = -EINVAL; + goto out_free_relocs; + } + + if (ehdr_field(e_type) != ET_EXEC) { + fprintf(stderr, "Input ELF is not an executable\n"); + printf("type 0x%lx\n", ehdr_field(e_type)); + err = -EINVAL; + goto out_free_relocs; + } + + if (ehdr_field(e_machine) != EM_MIPS) { + fprintf(stderr, "Input ELF does not target MIPS\n"); + err = -EINVAL; + goto out_free_relocs; + } + + phdr32 = elf + ehdr_field(e_phoff); + phdr64 = elf + ehdr_field(e_phoff); + shdr32 = elf + ehdr_field(e_shoff); + shdr64 = elf + ehdr_field(e_shoff); + shstrtab = elf + shdr_field(ehdr_field(e_shstrndx), sh_offset); + + i_rel_shdr = UINT_MAX; + for (i = 0; i < ehdr_field(e_shnum); i++) { + sh_name = shstr(shdr_field(i, sh_name)); + + if (!strcmp(sh_name, ".rel")) { + i_rel_shdr = i; + continue; + } + + if (!strcmp(sh_name, ".text")) { + text_base = shdr_field(i, sh_addr); + continue; + } + } + if (i_rel_shdr == UINT_MAX) { + fprintf(stderr, "Unable to find .rel section\n"); + err = -EINVAL; + goto out_free_relocs; + } + if (!text_base) { + fprintf(stderr, "Unable to find .text base address\n"); + err = -EINVAL; + goto out_free_relocs; + } + + rel_pfx = is_64 ? ".rela." : ".rel."; + + for (i = 0; i < ehdr_field(e_shnum); i++) { + sh_type = shdr_field(i, sh_type); + if ((sh_type != SHT_REL) && (sh_type != SHT_RELA)) + continue; + + sh_name = shstr(shdr_field(i, sh_name)); + if (strncmp(sh_name, rel_pfx, strlen(rel_pfx))) { + if (strcmp(sh_name, ".rel") && strcmp(sh_name, ".rel.dyn")) + fprintf(stderr, "WARNING: Unexpected reloc section name '%s'\n", sh_name); + continue; + } + + /* + * Skip reloc sections which either don't correspond to another + * section in the ELF, or whose corresponding section isn't + * loaded as part of the U-Boot binary (ie. doesn't have the + * alloc flags set). + */ + skip = true; + for (j = 0; j < ehdr_field(e_shnum); j++) { + if (strcmp(&sh_name[strlen(rel_pfx) - 1], shstr(shdr_field(j, sh_name)))) + continue; + + skip = !(shdr_field(j, sh_flags) & SHF_ALLOC); + break; + } + if (skip) + continue; + + sh_offset = shdr_field(i, sh_offset); + sh_entsize = shdr_field(i, sh_entsize); + sh_entries = shdr_field(i, sh_size) / sh_entsize; + + if (sh_type == SHT_REL) { + if (is_64) { + fprintf(stderr, "REL-style reloc in MIPS64 ELF?\n"); + err = -EINVAL; + goto out_free_relocs; + } else { + parse_fn = parse_mips32_rel; + } + } else { + if (is_64) { + parse_fn = parse_mips64_rela; + } else { + fprintf(stderr, "RELA-style reloc in MIPS32 ELF?\n"); + err = -EINVAL; + goto out_free_relocs; + } + } + + for (j = 0; j < sh_entries; j++) { + err = parse_fn(elf + sh_offset + (j * sh_entsize)); + if (err) + goto out_free_relocs; + } + } + + /* Sort relocs in ascending order of offset */ + qsort(relocs, relocs_idx, sizeof(*relocs), compare_relocs); + + /* Make reloc offsets relative to their predecessor */ + for (i = relocs_idx - 1; i > 0; i--) + relocs[i].offset -= relocs[i - 1].offset; + + /* Write the relocations to the .rel section */ + buf = buf_start = elf + shdr_field(i_rel_shdr, sh_offset); + for (i = 0; i < relocs_idx; i++) { + output_uint(&buf, relocs[i].type); + output_uint(&buf, relocs[i].offset >> 2); + } + + /* Write a terminating R_MIPS_NONE (0) */ + output_uint(&buf, R_MIPS_NONE); + + /* Ensure the relocs didn't overflow the .rel section */ + rel_size = shdr_field(i_rel_shdr, sh_size); + rel_actual_size = buf - buf_start; + if (rel_actual_size > rel_size) { + fprintf(stderr, "Relocs overflowed .rel section\n"); + return -ENOMEM; + } + + /* Update the .rel section's size */ + set_shdr_field(i_rel_shdr, sh_size, rel_actual_size); + + /* Shrink the PT_LOAD program header filesz (ie. shrink u-boot.bin) */ + for (i = 0; i < ehdr_field(e_phnum); i++) { + if (phdr_field(i, p_type) != PT_LOAD) + continue; + + load_sz = phdr_field(i, p_filesz); + load_sz -= rel_size - rel_actual_size; + set_phdr_field(i, p_filesz, load_sz); + break; + } + + /* Make sure data is written back to the file */ + err = msync(elf, st.st_size, MS_SYNC); + if (err) { + fprintf(stderr, "Failed to msync: %d\n", errno); + goto out_free_relocs; + } + +out_free_relocs: + free(relocs); + munmap(elf, st.st_size); +out_close_fd: + close(fd); +out_ret: + return err; +}
Hi Paul,
Am 16.06.2017 um 02:05 schrieb Paul Burton:
nice work, thanks. Nits below
what's the purpose of .$@.relocs? The mips-relocs tool only has one arguments and the kernel Makefile doesn't have this
+u-boot: FORCE
- @true
- $(call if_changed,relocs)
+.PHONY: FORCE
I think we could now drop the extra PF_OBJCOPY variable and directly assign the values to OBJCOPYFLAGS
- .align PTRLOG
- bal 1f
nop
- PTR _gp
-1:
- PTR_L gp, 0(ra)
END(_start)
- void relocate_code (addr_sp, gd, addr_moni)
- This "function" does not return, instead it continues in RAM
- after relocating the monitor code.
