[U-Boot] [PATCH V2] ARM: davinci: da850evm: Enable SPL_OF_CONTROL without PLATDATA
With the memory mapping giving us some more avialable RAM, this updates the da850-evm-u-boot.dtsi to include the serial port, SPI and Flash nodes along with some dependent nodes in the SPL dtb. This also removes the platform data initialization code for the serial port and SPI Flash.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Add BSS entries to omapl138_lcdk config file, untested as I have no hardware diff --git a/arch/arm/dts/da850-evm-u-boot.dtsi b/arch/arm/dts/da850-evm-u-boot.dtsi index ab1de77954..ab9368b9d3 100644 --- a/arch/arm/dts/da850-evm-u-boot.dtsi +++ b/arch/arm/dts/da850-evm-u-boot.dtsi @@ -6,6 +6,24 @@ * Copyright (C) Adam Ford */
+/ { + soc@1c00000 { + u-boot,dm-spl; + }; +}; + &flash { compatible = "m25p64", "spi-flash"; }; + +&mmc0 { + u-boot,dm-spl; +}; + +&serial2 { + u-boot,dm-spl; +}; + +&spi1 { + u-boot,dm-spl; +}; diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index b0b29b3887..e8ec553f99 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -49,33 +49,6 @@ DECLARE_GLOBAL_DATA_PTR;
#define CFG_MAC_ADDR_OFFSET (flash->size - SZ_64K)
-#ifdef CONFIG_SPL_BUILD -#include <ns16550.h> -#include <dm/platform_data/spi_davinci.h> - -static const struct ns16550_platdata da850evm_serial = { - .base = DAVINCI_UART2_BASE, - .reg_shift = 2, - .clock = 150000000, - .fcr = UART_FCR_DEFVAL, -}; - -U_BOOT_DEVICE(da850evm_uart) = { - .name = "ns16550_serial", - .platdata = &da850evm_serial, -}; - -static const struct davinci_spi_platdata davinci_spi_data = { - .regs = (struct davinci_spi_regs *)0x01f0e000, - .num_cs = 4, -}; - -U_BOOT_DEVICE(davinci_spi) = { - .name = "davinci_spi", - .platdata = &davinci_spi_data, -}; -#endif - #ifdef CONFIG_MAC_ADDR_IN_SPIFLASH static int get_mac_addr(u8 *addr) { diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 41dae05fb9..4b09ba10a6 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 CONFIG_TARGET_DA850EVM=y @@ -13,6 +14,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_BOOTDELAY=3 +CONFIG_DEFAULT_FDT_FILE="da850-evm.dtb" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set @@ -20,6 +22,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " @@ -39,10 +42,11 @@ CONFIG_CMD_DIAG=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" -CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 48b7c2a97a..af5ba813c2 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 CONFIG_TARGET_DA850EVM=y @@ -12,12 +13,14 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_BOOTDELAY=3 +CONFIG_DEFAULT_FDT_FILE="da850-evm.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y @@ -37,13 +40,15 @@ CONFIG_CMD_DIAG=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" -CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y +CONFIG_DM_MMC=y CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 2002444e42..e592df1aea 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -43,6 +43,9 @@ #define PHYS_SDRAM_1_SIZE (128 << 20) /* SDRAM size 128MB */ #define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* max size from SPRS586*/
+#define CONFIG_SPL_BSS_START_ADDR DAVINCI_DDR_EMIF_DATA_BASE +#define CONFIG_SPL_BSS_MAX_SIZE 0x1080000 + /* memtest start addr */ #define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM_1 + 0x2000000)
Adam Ford
