[U-Boot] [PATCH 3/9 v3] mmc: Add Marvell Xenon SDHCI controller driver
This driver implementes platform specific code for the Xenon SDHCI controller which is integrated in the Marvell MVEBU Armada 37xx and Armada 7k / 8K SoCs.
History: This driver is ported from the Marvell U-Boot version 2015.01 which is written by Victor Gu xigu@marvell.com with minor changes ported from the Linux driver which is written by Ziji Hu huziji@marvell.com.
Signed-off-by: Stefan Roese sr@denx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- v3: - Removed unreferenced macros - Used BIT(x) consistantly - Removed unreferenced "wait" variable from xenon_mmc_phy_init() - Used SLOT_MASK(slot) instead of (1 << slot) - Moved init of host_caps and shifted it to the host struct - Removed "enable" parameter from multiple functions and made them a disable or enable function instead - Used strncmp instead of strcmp
v2: - Renamed MMC_XENON_SDHCI to MMC_SDHCI_XENON as requested by Masahiro for the new consistant MMC naming
drivers/mmc/Kconfig | 11 + drivers/mmc/Makefile | 1 + drivers/mmc/xenon_sdhci.c | 589 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 601 insertions(+) create mode 100644 drivers/mmc/xenon_sdhci.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 9ed8da39ef..147e52d332 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -287,6 +287,17 @@ config MMC_SDHCI_SPEAR
If unsure, say N.
+config MMC_SDHCI_XENON + bool "SDHCI support for the Xenon SDHCI controller" + depends on MMC_SDHCI && DM_MMC && OF_CONTROL + help + Support for Xenon SDHCI host controller on Marvell Armada 3700 + 7k/8k ARM SoCs platforms + + If you have a controller with this interface, say Y here. + + If unsure, say N. + config MMC_SDHCI_TEGRA bool "SDHCI platform support for the Tegra SD/MMC Controller" depends on TEGRA diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 4dca09c955..6af7f79ff8 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -68,6 +68,7 @@ obj-$(CONFIG_MMC_SDHCI_MV) += mv_sdhci.o obj-$(CONFIG_MMC_SDHCI_S5P) += s5p_sdhci.o obj-$(CONFIG_MMC_SDHCI_SPEAR) += spear_sdhci.o obj-$(CONFIG_MMC_SDHCI_TEGRA) += tegra_mmc.o +obj-$(CONFIG_MMC_SDHCI_XENON) += xenon_sdhci.o
obj-$(CONFIG_MMC_SUNXI) += sunxi_mmc.o obj-$(CONFIG_MMC_UNIPHIER) += uniphier-sd.o diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c new file mode 100644 index 0000000000..f36b482288 --- /dev/null +++ b/drivers/mmc/xenon_sdhci.c @@ -0,0 +1,589 @@ +/* + * Driver for Marvell SOC Platform Group Xenon SDHC as a platform device + * + * Copyright (C) 2016 Marvell, All Rights Reserved. + * + * Author: Victor Gu xigu@marvell.com + * Date: 2016-8-24 + * + * Included parts of the Linux driver version which was written by: + * Hu Ziji huziji@marvell.com + * + * Ported to from Marvell 2015.01 to mainline U-Boot 2017.01: + * Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <malloc.h> +#include <sdhci.