- a0 = addr_sp
- a1 = gd
- a2 = destination address
- move fp, sp
- move t1, a2
-1:
- PTR_L t3, 0(t0)
- PTR_S t3, 0(t1)
- blt t0, t2, 1b
- PTR_LI t2, 2
-1:
- PTR_L t1, 0(t8)
- beqz t1, 2f
PTR_ADD t1, s1
- PTR_S t1, 0(t8)
-2:
- PTR_ADDIU t2, 1
- blt t2, t3, 1b
-1:
nop
- PTR_S t8, 0(t3)
-2:
- blt t1, t2, 1b
- jalr t9
PTR_ADD a0, s1
* Clear BSS
-1:
- PTR_S zero, 0(t1)
- blt t1, t2, 1b
- move a1, s2
- jr t9
move ra, zero
- .got : {
*(.got)
- .rel.dyn : {
*(.rel.dyn)
__rel_dyn_end = .;
- .padding : {
LONG(0xFFFFFFFF)
.rel : {
__rel_start = .;
BYTE(0x0)
_end = .;
- .bss __rel_start (OVERLAY) : { __bss_start = .; *(.sbss.*) *(.bss.*)
- MIPS Relocations
- Copyright (c) 2017 Imagination Technologies Ltd.
- MIPS Relocation
- __rel_start: Relocation data generated by the mips-relocs tool
- This data, found in the .rel section, is generated by the mips-relocs tool &
- contains a record of all locations in the U-Boot binary that need to be
- fixed up during relocation.
- The data is a sequence of unsigned integers, which are of somewhat arbitrary
- size. This is achieved by encoding integers as a sequence of bytes, each of
- which contains 7 bits of data with the most significant bit indicating
- whether any further bytes need to be read. The least significant bits of the
- integer are found in the first byte - ie. it somewhat resembles little
- endian.
- Each pair of two integers represents a relocation that must be applied. The
- first integer represents the type of relocation as a standard ELF relocation
- type (ie. R_MIPS_*). The second integer represents the offset at which to
- apply the relocation, relative to the previous relocation or for the first
- relocation the start of the relocated .text section.
- The end of the relocation data is indicated when type R_MIPS_NONE (0) is
- read, at which point no further integers should be read. That is, the
- terminating R_MIPS_NONE reloc includes no offset.
could you move this to asm/sections.h (or asm-generic/sections.h perhaps) to suppress a checkpatch.pl warning and to have linker script exports in one place?
- read_uint() - Read an unsigned integer from the buffer
- @buf: pointer to a pointer to the reloc buffer
- Read one whole unsigned integer from the relocation data pointed to by @buf,
- advancing @buf past the bytes encoding the integer.
- Returns: the integer read from @buf
- unsigned long val = 0;
- unsigned int shift = 0;
- uint8_t new;
- do {
new = *(*buf)++;
shift += 7;
- } while (new & 0x80);
- return val;
- apply_reloc() - Apply a single relocation
- @type: the type of reloc (R_MIPS_*)
- @addr: the address that the reloc should be applied to
- @off: the relocation offset, ie. number of bytes we're moving U-Boot by
- Apply a single relocation of type @type at @addr. This function is
- intentionally simple, and does the bare minimum needed to fixup the
- relocated U-Boot - in particular, it does not check for overflows.
- switch (type) {
- case R_MIPS_26:
break;
- case R_MIPS_32:
break;
- case R_MIPS_64:
break;
- case R_MIPS_HI16:
break;
- default:
- relocate_code() - Relocate U-Boot, generally from flash to DDR
- @start_addr_sp: new stack pointer
- @new_gd: pointer to relocated global data
- @relocaddr: the address to relocate to
- Relocate U-Boot from its current location (generally in flash) to a new one
- (generally in DDR). This function will copy the U-Boot binary & apply
- relocations as necessary, then jump to board_init_r in the new build of
- U-Boot. As such, this function does not return.
