[PATCH] arm64: zynqmp: Remove unused snps,refclk_fladj property
The commit c55ac51a550c ("usb: dwc3: Program GFLADJ") hopefully fixed issues around fladj logic. This DT property was used in Xilinx stack only that's why remove because it is not needed anymore.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp.dtsi | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 34504a8cbb92..0a06c73390b2 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -870,7 +870,6 @@ interrupts = <0 65 4>, <0 69 4>, <0 75 4>; iommus = <&smmu 0x860>; snps,quirk-frame-length-adjustment = <0x20>; - snps,refclk_fladj; clock-names = "ref"; snps,enable_guctl1_resume_quirk; snps,enable_guctl1_ipd_quirk; @@ -902,7 +901,6 @@ interrupts = <0 70 4>, <0 74 4>, <0 76 4>; iommus = <&smmu 0x861>; snps,quirk-frame-length-adjustment = <0x20>; - snps,refclk_fladj; clock-names = "ref"; snps,enable_guctl1_resume_quirk; snps,enable_guctl1_ipd_quirk;
Applied. M
Michal Simek