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Register Offset of SD Host Controller SOCP self-defined register */ +#define SDHC_SYS_CFG_INFO 0x0104 +#define SLOT_TYPE_SDIO_SHIFT 24 +#define SLOT_TYPE_EMMC_MASK 0xFF +#define SLOT_TYPE_EMMC_SHIFT 16 +#define SLOT_TYPE_SD_SDIO_MMC_MASK 0xFF +#define SLOT_TYPE_SD_SDIO_MMC_SHIFT 8 +#define NR_SUPPORTED_SLOT_MASK 0x7 + +#define SDHC_SYS_OP_CTRL 0x0108 +#define AUTO_CLKGATE_DISABLE_MASK BIT(20) +#define SDCLK_IDLEOFF_ENABLE_SHIFT 8 +#define SLOT_ENABLE_SHIFT 0 + +#define SDHC_SYS_EXT_OP_CTRL 0x010C +#define MASK_CMD_CONFLICT_ERROR BIT(8) + +#define SDHC_SLOT_OP_STATUS_CTRL 0x0128 +#define DELAY_90_DEGREE_MASK_EMMC5 BIT(7) +#define DELAY_90_DEGREE_SHIFT_EMMC5 7 +#define EMMC_5_0_PHY_FIXED_DELAY_MASK 0x7F +#define EMMC_PHY_FIXED_DELAY_MASK 0xFF +#define EMMC_PHY_FIXED_DELAY_WINDOW_MIN (EMMC_PHY_FIXED_DELAY_MASK >> 3) +#define SDH_PHY_FIXED_DELAY_MASK 0x1FF +#define SDH_PHY_FIXED_DELAY_WINDOW_MIN (SDH_PHY_FIXED_DELAY_MASK >> 4) + +#define TUN_CONSECUTIVE_TIMES_SHIFT 16 +#define TUN_CONSECUTIVE_TIMES_MASK 0x7 +#define TUN_CONSECUTIVE_TIMES 0x4 +#define TUNING_STEP_SHIFT 12 +#define TUNING_STEP_MASK 0xF +#define TUNING_STEP_DIVIDER BIT(6) + +#define FORCE_SEL_INVERSE_CLK_SHIFT 11 + +#define SDHC_SLOT_FIFO_CTRL 0x012c + +#define SDHC_SLOT_EMMC_CTRL 0x0130 +#define ENABLE_DATA_STROBE BIT(24) +#define SET_EMMC_RSTN BIT(16) +#define DISABLE_RD_DATA_CRC BIT(14) +#define DISABLE_CRC_STAT_TOKEN BIT(13) +#define EMMC_VCCQ_MASK 0x3 +#define EMMC_VCCQ_1_8V 0x1 +#define EMMC_VCCQ_3_3V 0x3 + +#define SDHC_SLOT_RETUNING_REQ_CTRL 0x0144 +/* retuning compatible */ +#define RETUNING_COMPATIBLE 0x1 + +#define SDHC_SLOT_EXT_PRESENT_STATE 0x014C +#define LOCK_STATE 0x1 + +#define SDHC_SLOT_DLL_CUR_DLY_VAL 0x0150 + +/* Tuning Parameter */ +#define TMR_RETUN_NO_PRESENT 0xf +#define XENON_MAX_TUN_COUNT 0xb +#define DEF_TUNING_COUNT 0x9 + +#define MMC_TIMING_FAKE 0xFF + +#define DEFAULT_SDCLK_FREQ 400000 +#define LOWEST_SDCLK_FREQ 100000 + +/* Xenon specific Mode Select value */ +#define XENON_SDHCI_CTRL_HS200 0x5 +#define XENON_SDHCI_CTRL_HS400 0x6 + +#define EMMC_PHY_REG_BASE 0x170 +#define EMMC_PHY_TIMING_ADJUST EMMC_PHY_REG_BASE +#define OUTPUT_QSN_PHASE_SELECT (1 << 17) +#define SAMPL_INV_QSP_PHASE_SELECT (1 << 18) +#define SAMPL_INV_QSP_PHASE_SELECT_SHIFT 18 +#define EMMC_PHY_SLOW_MODE (1 << 29) +#define PHY_INITIALIZAION (1 << 31) +#define WAIT_CYCLE_BEFORE_USING_MASK 0xf +#define WAIT_CYCLE_BEFORE_USING_SHIFT 12 +#define FC_SYNC_EN_DURATION_MASK 0xf +#define FC_SYNC_EN_DURATION_SHIFT 8 +#define FC_SYNC_RST_EN_DURATION_MASK 0xf +#define FC_SYNC_RST_EN_DURATION_SHIFT 4 +#define FC_SYNC_RST_DURATION_MASK 0xf +#define FC_SYNC_RST_DURATION_SHIFT 0 + +#define EMMC_PHY_FUNC_CONTROL (EMMC_PHY_REG_BASE + 0x4) +#define DQ_ASYNC_MODE (1 << 4) +#define DQ_DDR_MODE_SHIFT 8 +#define DQ_DDR_MODE_MASK 0xff +#define CMD_DDR_MODE (1 << 16) + +#define EMMC_PHY_PAD_CONTROL (EMMC_PHY_REG_BASE + 0x8) +#define REC_EN_SHIFT 24 +#define REC_EN_MASK 0xf +#define FC_DQ_RECEN (1 << 24) +#define FC_CMD_RECEN (1 << 25) +#define FC_QSP_RECEN (1 << 26) +#define FC_QSN_RECEN (1 << 27) +#define OEN_QSN (1 << 28) +#define AUTO_RECEN_CTRL (1 << 30) + +#define EMMC_PHY_PAD_CONTROL1 (EMMC_PHY_REG_BASE + 0xc) +#define EMMC5_1_FC_QSP_PD BIT(9) +#define EMMC5_1_FC_QSP_PU BIT(25) +#define