- unsigned long addr, length, bss_len;
- uint8_t *buf, *bss_start;
- unsigned int type;
- long off;
- off = relocaddr - (unsigned long)__text_start;
- if (off & 0xffff)
- /* Copy U-Boot to RAM */
- length = __image_copy_end - __text_start;
- memcpy((void *)relocaddr, __text_start, length);
- /* Now apply relocations to the copy in RAM */
- buf = __rel_start;
- addr = relocaddr;
- while (true) {
break;
- /* Ensure the icache is coherent */
- flush_cache(relocaddr, length);
- /* Clear the .bss section */
- bss_start = (uint8_t *)((unsigned long)__bss_start + off);
- bss_len = (unsigned long)&__bss_end - (unsigned long)__bss_start;
- memset(bss_start, 0, bss_len);
- /* Jump to the relocated U-Boot */
- asm volatile(
"move $29, %0\n"
" move $4, %1\n"
" move $5, %2\n"
" move $31, $0\n"
" jr %3"
: /* no outputs */
"r"(new_gd),
"r"(relocaddr),
- /* Since we jumped to the new U-Boot above, we won't get here */
- unreachable();
- MIPS Relocation Data Generator
- uint64_t _val; \
- unsigned int _size; \
- if (is_64) { \
- } else { \
- switch (_size) { \
- case 1: \
break; \
- case 2: \
break; \
- case 4: \
break; \
- case 8: \
break; \
- _val; \
- uint64_t _val; \
- if (is_64) \
- else \
- case 1: \
_val = val; \
break; \
- case 2: \
break; \
- case 4: \
break; \
- case 8: \
break; \
- if (is_64) \
- else \
- hdr_field(e, 0, field)
- hdr_field(p, idx, field)
- hdr_field(s, idx, field)
- set_hdr_field(p, idx, field, val)
- set_hdr_field(s, idx, field, val)
- uint8_t type;
- uint64_t offset;
- struct mips_reloc *new;
- size_t new_sz;
- switch (type) {
- case R_MIPS_NONE:
- case R_MIPS_LO16:
- case R_MIPS_PC16:
- case R_MIPS_HIGHER:
- case R_MIPS_HIGHEST:
- case R_MIPS_PC21_S2:
- case R_MIPS_PC26_S2:
- default:
break;
- if (relocs_idx == relocs_sz) {
if (!new) {
return -ENOMEM;
relocs = new;
relocs_sz = new_sz;
- relocs[relocs_idx++] = (struct mips_reloc){
.type = type,
.offset = off,
- const Elf32_Rel *rel = _rel;
- uint32_t off, type;
- off = is_be ? be32toh(rel->r_offset) : le32toh(rel->r_offset);
- off -= text_base;
- type = is_be ? be32toh(rel->r_info) : le32toh(rel->r_info);
- type = ELF32_R_TYPE(type);
- return add_reloc(type, off);
- const Elf64_Rela *rel = _rel;
- uint64_t off, type;
- off = is_be ? be64toh(rel->r_offset) : le64toh(rel->r_offset);
- off -= text_base;
- type = rel->r_info >> (64 - 8);
- uint64_t tmp;
- do {
tmp = val & 0x7f;
val >>= 7;
tmp |= !!val << 7;
*(*buf)++ = tmp;
- } while (val);
- const struct mips_reloc *ra = a, *rb = b;
- return ra->offset - rb->offset;
- unsigned int i, j, i_rel_shdr, sh_type, sh_entsize, sh_entries;
- size_t rel_size, rel_actual_size, load_sz;
- const char *shstrtab, *sh_name, *rel_pfx;
- int (*parse_fn)(const void *rel);
- uint8_t *buf_start, *buf;
- const Elf32_Ehdr *ehdr32;
- const Elf64_Ehdr *ehdr64;
- uintptr_t sh_offset;
- Elf32_Phdr *phdr32;
- Elf64_Phdr *phdr64;
- Elf32_Shdr *shdr32;
- Elf64_Shdr *shdr64;
- struct stat st;
- int err, fd;
- void *elf;
- bool skip;
- fd = open(argv[1], O_RDWR);
- if (fd == -1) {
err = errno;
goto out_ret;
- err = fstat(fd, &st);
- if (err) {
goto out_close_fd;
- elf = mmap(NULL, st.st_size, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
- if (elf == MAP_FAILED) {
err = errno;
goto out_close_fd;
- ehdr32 = elf;
- ehdr64 = elf;
- if (memcmp(&ehdr32->e_ident[EI_MAG0], ELFMAG, SELFMAG)) {
err = -EINVAL;
- if (ehdr32->e_ident[EI_VERSION] != EV_CURRENT) {
err = -EINVAL;
- switch (ehdr32->e_ident[EI_CLASS]) {
- case ELFCLASS32:
is_64 = false;
break;
- case ELFCLASS64:
is_64 = true;
break;
- default:
err = -EINVAL;
- switch (ehdr32->e_ident[EI_DATA]) {
- case ELFDATA2LSB:
is_be = false;
break;
- case ELFDATA2MSB:
is_be = true;
break;
- default:
err = -EINVAL;
- if (ehdr_field(e_type) != ET_EXEC) {
err = -EINVAL;
- if (ehdr_field(e_machine) != EM_MIPS) {
err = -EINVAL;
- phdr32 = elf + ehdr_field(e_phoff);
- phdr64 = elf + ehdr_field(e_phoff);
- shdr32 = elf + ehdr_field(e_shoff);
- shdr64 = elf + ehdr_field(e_shoff);
- shstrtab = elf + shdr_field(ehdr_field(e_shstrndx), sh_offset);
- i_rel_shdr = UINT_MAX;
- for (i = 0; i < ehdr_field(e_shnum); i++) {
i_rel_shdr = i;
continue;
continue;
- if (i_rel_shdr == UINT_MAX) {
err = -EINVAL;
- if (!text_base) {
err = -EINVAL;
- rel_pfx = is_64 ? ".rela." : ".rel.";
continue;
continue;
* alloc flags set).
