[PATCH v2 1/1] doc: man-page for tftpput
Provide a man-page for the tftpput command.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org --- v2: fix typos --- doc/usage/cmd/tftpput.rst | 69 +++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 70 insertions(+) create mode 100644 doc/usage/cmd/tftpput.rst
diff --git a/doc/usage/cmd/tftpput.rst b/doc/usage/cmd/tftpput.rst new file mode 100644 index 0000000000..c14df86628 --- /dev/null +++ b/doc/usage/cmd/tftpput.rst @@ -0,0 +1,69 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +tftpput command +=============== + +Synopsis +-------- + +:: + + tftpput address size [[hostIPaddr:]filename] + +Decription +---------- + +The tftpput command is used to transfer a file to a TFTP server. + +address + memory address where the data starts + +size + number of bytes to be transferred + +hostIPaddr + IP address of the TFTP server, defaults to $serverip + +filename + path of the file to be written. If not provided, the client's IP address is + used to construct a default file name, e.g. C0.A8.00.28.img for IP address + 192.168.0.40. + +Example +------- + +In the example the following steps are executed: + +* setup client network address +* load a file from the SD-card +* send the file via TFTP to a server + +:: + + => setenv autoload no + => dhcp + BOOTP broadcast 1 + DHCP client bound to address 192.168.1.40 (7 ms) + => load mmc 0:1 $loadaddr test.txt + 260096 bytes read in 13 ms (19.1 MiB/s) + => tftpput $loadaddr $filesize 192.168.1.3:upload/test.txt + Using ethernet@1c30000 device + TFTP to server 192.168.1.3; our IP address is 192.168.1.40 + Filename 'upload/test.txt'. + Save address: 0x42000000 + Save size: 0x3f800 + Saving: ################# + 4.4 MiB/s + done + Bytes transferred = 260096 (3f800 hex) + => + +Configuration +------------- + +The command is only available if CONFIG_CMD_TFTPPUT=y. + +Return value +------------ + +The return value $? is 0 (true) on success and 1 (false) otherwise. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 28f9683a3e..f1beeec59c 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -63,6 +63,7 @@ Shell commands cmd/scp03 cmd/setexpr cmd/size + cmd/tftpput cmd/true cmd/ums cmd/wdt