EMMC5_1_FC_CMD_PD BIT(8) +#define EMMC5_1_FC_CMD_PU BIT(24) +#define EMMC5_1_FC_DQ_PD 0xff +#define EMMC5_1_FC_DQ_PU (0xff << 16) + +#define EMMC_PHY_PAD_CONTROL2 (EMMC_PHY_REG_BASE + 0x10) +#define EMMC_PHY_DLL_CONTROL (EMMC_PHY_REG_BASE + 0x14) +#define DLL_DELAY_TEST_LOWER_SHIFT 8 +#define DLL_DELAY_TEST_LOWER_MASK 0xff +#define DLL_BYPASS_EN 0x1 + +#define EMMC_LOGIC_TIMING_ADJUST (EMMC_PHY_REG_BASE + 0x18) +#define EMMC_LOGIC_TIMING_ADJUST_LOW (EMMC_PHY_REG_BASE + 0x1c) + +/* Recommend by HW team */ +#define LOGIC_TIMING_VALUE 0x5a54 + +#define SDHCI_RETUNE_EVT_INTSIG 0x00001000 + +/* Hyperion only have one slot 0 */ +#define XENON_MMC_SLOT_ID_HYPERION 0 + +#define MMC_TIMING_LEGACY 0 +#define MMC_TIMING_MMC_HS 1 +#define MMC_TIMING_SD_HS 2 +#define MMC_TIMING_UHS_SDR12 3 +#define MMC_TIMING_UHS_SDR25 4 +#define MMC_TIMING_UHS_SDR50 5 +#define MMC_TIMING_UHS_SDR104 6 +#define MMC_TIMING_UHS_DDR50 7 +#define MMC_TIMING_MMC_DDR52 8 +#define MMC_TIMING_MMC_HS200 9 +#define MMC_TIMING_MMC_HS400 10 + +#define XENON_MMC_MAX_CLK 400000000 + +enum soc_pad_ctrl_type { + SOC_PAD_SD, + SOC_PAD_FIXED_1_8V, +}; + +struct xenon_sdhci_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +struct xenon_sdhci_priv { + struct sdhci_host host; + + u8 timing; + + unsigned int clock; + + void *pad_ctrl_reg; + int pad_type; +}; + +static int xenon_mmc_phy_init(struct sdhci_host *host) +{ + struct xenon_sdhci_priv *priv = host->mmc->priv; + u32 clock = priv->clock; + u32 wait; + u32 time; + u32 var; + + /* Enable QSP PHASE SELECT */ + var = sdhci_readl(host, EMMC_PHY_TIMING_ADJUST); + var |= SAMPL_INV_QSP_PHASE_SELECT; + if ((priv->timing == MMC_TIMING_UHS_SDR50) || + (priv->timing == MMC_TIMING_UHS_SDR25) || + (priv->timing == MMC_TIMING_UHS_SDR12) || + (priv->timing == MMC_TIMING_SD_HS) || + (priv->timing == MMC_TIMING_LEGACY)) + var |= EMMC_PHY_SLOW_MODE; + sdhci_writel(host, var, EMMC_PHY_TIMING_ADJUST); + + /* Poll for host MMC PHY clock init to be stable */ + /* Wait up to 10ms */ + time = 100; + while (time--) { + var = sdhci_readl(host, SDHCI_CLOCK_CONTROL); + if (var & SDHCI_CLOCK_INT_STABLE) + break; + + udelay(100); + } + + if (time <= 0) { + error("Failed to enable MMC internal clock in time\n"); + return -ETIMEDOUT; + } + + /* Init PHY */ + var = sdhci_readl(host, EMMC_PHY_TIMING_ADJUST); + var |= PHY_INITIALIZAION; + sdhci_writel(host, var, EMMC_PHY_TIMING_ADJUST); + + /* Add duration of FC_SYNC_RST */ + wait = (var >> FC_SYNC_RST_DURATION_SHIFT) & FC_SYNC_RST_DURATION_MASK; + /* Add interval between FC_SYNC_EN and FC_SYNC_RST */ + wait += (var >> FC_SYNC_RST_EN_DURATION_SHIFT) & + FC_SYNC_RST_EN_DURATION_MASK; + /* Add duration of asserting FC_SYNC_EN */ + wait += (var >> FC_SYNC_EN_DURATION_SHIFT) & FC_SYNC_EN_DURATION_MASK; + /* Add duration of waiting for PHY */ + wait += (var >> WAIT_CYCLE_BEFORE_USING_SHIFT) & + WAIT_CYCLE_BEFORE_USING_MASK; + /* + * According to Moyang, 4 addtional bus clock and 4 AXI bus clock + * are required + */ + /* left shift 20 bits */ + wait += 8; + wait <<= 20; + + if (clock == 0) { + /* Use the possibly slowest bus frequency value */ + clock = 100000; + } + + /* Get the wait time in unit of ms */ + wait = wait / clock; + wait++; + + /* Poll for host eMMC PHY init to complete */ + /* Wait up to 10ms */ + time = 100; + while (time--) { + var = sdhci_readl(host, EMMC_PHY_TIMING_ADJUST); + var &= PHY_INITIALIZAION; + if (!var) + break; + + /* wait for host eMMC PHY init to complete */ + udelay(100); + } + + if (time <= 0) { + error("Failed to init MMC PHY in time\n"); + return -ETIMEDOUT; + } + + return 0; +} + +#define ARMADA_3700_SOC_PAD_1_8V 0x1 +#define ARMADA_3700_SOC_PAD_3_3V 0x0 + +static void armada_3700_soc_pad_voltage_set(struct sdhci_host *host) +{ + struct xenon_sdhci_priv *priv = host->mmc->priv; + + if (priv->pad_type == SOC_PAD_FIXED_1_8V) + writel(ARMADA_3700_SOC_PAD_1_8V, priv->pad_ctrl_reg); + else if (priv->pad_type == SOC_PAD_SD) + writel(ARMADA_3700_SOC_PAD_3_3V, priv->pad_ctrl_reg); +} + +static void xenon_mmc_phy_set(struct sdhci_host *host) +{ + struct xenon_sdhci_priv *priv = host->mmc->priv; + u32 var; + + /* Setup pad, set bit[30], bit[28] and bits[26:24] */ + var = sdhci_readl(host, EMMC_PHY_PAD_CONTROL); + var |= AUTO_RECEN_CTRL | OEN_QSN | FC_QSP_RECEN | + FC_CMD_RECEN | FC_DQ_RECEN; + sdhci_writel(host, var, EMMC_PHY_PAD_CONTROL); + + /* Set CMD and DQ Pull Up */ + var = sdhci_readl(host, EMMC_PHY_PAD_CONTROL1); + var |= (EMMC5_1_FC_CMD_PU | EMMC5_1_FC_DQ_PU); + var &= ~(EMMC5_1_FC_CMD_PD | EMMC5_1_FC_DQ_PD); + sdhci_writel(host, var, EMMC_PHY_PAD_CONTROL1); + + /* + * If timing belongs to high speed, set bit[17] of + * EMMC_PHY_TIMING_ADJUST register + */ + if ((priv->timing == MMC_TIMING_MMC_HS400) || + (priv->timing == MMC_TIMING_MMC_HS200) || + (priv->timing == MMC_TIMING_UHS_SDR50) || + (priv->timing == MMC_TIMING_UHS_SDR104) || + (priv->timing == MMC_TIMING_UHS_DDR50) || + (priv->timing == MMC_TIMING_UHS_SDR25) || + (priv->timing == MMC_TIMING_MMC_DDR52)) { + var = sdhci_readl(host, EMMC_PHY_TIMING_ADJUST); + var |= OUTPUT_QSN_PHASE_SELECT; + sdhci_writel(host, var, EMMC_PHY_TIMING_ADJUST); + } + + /* + * When setting EMMC_PHY_FUNC_CONTROL register, + * SD clock should be disabled + */ + var = sdhci_readl(host, SDHCI_CLOCK_CONTROL); + var &= ~SDHCI_CLOCK_CARD_EN; + sdhci_writew(host, var, SDHCI_CLOCK_CONTROL); + + var = sdhci_readl(host, EMMC_PHY_FUNC_CONTROL); + if (host->mmc->ddr_mode) { + var |= (DQ_DDR_MODE_MASK << DQ_DDR_MODE_SHIFT) | CMD_DDR_MODE; + } else { + var &= ~((DQ_DDR_MODE_MASK << DQ_DDR_MODE_SHIFT) | + CMD_DDR_MODE); + } + sdhci_writel(host, var, EMMC_PHY_FUNC_CONTROL); + + /* Enable bus clock */ + var = sdhci_readl(host, SDHCI_CLOCK_CONTROL); + var |= SDHCI_CLOCK_CARD_EN; + sdhci_writew(host, var, SDHCI_CLOCK_CONTROL); + + xenon_mmc_phy_init(host); +} + +/* Enable/Disable the Auto Clock Gating function of this slot */ +static void xenon_mmc_set_acg(struct sdhci_host *host, bool enable) +{ + u32 var; + + var = sdhci_readl(host, SDHC_SYS_OP_CTRL); + if (enable) + var &= ~AUTO_CLKGATE_DISABLE_MASK; + else + var |= AUTO_CLKGATE_DISABLE_MASK; + + sdhci_writel(host, var, SDHC_SYS_OP_CTRL); +} + +/* Enable specific slot */ +static void