[U-Boot] Pull request: u-boot-rockchip-20190828
Hi Tom,
Please pull the rockchip update: - Fix efuse read data number for rk3399 - make_fit_atf.py: fix .its generation for a single atf image
Travis: https://travis-ci.org/keveryang/u-boot/builds/590954707
Thanks, - Kever
The following changes since commit dfd590075ca263d6b3ed22465a94d33a8ee93e07:
Merge tag 'efi-2019-10-rc5' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi (2019-09-26 17:22:22 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20190928
for you to fetch changes up to d46b548290042a248216cbaed99964dc77a26bf4:
rockchip: make_fit_atf.py: fix .its generation for a single atf image (2019-09-28 22:26:32 +0800)
---------------------------------------------------------------- Heiko Stuebner (2): rockchip: misc: read the correct number of bytes from the efuse rockchip: make_fit_atf.py: fix .its generation for a single atf image
arch/arm/mach-rockchip/make_fit_atf.py | 4 ++-- arch/arm/mach-rockchip/misc.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
On Sun, Sep 29, 2019 at 02:50:54PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
