[Rock Pi 4+] Mainline LPDDR4 RAM initialisation is not sufficient to boot successfully
Good afternoon,
There appear to be a number of issues with the Rockchip rk3399 DDR RAM initialisation sequence in Mainline. Specifically, I'm seeing consistent failures on the Rock Pi 4+ during early boot. A typical failure looks something like this:
U-Boot TPL 2022.07-rc3-00005-g1b04a961c6 (May 25 2022 - 11:09:19) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: col error Cap error! 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM...
Even when the system boots to a terminal, which happens very infrequently, the LPDDR4 RAM chip at Channel 1 can have conflicting discovery information printed during TPL. The following 3 lines were printed during successive reboots using the same SD card with no changes:
# Boot 1: BW=32 Col=9 Bk=4 CS0 Row=16/15 CS=1 Die BW=16 Size=384MB
# Boot 2: BW=32 Col=10 Bk=4 CS0 Row=16/15 CS=1 Die BW=16 Size=768MB
# Boot 3: BW=32 Col=10 Bk=4 CS0 Row=15 CS=1 Die BW=16 Size=512MB
The story changes when I build the idbloader.img image with Rockchip's TBL (?) binary blob [0]. With that built in, presumably in place of the upstream TBL, both RAM chips are successfully enumerated and boot succeeds with 100% success rate:
tools/mkimage -n rk3399 -T rksd -d \ rk3399_ddr_933MHz_v1.25.bin:spl/u-boot-spl.bin idbloader.img
Another thing that is very different between the 2 is the initial frequency the LPDDR4 chips are clocked at. Using the upstream TBL version, the default is 50Mhz, which seems very low. If using the Rockchip supplied binary blob file, this is increased to a respectable 416MHz:
# Mainline Channel 0: LPDDR4, 50MHz
# Rockchip TBL blob Channel 0: LPDDR4,416MHz
One thing I did try was to load in the 400Mhz configuration settings from drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc as the default initial values, instead of the 50MHz default taken from arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi, but this failed in a number of ways:
Setting clock: Freq: 400MHz (400000000) Calling SDRAM init: 2 Channels Starting SDRAM initialization... mr5:0 mr12:0 mr14:0 Training failed for rank 2, ch 0 (ret: -22) mr5:0 mr12:0 mr14:0 Training failed for rank 1, ch 0 (ret: -22) mr5:0 mr12:0 mr14:0 Training failed for rank 2, ch 1 (ret: -22) mr5:0 mr12:0 mr14:0 Training failed for rank 1, ch 1 (ret: -22) Rank for Channel 1 is 0x0 Rank for Channel 0 is 0x0 Rank for Channel 1 is 0x0 sdram_init: LPDDR4 - 400MHz failed! rk3399_dmc_init DRAM init failed -22
So my question is; does Rockchip, or anyone else for that matter, have any plans on updating Mainline U-Boot with the upgraded/working LPDDR4 initialisation sequence?
As ever, any information / help would be gratefully received.
NB: If I have missed any critical people out from this discussion, please feel free to loop as many of them in as you see fit.
Kind regards, Lee
[0] https://github.com/rockchip-linux/rkbin/blob/master/bin/rk33/rk3399_ddr_933M...
On Wed, 25 May 2022, Lee Jones wrote:
Good afternoon,
Can anyone from Rockchip help with this please?
What does the binary blob [0] do differently to the U-boot implementation.
Are you able to publish the source for the DDR binary blob?
Please help me fix U-boot.
Kind regards, Lee
Could you help us to get the DRAM part number which initialization failures on the Rock Pi 4+. We have found that some LPDDR4 abnormal operation at 50MHz. I think you can try that use 400MHz to detect capacity.
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index c0a06dcaed..810f9a98c9 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -2538,24 +2538,42 @@ static int lpddr4_set_ctl(struct dram_info *dram, return 0; }
-static int lpddr4_set_rate(struct dram_info *dram, +static int lpddr4_set_rate_0(struct dram_info *dram, struct rk3399_sdram_params *params) { - u32 ctl_fn; + u32 ctl_fn = 0; u32 phy_fn;
- for (ctl_fn = 0; ctl_fn < 2; ctl_fn++) { - phy_fn = lpddr4_get_phy_fn(params, ctl_fn); + phy_fn = lpddr4_get_phy_fn(params, ctl_fn);
- lpddr4_set_phy(dram, params, phy_fn, &dfs_cfgs_lpddr4[ctl_fn]); - lpddr4_set_ctl(dram, params, ctl_fn, - dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq); + lpddr4_set_phy(dram, params, phy_fn, &dfs_cfgs_lpddr4[ctl_fn]); + lpddr4_set_ctl(dram, params, ctl_fn, + dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq);
- if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) - printf("%s: change freq to %d mhz %d, %d\n", __func__, - dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq, - ctl_fn, phy_fn); - } + if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) + printf("%s: change freq to %d mhz %d, %d\n", __func__, + dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq, + ctl_fn, phy_fn); + + return 0; +} + +static int lpddr4_set_rate_1(struct dram_info *dram, + struct rk3399_sdram_params *params) +{ + u32 ctl_fn = 1; + u32 phy_fn; + + phy_fn = lpddr4_get_phy_fn(params, ctl_fn); + + lpddr4_set_phy(dram, params, phy_fn, &dfs_cfgs_lpddr4[ctl_fn]); + lpddr4_set_ctl(dram, params, ctl_fn, + dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq); + + if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) + printf("%s: change freq to %d mhz %d, %d\n", __func__, + dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq, + ctl_fn, phy_fn);
return 0; } @@ -2955,6 +2973,11 @@ static int sdram_init(struct dram_info *dram, params->ch[ch].cap_info.rank = rank; }
+ #if defined(CONFIG_RAM_RK3399_LPDDR4) + lpddr4_set_rate_0(dram, params); + params->base.ddr_freq = dfs_cfgs_lpddr4[0].base.ddr_freq / MHz; + #endif + params->base.num_channels = 0; for (channel = 0; channel < 2; channel++) { const struct chan_info *chan = &dram->chan[channel]; @@ -3058,7 +3081,7 @@ static const struct sdram_rk3399_ops rk3399_ops = { .get_phy_index_params = get_phy_index_params, #else .data_training_first = lpddr4_mr_detect, - .set_rate_index = lpddr4_set_rate, + .set_rate_index = lpddr4_set_rate_1, .modify_param = lpddr4_modify_param, .get_phy_index_params = lpddr4_get_phy_index_params, #endif
From: Lee Jones Date: 2022-06-17 03:15 To: u-boot; linux-rockchip CC: wxt; kever.yang; zhangqing; derrick.huang; chenjh; hisping.lin; typ; cwz; chenfen; jagan; sjg; cym; pgwipeout; adelva; rammuthiah Subject: Re: [Rock Pi 4+] Mainline LPDDR4 RAM initialisation is not sufficient to boot successfully On Wed, 25 May 2022, Lee Jones wrote:
Good afternoon,
Kind regards, Lee
I have tested 3 boards; one appears to be fully working, on another 1 of the 2 LPDDR4 (Channel 1) chips consistently fails with a Col and Cap Error and on the final one both chips (Channel 0 & 1) fail in the same way as the last (Col and Cap errors).
All chips are: H9HCNNNBKUML
Wonderful. This solves the problem. Thank you so much!
Would you like to submit this into upstream U-boot yourself, or would you like me to do that for you?
If the former, please Cc me on the patch and add my:
Tested-by Lee Jones lee.jones@linaro.org
If the latter, please let me know and I'll do what I can to help.
cym@rock-chips.com
Lee Jones