xenon_mmc_set_slot(struct sdhci_host *host, u8 slot, bool enable) +{ + u32 var; + + var = sdhci_readl(host, SDHC_SYS_OP_CTRL); + if (enable) + var |= (0x1 << slot) << SLOT_ENABLE_SHIFT; + else + var &= ~((0x1 << slot) << SLOT_ENABLE_SHIFT); + sdhci_writel(host, var, SDHC_SYS_OP_CTRL); +} + +/* Enable Parallel Transfer Mode */ +static void xenon_mmc_set_parallel_tran(struct sdhci_host *host, u8 slot, + bool enable) +{ + u32 var; + + var = sdhci_readl(host, SDHC_SYS_EXT_OP_CTRL); + if (enable) + var |= (0x1 << slot); + else + var &= ~(0x1 << slot); + sdhci_writel(host, var, SDHC_SYS_EXT_OP_CTRL); +} + +static void xenon_mmc_set_tuning(struct sdhci_host *host, u8 slot, bool enable) +{ + u32 var; + + /* Set the Re-Tuning Request functionality */ + var = sdhci_readl(host, SDHC_SLOT_RETUNING_REQ_CTRL); + if (enable) + var |= RETUNING_COMPATIBLE; + else + var &= ~RETUNING_COMPATIBLE; + sdhci_writel(host, var, SDHC_SLOT_RETUNING_REQ_CTRL); + + /* Set the Re-tuning Event Signal Enable */ + var = sdhci_readl(host, SDHCI_SIGNAL_ENABLE); + if (enable) + var |= SDHCI_RETUNE_EVT_INTSIG; + else + var &= ~SDHCI_RETUNE_EVT_INTSIG; + sdhci_writel(host, var, SDHCI_SIGNAL_ENABLE); +} + +/* Mask command conflict error */ +static void xenon_mask_cmd_conflict_err(struct sdhci_host *host) +{ + u32 reg; + + reg = sdhci_readl(host, SDHC_SYS_EXT_OP_CTRL); + reg |= MASK_CMD_CONFLICT_ERROR; + sdhci_writel(host, reg, SDHC_SYS_EXT_OP_CTRL); +} + +/* Platform specific function for post set_ios configuration */ +static void xenon_sdhci_set_ios_post(struct sdhci_host *host) +{ + struct xenon_sdhci_priv *priv = host->mmc->priv; + uint speed = host->mmc->tran_speed; + int pwr_18v = 0; + + if ((sdhci_readb(host, SDHCI_POWER_CONTROL) & ~SDHCI_POWER_ON) == + SDHCI_POWER_180) + pwr_18v = 1; + + /* Set timing variable according to the configured speed */ + if (IS_SD(host->mmc)) { + /* SD/SDIO */ + if (pwr_18v) { + if (host->mmc->ddr_mode) + priv->timing = MMC_TIMING_UHS_DDR50; + else if (speed <= 25000000) + priv->timing = MMC_TIMING_UHS_SDR25; + else + priv->timing = MMC_TIMING_UHS_SDR50; + } else { + if (speed <= 25000000) + priv->timing = MMC_TIMING_LEGACY; + else + priv->timing = MMC_TIMING_SD_HS; + } + } else { + /* eMMC */ + if (host->mmc->ddr_mode) + priv->timing = MMC_TIMING_MMC_DDR52; + else if (speed <= 26000000) + priv->timing = MMC_TIMING_LEGACY; + else + priv->timing = MMC_TIMING_MMC_HS; + } + + /* Re-init the PHY */ + xenon_mmc_phy_set(host); +} + +/* Install a driver specific handler for post set_ios configuration */ +static const struct sdhci_ops xenon_sdhci_ops = { + .set_ios_post = xenon_sdhci_set_ios_post +}; + +static int xenon_sdhci_probe(struct udevice *dev) +{ + struct xenon_sdhci_plat *plat = dev_get_platdata(dev); + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct xenon_sdhci_priv *priv = dev_get_priv(dev); + struct sdhci_host *host = dev_get_priv(dev); + int ret; + + host->mmc = &plat->mmc; + host->mmc->priv = host; + host->mmc->dev = dev; + upriv->mmc = host->mmc; + + /* Set quirks */ + host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_32BIT_DMA_ADDR; + + /* Set default