skip = true;
continue;
break;
if (skip)
continue;
if (is_64) {
err = -EINVAL;
} else {
} else {
if (is_64) {
} else {
err = -EINVAL;
if (err)
- /* Sort relocs in ascending order of offset */
- qsort(relocs, relocs_idx, sizeof(*relocs), compare_relocs);
- /* Make reloc offsets relative to their predecessor */
- for (i = relocs_idx - 1; i > 0; i--)
- /* Write the relocations to the .rel section */
- buf = buf_start = elf + shdr_field(i_rel_shdr, sh_offset);
- for (i = 0; i < relocs_idx; i++) {
- /* Write a terminating R_MIPS_NONE (0) */
- output_uint(&buf, R_MIPS_NONE);
- /* Ensure the relocs didn't overflow the .rel section */
- rel_size = shdr_field(i_rel_shdr, sh_size);
- rel_actual_size = buf - buf_start;
- if (rel_actual_size > rel_size) {
return -ENOMEM;
- /* Update the .rel section's size */
- set_shdr_field(i_rel_shdr, sh_size, rel_actual_size);
- /* Shrink the PT_LOAD program header filesz (ie. shrink u-boot.bin) */
- for (i = 0; i < ehdr_field(e_phnum); i++) {
continue;
break;
- /* Make sure data is written back to the file */
- err = msync(elf, st.st_size, MS_SYNC);
- if (err) {
+out_free_relocs:
- free(relocs);
- munmap(elf, st.st_size);
+out_close_fd:
- close(fd);
+out_ret:
- return err;
Hi Daniel,
On Friday, 16 June 2017 06:49:55 PDT Daniel Schwierzeck wrote:
Hi Paul,
Thanks for reviewing. Hope to get more submitted soon..!
Well spotted. At one point I experimented with having the mips-relocs tool output a separate file then inserting it into the ELF using objcopy, but that didn't work out so well. Will remove for v2.
+u-boot: FORCE
- @true
+.PHONY: FORCE
endif
Sure, will do in v2.
- MIPS Relocation
OK, will do.
Thanks, Paul
Changes in v2: - Drop unused .$@.relocs from Makefile.postlink. - Remove PF_OBJCOPY & assign to OBJCOPYFLAGS directly in config.mk. - Move declaration of __rel_start to asm/sections.h.
arch/mips/Makefile.postlink | 23 +++ arch/mips/config.mk | 21 +- arch/mips/cpu/start.S | 130 ------------ arch/mips/cpu/u-boot.lds | 41 +--- arch/mips/include/asm/relocs.h | 24 +++ arch/mips/include/asm/sections.h | 7 + arch/mips/lib/Makefile | 1 + arch/mips/lib/reloc.c | 159 +++++++++++++++ common/board_f.c | 2 +- tools/.gitignore | 1 + tools/Makefile | 2 + tools/mips-relocs.c | 426 +++++++++++++++++++++++++++++++++++++++ 12 files changed, 658 insertions(+), 179 deletions(-) create mode 100644 arch/mips/Makefile.postlink create mode 100644 arch/mips/include/asm/relocs.h create mode 100644 arch/mips/lib/reloc.c create mode 100644 tools/mips-relocs.c
diff --git a/arch/mips/Makefile.postlink b/arch/mips/Makefile.postlink new file mode 100644 index 0000000000..7da3acdf52 --- /dev/null +++ b/arch/mips/Makefile.postlink @@ -0,0 +1,23 @@ +# +# Copyright (c) 2017 Imagination Technologies Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +PHONY := __archpost +__archpost: + +-include include/config/auto.conf +include scripts/Kbuild.include + +CMD_RELOCS = tools/mips-relocs +quiet_cmd_relocs = RELOCS $@ + cmd_relocs = $(CMD_RELOCS) $@ + +u-boot: FORCE + @true + $(call if_changed,relocs) + +.PHONY: FORCE + +FORCE: diff --git a/arch/mips/config.mk b/arch/mips/config.mk index 2c72c1553d..cefdbe65e1 100644 --- a/arch/mips/config.mk +++ b/arch/mips/config.mk @@ -56,25 +56,14 @@ PLATFORM_ELFFLAGS += -B mips $(OBJCOPYFLAGS) # LDFLAGS_vmlinux += -G 0 -static -n -nostdlib # MODFLAGS += -mlong-calls # -# On the other hand, we want PIC in the U-Boot code to relocate it from ROM -# to RAM. $28 is always used as gp. -# -ifdef CONFIG_SPL_BUILD -PF_ABICALLS := -mno-abicalls -PF_PIC := -fno-pic -PF_PIE := -else -PF_ABICALLS := -mabicalls -PF_PIC := -fpic -PF_PIE := -pie -PF_OBJCOPY := -j .got -j .rel.dyn -j .padding -PF_OBJCOPY += -j .dtb.init.rodata +ifndef CONFIG_SPL_BUILD +OBJCOPYFLAGS += -j .got -j .rel -j .padding -j .dtb.init.rodata +LDFLAGS_FINAL += --emit-relocs endif
-PLATFORM_CPPFLAGS += -G 0 $(PF_ABICALLS) $(PF_PIC) +PLATFORM_CPPFLAGS += -G 0 -mno-abicalls -fno-pic PLATFORM_CPPFLAGS += -msoft-float PLATFORM_LDFLAGS += -G 0 -static -n -nostdlib PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections -LDFLAGS_FINAL += --gc-sections $(PF_PIE) +LDFLAGS_FINAL += --gc-sections OBJCOPYFLAGS += -j .text -j .rodata -j .data -j .u_boot_list -OBJCOPYFLAGS += $(PF_OBJCOPY) diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index d01ee9f9bd..952c57afd7 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -221,18 +221,6 @@ wr_done: ehb #endif
_end = .;
