[U-Boot] [PATCH] Remove volatile qualifier in get_ram_size() calls
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- This change just prevents checkpatch from emitting spurious warnings; it does not affect the building process or results. It has been tested by comparing the build logs for jadecpu with and without the patch, using BUILD_NCPUS=1 to ensure both logs were ordered identically. The binaries were also compared (actually the .srec files) and found identical except for the version string.
arch/arm/cpu/arm926ejs/orion5x/dram.c | 4 ++-- board/BuS/eb_cpux9k2/cpux9k2.c | 2 +- board/atmel/at91rm9200ek/at91rm9200ek.c | 2 +- board/davedenx/qong/qong.c | 2 +- board/davinci/common/misc.c | 2 +- board/efikamx/efikamx.c | 2 +- board/eukrea/cpu9260/cpu9260.c | 2 +- board/eukrea/cpuat91/cpuat91.c | 2 +- board/freescale/mx31ads/mx31ads.c | 2 +- board/freescale/mx31pdk/mx31pdk.c | 2 +- board/freescale/mx51evk/mx51evk.c | 2 +- board/freescale/mx53ard/mx53ard.c | 4 ++-- board/freescale/mx53evk/mx53evk.c | 2 +- board/freescale/mx53loco/mx53loco.c | 4 ++-- board/freescale/mx53smd/mx53smd.c | 4 ++-- board/imx31_phycore/imx31_phycore.c | 2 +- board/karo/tx25/tx25.c | 6 +++--- board/keymile/km_arm/km_arm.c | 2 +- board/logicpd/imx27lite/imx27lite.c | 6 +++--- board/logicpd/imx31_litekit/imx31_litekit.c | 2 +- board/mx1ads/mx1ads.c | 2 +- board/ronetix/pm9261/pm9261.c | 2 +- board/ronetix/pm9263/pm9263.c | 2 +- board/ronetix/pm9g45/pm9g45.c | 2 +- board/syteco/jadecpu/jadecpu.c | 2 +- common/memsize.c | 2 +- include/common.h | 2 +- 27 files changed, 35 insertions(+), 35 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/orion5x/dram.c b/arch/arm/cpu/arm926ejs/orion5x/dram.c index 3e1ff7d..5cc31a9 100644 --- a/arch/arm/cpu/arm926ejs/orion5x/dram.c +++ b/arch/arm/cpu/arm926ejs/orion5x/dram.c @@ -53,7 +53,7 @@ int dram_init (void) { /* dram_init must store complete ramsize in gd->ram_size */ gd->ram_size = get_ram_size( - (volatile long *) orion5x_sdram_bar(0), + (long *) orion5x_sdram_bar(0), CONFIG_MAX_RAM_BANK_SIZE); return 0; } @@ -65,7 +65,7 @@ void dram_init_banksize (void) for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { gd->bd->bi_dram[i].start = orion5x_sdram_bar(i); gd->bd->bi_dram[i].size = get_ram_size( - (volatile long *) (gd->bd->bi_dram[i].start), + (long *) (gd->bd->bi_dram[i].start), CONFIG_MAX_RAM_BANK_SIZE); } } diff --git a/board/BuS/eb_cpux9k2/cpux9k2.c b/board/BuS/eb_cpux9k2/cpux9k2.c index a918b04..856d798 100644 --- a/board/BuS/eb_cpux9k2/cpux9k2.c +++ b/board/BuS/eb_cpux9k2/cpux9k2.c @@ -141,7 +141,7 @@ void reset_phy(void)
int dram_init(void) { - gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE); return 0; } diff --git a/board/atmel/at91rm9200ek/at91rm9200ek.c b/board/atmel/at91rm9200ek/at91rm9200ek.c index ec0daba..2b4d845 100644 --- a/board/atmel/at91rm9200ek/at91rm9200ek.c +++ b/board/atmel/at91rm9200ek/at91rm9200ek.c @@ -64,7 +64,7 @@ int board_early_init_f(void) int dram_init (void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE); return 0; } diff --git a/board/davedenx/qong/qong.c b/board/davedenx/qong/qong.c index b1238d5..ec22627 100644 --- a/board/davedenx/qong/qong.c +++ b/board/davedenx/qong/qong.c @@ -44,7 +44,7 @@ void hw_watchdog_reset(void) int dram_init (void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/davinci/common/misc.c b/board/davinci/common/misc.c index 2bfdf23..6103339 100644 --- a/board/davinci/common/misc.c +++ b/board/davinci/common/misc.c @@ -38,7 +38,7 @@ int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ gd->ram_size = get_ram_size( - (volatile void *)CONFIG_SYS_SDRAM_BASE, + (void *)CONFIG_SYS_SDRAM_BASE, CONFIG_MAX_RAM_BANK_SIZE); return 0; } diff --git a/board/efikamx/efikamx.c b/board/efikamx/efikamx.c index 16be532..4b36918 100644 --- a/board/efikamx/efikamx.c +++ b/board/efikamx/efikamx.c @@ -113,7 +113,7 @@ u32 get_board_rev(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c index 0959c5c..402f19f 100644 --- a/board/eukrea/cpu9260/cpu9260.c +++ b/board/eukrea/cpu9260/cpu9260.c @@ -174,7 +174,7 @@ int board_init(void)