timing */ + priv->timing = MMC_TIMING_LEGACY; + + /* Disable auto clock gating during init */ + xenon_mmc_set_acg(host, false); + + /* Enable slot */ + xenon_mmc_set_slot(host, XENON_MMC_SLOT_ID_HYPERION, true); + + /* + * Set default power on SoC PHY PAD register (currently only + * available on the Armada 3700) + */ + if (priv->pad_ctrl_reg) + armada_3700_soc_pad_voltage_set(host); + + ret = sdhci_setup_cfg(&plat->cfg, host, XENON_MMC_MAX_CLK, 0); + if (ret) + return ret; + + plat->cfg.host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | + MMC_MODE_DDR_52MHz; + + switch (fdtdec_get_int(gd->fdt_blob, dev->of_offset, "bus-width", 1)) { + case 8: + plat->cfg.host_caps |= MMC_MODE_8BIT; + break; + case 4: + plat->cfg.host_caps |= MMC_MODE_4BIT; + break; + case 1: + break; + default: + printf("Invalid "bus-width" value\n"); + return -EINVAL; + } + + host->ops = &xenon_sdhci_ops; + + ret = sdhci_probe(dev); + if (ret) + return ret; + + /* Enable parallel transfer */ + xenon_mmc_set_parallel_tran(host, XENON_MMC_SLOT_ID_HYPERION, true); + + /* Disable tuning functionality of this slot */ + xenon_mmc_set_tuning(host, XENON_MMC_SLOT_ID_HYPERION, false); + + /* Enable auto clock gating after init */ + xenon_mmc_set_acg(host, true); + + xenon_mask_cmd_conflict_err(host); + + return ret; +} + +static int xenon_sdhci_ofdata_to_platdata(struct udevice *dev) +{ + struct sdhci_host *host = dev_get_priv(dev); + struct xenon_sdhci_priv *priv = dev_get_priv(dev); + const char *name; + + host->name = dev->name; + host->ioaddr = (void *)dev_get_addr(dev); + + if (of_device_is_compatible(dev, "marvell,armada-3700-sdhci")) + priv->pad_ctrl_reg = (void *)dev_get_addr_index(dev, 1); + + name = fdt_getprop(gd->fdt_blob, dev->of_offset, "marvell,pad-type", + NULL); + if (name) { + if (0 == strcmp(name, "sd")) { + priv->pad_type = SOC_PAD_SD; + } else if (0 == strcmp(name, "fixed-1-8v")) { + priv->pad_type = SOC_PAD_FIXED_1_8V; + } else { + printf("Unsupported SOC PHY PAD ctrl type %s\n", name); + return -EINVAL; + } + } + + return 0; +} + +static int xenon_sdhci_bind(struct udevice *dev) +{ + struct xenon_sdhci_plat *plat = dev_get_platdata(dev); + + return sdhci_bind(dev, &plat->mmc, &plat->cfg); +} + +static const struct udevice_id xenon_sdhci_ids[] = { + { .compatible = "marvell,armada-8k-sdhci",}, + { .compatible = "marvell,armada-3700-sdhci",}, + { } +}; + +U_BOOT_DRIVER(xenon_sdhci_drv) = { + .name = "xenon_sdhci", + .id = UCLASS_MMC, + .of_match = xenon_sdhci_ids, + .ofdata_to_platdata = xenon_sdhci_ofdata_to_platdata, + .ops = &sdhci_ops, + .bind = xenon_sdhci_bind, + .probe = xenon_sdhci_probe, + .priv_auto_alloc_size = sizeof(struct xenon_sdhci_priv), + .platdata_auto_alloc_size = sizeof(struct xenon_sdhci_plat), +};
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Beset Regards, Jaehoon Chung
v3:
v2:
If unsure, say N.
- bool "SDHCI support for the Xenon SDHCI controller"
- depends on MMC_SDHCI && DM_MMC && OF_CONTROL
- help
If unsure, say N.
- Driver for Marvell SOC Platform Group Xenon SDHC as a platform device
- Copyright (C) 2016 Marvell, All Rights Reserved.