- .bss __rel_dyn_start (OVERLAY) : { + .bss __rel_start (OVERLAY) : { __bss_start = .; *(.sbss.*) *(.bss.*) diff --git a/arch/mips/include/asm/relocs.h b/arch/mips/include/asm/relocs.h new file mode 100644 index 0000000000..92e9d04f7c --- /dev/null +++ b/arch/mips/include/asm/relocs.h @@ -0,0 +1,24 @@ +/* + * MIPS Relocations + * + * Copyright (c) 2017 Imagination Technologies Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MIPS_RELOCS_H__ +#define __ASM_MIPS_RELOCS_H__ + +#define R_MIPS_NONE 0 +#define R_MIPS_32 2 +#define R_MIPS_26 4 +#define R_MIPS_HI16 5 +#define R_MIPS_LO16 6 +#define R_MIPS_PC16 10 +#define R_MIPS_64 18 +#define R_MIPS_HIGHER 28 +#define R_MIPS_HIGHEST 29 +#define R_MIPS_PC21_S2 60 +#define R_MIPS_PC26_S2 61 + +#endif /* __ASM_MIPS_RELOCS_H__ */ diff --git a/arch/mips/include/asm/sections.h b/arch/mips/include/asm/sections.h index fc4640a392..b9d217999e 100644 --- a/arch/mips/include/asm/sections.h +++ b/arch/mips/include/asm/sections.h @@ -8,4 +8,11 @@
#include <asm-generic/sections.h>
+/** + * __rel_start: Relocation data generated by the mips-relocs tool + * + * See arch/mips/lib/reloc.c for details on the format & use of this data. + */ +extern uint8_t __rel_start[]; + #endif diff --git a/arch/mips/lib/Makefile b/arch/mips/lib/Makefile index 659c6ad187..ef557c6932 100644 --- a/arch/mips/lib/Makefile +++ b/arch/mips/lib/Makefile @@ -8,6 +8,7 @@ obj-y += cache.o obj-y += cache_init.o obj-y += genex.o +obj-y += reloc.o obj-y += stack.o obj-y += traps.o
diff --git a/arch/mips/lib/reloc.c b/arch/mips/lib/reloc.c new file mode 100644 index 0000000000..268dbabfd6 --- /dev/null +++ b/arch/mips/lib/reloc.c @@ -0,0 +1,159 @@ +/* + * MIPS Relocation + * + * Copyright (c) 2017 Imagination Technologies Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Relocation data, found in the .rel section, is generated by the mips-relocs + * tool & contains a record of all locations in the U-Boot binary that need to + * be fixed up during relocation. + * + * The data is a sequence of unsigned integers, which are of somewhat arbitrary + * size. This is achieved by encoding integers as a sequence of bytes, each of + * which contains 7 bits of data with the most significant bit indicating + * whether any further bytes need to be read. The least significant bits of the + * integer are found in the first byte - ie. it somewhat resembles little + * endian. + * + * Each pair of two integers represents a relocation that must be applied. The + * first integer represents the type of relocation as a standard ELF relocation + * type (ie. R_MIPS_*). The second integer represents the offset at which to + * apply the relocation, relative to the previous relocation or for the first + * relocation the start of the relocated .text section. + * + * The end of the relocation data is indicated when type R_MIPS_NONE (0) is + * read, at which point no further integers should be read. That is, the + * terminating R_MIPS_NONE reloc includes no offset. + */ + +#include <common.h> +#include <asm/relocs.h> +#include <asm/sections.h> + +/** + * read_uint() - Read an unsigned integer from the buffer + * @buf: pointer to a pointer to the reloc buffer + * + * Read one whole unsigned integer from the relocation data pointed to by @buf, + * advancing @buf past the bytes encoding the integer. + * + * Returns: the integer read from @buf + */ +static unsigned long read_uint(uint8_t **buf) +{ + unsigned long val = 0; + unsigned int shift = 0; + uint8_t new; + + do { + new = *(*buf)++; + val |= (new & 0x7f) << shift; + shift += 7; + } while (new & 0x80); + + return val; +} + +/** + * apply_reloc() - Apply a single relocation + * @type: the type of reloc (R_MIPS_*) + * @addr: the address that the reloc should be applied to + * @off: the relocation offset, ie. number of bytes we're moving U-Boot by + * + * Apply a single relocation of type @type at @addr. This function is + * intentionally simple, and does the bare minimum needed to fixup the + * relocated U-Boot - in particular, it does not check for overflows. + */ +static void apply_reloc(unsigned int type, void *addr, long off) +{ + switch (type) { + case R_MIPS_26: + *(uint32_t *)addr += (off >> 2) & 0x3ffffff; + break; + + case R_MIPS_32: + *(uint32_t *)addr += off; + break; + + case R_MIPS_64: + *(uint64_t *)addr += off; + break; + + case R_MIPS_HI16: + *(uint32_t *)addr += off >> 16; + break; + + default: + panic("Unhandled reloc type %u\n", type); + } +} + +/** + * relocate_code() - Relocate U-Boot, generally from flash to DDR + * @start_addr_sp: new stack pointer + * @new_gd: pointer to relocated global data + * @relocaddr: the address to