int dram_init(void) { - gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE); return 0; } diff --git a/board/eukrea/cpuat91/cpuat91.c b/board/eukrea/cpuat91/cpuat91.c index 5d05414..f654f87 100644 --- a/board/eukrea/cpuat91/cpuat91.c +++ b/board/eukrea/cpuat91/cpuat91.c @@ -63,7 +63,7 @@ int board_early_init_f(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE); return 0; } diff --git a/board/freescale/mx31ads/mx31ads.c b/board/freescale/mx31ads/mx31ads.c index 9bf9c18..7637c92 100644 --- a/board/freescale/mx31ads/mx31ads.c +++ b/board/freescale/mx31ads/mx31ads.c @@ -31,7 +31,7 @@ DECLARE_GLOBAL_DATA_PTR; int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM_1, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c index 08addd2..f6e190a 100644 --- a/board/freescale/mx31pdk/mx31pdk.c +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -42,7 +42,7 @@ void hw_watchdog_reset(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index e2d3d74..fd7342f 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -53,7 +53,7 @@ u32 get_board_rev(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index b51d209..134603a 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -46,8 +46,8 @@ int dram_init(void) { u32 size1, size2;
- size1 = get_ram_size((volatile void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); - size2 = get_ram_size((volatile void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); + size1 = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); + size2 = get_ram_size((void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE);
gd->ram_size = size1 + size2;
diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index a89aa25..88095dc 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -46,7 +46,7 @@ u32 get_board_rev(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index d032428..18b388e 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -47,8 +47,8 @@ int dram_init(void) { u32 size1, size2;
diff --git a/board/freescale/mx53smd/mx53smd.c b/board/freescale/mx53smd/mx53smd.c index f3c433f..21b5d14 100644 --- a/board/freescale/mx53smd/mx53smd.c +++ b/board/freescale/mx53smd/mx53smd.c @@ -44,8 +44,8 @@ int dram_init(void) { u32 size1, size2;
diff --git a/board/imx31_phycore/imx31_phycore.c b/board/imx31_phycore/imx31_phycore.c index ca7d6e2..773900e 100644 --- a/board/imx31_phycore/imx31_phycore.c +++ b/board/imx31_phycore/imx31_phycore.c @@ -33,7 +33,7 @@ DECLARE_GLOBAL_DATA_PTR; int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM_1, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/karo/tx25/tx25.c b/board/karo/tx25/tx25.c index 269858c..423cdb5 100644 --- a/board/karo/tx25/tx25.c +++ b/board/karo/tx25/tx25.c @@ -160,7 +160,7 @@ int board_late_init(void) int dram_init (void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM_1, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } @@ -168,11 +168,11 @@ int dram_init (void) void dram_init_banksize(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((volatile void *)PHYS_SDRAM_1, + gd->bd->bi_dram[0].size = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); #if CONFIG_NR_DRAM_BANKS > 1 gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = get_ram_size((volatile void *)PHYS_SDRAM_2, + gd->bd->bi_dram[1].size = get_ram_size((void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); #else
diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 5da856f..a8f2b23 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -321,7 +321,7 @@ int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ /* Fix this */ - gd->ram_size = get_ram_size((volatile void *)kw_sdram_bar(0), + gd->ram_size = get_ram_size((void *)kw_sdram_bar(0), kw_sdram_bs(0)); return 0; } diff --git a/board/logicpd/imx27lite/imx27lite.c b/board/logicpd/imx27lite/imx27lite.c index 6eb5cc2..1b24c35 100644 --- a/board/logicpd/imx27lite/imx27lite.c +++ b/board/logicpd/imx27lite/imx27lite.c @@ -67,7 +67,7 @@ int board_init (void) int dram_init (void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); return 0; } @@ -75,11 +75,11 @@ int dram_init (void) void dram_init_banksize(void) { gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; - gd->bd->bi_dram[0].size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + gd->bd->bi_dram[0].size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); #if CONFIG_NR_DRAM_BANKS > 1 gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = get_ram_size((volatile void *)PHYS_SDRAM_2, + gd->bd->bi_dram[1].size = get_ram_size((void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); #endif } diff --git a/board/logicpd/imx31_litekit/imx31_litekit.c b/board/logicpd/imx31_litekit/imx31_litekit.c index bf635c3..09cc9c5 100644 --- a/board/logicpd/imx31_litekit/imx31_litekit.c +++ b/board/logicpd/imx31_litekit/imx31_litekit.c @@ -32,7 +32,7 @@ DECLARE_GLOBAL_DATA_PTR; int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM_1, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/mx1ads/mx1ads.c b/board/mx1ads/mx1ads.c index c11c0fe..86b49fb 100644 --- a/board/mx1ads/mx1ads.c +++ b/board/mx1ads/mx1ads.c @@ -169,7 +169,7 @@ int board_late_init (void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM_1, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); return 0; } diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index e0f44dd..2c50fe8 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -282,7 +282,7 @@ int board_eth_init(bd_t *bis) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); return 0; } diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index ec9f865..8071600 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -379,7 +379,7 @@ int board_init(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); return 0; } diff --git a/board/ronetix/pm9g45/pm9g45.c b/board/ronetix/pm9g45/pm9g45.c index 79b7c9d..fa69599 100644 --- a/board/ronetix/pm9g45/pm9g45.c +++ b/board/ronetix/pm9g45/pm9g45.c @@ -160,7 +160,7 @@ int board_init(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); return 0; } diff --git a/board/syteco/jadecpu/jadecpu.c b/board/syteco/jadecpu/jadecpu.c index a7b6e70..63a0d33 100644 --- a/board/syteco/jadecpu/jadecpu.c +++ b/board/syteco/jadecpu/jadecpu.c @@ -152,7 +152,7 @@ int misc_init_r(void) int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM, + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
return 0; diff --git a/common/memsize.c b/common/memsize.c index 6c275c9..963e4f3 100644 --- a/common/memsize.c +++ b/common/memsize.c @@ -37,7 +37,7 @@ * the actually available RAM size between addresses `base' and * `base + maxsize'. */ -long get_ram_size(volatile long *base, long maxsize) +long get_ram_size(long *base, long maxsize) { volatile long *addr; long save[32]; diff --git a/include/common.h b/include/common.h index 2c8513a..c5d2dce 100644 --- a/include/common.h +++ b/include/common.h @@ -317,7 +317,7 @@ const char *symbol_lookup(unsigned long addr, unsigned long *caddr); void api_init (void);
/* common/memsize.c */ -long get_ram_size (volatile long *, long); +long get_ram_size (long *, long);
/* $(BOARD)/$(BOARD).c */ void reset_phy (void);
Hi Wolfgang,
Signed-off-by: Albert ARIBAUDalbert.u.boot@aribaud.net
There seems to be no comments or dissents for this patch. Can it get in? I can pull it into u-boot-arm, but as it is a codebase-global change I would prefer it to go into u-boot so that all repositories can be rebased on it and any issues or incompatibilities can be uncovered as early as possible.
Amicalement,
Applied to u-boot-arm/master.
Amicalement,
Albert ARIBAUD
