[PATCH V2] nvme: Fix cache alignment
The various structures in the driver are already correctly padded and cache aligned in memory, however the cache operations are called on the structure sizes, which themselves might not be cache aligned. Add the necessary rounding to fix this, which permits the nvme to work on arm64.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Bin Meng bmeng.cn@gmail.com --- V2: Fix typo in the bugfix description --- drivers/nvme/nvme.c | 50 +++++++++++++++++++++++++++++---------------- 1 file changed, 32 insertions(+), 18 deletions(-)
diff --git a/drivers/nvme/nvme.c b/drivers/nvme/nvme.c index 5d6331ad34..758415a53b 100644 --- a/drivers/nvme/nvme.c +++ b/drivers/nvme/nvme.c @@ -53,6 +53,27 @@ struct nvme_queue { unsigned long cmdid_data[]; };
+static void nvme_align_dcache_range(void *start, unsigned long size, + unsigned long *s, unsigned long *e) +{ + *s = rounddown((uintptr_t)start, ARCH_DMA_MINALIGN); + *e = roundup((uintptr_t)start + size, ARCH_DMA_MINALIGN); +} + +static void nvme_flush_dcache_range(void *start, unsigned long size) +{ + unsigned long s, e; + nvme_align_dcache_range(start, size, &s, &e); + flush_dcache_range(s, e); +} + +static void nvme_invalidate_dcache_range(void *start, unsigned long size) +{ + unsigned long s, e; + nvme_align_dcache_range(start, size, &s, &e); + invalidate_dcache_range(s, e); +} + static int nvme_wait_ready(struct nvme_dev *dev, bool enabled) { u32 bit = enabled ? NVME_CSTS_RDY : 0; @@ -129,8 +150,7 @@ static int nvme_setup_prps(struct nvme_dev *dev, u64 *prp2, } *prp2 = (ulong)dev->prp_pool;
- flush_dcache_range((ulong)dev->prp_pool, (ulong)dev->prp_pool + - dev->prp_entry_num * sizeof(u64)); + nvme_flush_dcache_range(dev->prp_pool, dev->prp_entry_num * sizeof(u64));
return 0; } @@ -144,10 +164,8 @@ static __le16 nvme_get_cmd_id(void)
static u16 nvme_read_completion_status(struct nvme_queue *nvmeq, u16 index) { - u64 start = (ulong)&nvmeq->cqes[index]; - u64 stop = start + sizeof(struct nvme_completion); - - invalidate_dcache_range(start, stop); + nvme_invalidate_dcache_range(&nvmeq->cqes[index], + sizeof(struct nvme_completion));
return le16_to_cpu(readw(&(nvmeq->cqes[index].status))); } @@ -163,8 +181,7 @@ static void nvme_submit_cmd(struct nvme_queue *nvmeq, struct nvme_command *cmd) u16 tail = nvmeq->sq_tail;
memcpy(&nvmeq->sq_cmds[tail], cmd, sizeof(*cmd)); - flush_dcache_range((ulong)&nvmeq->sq_cmds[tail], - (ulong)&nvmeq->sq_cmds[tail] + sizeof(*cmd)); + nvme_flush_dcache_range(&nvmeq->sq_cmds[tail], sizeof(*cmd));
if (++tail == nvmeq->q_depth) tail = 0; @@ -338,8 +355,7 @@ static void nvme_init_queue(struct nvme_queue *nvmeq, u16 qid) nvmeq->cq_phase = 1; nvmeq->q_db = &dev->dbs[qid * 2 * dev->db_stride]; memset((void *)nvmeq->cqes, 0, NVME_CQ_SIZE(nvmeq->q_depth)); - flush_dcache_range((ulong)nvmeq->cqes, - (ulong)nvmeq->cqes + NVME_CQ_SIZE(nvmeq->q_depth)); + nvme_flush_dcache_range(nvmeq->cqes, NVME_CQ_SIZE(nvmeq->q_depth)); dev->online_queues++; }
@@ -466,13 +482,13 @@ int nvme_identify(struct nvme_dev *dev, unsigned nsid,
c.identify.cns = cpu_to_le32(cns);
- invalidate_dcache_range(dma_addr, - dma_addr + sizeof(struct nvme_id_ctrl)); + nvme_invalidate_dcache_range((void *)dma_addr, + sizeof(struct nvme_id_ctrl));
ret = nvme_submit_admin_cmd(dev, &c, NULL); if (!ret) - invalidate_dcache_range(dma_addr, - dma_addr + sizeof(struct nvme_id_ctrl)); + nvme_invalidate_dcache_range((void *)dma_addr, + sizeof(struct nvme_id_ctrl));
return ret; } @@ -729,8 +745,7 @@ static ulong nvme_blk_rw(struct udevice *udev, lbaint_t blknr, u16 lbas = 1 << (dev->max_transfer_shift - ns->lba_shift); u64 total_lbas = blkcnt;
- flush_dcache_range((unsigned long)buffer, - (unsigned long)buffer + total_len); + nvme_flush_dcache_range(buffer, total_len);
c.rw.opcode = read ? nvme_cmd_read : nvme_cmd_write; c.rw.flags = 0; @@ -767,8 +782,7 @@ static ulong nvme_blk_rw(struct udevice *udev, lbaint_t blknr, }
if (read) - invalidate_dcache_range((unsigned long)buffer, - (unsigned long)buffer + total_len); + nvme_invalidate_dcache_range(buffer, total_len);
return (total_len - temp_len) >> desc->log2blksz; }
Hi Marek,
Would you give a chance to test Andre's patch? http://patchwork.ozlabs.org/project/uboot/patch/20210208133154.12645-1-andre...
Cc some people who have looked at Andre's patch
Regards, Bin
On 2/16/21 2:00 AM, Bin Meng wrote:
Hi Marek,
I'll let you decide which patch to pick, thanks.
Bin Meng