- Author: Victor Gu xigu@marvell.com
- Date: 2016-8-24
- Included parts of the Linux driver version which was written by:
- Hu Ziji huziji@marvell.com
- Ported to from Marvell 2015.01 to mainline U-Boot 2017.01:
- Stefan Roese sr@denx.de
- SPDX-License-Identifier: GPL-2.0
- SOC_PAD_SD,
- SOC_PAD_FIXED_1_8V,
- struct mmc_config cfg;
- struct mmc mmc;
- struct sdhci_host host;
- u8 timing;
- unsigned int clock;
- void *pad_ctrl_reg;
- int pad_type;
- struct xenon_sdhci_priv *priv = host->mmc->priv;
- u32 clock = priv->clock;
- u32 wait;
- u32 time;
- u32 var;
- /* Enable QSP PHASE SELECT */
- var = sdhci_readl(host, EMMC_PHY_TIMING_ADJUST);
- var |= SAMPL_INV_QSP_PHASE_SELECT;
- if ((priv->timing == MMC_TIMING_UHS_SDR50) ||
- sdhci_writel(host, var, EMMC_PHY_TIMING_ADJUST);
- /* Poll for host MMC PHY clock init to be stable */
- /* Wait up to 10ms */
- time = 100;
- while (time--) {
break;
udelay(100);
- if (time <= 0) {
return -ETIMEDOUT;
- /* Init PHY */
- var |= PHY_INITIALIZAION;
- /* Add duration of FC_SYNC_RST */
- wait = (var >> FC_SYNC_RST_DURATION_SHIFT) & FC_SYNC_RST_DURATION_MASK;
- /* Add interval between FC_SYNC_EN and FC_SYNC_RST */
- wait += (var >> FC_SYNC_RST_EN_DURATION_SHIFT) &
- /* Add duration of asserting FC_SYNC_EN */
- wait += (var >> FC_SYNC_EN_DURATION_SHIFT) & FC_SYNC_EN_DURATION_MASK;
- /* Add duration of waiting for PHY */
- wait += (var >> WAIT_CYCLE_BEFORE_USING_SHIFT) &
* are required
- /* left shift 20 bits */
- wait += 8;
- wait <<= 20;
- if (clock == 0) {
clock = 100000;
- /* Get the wait time in unit of ms */
- wait = wait / clock;
- wait++;
- /* Poll for host eMMC PHY init to complete */
- time = 100;
- while (time--) {
if (!var)
break;
udelay(100);
- if (time <= 0) {
return -ETIMEDOUT;
- if (priv->pad_type == SOC_PAD_FIXED_1_8V)
- else if (priv->pad_type == SOC_PAD_SD)
- u32 var;
- /* Setup pad, set bit[30], bit[28] and bits[26:24] */
- var = sdhci_readl(host, EMMC_PHY_PAD_CONTROL);
- var |= AUTO_RECEN_CTRL | OEN_QSN | FC_QSP_RECEN |
- sdhci_writel(host, var, EMMC_PHY_PAD_CONTROL);
- /* Set CMD and DQ Pull Up */
- var = sdhci_readl(host, EMMC_PHY_PAD_CONTROL1);
- var |= (EMMC5_1_FC_CMD_PU | EMMC5_1_FC_DQ_PU);
- var &= ~(EMMC5_1_FC_CMD_PD | EMMC5_1_FC_DQ_PD);
- sdhci_writel(host, var, EMMC_PHY_PAD_CONTROL1);
- if ((priv->timing == MMC_TIMING_MMC_HS400) ||
- var = sdhci_readl(host, SDHCI_CLOCK_CONTROL);
- var &= ~SDHCI_CLOCK_CARD_EN;
- sdhci_writew(host, var, SDHCI_CLOCK_CONTROL);
- var = sdhci_readl(host, EMMC_PHY_FUNC_CONTROL);
- if (host->mmc->ddr_mode) {
- } else {
CMD_DDR_MODE);
- sdhci_writel(host, var, EMMC_PHY_FUNC_CONTROL);
- /* Enable bus clock */
- var |= SDHCI_CLOCK_CARD_EN;
- xenon_mmc_phy_init(host);
- u32 var;
- var = sdhci_readl(host, SDHC_SYS_OP_CTRL);
- if (enable)
- else
- sdhci_writel(host, var, SDHC_SYS_OP_CTRL);
- u32 var;
- if (enable)
- else
bool enable)
- u32 var;
- var = sdhci_readl(host, SDHC_SYS_EXT_OP_CTRL);
- if (enable)
- else
- sdhci_writel(host, var, SDHC_SYS_EXT_OP_CTRL);
- u32 var;
- /* Set the Re-Tuning Request functionality */
- var = sdhci_readl(host, SDHC_SLOT_RETUNING_REQ_CTRL);
- if (enable)
- else
- sdhci_writel(host, var, SDHC_SLOT_RETUNING_REQ_CTRL);
- /* Set the Re-tuning Event Signal Enable */