relocate to + * + * Relocate U-Boot from its current location (generally in flash) to a new one + * (generally in DDR). This function will copy the U-Boot binary & apply + * relocations as necessary, then jump to board_init_r in the new build of + * U-Boot. As such, this function does not return. + */ +void relocate_code(ulong start_addr_sp, gd_t *new_gd, ulong relocaddr) +{ + unsigned long addr, length, bss_len; + uint8_t *buf, *bss_start; + unsigned int type; + long off; + + /* + * Ensure that we're relocating by an offset which is a multiple of + * 64KiB, ie. doesn't change the least significant 16 bits of any + * addresses. This allows us to discard R_MIPS_LO16 relocs, saving + * space in the U-Boot binary & complexity in handling them. + */ + off = relocaddr - (unsigned long)__text_start; + if (off & 0xffff) + panic("Mis-aligned relocation\n"); + + /* Copy U-Boot to RAM */ + length = __image_copy_end - __text_start; + memcpy((void *)relocaddr, __text_start, length); + + /* Now apply relocations to the copy in RAM */ + buf = __rel_start; + addr = relocaddr; + while (true) { + type = read_uint(&buf); + if (type == R_MIPS_NONE) + break; + + addr += read_uint(&buf) << 2; + apply_reloc(type, (void *)addr, off); + } + + /* Ensure the icache is coherent */ + flush_cache(relocaddr, length); + + /* Clear the .bss section */ + bss_start = (uint8_t *)((unsigned long)__bss_start + off); + bss_len = (unsigned long)&__bss_end - (unsigned long)__bss_start; + memset(bss_start, 0, bss_len); + + /* Jump to the relocated U-Boot */ + asm volatile( + "move $29, %0\n" + " move $4, %1\n" + " move $5, %2\n" + " move $31, $0\n" + " jr %3" + : /* no outputs */ + : "r"(start_addr_sp), + "r"(new_gd), + "r"(relocaddr), + "r"((unsigned long)board_init_r + off)); + + /* Since we jumped to the new U-Boot above, we won't get here */ + unreachable(); +} diff --git a/common/board_f.c b/common/board_f.c index 46e52849fb..5983bf62e7 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -418,7 +418,7 @@ static int reserve_uboot(void) */ gd->relocaddr -= gd->mon_len; gd->relocaddr &= ~(4096 - 1); -#ifdef CONFIG_E500 +#if defined(CONFIG_E500) || defined(CONFIG_MIPS) /* round down to next 64 kB limit so that IVPR stays aligned */ gd->relocaddr &= ~(65536 - 1); #endif diff --git a/tools/.gitignore b/tools/.gitignore index 6ec71f5c7f..ac0c979319 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -11,6 +11,7 @@ /img2srec /kwboot /dumpimage +/mips-relocs /mkenvimage /mkimage /mkexynosspl diff --git a/tools/Makefile b/tools/Makefile index cb1683e153..56098e6943 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -209,6 +209,8 @@ hostprogs-$(CONFIG_STATIC_RELA) += relocate-rela hostprogs-y += fdtgrep fdtgrep-objs += $(LIBFDT_OBJS) fdtgrep.o
there is a regression on qemu_mips when started with Qemu. The code execution hangs in an endless loop and doesn't reach the console prompt.
I could debug it to following location:
int bootm_find_images(int flag, int argc, char * const argv[]) { int ret;
/* find ramdisk */ ret = boot_get_ramdisk(argc, argv, &images, IH_INITRD_ARCH, &images.rd_start, &images.rd_end); if (ret) { puts("Ramdisk image is corrupt or invalid\n"); return 1; } ... }
The code flow goes into the "if (ret)" branch. At the "return 1" the $ra register contains the address of bootm_find_images(). Thus the code is executed in an endless loop. I don't know yet if that's a miscalculated relocation or a stack overflow (maybe due to the changed 64KiB alignment of the U-Boot relocation address) because $ra in bootm_find_images() is loaded from stack:
bfc08f1c <bootm_find_images>: bfc08f1c: 3c02bfc3 lui v0,0xbfc3 bfc08f20: 27bdffe0 addiu sp,sp,-32 ... bfc08f6c: 8fbf001c lw ra,28(sp) bfc08f70: 00601025 move v0,v1 bfc08f74: 03e00008 jr ra bfc08f78: 27bd0020 addiu sp,sp,32
This regression leads to broken pytest for qemu_mips and therefore to failing Travis CI [1]. I used the kernel.org MIPS toolchain with gcc-4.9 (same as in Travis CI). Could you please have a look?
[1] https://travis-ci.org/danielschwierzeck/u-boot/jobs/243667863
Hi Daniel,
calls are indirected through the GOT & the t9 register: 8f998064 lw t9,-32668(gp) 0320f809 jalr t9
Without -fpic the call is simply: 0f803f01 jal be00fc04 <puts>
sequence to calculate the value of the gp register, for example: 3c1c0004 lui gp,0x4 279c3384 addiu gp,gp,13188 0399e021 addu gp,gp,t9
This was due to an R_MIPS_26 relocation applied to a j instruction in show_board_info, which overflowed into the opcode field & changed the j into a jal.
v3 should fix it.
