[PATCH] Revert "clk: Detect failure to set defaults"
This reverts commit 92f1e9a4b31c0bf0f4f61ab823a6a88657323646. The aforementioned patch causes massive breakage on all platforms which have 'assigned-clock' DT property in their DT which references any clock that are not supported by the platform clock driver. That can easily happen either in SPL, or because the clock driver is reduced. Currently it seems all iMX8M are affected and fail to boot altogether.
Signed-off-by: Marek Vasut marex@denx.de Cc: Peng Fan peng.fan@oss.nxp.com Cc: Simon Glass sjg@chromium.org --- drivers/clk/clk-uclass.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index f2d26427543..094b1abf13c 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -846,17 +846,13 @@ void devm_clk_put(struct udevice *dev, struct clk *clk)
int clk_uclass_post_probe(struct udevice *dev) { - int ret; - /* * when a clock provider is probed. Call clk_set_defaults() * also after the device is probed. This takes care of cases * where the DT is used to setup default parents and rates * using assigned-clocks */ - ret = clk_set_defaults(dev, CLK_DEFAULTS_POST); - if (ret) - return log_ret(ret); + clk_set_defaults(dev, CLK_DEFAULTS_POST);
return 0; }
Hi Marek,
Please CC clock maintainers for future patches.
- int ret;
- when a clock provider is probed. Call clk_set_defaults()
- also after the device is probed. This takes care of cases
- where the DT is used to setup default parents and rates
- using assigned-clocks
- if (ret)
return 0; }
See [1] for previous discussion. For more background,
- Device trees for i.MX are sync'd with Linux. - General clock assignments may live in the clock-controller node, including those which U-Boot does not implement, but which Linux does. It's OK to not set up these clocks, but U-Boot doesn't know that and fails.
We don't necessarily need to revert this commit, but we do need a way to say "it's OK not to set the defaults, since we can function without them". Tom suggested doing this in the clock driver last time. I think a Kconfig or a device tree property would work, perhaps something like 'u-boot,clock-defaults-optional'.
--Sean
[1] https://lore.kernel.org/u-boot/20211029012801.15193-1-peng.fan@oss.nxp.com/
On 1/1/22 22:41, Sean Anderson wrote:
Hi Marek,
btw. I'm surprised the commit 92f1e9a4b31c0bf0f4f61ab823a6a88657323646 has zero reviews/acks from clock maintainers.
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index f2d26427543..094b1abf13c 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -846,17 +846,13 @@ void devm_clk_put(struct udevice *dev, struct clk *clk) int clk_uclass_post_probe(struct udevice *dev) { - int ret;
/* * when a clock provider is probed. Call clk_set_defaults() * also after the device is probed. This takes care of cases * where the DT is used to setup default parents and rates * using assigned-clocks */ - ret = clk_set_defaults(dev, CLK_DEFAULTS_POST); - if (ret) - return log_ret(ret); + clk_set_defaults(dev, CLK_DEFAULTS_POST); return 0; }
clock assignments can be anywhere, even in non-clock-controller nodes.
We didn't need custom DT properties before, Linux doesn't need them either, so that approach seems wrong.
If the clock driver could say "skip unimplemented clock, because I don't implement them and that is OK", that sounds like the right approach.
Unless the 2022.01 release should be completely broken for a lot of platforms, I would propose we revert the clock uclass patch now and re-add it right after the release, so we would not roll out a completely broken release and would have more time to fix this properly.
Hi Marek,
It'll be no more broken than v2021.10 was for whatever platforms have problems here, yes? Since that's what has the problematic commit.
Hi Marek,
So it seems. Does that mean we are OK with releasing such a broken release, even though there is an easy way to improve the situation ?
Hi Marek,
I will defer to the clock maintainer who I see agrees with your patch. I was just noting that we'd already shipped one release so a last minute revert is not something I'm happy about either.
Hi Marek,
- int ret;
- if (ret)
- clk_set_defaults(dev, CLK_DEFAULTS_POST); return 0; }
I'll just note that we should not be ignoring errors. It makes things very hard to debug. The root cause of this issue, IMO, is that the clock subsystem started ignoring errors. People relied on that and then it was hard to put the cat back in the bag.
But we should put the cat back in the bag and use a DT property to indicate that the defaults are advisory only, for the case where the U-Boot driver does not support a clock.
So long we we can undo this patch immediately after the release, you can add my: Reviewed-by: Simon Glass sjg@chromium.org
Hi Tom,
Do you want me to send a PR for this or can you pick it up directly?
--Sean
This one has already been applied: https://source.denx.de/u-boot/u-boot/-/commit/75f080df46f28f24a617652c8af028...
Hi Marek,
At the time, I reviewed it. However, I was also not a clock maintainer at that point, and my RB was not picked up when Simon sent v2.
Ultimately the original problem was that errors when assigning clocks automatically were generally not reported. The only way to detect them was to verify that the clocks were configured correctly after the fact. My attempt to address this was [2].
[1] https://lore.kernel.org/u-boot/e9eea30a-970b-7d70-267f-520071b483f1@gmail.co... [2] https://lore.kernel.org/u-boot/20210409021313.433558-2-seanga2@gmail.com/
- int ret;
- if (ret)
Sure, but since those assignments are made only when the device is probed, it is generally safe to assume that they are necessary for the device to function. This is opposed to assignments in the clock node, which may be OK to ignore (as long as the system functions properly).
I agree with Marek here. We knew this broke boards before v2021.10 was released, but it was not reverted for that release. We should not make the same mistake again. Reviewed-by: Sean Anderson seanga2@gmail.com
[3] https://lore.kernel.org/u-boot/dbde2b83044ce9f3e8c360e9ddce0fa8db16f8ef.came...
Hi Marek,
Reviewed-by: Fabio Estevam festevam@gmail.com
Signed-off-by: Marek Vasut marex@denx.de Cc: Peng Fan peng.fan@oss.nxp.com Cc: Simon Glass sjg@chromium.org Reviewed-by: Sean Anderson seanga2@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
participants (5)
Fabio Estevam
Sean Anderson