- var = sdhci_readl(host, SDHCI_SIGNAL_ENABLE);
- if (enable)
- else
- sdhci_writel(host, var, SDHCI_SIGNAL_ENABLE);
- u32 reg;
- reg = sdhci_readl(host, SDHC_SYS_EXT_OP_CTRL);
- reg |= MASK_CMD_CONFLICT_ERROR;
- sdhci_writel(host, reg, SDHC_SYS_EXT_OP_CTRL);
- uint speed = host->mmc->tran_speed;
- int pwr_18v = 0;
- if ((sdhci_readb(host, SDHCI_POWER_CONTROL) & ~SDHCI_POWER_ON) ==
SDHCI_POWER_180)
pwr_18v = 1;
- /* Set timing variable according to the configured speed */
- if (IS_SD(host->mmc)) {
/* SD/SDIO */
if (pwr_18v) {
else
} else {
else
- } else {
/* eMMC */
else
- /* Re-init the PHY */
- xenon_mmc_phy_set(host);
- .set_ios_post = xenon_sdhci_set_ios_post
- struct xenon_sdhci_plat *plat = dev_get_platdata(dev);
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct xenon_sdhci_priv *priv = dev_get_priv(dev);
- struct sdhci_host *host = dev_get_priv(dev);
- int ret;
- host->mmc = &plat->mmc;
- host->mmc->priv = host;
- host->mmc->dev = dev;
- upriv->mmc = host->mmc;
- /* Set quirks */
- host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_32BIT_DMA_ADDR;
- /* Set default timing */
- priv->timing = MMC_TIMING_LEGACY;
- /* Disable auto clock gating during init */
- xenon_mmc_set_acg(host, false);
- /* Enable slot */
- xenon_mmc_set_slot(host, XENON_MMC_SLOT_ID_HYPERION, true);
- if (priv->pad_ctrl_reg)
- ret = sdhci_setup_cfg(&plat->cfg, host, XENON_MMC_MAX_CLK, 0);
- if (ret)
return ret;
- plat->cfg.host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz |
MMC_MODE_DDR_52MHz;
- switch (fdtdec_get_int(gd->fdt_blob, dev->of_offset, "bus-width", 1)) {
- case 8:
break;
- case 4:
break;
- case 1:
break;
- default:
printf("Invalid \"bus-width\" value\n");
return -EINVAL;
- host->ops = &xenon_sdhci_ops;
- ret = sdhci_probe(dev);
- if (ret)
return ret;
- /* Enable parallel transfer */
- xenon_mmc_set_parallel_tran(host, XENON_MMC_SLOT_ID_HYPERION, true);
- /* Disable tuning functionality of this slot */
- xenon_mmc_set_tuning(host, XENON_MMC_SLOT_ID_HYPERION, false);
- /* Enable auto clock gating after init */
- xenon_mmc_set_acg(host, true);
- xenon_mask_cmd_conflict_err(host);
- return ret;
- const char *name;
- host->name = dev->name;
- host->ioaddr = (void *)dev_get_addr(dev);
- if (of_device_is_compatible(dev, "marvell,armada-3700-sdhci"))
- name = fdt_getprop(gd->fdt_blob, dev->of_offset, "marvell,pad-type",
NULL);
- if (name) {
} else {
return -EINVAL;
- return sdhci_bind(dev, &plat->mmc, &plat->cfg);
- { .compatible = "marvell,armada-8k-sdhci",},
- { .compatible = "marvell,armada-3700-sdhci",},
- .name = "xenon_sdhci",
- .id = UCLASS_MMC,
- .of_match = xenon_sdhci_ids,
- .ofdata_to_platdata = xenon_sdhci_ofdata_to_platdata,
- .ops = &sdhci_ops,
- .bind = xenon_sdhci_bind,
- .probe = xenon_sdhci_probe,
- .priv_auto_alloc_size = sizeof(struct xenon_sdhci_priv),
- .platdata_auto_alloc_size = sizeof(struct xenon_sdhci_plat),
Hi Jaehoon,
Thanks. Will you pull the 3 patches (1/9 ... 3/9) via your mmc repository? Or are you okay with me pushing them via the Marvell repository?
Thanks, Stefan
Hi Stefan.
On 01/24/2017 04:43 PM, Stefan Roese wrote:
Hi Jaehoon,
I'm ok about pushing on Marvell repository. :) Thanks!
Best Regards, Jaehoon Chung
Thanks, Stefan
Jaehoon Chung
Stefan Roese