Thanks, Paul
Changes in v3: - Fix R_MIPS_26 case that was breaking qemu_mips_defconfig.
arch/mips/Makefile.postlink | 23 +++ arch/mips/config.mk | 21 +- arch/mips/cpu/start.S | 130 ------------ arch/mips/cpu/u-boot.lds | 41 +--- arch/mips/include/asm/relocs.h | 24 +++ arch/mips/include/asm/sections.h | 7 + arch/mips/lib/Makefile | 1 + arch/mips/lib/reloc.c | 164 +++++++++++++++ common/board_f.c | 2 +- tools/.gitignore | 1 + tools/Makefile | 2 + tools/mips-relocs.c | 426 +++++++++++++++++++++++++++++++++++++++ 12 files changed, 663 insertions(+), 179 deletions(-) create mode 100644 arch/mips/Makefile.postlink create mode 100644 arch/mips/include/asm/relocs.h create mode 100644 arch/mips/lib/reloc.c create mode 100644 tools/mips-relocs.c
_end = .;
diff --git a/arch/mips/lib/reloc.c b/arch/mips/lib/reloc.c new file mode 100644 index 0000000000..d0c52c9674 --- /dev/null +++ b/arch/mips/lib/reloc.c @@ -0,0 +1,164 @@ +/* + * MIPS Relocation + * + * Copyright (c) 2017 Imagination Technologies Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Relocation data, found in the .rel section, is generated by the mips-relocs + * tool & contains a record of all locations in the U-Boot binary that need to + * be fixed up during relocation. + * + * The data is a sequence of unsigned integers, which are of somewhat arbitrary + * size. This is achieved by encoding integers as a sequence of bytes, each of + * which contains 7 bits of data with the most significant bit indicating + * whether any further bytes need to be read. The least significant bits of the + * integer are found in the first byte - ie. it somewhat resembles little + * endian. + * + * Each pair of two integers represents a relocation that must be applied. The + * first integer represents the type of relocation as a standard ELF relocation + * type (ie. R_MIPS_*). The second integer represents the offset at which to + * apply the relocation, relative to the previous relocation or for the first + * relocation the start of the relocated .text section. + * + * The end of the relocation data is indicated when type R_MIPS_NONE (0) is + * read, at which point no further integers should be read. That is, the + * terminating R_MIPS_NONE reloc includes no offset. + */ + +#include <common.h> +#include <asm/relocs.h> +#include <asm/sections.h> + +/** + * read_uint() - Read an unsigned integer from the buffer + * @buf: pointer to a pointer to the reloc buffer + * + * Read one whole unsigned integer from the relocation data pointed to by @buf, + * advancing @buf past the bytes encoding the integer. + * + * Returns: the integer read from @buf + */ +static unsigned long read_uint(uint8_t **buf) +{ + unsigned long val = 0; + unsigned int shift = 0; + uint8_t new; + + do { + new = *(*buf)++; + val |= (new & 0x7f) << shift; + shift += 7; + } while (new & 0x80); + + return val; +} + +/** + * apply_reloc() - Apply a single relocation + * @type: the type of reloc (R_MIPS_*) + * @addr: the address that the reloc should be applied to + * @off: the relocation offset, ie. number of bytes we're moving U-Boot by + * + * Apply a single relocation of type @type at @addr. This function is + * intentionally simple, and does the bare minimum needed to fixup the + * relocated U-Boot - in particular, it does not check for overflows. + */ +static void apply_reloc(unsigned int type, void *addr, long off) +{ + uint32_t u32; + + switch (type) { + case R_MIPS_26: + u32 = *(uint32_t *)addr; + u32 = (u32 & GENMASK(31, 26)) | + ((u32 + (off >> 2)) & GENMASK(25, 0)); + *(uint32_t *)addr = u32; + break; + + case R_MIPS_32: + *(uint32_t *)addr += off; + break; + + case R_MIPS_64: + *(uint64_t *)addr += off; + break; + + case R_MIPS_HI16: + *(uint32_t *)addr += off >> 16; + break; + + default: + panic("Unhandled reloc type %u\n", type); + } +} + +/** + * relocate_code() - Relocate U-Boot, generally from flash to DDR + * @start_addr_sp: new stack pointer + * @new_gd: pointer to relocated global data + * @relocaddr: the address to relocate to + * + * Relocate U-Boot from its current location (generally in flash) to a new one + * (generally in DDR). This function will copy the U-Boot binary & apply + * relocations as necessary, then jump to board_init_r in the new build of + * U-Boot. As such, this function does not return. + */ +void relocate_code(ulong start_addr_sp, gd_t *new_gd, ulong relocaddr) +{ + unsigned long addr, length, bss_len; + uint8_t *buf, *bss_start; + unsigned int type; + long off; + + /* + * Ensure that we're relocating by an offset which is a multiple of + * 64KiB, ie. doesn't change the least significant 16 bits of any + * addresses. This allows us to discard R_MIPS_LO16 relocs, saving + * space in the U-Boot binary & complexity in handling them. + */ + off = relocaddr - (unsigned long)__text_start; + if (off & 0xffff) + panic("Mis-aligned relocation\n"); + + /* Copy U-Boot to RAM */ + length = __image_copy_end - __text_start; + memcpy((void *)relocaddr, __text_start, length); + + /* Now apply relocations to the copy in RAM */ + buf = __rel_start; + addr = relocaddr; + while (true) { + type = read_uint(&buf); + if (type == R_MIPS_NONE) + break; + + addr += read_uint(&buf) << 2; + apply_reloc(type, (void *)addr, off); + } + + /* Ensure the icache is coherent */ + flush_cache(relocaddr, length); + + /* Clear the .bss section */ + bss_start = (uint8_t *)((unsigned long)__bss_start + off); + bss_len = (unsigned long)&__bss_end - (unsigned long)__bss_start; + memset(bss_start, 0, bss_len); + + /* Jump to the relocated U-Boot */ + asm volatile( + "move $29, %0\n" + " move $4, %1\n" + " move $5, %2\n" + " move $31, $0\n" + " jr %3" + : /* no outputs */ + : "r"(start_addr_sp), + "r"(new_gd), + "r"(relocaddr), + "r"((unsigned long)board_init_r + off)); + + /* Since we jumped to the new U-Boot above, we won't get here */ + unreachable(); +} diff --git a/common/board_f.c b/common/board_f.c index 46e52849fb..5983bf62e7 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -418,7 +418,7 @@ static int reserve_uboot(void) */ gd->relocaddr -= gd->mon_len; gd->relocaddr &= ~(4096 - 1); -#ifdef CONFIG_E500 +#if defined(CONFIG_E500) || defined(CONFIG_MIPS) /* round down to next 64 kB limit so that IVPR stays aligned */ gd->relocaddr &= ~(65536 - 1); #endif diff --git a/tools/.gitignore b/tools/.gitignore index 6ec71f5c7f..ac0c979319 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -11,6 +11,7 @@ /img2srec /kwboot /dumpimage +/mips-relocs /mkenvimage /mkimage /mkexynosspl diff --git a/tools/Makefile b/tools/Makefile index cb1683e153..56098e6943 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -209,6 +209,8 @@ hostprogs-$(CONFIG_STATIC_RELA) += relocate-rela hostprogs-y += fdtgrep fdtgrep-objs += $(LIBFDT_OBJS) fdtgrep.o
Am 19.06.2017 um 20:53 schrieb Paul Burton:
Changes in v3:
Changes in v2:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Tested-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
applied to u-boot-mips/next, thanks.
I've been a bit busy lately and I couldn't test this until now, but I have to say that this commit breaks u-boot bmips support :(
BTW, I tried this on several bmips boards (one of them is a Netgear CG3100D, which uses u-boot.bin instead of u-boot.elf)
Do you have any idea on what could be hapenning?
Regards, Álvaro.
Changes in v3:
Changes in v2:
Am 30.07.2017 um 14:27 schrieb Álvaro Fernández Rojas:
maybe you need to specify "--emit-relocs" too when linking u-boot.elf from u-boot-elf.o. But u-boot-elf.o should already contain the correct .reloc section with the updated relocation entries so you don't need to rerun the reloc-tool on u-boot.elf.
I tried that and it doesn't work. However, I've just found out that if I remove the relocs call it boots again... https://gist.github.com/Noltari/ce3a6a9dda69e74caf7ba33c9c8ade9a
2017-07-30 18:04 GMT+02:00 Álvaro Fernández Rojas noltari@gmail.com:
I wonder how this can work. Even the u-boot.elf now contains position-dependent code so that an update of the relocation entries is required there too. Without the updated entries, U-Boot can't execute after jumping from relocate_code() to board_init_r(). Did you use a clean build if U-Boot?
Indeed - without the .rel section being generated by the mips-relocs tool I'd expect relocate_code() to either apply some bogus relocations or none at all (depending what's in the memory starting from __rel_start) and then, if it gets there at all, for the "relocated" U-Boot to fall over pretty quickly.
Fernandez - I don't suppose you're aware of an emulated version of any of the supported bmips systems? That would be an easy way for me to take a look. FYI the systems I use most (Boston & Malta) also use u-boot.bin or derivatives thereof & I'm sure the .rel section is copied across to it, so I doubt it has anything to do with binary formats.
Thanks, Paul
Hi Paul,
Is it possible that CFE is taking care of that? For what I've seen in old versions of CFE, it looks like it does some parsing of the .elf files: https://github.com/Noltari/cfe_bcm63xx/blob/master/cfe/cfe/main/cfe_ldr_elf.... "This program parses ELF executables and loads them into memory"
Nope, sorry but I've never emulated any bmips hardware...
Thanks, Paul
Regards, Álvaro.
Hi Daniel,
Yeah, I used a clean build of u-boot (upstream with just the patch mentioned before): https://gist.github.com/Noltari/ce3a6a9dda69e74caf7ba33c9c8ade9a#file-u-boot...
Regards, Álvaro.
Hi Daniel,
v3 should fix it.
it works now, thanks for fixing.
Are you aware of any changes regarding MIPS relocation in gcc-6.x and recent binutils or MIPS R6 which could cause other regressions? I still need to extend my Qemu test scripts with Boston and MIPS R6 and to get/build a gcc-6.x toolchain. Thus I can't verify this at the moment ;)
Hi Daniel,
Hi Daniel,
int ret;
if (ret) {
v3 should fix it.
I'm not aware of any, though I haven't tested with gcc 6 either.
MIPSr6 introduces a bunch of new PC-relative relocations, but since they're PC-relative we don't need to care about them & the mips-relocs tool simply ignores them. I did test both r2 & r6 Malta builds, along with varying combinations of big & little endian, 32 & 64 bit.
Thanks, Paul
On Thu, Jun 15, 2017 at 05:05:09PM -0700, Paul Burton wrote:
This commit allows an architecture to provide a Makefile.postlink whose u-boot target gets invoked after the u-boot ELF is linked. This will be of use for MIPS in a following commit.
This mirrors Linux commit fbe6e37dab97 ("kbuild: add arch specific post-link Makefile").
Signed-off-by: Paul Burton paul.burton@imgtec.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: u-boot@lists.denx.de
Makefile | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
participants (5)
Daniel Schwierzeck
Paul Burton
